查看: 1355|回复: 4
[分享] [原创] Microsemi MPF300PolarFire FPGA图像和视频解决方案
发表于 2019-5-12 09:01:20 | 显示全部楼层 |阅读模式
关键词:PolarFire FPGA 无线通信 智能光模块 视频广播
时间:2019-04-11 10:34:40       来源:中电网
Microsemi公司的PolaRFIre™ FPGA是第五代非易失FPGA器件,采用28nm非易失工艺技术,采用业界最低功耗的FPGA构造,最低功耗12.7Gbps收发器通路,内置了低功耗双PCI Express Gen2 (EP/RP),以及可选择数据安全器件,低功耗加密协处理器.因此具有最佳的成本器件,并提供中等密度器件的最低功耗.PolarFire™ FPGA有多达481K逻辑单元,包括有可断裂D型触发器的4输入查找表(LUT),20Kb双或两端口大静态随机存储器(LSRAM)区块,64x12两端口区块,具有预加器,48位累加器的18x18数学区块,以及可选择16深x18系数ROM,高速串行连接性,内置了多吉比特和多协议收发器,速度从250Mbps到12.7 Gbps,高速I/O(HSIO)支持高达1600 Mbps DDR4, 1333 Mbps DDR3L和1333 Mbps,集成了I/O数字的LPDDR3/DDR3存储器,PolarFire™ FPGA工作在1.0V和1.05V电压,商用温度(0℃- 100℃) 和工业温度(–40℃-100℃).主要用在有线接入网(1G-40G),无线异构网络,无线骨干网,智能光模块以及视频广播.本文介绍了MPF300 PolarFire™ FPGA主要特性,框图和收发器通路模式图,评估板MPF300-VIDEO-KIT主要特性和框图,电路图和PCB设计图.
PolarFire™ FPGAs are the fifth-generation family of non-volatile FPGA devices from Microsemi, built onstate-of-the-art 28nm non-volatile process technology. Cost-optimized PolarFire FPGAs deliver thelowest power at mid-range densities. PolarFire FPGAs lower the cost of mid-range FPGAs by integratingthe industry’s lowest power FPGA fabric, lowest power 12.7 Gbps transceiver lane, built-in low powerdual PCI Express Gen2 (EP/RP), and, on select data security (S) devices, an integrated low-power crypto co-processor. PolarFire FPGAs can operate at 1.0 V and 1.05 V, offering the end user the ability to tradeoff power and performance to match the application requirements.
This document describes the features of the production PolarFire FPGA extended commercial(0℃ to100℃) and industrial (–40℃ to 100℃) device offerings. Please refer to the datasheet for current siliconstatus and electrical characteristics.
MPF300 PolarFire™ FPGA主要特性:
Up to 481K logic elements consisting of a 4-input look-up table (LUT) with a fractureable D-type flipflop
20 Kb dual- or two-port large static random access memory (LSRAM) block with built-in single errorcorrect double error detect (SECDED)
64 × 12 two-port μRAM block implemented as an array of latches
18 × 18 math block with a pre-adder, a 48-bit accumulator, and an optional 16 deep x 18 coefficientROM
Built-in μPROM, modifiable at program time, readable at run time for user data storage
High-speed serial connectivity with built-in multi-gigabit multi-protocol transceivers from 250 Mbpsto 12.7 Gbps
Integrated dual PCIe for up to ×4 Gen2 endpoint (EP) and root port (RP) designs
High-speed I/O (HSIO) supporting up to 1600 Mbps DDR4, 1333 Mbps DDR3L, and 1333 Mbps
LPDDR3/DDR3 memories with integrated I/O digital
General purpose I/O (GPIO) supporting 3.3 V, built-in CDR for serial gigabit Ethernet, 1067 MbpsDDR3, and 1600 Mbps LVDS I/O speed with integrated I/O digital logic
Low-power phase-locked loops (PLLs) and delay-locked loops (DLLs) for high precision and low-jitterV and 1.05 V operating modes
Low-Power Features
Low device static power
Low inrush current
Low power transceivers
Reliability Features
FPGA configuration cells single event upset (SEU) immune
Built-in SECDED and memory interleaving on LSRAMs
System controller suspend mode for safety-critical designs
Security Features
Cryptography Research Incorporated (CRI)-patented differential power analysis (DPA) bitstreamprotection
Integrated physically unclonable function (PUF)
56 KBytes of secure non-volatile memory (sNVM)
Built-in tamper detectors and countermeasures
Digest integrity check for FPGA, μPROM, and sNVM
Data security features in S devices—true random number generator, integrated Athena TeraFireEXP5200B Crypto Coprocessor, suite B capable, and CRI DPA countermeasure pass-through license
Libero® SoCPolarFire FPGA Toolset
Complete FPGA and embedded software development environment
Includes Synplify Pro synthesis and Mentor ModelSim ME simulation
图1.MPF300 PolarFire™ FPGA框图
图2.MPF300 PolarFire™ FPGA收发器通路模式图
MPF300 PolarFire™ FPGA主要应用:
• Wireline access, edge, metro(1G–40G)
• Wireless heterogeneous networks
• Wireless backhaul
• Smart optical modules
• Video broadcasting
Communications
• Significantly improved networkcapacity and coverage with limitedspectrum and CAPEX
• Delivers 4K video
• Lower OPEX
• IoT growth with minimal energyconsumption
• Lower physical and carbon footprint
Defense
• Anti-tamper for Foreign MilitarySales (FMS)
• Increasing automation in vehiclesand weaponry
• Enhancing operator situationalawareness
• Battlefield portability and increasedmission life
• Increased cybersecurity
• Supply chain security
Industrial
• Increased networking of factoryautomation
• M2M—growth of additional sensorsand nodes
• Rise of cloud services requiringdecentralized, secure computing
• Portability becoming more prevalent
• Cyber security threats
• Functional safety
图像和视频评估板MPF300-VIDEO-KIT
Microchip ’s PolarFire Video and Imaging Kit offers a high-performance evaluation of 4K image processing and rendering using dual camera sensors as well as numerous display interfaces. The kit is purpose-built for effortless prototyping of popular imaging and video protocols including MIPI CSI-2 TX, MIPI CSI-2 RX, HDMI 1.4 TX, HDMI2.0, DSI, and HD/3G SDI.
