重要提示:PCB作品文件展下载说明
Name | Part Type | PCB Decal | Value | 1J1 | CONN_H-DC-092 | CONN_H-DC-092 | DC-05-06 | 1J2 | COVER-1R00X3R50 | COVER-1R00X3R50 | MARK | 1J48 | COVER-1R00X3R50 | COVER-1R00X3R50 | MARK | 1L1 | L5050 | L5050 | 2.2UH_2A_DCR≤50MOHM | 1L2 | L5050 | L5050 | 2.2UH_2A_DCR≤50MOHM | 1L3 | L5050 | L5050 | 4.7UH_2A_DCR≤70MOHM | 1L4 | L5050 | L5050 | 4.7UH_2A_DCR≤70MOHM | 1M1 | MARK | MARK | MARK | 1M2 | MARK | MARK | MARK | 1M3 | MARK | MARK | MARK | 1M4 | MARK | MARK | MARK | 1Q1 | SOT-23 | SOT-23 | PMBT3904 | 1Q2 | SOT-23 | SOT-23 | PMBT3904 | 1Q3 | SOT-23 | SOT-23 | WPM2015 | 1Q4 | SOT-23 | SOT-23 | WPM2015 | 1Q5 | SOT-23 | SOT-23 | PMBT3904 | 1TP6 | TP1.1X2.5 | TP1.1X2.5 | HOLE | 1TP8 | TP1.1X2.5 | TP1.1X2.5 | HOLE | 1TP9 | TP1.1X2.5 | TP1.1X2.5 | HOLE | 1U1 | SOT23-6 | SOT23-6 | SY8120B1ABC | 1U2 | SOT23-6 | SOT23-6 | SY8120B1ABC | 1U3 | SOT23-6 | SOT23-6 | SY8120B1ABC | 1U4 | SOT23-6 | SOT23-6 | SY8120B1ABC | 1U6 | SOT23-5 | SOT23-5 | WL2803E18-5 | 1U7 | SOT23-5 | SOT23-5 | WL2803E18-5 | 2U2 | SOT-23 | SOT-23 | MAX809RD/RS809R | 2U3 | DIP-IR | DIP-IR | NC | 2Y2 | Y-SMD4P3225 | Y-SMD4P3225 | 24MHZ_CL12PF_20PPM | 3U4 | BGA78-DDR3 | BGA78-DDR3 | K4B4G0846D-BCMA | 3U5 | BGA78-DDR3 | BGA78-DDR3 | K4B4G0846D-BCMA | 3U6 | BGA78-DDR3 | BGA78-DDR3 | K4B4G0846D-BCMA | 3U7 | BGA78-DDR3 | BGA78-DDR3 | K4B4G0846D-BCMA | 4U7 | BGA169-INAND | BGA169-INAND | THGBMFG6C1LBAIL | 5T2 | TP30 | TP30 | GPIODV_24 | 5T3 | TP30 | TP30 | GPIODV_24 | 5T4 | TP30 | TP30 | GPIODV_24 | 5T5 | TP30 | TP30 | GPIODV_24 | 5T6 | TP30 | TP30 | GPIODV_24 | 6J1 | TF-CARD-PUSH | TF-CARD-PUSH | TFWF1-EBF1-1X0X | 6SW1 | SW_KFC-A06-T-03-1R | SW_KFC-A06-T-03-1R | UPDATE_KEY | 7J1 | J-MS-156 | J-MS-156 | ACA-5036-A3-CC-S | 7J2 | J-MS-156 | J-MS-156 | ACA-5036-A3-CC-S | 7L1 | L3030 | L3030 | 4.7UH_1.1A_DCR125MOHM | 7Q1 | SOT-23 | SOT-23 | NC | 7Q2 | SOT-23 | SOT-23 | NC | 7Q3 | SOT-23 | SOT-23 | NC | 7U1 | AP62X2_13X15 | AP62X2_13X15 | AP6354 | 7Y1 | Y-SMD4P3225 | Y-SMD4P3225 | 37.4MHZ_10PPM | 8F2 | FUSE-0805 | FUSE-0805 | FUSE-500MA | 8J4 | CONN_USB-SM-04F-S1-B1-R9_JINJIA | CONN_USB-SM-04F-S1-B1-R9_JINJIA | USB-2004F-B-T3-P02 | 8L4 | ACM2012-2P | ACM2012-2P | NC | 9D1 | DFN2510P10E | DFN2510P10E | AZ1345-04F | 9D2 | DFN2510P10E | DFN2510P10E | AZ1345-04F | 9D6 | SOD-123 | SOD-123 | NC | 9J1 | CONN_HDMI | CONN_HDMI | HDA31-F1F1-1000-A | 9L1 | EMI-TF2010A4X | EMI-TF2010A4X | NC | 9L2 | EMI-TF2010A4X | EMI-TF2010A4X | NC | 9Q2 | SOT-23 | SOT-23 | WNM2020 | 9Q3 | SOT-23 | SOT-23 | WNM2020 | 9Q5 | SOT-23 | SOT-23 | WNM2020 | 9Q6 | SOT-23 | SOT-23 | WNM2016 | 9RN2 | RN0402 | RN0402 | 4X0R | 9RN3 | RN0402 | RN0402 | 4X0R | 9U2 | SOT23-5 | SOT23-5 | NC | AJ1 | CONN_EARPHONE_CKX-035-398ACBZ6 | CONN_EARPHONE_CKX-035-398ACBZ6 | CKX-035-398ACBZ6 | ANT1 | CAPC5020X100N | CAPC5020X100N | NC | AQ1 | SOT-23 | SOT-23 | PMBT3904 | AQ2 | SOT-23 | SOT-23 | PMBT3904 | AU2 | SOP50P490X110-11N | SOP50P490X110-11N | DIO2125XM10 | AU3 | SOIC-8-150MIL | SOIC-8-150MIL | ES7134LV/CS4334-DSZ | AU4 | TSSOP-10-PT05 | TSSOP-10-PT05 | NC | AU5 | UQFN-N10 | UQFN-N10 | TS5USBA224 | BT1 | TP48 | TP48 | GPIODV_24 | BT2 | TP48 | TP48 | GPIODV_24 | BT3 | TP48 | TP48 | GPIODV_24 | BT4 | TP48 | TP48 | GPIODV_24 | BT5 | TP48 | TP48 | GPIODV_24 | BY1 | XT-SMD4P3225 | XT-SMD4P3225 | NC | MT1 | TP48 | TP48 | TMS | MT2 | TP48 | TP48 | TCK | MT3 | TP48 | TP48 | TDI | MT4 | TP48 | TP48 | TDO | MU1 | AW-CM389NF | AW-CM389NF | NC | PJ1 | CJ-RJ45-1X1-12SL-SMD | CJ-RJ45-1X1-12SL-SMD | CJ-RJ45-1X1-12SL | PT1 | TS8121C | TS8121C | H1601CG | PTP1 | TP30 | TP30 | GPIODV_24 | PTP2 | TP30 | TP30 | GPIODV_24 | PU1 | QFN40P4X4-33N | QFN40P4X4-33N | IP101GR | PY1 | XT-SMD4P3225 | XT-SMD4P3225 | 25MHZ_CL12PF_±20PPM | U1 | BGA334_0P65 | BGA334_0P65 | AML_S905 |
重要提示:PCB作品文件展下载说明
