查看: 11727|回复: 63
[Allegro16.6以下] RK3288+RK1608B+TC358748XBG+RTL8211E 做的minipc PCB文件共享
    17万
    管理员
    原创先锋奖终身成就奖优秀斑竹奖宣传大使奖社区居民社区明星社区劳模最爱沙发新人进步奖忠实会员金点子奖特殊贡献奖
    发表于 2019-8-14 11:16:40 | 显示全部楼层 |阅读模式
    重要提示:PCB作品文件展下载说明
    ANT1ANT_1P1G_ANT2_40R00X9R00_ANT_DIANT_DIPOLE_1ANT2_40R00X9R00
    CM2CM_C_MTM-C_100UF/16V100uF/16VMTM-C
    CM3CM_C_MTM-C_100UF/16V100uF/16VMTM-C
    CM4CM_C_MTM-C_100UF/16V100uF/16VMTM-C
    D1DIODE_SOD_323_1N4148WS1N4148WSSOD_323
    D6DIODE_SOD_123_B5819WB5819WSOD_123
    ED1ESD_1_SOT23_NC/ESDA6V8UL/AZC199NC/ESDA6V8UL/AZC199-02SSOT23
    ED2ESD_1_SOT23_NC/ESDA6V8UL/AZC199NC/ESDA6V8UL/AZC199-02SSOT23
    ED3DIODE BI-DIRTRIG_E0402N_NC/ESDNC/ESD9B5VE0402N
    ED4DIODE BI-DIRTRIG_E0402N_NC/ESDNC/ESD9B5VE0402N
    ED5DIODE BI-DIRTRIG_E0402N_NC/ESDNC/ESD9B5VE0402N
    ED6DIODE BI-DIRTRIG_E0402N_NC/ESDNC/ESD9B5VE0402N
    ED7DIODE BI-DIRTRIG_E0402N_NC/ESDNC/ESD9B5VE0402N
    ED8DIODE BI-DIRTRIG_E0402N_NC/ESDNC/ESD9B5VE0402N
    ED9DIODE BI-DIRTRIG_E0402N_NC/ESDNC/ESD9B5VE0402N
    ED10DIODE BI-DIRTRIG_E0402N_ESD9B5ESD9B5VE0402N
    ED13DIODE BI-DIRTRIG_E0402N_NCNCE0402N
    ED14DIODE BI-DIRTRIG_E0402N_NCNCE0402N
    ED21ESD_1_SOT23_NC/ESDA6V8UL/AZC199NC/ESDA6V8UL/AZC199-02SSOT23
    ED22ESD_1_SOT23_NC/ESDA6V8UL/AZC199NC/ESDA6V8UL/AZC199-02SSOT23
    ED23ESD_1_SOT23_NC/ESDA6V8UL/AZC199NC/ESDA6V8UL/AZC199-02SSOT23
    ED24ESD_1_SOT23_NC/ESDA6V8UL/AZC199NC/ESDA6V8UL/AZC199-02SSOT23
    ED25DIODE BI-DIRTRIG_E0402_ESD9B5VESD9B5VE0402
    ED34DIODE BI-DIRTRIG_E0402N_ESD9B5ESD9B5VE0402N
    ED35DIODE BI_DIRTRIG_ESD0402_ESD53ESD5311NESD0402
    F3FUSE_0_R1210_2A2AR1210
    FB4004BEAD_L0603_120R-100MHZ120R-100MHzL0603
    FB4005BEAD_L0603_120R-100MHZ120R-100MHzL0603
    FB4006BEAD_L0603_120R-100MHZ120R-100MHzL0603
    FB4007BEAD_L0603_120R-100MHZ120R-100MHzL0603
    H1HOLE_HOLE_C4R10_C6R00_HOLE_C4R1HOLE_C4R10_C6R00HOLE_C4R10_C6R00
    H2HOLE_HOLE_C4R10_C6R00_HOLE_C4R1HOLE_C4R10_C6R00HOLE_C4R10_C6R00
    H3HOLE_HOLE_C4R10_C6R00_HOLE_C4R1HOLE_C4R10_C6R00HOLE_C4R10_C6R00
    H4HOLE_HOLE_C4R10_C6R00_HOLE_C4R1HOLE_C4R10_C6R00HOLE_C4R10_C6R00
    H5HOLE_HOLE_C4R10_C6R00_HOLE_C4R1HOLE_C4R10_C6R00HOLE_C4R10_C6R00
    H6HOLE_HOLE_C4R10_C6R00_HOLE_C4R1HOLE_C4R10_C6R00HOLE_C4R10_C6R00
    H7HOLE_HOLE_C4R10_C6R00_HOLE_C4R1HOLE_C4R10_C6R00HOLE_C4R10_C6R00
    H8HOLE_HOLE_C4R10_C6R00_HOLE_C4R1HOLE_C4R10_C6R00HOLE_C4R10_C6R00
    J2TFCARD_SOCKET_TF9_CKT01_009D_TFTF-CKT01-009DTF9_CKT01_009D
