REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME | AUDIO_SEL1 | CON1X2_2MM | CON1x2_2MM | CON1X2_2MM | BT1 | BT_SCDM3R3224 | 0.22F,3.3V,Gold-Cap | BT_SCDM3R3224 | COM1 | DB9 | xx_DB9_MALE | DB9 | COM2 | DB9 | DB9_MALE | DB9 | D1 | SCD34 | SCD34 | SCD34 | D2 | SCD34 | SCD34 | SCD34 | D4 | LED-SMD | GREEN | LED-SMD | D7 | LED-SMD | GREEN | LED-SMD | D8 | LED-SMD | BLUE | LED-SMD | D11 | LED-SMD | GREEN | LED-SMD | D12 | LED-SMD | GREEN | LED-SMD | D36 | Q_SOT23 | BAT54S | Q_SOT23 | F1 | MF-R250 | MF-R250 | MF-R250 | F2 | MF-NSMF050-2 | MF-NSMF050-2 | MF-NSMF050-2 | H9 | HOLE_C236D126 | Mount_hole | HOLE_C236D126 | ICE1 | IDECON2X10_254 | Multi_ICE_10X2 | IDECON2X10_254 | IRDA1 | IRDIP-IRM4838 | IR RECEIVER,IRM3638N3 | IRDIP-IRM4838 | J2 | CON30_1MM | 3760-F30C | CON30_1MM | J4 | SMDCON1X6P1MM-CSI-1181-XXXX | WAFER1X6(CSI-1181-061R) | SMDCON1X6P1MM-CSI-1181-XXXX | J5 | SMDCON1X6P1MM-CSI-1181-XXXX | WAFER1X6(CSI-1182-061R) | SMDCON1X6P1MM-CSI-1181-XXXX | J7 | CON1X3_254 | CON1X3_254 | CON1X3_254 | J8 | CON1X2_2MM | CON1x2_2MM | CON1X2_2MM | J11 | CON1X3_2MM | CON1X3_2MM | CON1X3_2MM | J12 | CON1X4_254 | xx_CON1X4_254 | CON1X4_254 | J14 | CON1X4_254 | xx_CON1X4_254 | CON1X4_254 | J16 | CON2X12_254 | xx_CON2X12_254 | CON2X12_254 | J17 | CON1X3_254 | CON1X3_254 | CON1X3_254 | J19 | CON1X2_2MM | CON1x2_2MM | CON1X2_2MM | J20 | PCIE_36P | PCIe x1 EdgeConnector | PCIE_36P | J24 | FPC14S_BL112_P05 | FPC,14x0.5mm,90D | FPC14S_BL112_P05 | J25 | CONDIP1X2_125 | Wafer 1x2_125 | CONDIP1X2_125 | J26 | CONDIP1X4_125 | Wafer 1x4_125 | CONDIP1X4_125 | J28 | CON30_1MM | 3760-F30C | CON30_1MM | J29 | CON2X5_254 | CON2X5_254 | CON2X5_254 | J32 | CON1X4_254 | xx_CON1X4_254 | CON1X4_254 | J33 | CONDIP1X4_125 | Wafer 1x4_125 | CONDIP1X4_125 | J34 | CON1X3_2MM | CON1X3_2MM | CON1X3_2MM | L1 | SDSG740D | 10uH | SDSG740D | L3 | SDSG740D | 15uH | SDSG740D | L4 | SDSG740D | 15uH | SDSG740D | L7 | SDSG740D | 6.8uH | SDSG740D | L13 | SDSG740D | 15uH | SDSG740D | L16 | L0805 | MLB-201209-0300P-N2 | L0805 | L18 | L0603 | MLB-160808-0010P-N1 | L0603 | L22 | L0402 | FBM-11-100505-121T | L0402 | L23 | L0805 | MLB-201209-0300P-N2 | L0805 | L33 | SMDL-EA-22AM03C02 | 2.2uH/2.35A/59mOhm | SMDL-EA-22AM03C02 | L40 | L0603 | MLB-160808-0010P-N1 | L0603 | L94 | L0805 | GB201209D152TT | L0805 | LINE_IN1 | MJ-08 | WTJ-035-05A | MJ-08 | LINE_OUT1 | MJ-08 | WTJ-035-05A | MJ-08 | MIC1 | MIC6MMP1_9MM | MIC,OBO-06BP | MIC6MMP1_9MM | OSC3 | XTAL_X32 | 24MHz | XTAL_X32 | PJ1 | PJ-25B | DC-1R2000Q | PJ-25B | PW_SW1 | DIPSW_JS_606S_R | SWITCH_JS-606A-R | DIPSW_JS_606S_R | Q9 | Q_SOT23BCE | PMBT3904 | Q_SOT23BCE | Q13 | Q_SOT23BCE | PMBT3904 | Q_SOT23BCE | Q14 | Q_SOT23BCE | PMBT3906 | Q_SOT23BCE | Q15 | Q_SOT23BCE | PMBT3904 | Q_SOT23BCE | Q21 | Q_SOT23BCE | PMBT3904 | Q_SOT23BCE | RJ45 | RJ45-GTC1111-02AL | GTC1111-02AL | RJ45-GTC1111-02AL | RN5 | 8P4R_0402 | 30 | 8P4R_0402 | RS485 | CON1X2_254 | CON1X2_254 | CON1X2_254 | S1 | RESET-SW | TS1102LA | RESET-SW | SD1 | SD-104G-TAA0-R | SD Socket,104G-TAA0-R | SD-104G-TAA0-R | SD2 | SD-104G-TAA0-R | SD Socket,104G-TAA0-R | SD-104G-TAA0-R | SW8 | SWSMD2X2_127 | SWSMD2X2_127 | SWSMD2X2_127 | TOP1 | QTH-030-01-L-D-A | QTH-030-04-LDA | QTH-030-01-L-D-A | TOP2 | QTH-030-01-L-D-A | QTH-030-04-LDA | QTH-030-01-L-D-A | TP57 | TPDIPC55D35 | T POINT R | TPDIPC55D35 | U1 | FBGA484_MOZART_NOSKT | Mozart_3s | FBGA484_MOZART_NOSKT | U2 | SOP8_TH | NX7102 | SOP8_TH | U3 | SOP8_TH | NX7102 | SOP8_TH | U4 | SOP8_TH | NX7102 | SOP8_TH | U5 | SOP8_TH | NX7102 | SOP8_TH | U6 | SOP8_TH | NX7102 | SOP8_TH | U7 | SOT143 | PT7M7811 | SOT143 | U8 | DIP08_300WA | xx_MX25L3205D | DIP08_300WA | U9 | SOP16_400W | MX25L12845EMI-10G | SOP16_400W | U10 | MSOP10_MD124 | MD124/MSOP10 | MSOP10_MD124 | U11 | BGA0_8MM9X13-96 | K4B2G1646B | BGA0_8MM9X13-96 | U13 | BGA0_8MM9X13-96 | K4B2G1646B | BGA0_8MM9X13-96 | U14 | QFN64_9X9MM_P05 | RTL8211EG-VB-CG | QFN64_9X9MM_P05 | U18 | IC48TSOP | H27U1G8F2BTR-BC | IC48TSOP | U19 | IC48TSOP | H27U1G8F2BTR-BC | IC48TSOP | U21 | IC8SOIC | ISL3485EARZ | IC8SOIC | U23 | TSSOP20_6_5X6_4P0_65 | SN74HC541PWR | TSSOP20_6_5X6_4P0_65 | U25 | SOT23-5P | xx_TPS2051BDBV | SOT23-5P | U26 | TSSOP16_5X6_4P065 | PI6C557-03LE | TSSOP16_5X6_4P065 | U28 | SOT-23 | AIC1722A_18PU | SOT-23 | U29 | QFN40_6X6MM_P05 | ADV7180 | QFN40_6X6MM_P05 | U30 | MPDS006C_16P | SN74AVC4T245 | MPDS006C_16P | U31 | MPDS006C_16P | SN74AVC4T245 | MPDS006C_16P | U32 | SOT26-6P | AP1511A | SOT26-6P | U33 | MSOP8-NS6642X | LTC6244CMS8 | MSOP8-NS6642X | U34 | SC70-6 | AD5602 | SC70-6 | U35 | SC70-6 | AD5602 | SC70-6 | U36 | SOT-23 | AIC1722A_18PU | SOT-23 | U37 | QFN32_5X5X0_9MM | ADV7391 | QFN32_5X5X0_9MM | U39 | Q_SOT23-5 | xx_TPS77028 | Q_SOT23-5 | U40 | QFN28_5X5_P05 | SSM2603 | QFN28_5X5_P05 | U46 | MPDS006C_16P | SN74AVC4T245 | MPDS006C_16P | U48 | MPDS006C_16P | SN74AVC4T245 | MPDS006C_16P | U49 | IC8SSOP | PCF8563TS/5 | IC8SSOP | UB1 | IC28SSOP | ICL3243ECAZ-T | IC28SSOP | UB2 | IC28SSOP | ICL3243ECAZ-T | IC28SSOP | USB1 | USBDIP_ATYPE6P | USB_A_Dip | USBDIP_ATYPE6P | USB2 | USBSMD_MUSB5 | USB_MINI_AB | USBSMD_MUSB5 | USBID_SEL1 | CON1X2_2MM | CON1x2_2MM | CON1X2_2MM | VIDEO_IN1 | RCA | RCA | RCA | VIDEO_OUT1 | RCA | RCA | RCA | VIDEO_SEL1 | CON1X2_2MM | CON1x2_2MM | CON1X2_2MM | Y2 | XTAL_X32 | xx_18.432MHz | XTAL_X32 | Y5 | XTAL_X32 | 25MHz | XTAL_X32 | Y6 | XTAL_X32 | 24MHz | XTAL_X32 | Y7 | XTAL_X32 | 25MHz | XTAL_X32 | Y9 | Y2 | 32.768 KHz | Y2 | Y10 | XTAL_X32 | 25MHz | XTAL_X32 | Y11 | XTAL_X32 | 28.6363MHz | XTAL_X32 |
