查看: 6491|回复: 28
[AD格式] FMC SDR module
发表于 2019-7-13 18:52:12 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
FMC SDR module was built as universal communication transceiver compatible with SpaceVPX FMC carriers, both 3U and 6U version It is not fully compatible with FMC specification - the module was extended to fit the RF front end. However it fits nicely to most FMC carriers like Xilinx and Microsemi devkits.
Features:
    [li]FMC LPC[/li][li]VADJ 2.5V[/li][li]AD9364 transceiver chip with shielded RF front-end (up/down converter)[/li][li]support for S and X-band[/li][li]optional external 28V supply for satellite operation[/li][li]all components with space herigate.
    三维
    三维
    [/li][li] Schematics.rar (337 KB, 下载次数: 23) FMC_SDR.rar (2.55 MB, 下载次数: 33)
    [/li][li]BOM[/li][li]
    CommentDescriptionDesignatorFootprintLibRefQuantity
    Plated HoleSingle Terminal SocketB19, B23, B24, B25MTG270_500PLATED_HOLE2.7_PAD5.04
    100nFNon-polarised capacitorC1, C3, C15, C25, C29, C31, C37, C40, C42, C44, C45, C48, C49, C50, C53, C55, C56, C59, C60, C61, C62, C72, C75, C76, C77, C78CAPC1005X55NCC0402_100NF_16V_10%_X7R26
    1uFNon-polarised capacitorC2, C11, C27, C33, C35, C36, C63, C66, C68, C70, C79, C82, C84, C86, C88, C94, C95CAPC1005X55NCC0402_1UF_16V_10%_X5R17
    10uFNon-polarised capacitorC4, C28, C30, C38, C41, C57, C58, C73, C74CAPC1608X87NCC0603_10UF_6.3V_20%_X5R9
    1nFNon-polarised capacitorC5, C6, C8, C17, C19, C21, C22, C23, C92CAPC1005X55NCC0402_1NF_50V_10%_X7R9
    1nFNon-polarised capacitorC7, C12CAPC0603X33NCC0201_1NF_16V_10%_X5R2
    18pFNon-polarised capacitorC9, C13, C14, C16CAPC1005X55NCC0402_18PF_50V_5%_C0G4
    1uFNon-polarised capacitorC10CAPC1608X87NCC0603_1UF_16V_10%_X7R1
    10uFNon-polarised capacitorC18, C20CAPC1608X80NCC0603_10UF_10V_10%_X5R2
    10nFNon-polarised capacitorC24, C32, C65, C81CAPC1005X55NCC0402_10NF_16V_10%_X7R4
    10nFNon-polarised capacitorC26, C34, C64, C67, C69, C71, C80, C83, C85, C87, C89, C90, C91, C96, C97, C98CAPC0603X33NCC0201_10NF_10V_10%_X5R16
    2.2uFPolarised capacitorC39, C52CAPMP3216X180NCTE3216-18_2.2UF_25V_10%2
    47uFNon-polarised capacitorC43, C46, C47CAPC3216X180NCC1206_47UF_25V_20%_X5R3
    22uFNon-polarised capacitorC51, C54CAPC3216X180NCC1206_22UF_35V_20%_JB_TDK_C3216JB1V226M160AC2
    UndefinedNon-polarised capacitorC93CAPC1608X90NCC0603_NO-VALUE1
    AD7291BCPZ8-Channel, I2C, 12-Bit SAR ADC with Temperature SensorIC1QFN50P400X400X80-21N-S275AD7291BCPZ1
    M24C02-RDW6TP2-Kbit (256 x 8bit) Serial I2C Bus EEPROMIC2SOP65P640X120-8NM24C02-RDW6TP1
    MCP9801-M/MS2-Wire High-Accuracy Temperature SensorIC3SOP65P490X110-8NMCP9801-M/MS1