    J3MINIUSB_0_USB_KIU90511S1R-_USBUSBUSB_KIU90511S1R-
    J4USB20_TYPE_A_USB20A4_USB_AF_01_USB-HUB_PORTBAUSB20A4_USB_AF_01_001
    J5SOCKET_DDR3 SODIMM_CON204_DDR3Con_DDR3_SO_DIMMCON204_DDR3_SO_DIMM
    J13JTAG_CEVA_JTAG_DSP_JTAG_CEVAJTAG_CEVAJTAG_DSP
    J14USB20_MINI_USB20MIN5_USB_M5_03_USB20_miniUSB20MIN5_USB_M5_03_002
    J506CON10_0_CN5-2R54_CN5-2R54CN5-2R54CN5-2R54
    J3007DCJACK_3P_DC3-3R5_DC3-3R5DC3-3R5DC3-3R5
    J3008FH91C_8S_0R5SH_FPC8R_1X8_0R50_DFH91C_8S_0R5SHFPC8R_1X8_0R50_DOWN_FH19C
    J3009AXT540124_CON40F_2X20_0R40_AXT5AXT540124CON40F_2X20_0R40_AXT540124
    J3010GND_GATE_CN2_5R08_DIP_GND_GATEGND_GATECN2_5R08_DIP
    J3011GND_GATE_CN2_5R08_DIP_GND_GATEGND_GATECN2_5R08_DIP
    J3012USB20_MINI_USB20MIN5_USB_M5_03_USB20_miniUSB20MIN5_USB_M5_03_002
    JP1RJ45_CON8_0_RJ45-NOLED_RJ45SRJ45SRJ45-NOLED
    L2INDUCTOR_1_IND-3X3_SWPA3015S3R3SWPA3015S3R3NT/1AIND-3X3
    L3INDUCTOR_1_IND-3X3_SWPA3015S3_1SWPA3015S3R3NTIND-3X3
    L6INDUCTOR_1_IND-3X3_2.2UH/1.5A2.2uH/1.5AIND-3X3
    L7INDUCTOR_1_IND-3X3_2.2UH/1.5A2.2uH/1.5AIND-3X3
    L9INDUCTOR_1_IND-3X3_2.2UH/1A2.2uH/1AIND-3X3
    L10INDUCTOR_1_IND-3X3_SWPA3015S3R3SWPA3015S3R3NT/1AIND-3X3
    L11INDUCTOR_L0603_BLM18PG181SN1BLM18PG181SN1L0603
    L12INDUCTOR_1_IND-3X3_2.2UH/1.5A2.2uH/1.5AIND-3X3
    L15INDUCTOR_1_IND-3X3_2.2UH/1.5A2.2uH/1.5AIND-3X3
    L16INDUCTOR_L0603_BLM18PG181SN1BLM18PG181SN1L0603
    L26INDUCTOR_2_IND-4X4_0.24UH/5A0.24uH/5AIND-4X4
    L27INDUCTOR_2_IND-4X4_0.24UH/5A0.24uH/5AIND-4X4
    L28INDUCTOR_1_IND-6X6_4.7UH/3A4.7uH/3AIND-6X6
    L29INDUCTORS OFFERRITE_IND_2520120.24uHIND_252012
    L44INDUCTORS OFFERRITE_IND_30301010uHIND_303010
    LED2LED_LED0603_LED_GREENLED_GREENLED0603
    LED3LED_LED0603_LEDLEDLED0603
    LED4LED_LED0603_LED_REDLED_REDLED0603
    LED5LED_LED0603_LEDLEDLED0603
    LED6LED_LED0603_LEDLEDLED0603
    LED7LED_LED0603_LEDLEDLED0603
    LED8LED_LED0603_LEDLEDLED0603
    LED9LED_LED0603_LED_BLUELED_BLUELED0603
    M1MARK_MARK_MARKMARKMARK
    M2MARK_MARK_MARKMARKMARK
    M3MARK_MARK_MARKMARKMARK
    M4MARK_MARK_MARKMARKMARK
    M5MARK_MARK_MARKMARKMARK
    M6MARK_MARK_MARKMARKMARK
    Q740852_1_SOT23_NC/8050NC/8050SOT23
    Q22MOSFETP_SOT23_WPM2015WPM2015SOT23
    Q2340852_1_SOT23_NC/8050NC/8050SOT23
    Q50640852_1_SOT23_80508050SOT23
    Q2307MOSFETP_SOT23_WPM2015-3/TRWPM2015-3/TRSOT23
    Q2308NPN_SOT23_S8050S8050SOT23
