1-1-1框架
  • 项目三作业布线布局
    项目三作业布线布局
  • 意法半导体的三端双向可控硅
    意法半导体的三端双向可控硅
  • 亿光反射式光电开关芯片ITR1204SR10A-TR
  • 如何提升微波网络分析仪的测量精度?
    如何提升微波网络分析仪的测量精度?
  • 14周年庆-发金币,500名额,每人50金币。学堂课程全场半价
[Allegro16.6以下] MDAS光纤+千兆网络分布系统-由EP2AGX45F780+KSZ9031RNX+KSZ8041NL+LMK0
查看11260 | 回复80 | 2019-7-8 12:56:05 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
12VLED_LED0603_GRNGRNLED0603
12V_INCON2_2PIN_3_81_3.81MM*23.81mm*22PIN_3_81
ACT1LED_LED0603_GRNGRNLED0603
ACT2LED_LED0603_GRNGRNLED0603
ACT3LED_LED0603_GRNGRNLED0603
ACT4LED_LED0603_GRNGRNLED0603
ACT5LED_LED0603_GRNGRNLED0603
ACT6LED_LED0603_GRNGRNLED0603
ACT7LED_LED0603_GRNGRNLED0603
ACT8LED_LED0603_GRNGRNLED0603
ADCCON4_SIP_4P_CON4CON4SIP_4P
ALMCON20_2_8PIN_1_5AAA_8PIN-1.5MM8PIN -1.5mm8PIN_1_5AAA
B1INDUCTOR_LB0805_BLM21PG331SN1BLM21PG331SN1LB0805
BAT1CAPACITORPOL_C_BAT1_CR1220CR1220C_BAT1
CPULED_LED0603_GRNGRNLED0603
D1DIODEBREAKDOWN_LED0603_SD101AWSD101AWSLED0603
D2DIODEBREAKDOWN_LED0603_SD101AWSD101AWSLED0603
D3DIODEBREAKDOWN_LED0603_SD101AWSD101AWSLED0603
D5BAS21/SOT_3_SOT23_BAS21/SOTBAS21/SOTSOT23
D6LED_LED0603_GRNGRNLED0603
D30DIODE_TUNINGVARACTORS_SOT23_SMVSMV-1249-074LFSOT23
D31BAS21/SOT_2_SOT23_BAS21/SOTBAS21/SOTSOT23
DONELED_LED0603_GRNGRNLED0603
FB1IND-FB_LB0603_500@100M500@100MLB0603
FB2IND-FB_LB0603_500@100M500@100MLB0603
FB3IND-FB_LB0603_500@100M500@100MLB0603
FB47IND-FB_LB0805_500@100M500@100MLB0805
FB48FERRITE_BEAD_LB0603_BLM18PG330BLM18PG330LB0603
FB49IND-FB_LB0603_500@100M500@100MLB0603
FB50IND-FB_LB0805_500@100M500@100MLB0805
FB74FERRITE_BEAD_LB0603_BLM18PG330BLM18PG330LB0603
FB75FERRITE_BEAD_LB0603_BLM18PG330BLM18PG330LB0603
FB76FERRITE_BEAD_LB0603_BLM18PG330BLM18PG330LB0603
FB77FBEAD_1_LB0603_FBEADFBEADLB0603
FB78FBEAD_1_LB0603_FBEADFBEADLB0603
FB79FBEAD_1_LB0603_FBEADFBEADLB0603
FB80FBEAD_1_LB0603_FBEADFBEADLB0603
FB81FBEAD_1_LB0603_FBEADFBEADLB0603
FB82FBEAD_1_LB0603_FBEADFBEADLB0603
FB83FBEAD_1_LB0603_FBEADFBEADLB0603
J1CON3_SIP3_CON3CON3SIP3
J2JUMPER_0_B00T_FORBOOTFor BOOTB00T
J4CON20_CON20_CON20CON20CON20
J5CON40_CON40_CON40CON40CON40
JTAG1CON20AP_2_8XJTAG_NCNC8XJTAG
L1INDUCTOR_IND_10MMX10MM2_MSS1048MSS1048-472IND_10MMX10MM2
L2INDUCTOR_IND_10MMX10MM2_MSS1048MSS1048-472IND_10MMX10MM2
L3INDUCTOR_IND_10MMX10MM2_MSS10_1MSS1048-332IND_10MMX10MM2
L4COIL_0_LB0603_BLM21PG331SN1BLM21PG331SN1LB0603
L5INDUCTOR_IND_10MMX10MM2_1.5UH/51.5uH/5AIND_10MMX10MM2