With a  300K logic element (LE) PolarFire FPGA with DDR4 and SPI-flash the kit is ideally suited for mid-bandwidth imaging and video applications. The PolarFire device on-board optimizes input/outputs (I/Os), transceiver rates, look-up table (LUT4) architecture, memories and DSPs for mid-density/mid-bandwidth ranges, to deliver a superior solution at a much lower power and lower total cost of ownership.
The kit is part of our broader Smart Embedded Vision solutions to open up new possibilities to implement systems that rely on visual data to make decisions across a broad spectrum of applications like Drones, Machine Vision, Thermal Imaging, Gaming, Video Surveillance, Robotics, Advanced Driver Assistance Systems (ADAS), Machine Learning, and HMI.
图3.PolarFire FPGA视频和图像评估板框图
图4.评估板MPF300-VIDEO-KIT外形图
评估板MPF300-VIDEO-KIT主要特性:
300K LE PolarFire FPGA in an FCG1152 Package
Sony Dual Camera Sensor (IMX334) over Amphenol FCI connector (CSI-2 RX)
HPC FMC Connector
4GB DDR4 x32
Power Management Unit for 1 or 1.05v PolarFire FPGA core voltage
USB to UART Interface
Embedded programming and debugging using SPI and JTAG
1x 1Gb SPI Flash Memory
HDMI 2.0 RX and TX
HDMI 1.4 TX
DSI Connector
CSI-2 TX Connector
POLARFIRE VIDEO KIT
图5.评估板MPF300-VIDEO-KIT电路图(1)
图6.评估板MPF300-VIDEO-KIT电路图(2)
图7.评估板MPF300-VIDEO-KIT电路图(3)
图8.评估板MPF300-VIDEO-KIT电路图(4)
图9.评估板MPF300-VIDEO-KIT电路图(5)
图10.评估板MPF300-VIDEO-KIT电路图(6)
图11.评估板MPF300-VIDEO-KIT电路图(7)
图12.评估板MPF300-VIDEO-KIT电路图(8)
图13.评估板MPF300-VIDEO-KIT电路图(9)
图14.评估板MPF300-VIDEO-KIT电路图(10)
图15.评估板MPF300-VIDEO-KIT电路图(11)
图16.评估板MPF300-VIDEO-KIT电路图(12)
图17.评估板MPF300-VIDEO-KIT电路图(13)
图18.评估板MPF300-VIDEO-KIT电路图(14)
图19.评估板MPF300-VIDEO-KIT电路图(15)
图20.评估板MPF300-VIDEO-KIT电路图(16)
图21.评估板MPF300-VIDEO-KIT电路图(17)
图22.评估板MPF300-VIDEO-KIT电路图(18)
图23.评估板MPF300-VIDEO-KIT电路图(19)
图24.评估板MPF300-VIDEO-KIT电路图(20)
图25.评估板MPF300-VIDEO-KIT电路图(21)
图26.评估板MPF300-VIDEO-KIT电路图(22)
图27.评估板MPF300-VIDEO-KIT电路图(23)
图28.评估板MPF300-VIDEO-KIT电路图(24)
图29.评估板MPF300-VIDEO-KIT电路图(25)
图30.评估板MPF300-VIDEO-KIT电路图(26)
图31.评估板MPF300-VIDEO-KIT电路图(27)
图32.评估板MPF300-VIDEO-KIT电路图(28)
图33.评估板MPF300-VIDEO-KIT PCB设计图(1):顶层
图34.评估板MPF300-VIDEO-KIT PCB设计图(2):底层
详情请见:
https://www.microsemi.com/existing-parts/parts/150747#resources
Microsemi_PolarFire_FPGA_Datasheet_DS0141_15_Update.pdf
Microsemi_PolarFire_FPGA_Video_Kit_User_Guide_UG0856_V1.pdf
Microsemi_PolarFire_FPGA_Dual_Camera_Video_Kit_Demo_Guide_DG0849_V1.pdf
Microsemi_PolarFire_FPGA_Product_Overview_PO0137_15.pdf
    前天 09:37
  • 签到天数: 77 天
    发表于 2019-5-12 12:18:43 | 显示全部楼层
    终身成就奖社区居民优秀斑竹奖
    发表于 2019-5-12 21:11:24 | 显示全部楼层
    谢谢分享Microsemi MPF300PolarFire FPGA图像和视频解决方案
    终身成就奖原创先锋奖优秀斑竹奖
    发表于 2019-5-13 00:07:20 | 显示全部楼层
    发表于 2019-5-13 08:07:27 | 显示全部楼层