    Q231440852_1_SOT23_80508050SOT23
    Q231540852_1_SOT23_80508050SOT23
    RP1RESISTOR4PACK_R0402S4_10K10KR0402S4
    RP2RESISTOR4PACK_R0402S4_10K10KR0402S4
    S1SWDIP-4_SW8_5R68X5R40X2R30_SW_SW_DIP-4SW8_5R68X5R40X2R30
    S2SWDIP-4_SW8_5R68X5R40X2R30_SW_SW_DIP-4SW8_5R68X5R40X2R30
    S3SWDIP-4_SW8_5R68X5R40X2R30_SW_SW_DIP-4SW8_5R68X5R40X2R30
    S4SWDIP-4_SW8_5R68X5R40X2R30_SW_SW_DIP-4SW8_5R68X5R40X2R30
    S700PSW3_B_SW-JT601-103AB2_PSW3_BPSW3_BSW-JT601-103AB2
    SW1SW4P_5_SW-5P_RESETRESETSW-5P
    SW6SW_SSSS811101_1_HOLD-PADS1_WP-SWP-selectHOLD-PADS1
    SW7SW4P_5_SW-5P_RESETRESETSW-5P
    SW8SW4P_5_SW-5P_RESETRESETSW-5P
    SW1102SW4P_1_SW4-SKQG-5_2X5_2H1_5B_RERECOVERSW4-SKQG-5_2X5_2H1_5B
    SW1104SW4P_5_SW-5P_RESETRESETSW-5P
    SW1105SW4P_5_SW-5P_RESETRESETSW-5P
    SW1106SW4P_5_SW-5P_RESETRESETSW-5P
    U1DSP_RK3288_BGA636_19R00X19R00X1RK3288BGA636_19R00X19R00X1R20
    U2DDR3_16BIT_FBGA96_14R00X11R00X1K4B4G1646QFBGA96_14R00X11R00X1R20
    U3DDR3_16BIT_FBGA96_14R00X11R00X1K4B4G1646QFBGA96_14R00X11R00X1R20
    U4DDR3_16BIT_FBGA96_14R00X11R00X1K4B4G1646QFBGA96_14R00X11R00X1R20
    U5DDR3_16BIT_FBGA96_14R00X11R00X1K4B4G1646QFBGA96_14R00X11R00X1R20
    U6NANDFLASH_0_TSOP1-48_NC/NAND_FLNC/NAND_FLASHTSOP1-48
    U7INAND_EMMC_169_INAND_169_KLM8G1KLM8G1GEAC-B031INAND_169
    U8TSD_0_TSOP1-48_NC/TSD_FLASHNC/tSD_FlashTSOP1-48
    U12INTERFACE_FT232RL_SSOP28_10R20XFT232RLSSOP28_10R20X5R30X2R00
    U13ESD_ESDA6V8UL_SOT_23_ESD5302FESD5302FSOT_23
    U14LPW5206H_SOT25_SY6280AAC/WS4601SY6280AAC/WS4601SOT25
    U15DS8008_4_SOT25_PT5108E23E-18PT5108E23E-18SOT25
    U18RK1608B_0_BGA217_39RX39RX45R_S_RK1608BBGA217_39RX39RX45R_S
    U19H5007_2_SOIC24_H5007(PULSE)H5007(Pulse)SOIC24
    U20RTL8169S_1_QFN48-6X6_RTL8211E-VRTL8211E-VB-CGQFN48-6X6
    U21MAX809SD_3_SOT23_NC/CE8809C263MNC/CE8809C263MASOT23
    U23AMPAK_SIPAP6335AP6XXX
    U24DS8008_4_SOT25_NC/PT5108E23E-15NC/PT5108E23E-15SOT25
    U27LPW5206H_SOT25_SY6280AAC/WS4601SY6280AAC/WS4601SOT25
    U29DCDC_MP1488_SOT_23_6L_MP1488MP1488SOT_23_6L
    U30LM4990_0_MSOP8_HYM8563HYM8563MSOP8
    U35DCDC_SY837_CSP20_1R96X1R56X0R66SYR837PKCCSP20_1R96X1R56X0R66
    U36DCDC_SY837_CSP20_1R96X1R56X0R_1SYR838PKCCSP20_1R96X1R56X0R66
    U76ACT8847_5_QFN48-6X6_ACT8846QM49ACT8846QM490-TQFN48-6X6
    U77PL-2303_0_SSOP28_FT232RLFT232RLSSOP28
    U144ESDA6V8UD/AZC199-02S_0_SOT23_ESESDA6V8UL/AZC199-02SSOT23
    U4001INTERFACE_TC358748_VFBGA80_7R00TC358748XBGVFBGA80_7R00X7R00X1R00