L6COIL_0_LB0805_0805LS-471X_L_0805LS-471X_L_LB0805
L7COIL_0_LB0603_BLM21PG331SN1BLM21PG331SN1LB0603
L11INDUCTOR_IND_10MMX10MM2_1.5UH/51.5uH/5AIND_10MMX10MM2
LAN1RJ45-1G _9_RJ45_RJ45BELFUSE SSRJ45 BelfuseSS-6488S-A-FLS-50RJ45
LAN2RJ45-1G _9_RJ45_RJ45BELFUSE SSRJ45 BelfuseSS-6488S-A-FLS-50RJ45
LAN3RJ45-1G _9_RJ45_RJ45BELFUSE SSRJ45 BelfuseSS-6488S-A-FLS-50RJ45
LAN4RJ45-1G _9_RJ45_RJ45BELFUSE SSRJ45 BelfuseSS-6488S-A-FLS-50RJ45
LAN5RJ45-1G _9_RJ45_RJ45BELFUSE SSRJ45 BelfuseSS-6488S-A-FLS-50RJ45
LAN6RJ45-1G _9_RJ45_RJ45BELFUSE SSRJ45 BelfuseSS-6488S-A-FLS-50RJ45
LAN7RJ45-1G _9_RJ45_RJ45BELFUSE SSRJ45 BelfuseSS-6488S-A-FLS-50RJ45
LAN8RJ45-1G _9_RJ45_RJ45BELFUSE SSRJ45 BelfuseSS-6488S-A-FLS-50RJ45
LAN9RJ45-1G _9_RJ45_RJ45BELFUSE SSRJ45 BelfuseSS-6488S-A-FLS-50RJ45
LAN10RJ45-1G _9_RJ45_RJ45BELFUSE SSRJ45 BelfuseSS-6488S-A-FLS-50RJ45
LINK7LED_LED0603_GRNGRNLED0603
LINK8LED_LED0603_GRNGRNLED0603
P1EP2AGX45F780_0_EP2AGX45F780_(S1EP2AGX45F780_2EP2AGX45F780
PLLLED_LED0603_GRNGRNLED0603
Q12N6249_0_SOT23_2N3904/STO232N3904/STO23SOT23
Q22N6249_0_SOT23_2N3904/STO232N3904/STO23SOT23
RS232CON5_CON5_5PIN_1.55Pin_1.5CON5
RS485CON3_CON3_CON3CON3CON3
SFP1SFP_MBPD_1.25GBPS1.25GbpsMBPD
SFP2SFP_MBPD_1.25GBPS1.25GbpsMBPD
SFP3SFP_MBPD_1.25GBPS1.25GbpsMBPD
SFP4SFP_MBPD_1.25GBPS1.25GbpsMBPD
SFP5SFP_MBPD_1.25GBPS1.25GbpsMBPD
SFP6SFP_MBPD_1.25GBPS1.25GbpsMBPD
SFP7SFP_MBPD_1.25GBPS1.25GbpsMBPD
SFP8SFP_MBPD_1.25GBPS1.25GbpsMBPD
T10H5007_1_H500X_PULSEH5007NLPULSE H5007NLH500X
T11H1102_NEW_H110X_H1102H1102H110X
TP1TEST POINT_TP_TESTPOINTTest pointTP
TP2TEST POINT_TP_TESTPOINTTest pointTP
TP3TEST POINT_TP_TESTPOINTTest pointTP
TP4TEST POINT_TP_TESTPOINTTest pointTP
U1FDS8984_0_SO8NB_FDS8984FDS8984SO8NB
U2XRP7713_0_QFN_32_XRP7713XRP7713QFN_32
U3FDS8984_0_SO8NB_FDS8984FDS8984SO8NB
U4FDS8984_0_SO8NB_FDS8984FDS8984SO8NB
U5LPC1778FBD144_1_TQFP144_LPC1778LPC1778FBD144TQFP144
U66PIN_3_SO8NB_TMP36TMP36SO8NB
U7IMP809_SOT23_CAT809SCAT809SSOT23
U8KS8721_0_MLF-32P_KSZ8041NL/QFNKSZ8041NL/QFNMLF-32P
U9SP3232E_0_SSOP16_SP3232SP3232SSOP16
U10SST25VF080-FP_SO8NB_W25Q32(NC)W25Q32(NC)SO8NB
U11KS8995M_1_KSZ9031RN_A_KSZ9031RNKSZ9031RNXKSZ9031RN_A
U12OSC-HALF_1_OSC4P_50MHZ/10PPM/5X50MHZ/10PPM/5X7OSC4P
U13KS8995M_1_KSZ9031RN_A_KSZ9031RNKSZ9031RNXKSZ9031RN_A
U14KS8995M_1_KSZ9031RN_A_KSZ9031RNKSZ9031RNXKSZ9031RN_A
U15KS8995M_1_KSZ9031RN_A_KSZ9031RNKSZ9031RNXKSZ9031RN_A
