查看: 5557|回复: 43
[AD格式] RFID_system
发表于 2019-7-13 19:02:29 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
RFID_system
This is simple RFID system for behaviour experiments with caged animals. The efuipment developed within this project is part of EcoHab cage.
示意图
示意图
RFID_Reader.PDF (6.11 MB, 下载次数: 0) RFID_reader-master.rar (70 KB, 下载次数: 6) RFID_PCB.rar (1.59 MB, 下载次数: 7)
BOM
CommentDescriptionDesignatorFootprintLibRefQuantity
100nFNon-polarised capacitorC1, C2A, C2B, C2C, C2D, C2E, C2F, C2G, C2H, C5, C7, C11A, C11B, C11C, C11D, C11E, C11F, C11G, C11H, C12, C14A, C14B, C14C, C14D, C14E, C14F, C14G, C14H, C15A, C15B, C15C, C15D, C15E, C15F, C15G, C15H, C19, C20CAPC1608X87NCC0603_100NF_50V_10%_X5R, CC0603_10NF_50V_10%_X7R38
22uFPolarised capacitorC3A, C3B, C3C, C3D, C3E, C3F, C3G, C3H, C13A, C13B, C13C, C13D, C13E, C13F, C13G, C13H, C16, C17, C18, C21, C22, C23, C24CAPAE430X540NCAE430-540_22UF_10V_20%23
10nFNon-polarised capacitorC4A, C4B, C4C, C4D, C4E, C4F, C4G, C4HCAPC1608X87NCC0603_10NF_50V_10%_X7R8
100pFNon-polarised capacitorC6A, C6B, C6C, C6D, C6E, C6F, C6G, C6HCAPC1608X90NCC0603_100PF_250V_5%_ATC_600S8
12pFNon-polarised capacitorC8, C9CAPC1608X87NCC0603_12PF_50V_5%_NP02
1nFNon-polarised capacitorC10A, C10B, C10C, C10D, C10E, C10F, C10G, C10HCAPC1608X87NCC0603_10NF_50V_10%_X7R8
PRTR5V0U2XUltra Low Capacitance Double Rail-to-Rail ESD Protection DiodeD1SOT190P230X110-4NPRTR5V0U2X1
Light Emitting DiodeDL1A, DL1B, DL1C, DL1D, DL1E, DL1F, DL1G, DL1H, DL2A, DL2B, DL2C, DL2D, DL2E, DL2F, DL2G, DL2H0805_LEDLED116
L78L33ACUTR3-Terminal Regulator 1=OUT 2=GND 3=INIC1SOT89L78L33ACUTR1
74LVC126AQuadruple Bus Buffer with 3-State OutputsIC2A, IC2B, IC2C, IC2D, IC2E, IC2F, IC2G, IC2HSOIC127P600X175-14N8
FamilyDual Right Angle 50 Ohm BNC Jack, White Valox CaseJ1, J2, J3, J4RENHOTEC_RHT-610-00494
Header, 3-Pin, Dual rowJ_PD, J_Prog1A, J_Prog1B, J_Prog1C, J_Prog1D, J_Prog1E, J_Prog1F, J_Prog1G, J_Prog1HHDR2X3Header 3X29
USB5 Pin + 1 Shield USB ReceptacleJ_USBWURTH_651005136521WURTH_6510051365211
0.5RFerrite BeadL11608[0603]IND_1UH_20%_BOURNS_SRP4020TA1
GreenLED x4 Green 1C2A-BOT_3C4A_5C6A_7C8A-TOPLD1, LD2LED_BIVAR_H485CGDL2
ILSI ISM92-3351AH-4.0000Oscillator 4 pins 3.3V 4MHzOSC1OSCSC250P320X500X130-4NOscillator 1E 2GND 3OUT 4VDD1
16MHzQuartz CrystalQ1XTAL1160X490X430XTAL_16MHZ_IQD_LFXTAL0032371
510Resistor - 1%R1, R2, R3, R4, R5, R6, R7, R8RESC1608X55NR0603_510R_1%_0.1W_100PPM8
10kResistor - 1%R9, R10, R11, R12, R13, R14RESC1608X55NR0603_10K_1%_0.1W_100PPM6
1kResistor - 1%R15A, R15B, R15C, R15D, R15E, R15F, R15G, R15H, R17A, R17B, R17C, R17D, R17E, R17F, R17G, R17HRESC1608X50NR0805_1K_1%_0.33W_100PPM_VISHAY_CRCW-HP16
10kResistor - 1%R16A, R16B, R16C, R16D, R16E, R16F, R16G, R16H, R19A, R19B, R19C, R19D, R19E, R19F, R19G, R19HRESC1608X50NR0805_1K_1%_0.33W_100PPM_VISHAY_CRCW-HP, R0603_10K_1%_0.1W_100PPM16
100Resistor - 1%R18A, R18B, R18C, R18D, R18E, R18F, R18G, R18HRESC1608X50NR0603_100R_1%_0.1W_100PPM8
15kResistor - 1%R20A, R20B, R20C, R20D, R20E, R20F, R20G, R20HRESC1608X50NR0603_15K_1%_0.1W_100PPM8
HEXRotary Code Switch 1 2 4 8 C1 C2SW1SW_OMRON_A6RV-162RFSW_OMRON_A6RV-162RF1
ATxmega16A4U-AU8/16-bit AVR XMEGA A4 Microcontroller, 1.6-3.6V, 16KB + 4KB Flash, 1KB EEPROM, 2KB SRAM, 44-pin TQFP, Industrial Grade (-40癈 to 85癈), Pb-FreeU144A_NATxmega16A4-AU1
ATtiny441-SU8-bit AVR Microcontroller, 1.8-5.5V, 2KB Flash, 128 Bytes SRAM, 12 GPIO pins, 14-pin SOIC, Industrial Grade (-40癈 to 85癈), Pb-FreeU2A, U2B, U2C, U2D, U2E, U2F, U2G, U2H14S1_LATtiny441-SU8
HTRC110HITAG reader chipU3A, U3B, U3C, U3D, U3E, U3F, U3G, U3HSOIC127P600X175-14NHTRC1108
评分
参与人数 1威望 +30 收起 理由
老吴 + 30 谢谢共享、贴bom奖励
查看全部评分
重要提示:PCB作品文件展下载说明
    5 小时前
  • 签到天数: 261 天
    发表于 2019-7-13 20:55:41 | 显示全部楼层
    发表于 2019-7-13 21:44:17 | 显示全部楼层
    发表于 2019-7-13 21:54:21 | 显示全部楼层
    发表于 2019-7-13 21:58:27 | 显示全部楼层
    终身成就奖社区居民优秀斑竹奖
    发表于 2019-7-13 22:51:37 | 显示全部楼层
    发表于 2019-7-14 06:43:11 | 显示全部楼层
    不断学习才能进步
    社区居民忠实会员最爱沙发终身成就奖优秀斑竹奖
    发表于 2019-7-14 07:03:51 | 显示全部楼层
    不断学习才能不断进步
  • 签到天数: 10 天
    发表于 2019-7-14 07:39:14 | 显示全部楼层
    1 小时前
  • 签到天数: 165 天
    你必须非常努力才能显
    发表于 2019-7-14 08:38:21 | 显示全部楼层