    U4003LDO_PT5108_SOT_23_5_RT9013-12BRT9013-12BSOT_23_5
    U4004INTERFACE_TC358748_VFBGA80_7R00TC358748XBGVFBGA80_7R00X7R00X1R00
    U4005LDO_PT5108_SOT_23_5_RT9013-12BRT9013-12BSOT_23_5
    U4009LDO_PT5108_SOT_23_5_PT5108E23E-PT5108E23E-18SOT_23_5
    U4011TPS54328_1_SOP8A_TPS54328TPS54328SOP8A
    U4012UM3212M8_MSOP8_UM3212M8UM3212M8MSOP8
    U4013UM3212M8_MSOP8_UM3212M8UM3212M8MSOP8
    U4014DS8008_6_SOT_23_5_SY8089SY8089SOT_23_5
    U4015DS8008_4_SOT_23_5_PT5108E23E-18PT5108E23E-18SOT_23_5
    U4016DS8008_4_SOT_23_5_PT5108E23E-18PT5108E23E-18SOT_23_5
    U4017DS8008_6_SOT_23_5_SY8089SY8089SOT_23_5
    U4018LDO_TT2102_0_SOT_23_5_TT2102TT2102SOT_23_5
    U4020DCDC_SY837_CSP20_1R96X1R56X0R66SYR837PKCCSP20_1R96X1R56X0R66
    U4021SN74AUC1G17_SOT_23_5_SN74AUC1G1SN74AUC1G17SOT_23_5
    U4022SN74AUC1G17_SOT_23_5_SN74AUC1G1SN74AUC1G17SOT_23_5
    U4023UM3212M8_MSOP8_UM3212M8UM3212M8MSOP8
    U4024LDO_PT5108_SOT_23_5_RT9193-28GBRT9193-28GBSOT_23_5
    U4025SN74AVC4T245_TSSOP_16_SN74AVC4TSN74AVC4T245TSSOP_16
    U4026SN74AVC4T245_TSSOP_16_SN74AVC4TSN74AVC4T245TSSOP_16
    VR1500VR_VR_10R00X10R00X5R00_H_500500VR_10R00X10R00X5R00_H
    VR1501VR_VR_10R00X10R00X5R00_H_NCNCVR_10R00X10R00X5R00_H
    Y2CRYSTAL-4_0_CRY-D3225_24M-20PPM24M-20ppmCRY-D3225
    Y3CRYSTAL-4_1_CRY-D3225_25MHZ-30P25MHz-30ppmCRY-D3225
    Y4CRYSTAL-4_1_CRY-D3225_37.4MHZ-137.4MHz-10ppmCRY-D3225
    Y5CRYSTAL_2_CRY_MC146_32.768KHZ32.768KHzCRY_MC146
    Y4001CRYSTAL_OSC_CRY-D3225_19.2MHZ19.2MHzCRY-D3225
    Y4002CRYSTAL_4P_CRY4_3R20X2R50X0R80_24MHzCRY4_3R20X2R50X0R80
    重要提示:PCB作品文件展下载说明
    17万
    管理员
     楼主| 发表于 2019-8-14 11:19:01 | 显示全部楼层
    PCB文件。回复可见 ,没原理图。
    游客,如果您要查看本帖隐藏内容请回复
    PADS-181015高级班
    社区居民忠实会员社区劳模终身成就奖特殊贡献奖原创先锋奖优秀斑竹奖金点子奖
    发表于 2019-8-14 11:29:45 | 显示全部楼层
    最后成功的人往往不是最有才华的人,而是那些默默付出直到最后一刻也不放弃的那些人!
    前天 08:10
  • 签到天数: 119 天
    你必须非常努力才能显
    发表于 2019-8-14 11:39:59 | 显示全部楼层
    社区居民终身成就奖特殊贡献奖原创先锋奖
    发表于 2019-8-14 13:34:15 | 显示全部楼层
    非常感谢楼主大神分享
    社区居民终身成就奖优秀斑竹奖社区明星宣传大使奖特殊贡献奖原创先锋奖
    发表于 2019-8-14 14:20:59 | 显示全部楼层
    1元学习Allegro(2期)
    发表于 2019-8-14 22:04:29 | 显示全部楼层
    3 天前
  • 签到天数: 77 天
    发表于 2019-8-14 22:11:35 | 显示全部楼层
    3 天前
  • 签到天数: 44 天
    1元学习Allegro(1期)
    终身成就奖特殊贡献奖社区居民忠实会员社区劳模优秀斑竹奖最爱沙发社区明星宣传大使奖
    发表于 2019-8-15 00:02:25 | 显示全部楼层
    不错的RK,有原理图就好了
    郁闷
    2024-11-7 10:22
  • 签到天数: 9 天
    发表于 2019-8-15 08:06:46 | 显示全部楼层