    ADP2164ACPZ-R76.5 V, 4 A, High Efficiency,Step-Down,DC-to-DC RegulatorIC4CP_16_26PM_ADP2164ACPZ-R71
    AD9364BBCZRF 1? transceiver with integrated 12-bit DACs and ADCsIC6BGA144C80P12X12_1000X1000X170AD9364BBCZ1
    SMAJ1, J3TELEGARTNER_J01151A0451TELEGARTNER_J01151A04512
    VITA 57Connector VITA 57, 160 Male contacts in 4 row cdghJ2SAMTEC_ASP-127797-01SAMTEC_ASP-127797-011
    M80-5000000M5-02-333-00-0002pin (2 power), THT socket with M2 jackscrewsJ5M80-5000000M5-02-333-00-000CON_M80-5000000M5-02-333-00-0001
    1k@100MHzL1INDC1005X55NIND0402_MURATA_BLM15HD102SN11
    330nHInductor With CoreL2, L3, L4, L5IND_COILCRAFT_0805CSIND_330NH_2%_COILCRAFT_0805CS4
    600R@100MHzL6INDC1608X75NIND0603_TDK_MMZ1608B601CTAH01
    2.2 A, 0.47 uHWE-MAIA SMD Power Inductor, size 2506, 2.2 A, 0.47 uHL7, L10WE-MAIA_25067843832100472
    390R@100MHzL8INDC1608X95NIND0603_TDK_MPZ1608R391A1
    4.7 A, 2.2 uHWE-MAIA SMD Power Inductor, size 4020, 4.7 A, 2.2 uHL9WE-MAIA_4020784383560221
    40MHz40MHz ?0ppm Crystal 7pF 40 Ohms 4-SMD, No LeadQ1XTAL_EPSON_TSX-32251
    10kResistor - 1%R1, R5, R6, R8, R22, R26, R29, R30, R33, R34RESC1005X40NR0402_10K_1%_0.0625W_100PPM10
    49R9Resistor - 1%R2RESC1005X40NR0402_49R9_1%_0.0625W_100PPM1
    100kResistor - 1%R3, R4, R11, R15, R16, R17RESC1005X40NR0402_100K_1%_0.0625W_100PPM6
    1Resistor - 1%R7, R9RESC1005X40NR0402_1R_1%_0.0625W_200PPM2
    14k3Resistor - 0.1%R10RESC1608X55NR0603_14K3_0.1%_0.063W_10PPM1
    160kResistor - 1%R12, R13, R14, R18, R19, R20RESC1005X40NR0402_160K_1%_0.0625W_100PPM6
    10Resistor - 1%R21, R24RESC1608X55NR0603_10R_1%_0.1W_200PPM2
    UndefinedResistorR23RESC1608X55NR0603_NO-VALUE1
    20kResistor - 1%R25RESC1005X40NR0402_20K_1%_0.0625W_100PPM1
    0ResistorR27, R31RESC1608X55NR0603_0R_JUMPER2
    16kResistor - 1%R28, R32RESC1005X40NR0402_16K_1%_0.0625W_100PPM2
    ADP1755ACPZ-R71.2 A, Low VIN, Low Dropout Linear Regulator, 1.6 to 3.6 V Vin, 0.75 to 3 V Vout, Industrial, 16-pin QFN (CP-16-4), ReelU1, U2CP-16-4_LCMP-0786-00436-12
    [/li]
评分
参与人数 1威望 +30 收起 理由
老吴 + 30 谢谢共享,贴bom奖励
查看全部评分
重要提示:PCB作品文件展下载说明
    昨天 15:34
  • 签到天数: 272 天
    社区居民社区劳模原创先锋奖终身成就奖特殊贡献奖优秀斑竹奖
    发表于 2019-7-13 19:55:45 | 显示全部楼层
    社区居民终身成就奖优秀斑竹奖社区明星宣传大使奖特殊贡献奖原创先锋奖
    发表于 2019-7-13 21:04:32 | 显示全部楼层
    1元学习Allegro(1期)
    发表于 2019-7-13 21:05:07 | 显示全部楼层
    发表于 2019-7-13 21:54:47 | 显示全部楼层
    发表于 2019-7-13 21:58:16 | 显示全部楼层
    不断学习才能进步
    社区居民忠实会员最爱沙发终身成就奖优秀斑竹奖
    发表于 2019-7-14 07:04:53 | 显示全部楼层
    不断学习才能不断进步
  • 签到天数: 10 天
    发表于 2019-7-14 07:39:02 | 显示全部楼层
    1 小时前
  • 签到天数: 165 天
    你必须非常努力才能显
    发表于 2019-7-14 08:38:49 | 显示全部楼层
    发表于 2019-7-14 08:48:54 | 显示全部楼层
