序号 | 物料名称 | 规格型号 | 单位 | 用量 | 位置号 | 1 | 批头线 | 5芯线,22#,150mm,2.54端子单头线,开尾剥皮15mm,线序(黄白黑棕橙) | pcs | 2 | | 2 | 批头线 | 5芯线,22#,150mm,2.54端子单头线,开尾剥皮15mm,线序(红黄绿白黑) | pcs | 6 | | 3 | PE袋 | 180*120mm,自封PE袋 | pcs | 1 | | 5 | 短路帽 | 短尾,2Pin,脚距2.54 | pcs | 1 | SW1 | 6 | 螺丝 | PA3*10mm,镀锌 | pcs | 4 | 固定外壳 | 7 | 螺丝 | PA3*6mm,镀锌 | pcs | 6 | 固定主板 | 8 | 易碎贴纸 | 易碎贴 | pcs | 1 | | 9 | 型号标贴 | 50*30mm,自行打印 | pcs | 1 | | 10 | 警告标 | 45*30mm | pcs | 1 | | 11 | 合格证 | 33*30mm,三角标 | pcs | 1 | | 12 | 气泡袋 | 250*220mm | pcs | 1 | | 13 | 包装外盒 | 210*175*45mm,白盒 | pcs | 1 | | 14 | 说明书 | | pcs | 1 | | 15 | 中间设备套壳 | | 套 | 1 | | 17 | 贴片IC | STC89C52RC,QFP-44 | pcs | 1 | U2 | 18 | 贴片IC | 81487,SOP-8 | pcs | 1 | U7 | 19 | 贴片IC | LM358,SOP-8 | pcs | 1 | U4 | 20 | 插件IC | LM7805CV,TO-220 | pcs | 1 | U6 | 21 | 插件IC | LM7812CV,TO-220 | pcs | 1 | U5 | 22 | 贴片电阻 | 10Ω,±5%,0805 | pcs | 1 | R79 | 23 | 贴片电阻 | 120Ω,±5%,0805 | pcs | 1 | R73 | 24 | 贴片电阻 | 470Ω,±5%,0805 | pcs | 1 | R100 | 25 | 贴片电阻 | 510Ω,±5%,0805 | pcs | 2 | R46,R47 | 26 | 贴片电阻 | 680Ω,±5%,0805 | pcs | 2 | R44,R45 | 27 | 贴片电阻 | 1KΩ,±5%,0805 | pcs | 6 | R48-R49,R52-R54,R78 | 28 | 贴片电阻 | 2KΩ,±5%,0805 | pcs | 7 | R28-R32,R84,R90 | 29 | 贴片电阻 | 4.7KΩ,±5%,0805 | pcs | 38 | R8,R11,R13-R18,R20-R25,R27,R60-R64,R68,R74,R75,R82,R88,R93-R96,R101-R104,R106-R110 | 30 | 贴片电阻 | 10KΩ,±5%,0805 | pcs | 28 | R9,R10,R1-R7,R12,R19,R26,R56-R59,R65-R67,R76-R77,R80-R81,R83,R87,R89,R105,R111 | 31 | 贴片电阻 | 18KΩ,±5%,0805 | pcs | 2 | R50,R51 | 32 | 贴片电阻 | 20KΩ,±5%,0805 | pcs | 12 | R33-R38,R71,R72,R85,R91,R97,R98 | 33 | 贴片电阻 | 200Ω,±5%,1206 | pcs | 7 | R39-R43,R86,R92 | 34 | 贴片排阻 | 10KΩ,±5%,8Pin,8P4R | pcs | 4 | RP1-RP4 | 35 | 贴片电容 | 104,±20%,50V,0805 | pcs | 7 | C1,C2,C4,C5,C6,C14,C20 | 36 | 贴片电容 | 1uF,±10%,25V,0805 | pcs | 3 | C3,C9-C10 | 37 | 贴片电容 | 20pF,±5%,50V,0805,NPO | pcs | 2 | C7,C8 | 38 | 插件电解电容 | 220uF,±20%,25V,Φ8*12mm,铝 | pcs | 3 | C11,C12,C13 | 39 | 插件晶振 | 11.0592MHZ,20pF,30PPM,HC-49/S | pcs | 1 | Y1 | 40 | 贴片三极管 | SS8050,SOT-23,Y1 | pcs | 22 | Q1-Q10,Q16-Q21,Q23-Q24,Q26-Q27, Q29-Q30 | 41 | 贴片三极管 | SS8550,SOT-23,Y2 | pcs | 8 | Q11-Q15,Q22,Q25,Q28 | 42 | 贴片二极管 | 1N4148,LL-34 | pcs | 10 | D1,D2,D3,D7,D8,D14,D15,D17,D20-D21 | 43 | 贴片二极管 | 1N5819,SOD-123,S4 | pcs | 7 | D9-D13,D22-D23 | 44 | 插件二极管 | 1N5404,DO-27 | pcs | 1 | D16 | 45 | 贴片稳压管 | MTZJ5C1,5.1V,±5%,1/2W,LL-34 | pcs | 5 | D4-D6,D18-D19 | 46 | 贴片稳压管 | ZM4735A,6.2V,1W,LL-41 | pcs | 2 | D24-D25 | 47 | 贴片发光二极管 | 白发红,1206,普亮 | pcs | 15 | LED1-LED5,LED9-LED16,LED19,LED20 | 48 | 贴片气体放电管 | BA401N,1812 | pcs | 1 | ZD1 | 49 | 插件气体放电管 | LT-B3R090L,陶瓷三脚封装 | pcs | 1 | ZD2 | 50 | 贴片TVS管 | SMBJ6.5CA,SMB | pcs | 3 | ZD3-ZD5 | 51 | 插件继电器 | HK19F-DC 12V-SHG,双刀双掷,8脚 | pcs | 7 | K1-K7 | 52 | 插件自恢复保险丝 | GR265-120,265V,120mA | pcs | 2 | F1,F2 | 53 | 插件自恢复保险丝 | JK30-200,30V,2A | pcs | 2 | F3,F4 | 54 | 插件轻触按键 | 6*6*5mm,插件 | pcs | 1 | S1 | 55 | 插件拨码开关 | DS-04P,脚距2.54,立式直拨型 | pcs | 1 | SW3 | 56 | 主板PCB | HLC-NET01 V:1.0 150*97*1.6mm FR4双面 | pcs | 1 | | 57 | 插件针座 | 5Pin,脚距2.54,插件立式 | pcs | 8 | J1,J2,J3,J4,J5,J6,J9, J10 | 58 | 插件针座 | 6Pin,脚距2.54,插件立式 | pcs | 1 | J7 | 59 | 排针 | 单排针,脚距2.54,40Pin,立式 | pcs | 0.150 | SW1(2pin),J8(4pin) | 60 | 接线端子 | KF128,绿色 | pcs | 1 | JD1 | 61 | DC座 | DC005,外径6.0mm,针2.0mm,卧式,DIP | pcs | 1 | DC1 |