U16KS8995M_1_KSZ9031RN_A_KSZ9031RNKSZ9031RNXKSZ9031RN_A
U17KS8995M_1_KSZ9031RN_A_KSZ9031RNKSZ9031RNXKSZ9031RN_A
U18KS8995M_1_KSZ9031RN_A_KSZ9031RNKSZ9031RNXKSZ9031RN_A
U19KS8995M_1_KSZ9031RN_A_KSZ9031RNKSZ9031RNXKSZ9031RN_A
U20KS8995M_1_KSZ9031RN_A_KSZ9031RNKSZ9031RNXKSZ9031RN_A
U21KS8995M_1_KSZ9031RN_A_KSZ9031RNKSZ9031RNXKSZ9031RN_A
U22LMK04031BISQ_0_LMK01020BBBBBB_LLMK04031BISQLMK01020BBBBBB
U23AP1117_0_SOT223-3L_SPX1117M3-LSPX1117M3-LSOT223-3L
U26W25Q32BVSSIG_SO8NBAAA_W25Q64BVSW25Q64BVSSIGSO8NBAAA
U28MAX1487_SO8NB_MAX3485CSAMAX3485CSASO8NB
U296PIN_0_SOP9-50-150_TPS54527DDATPS54527DDASOP9-50-150
U30OSC-HALF_1_OSC4P_50MHZ/10PPM/5X50MHZ/10PPM/5X7OSC4P
U31KS8721_0_MLF-32P_KSZ8041NL/QFNKSZ8041NL/QFNMLF-32P
U32KS8721_0_MLF-32P_KSZ8041NL/QFNKSZ8041NL/QFNMLF-32P
U33KS8721_0_MLF-32P_KSZ8041NL/QFNKSZ8041NL/QFNMLF-32P
U34KS8721_0_MLF-32P_KSZ8041NL/QFNKSZ8041NL/QFNMLF-32P
U35KS8721_0_MLF-32P_KSZ8041NL/QFNKSZ8041NL/QFNMLF-32P
U36KS8721_0_MLF-32P_KSZ8041NL/QFNKSZ8041NL/QFNMLF-32P
U37KS8721_0_MLF-32P_KSZ8041NL/QFNKSZ8041NL/QFNMLF-32P
U38KS8721_0_MLF-32P_KSZ8041NL/QFNKSZ8041NL/QFNMLF-32P
U396PIN_0_SOP9-50-150_TPS54527DDATPS54527DDASOP9-50-150
U41JTAG CON_SIP_10P_JTAGCONJTAG CONSIP_10P
U51TPS74801_TPS74801_SON10_TPS7480TPS74801TPS74801_SON10
U52TPS74701_TPS74701_SON10_TPS7480TPS74801TPS74701_SON10
XIOCON20_10X2_2X10_2.54MM2x10_2.54mm10X2
Y1ZTA_Y200W_ZTAZTAY200W
Y2CRYSTAL_XTAL_HC49SMT_24MHZ24MHZXTAL_HC49SMT
Y3CRYSTAL_XTAL32768_32.8K32.8KXTAL32768
Y4OSC_DIP8_9_JZ3472AAAA_12.50MHZ12.50MhzJZ3472AAAA
Y5CRYSTAL_XTAL_HC49SMT_HC49SM-12MHC49SM-12M288-1B25B14XTAL_HC49SMT
Z1ZC2800E/SOT_5_LED0603_PESD3V3S1PESD3V3S1UBLED0603
Z2ZC2800E/SOT_5_LED0603_PESD3V3S1PESD3V3S1UBLED0603
Z3ZC2800E/SOT_5_LED0603_PESD3V3S1PESD3V3S1UBLED0603
Z4ZC2800E/SOT_5_LED0603_PESD3V3S1PESD3V3S1UBLED0603
Z5ZC2800E/SOT_5_LED0603_PESD3V3S1PESD3V3S1UBLED0603
Z6ZC2800E/SOT_5_LED0603_PESD3V3S1PESD3V3S1UBLED0603
Z7ZC2800E/SOT_5_LED0603_PESD3V3S1PESD3V3S1UBLED0603
重要提示:PCB作品文件展下载说明
老吴 | 2019-7-8 12:57:39 | 显示全部楼层
本站独有,作品仅限学习交流。。禁止转载到其他网站(或网络上)。
PCB文件回复可见下载。
游客,如果您要查看本帖隐藏内容请回复
i_333333 | 2019-7-8 13:32:44 | 显示全部楼层
非常感谢楼主大神分享
love欣 | 2019-7-8 14:19:24 | 显示全部楼层
带刀的老鼠 | 2019-7-8 14:49:08 | 显示全部楼层
路途之路 | 2019-7-8 14:55:20 | 显示全部楼层
dancell | 2019-7-8 15:03:16 | 显示全部楼层
pcb371091540 | 2019-7-8 20:20:58 | 显示全部楼层
cdl511 | 2019-7-8 20:28:21 | 显示全部楼层
lijunming1983cn | 2019-7-9 08:44:12 | 显示全部楼层
