Name | PCB Decal | Value | Part Type | 1H1 | HOLE-D3MM | HOLE-D3MM | HOLE-D3MM | 1H2 | HOLE-D3MM | HOLE-D3MM | HOLE-D3MM | 1H3 | HOLE-D3MM | HOLE-D3MM | HOLE-D3MM | 1H4 | HOLE-D3MM | HOLE-D3MM | HOLE-D3MM | BAT201 | A1254WR-S-03P | LI_8.4V | A1254WR-S-03P | BAT560 | SMD_125_2P | FPC1.25-2P | SMD_125_2P | BZ401 | B09650 | BUZZER | B09650 | Name | PCB Decal | Value | Part Type | 1H1 | HOLE-D3MM | HOLE-D3MM | HOLE-D3MM | 1H2 | HOLE-D3MM | HOLE-D3MM | HOLE-D3MM | 1H3 | HOLE-D3MM | HOLE-D3MM | HOLE-D3MM | 1H4 | HOLE-D3MM | HOLE-D3MM | HOLE-D3MM | BAT201 | A1254WR-S-03P | LI_8.4V | A1254WR-S-03P | BAT560 | SMD_125_2P | FPC1.25-2P | SMD_125_2P | BZ401 | B09650 | BUZZER | B09650 | CON2 | CON_20_4P | PH_2.0_4P | CON_20_4P | CON3 | CON_20_4P | PH_2.0_4P | CON_20_4P | CON4 | CON_20_4P | PH_2.0_4P | CON_20_4P | CON6 | CON_FPC_05_40P_DW_L | FPC0.5MM/40P | CON_FPC_05_40P_DW_L | CON7 | FFC6PIW | FPC6P/0.5mm | FFC6PIW | CON8 | SMD_10_4P | WAFER_1.0-4P | SMD_10_4P | CON9 | SMD_10_4P | WAFER_1.0-4P | SMD_10_4P | CON10 | CON_20_4P | PH_2.0_4P | CON_20_4P | CON11 | CON_20_4P | PH_2.0_4P | CON_20_4P | CON12 | CON_20_3P | PH_2.0_3P/NC | CON_20_3P | CON13 | CON_20_5P | NC/CON_2.0_5P | CON_20_5P | CON14 | CON_20_4P | PH_2.0_4P | CON_20_4P | CON15 | CON_20_4P | PH_2.0_4P | CON_20_4P | CON16 | CON_20_4P | PH_2.0_4P | CON_20_4P | CON17 | MINI_PCIE_52PB | MINI_PCIE_52P_5H | MINI_PCIE_52PB | CON21 | CON_20_4PIN | NC/CON_2.0_4P | CON_20_4PIN | CON22 | SMD_10_2P | WAFER_1.0-2P | SMD_10_2P | CON23 | CON_20_4PIN | NC/CON_2.0_4P | CON_20_4PIN | CON24 | SMD_10_5P | WAFER_1.0-5P | SMD_10_5P | CON25 | CON_20_3P | PH_2.0_3P/NC | CON_20_3P | D101 | LED0603X2 | LED_R/G | LED0603X2 | D201 | SOD123 | NC/SBA140AS | SOD123 | D202 | SOD-323 | LMDL914T1G | SOD-323 | D203 | SOD123 | SBA140AS | SOD123 | D204 | SOD123 | SBA140AS | SOD123 | D205 | SOD123 | NC/SMF15A | SOD123 | D206 | DO_214AC | SS32 | DO_214AC | D207 | SOD-323 | LMDL914T1G | SOD-323 | D208 | SOD123 | NC/SBA140AS | SOD123 | D401 | SOD123 | SBA140AS | SOD123 | D402 | SOD-323 | LMDL914T1G | SOD-323 | D403 | LED_0603 | BLUE_LED | LED_0603 | D501 | SOD123 | SBA140AS | SOD123 | D502 | SOT23 | BAT54S | SOT23 | D503 | SOD-323 | BZT52C5V6SW8 | SOD-323 | D504 | SOD123 | SBA140AS | SOD123 | D560 | SOD123 | SBA140AS | SOD123 | D561 | SOD123 | SBA140AS | SOD123 | ED29 | E0402N | NC/PE1605M1Q | E0402N | ED30 | E0402N | PE1605M1Q | E0402N | ED31 | E0402N | PE1605M1Q | E0402N | ED32 | E0402N | PE1605M1Q | E0402N | ED33 | E0402N | PE1605M1Q | E0402N | ED34 | E0402N | PE1605M1Q | E0402N | ED42 | E0402N | NC/PE1605M1Q | E0402N | ED43 | E0402N | PE1605M1Q | E0402N | ED44 | SOD123 | SMF15A | SOD123 | ED45 | SOD123 | SMF15A | SOD123 | ED46 | E0402N | NC/PE1605M1Q | E0402N | ED47 | E0402N | NC/PE1605M1Q | E0402N | ED48 | E0402N | PE1605M1Q | E0402N | ED49 | E0402N | PE1605M1Q | E0402N | F150 | R0805 | SMD0805P075TF | R0805 | F151 | R0805 | SMD0805P075TF | R0805 | F152 | R0805 | SMD0805P075TF | R0805 | FB150 | MC2012 | NC/SDCW2012-2-900 | MC2012 | FB151 | MC2012 | NC/SDCW2012-2-900 | MC2012 | FB153 | L0603 | 600R/100M | L0603 | FB320 | L0603 | 180R-100M/NC | L0603 | FB321 | L0603 | 180R-100M | L0603 | FB322 | L0603 | 1K/100M | L0603 | FB323 | L0603 | 1K/100M | L0603 | FB324 | L0603 | 1K/100M | L0603 | FB325 | L0603 | 1K/100M | L0603 | FB401 | L0603 | 600R/100M | L0603 | FB402 | L0603 | 600R/100M | L0603 | JP1 | DC005 | DC-005_3P | DC005 | JP2 | USB_A_F | USB_HOST | USB_A_F | JP6 | RJ45-MINI_5JA | JP45+LED | RJ45-MINI_5JA | JP7 | WIFI-RF | RF | WIFI-RF | JP10 | TF_7M_8PIN | TF_SD_SOCKET | TF_7M_8PIN | JP11 | SIM_08A_6PIN | SIMCARDSOKET | SIM_08A_6PIN | JP12 | SIM_08A_6PIN | SIMCARDSOKET | SIM_08A_6PIN | JP13 | USB_A_F | USB_HOST | USB_A_F | L201 | IND-4X4 | 1UH/6.6A | IND-4X4 | L202 | IND-4X4 | 2.2UH/3A | IND-4X4 | L203 | IND-4X4 | 1UH/6.6A | IND-4X4 | L204 | IND-4X4 | 2.2UH/3A | IND-4X4 | L205 | IND-3X3 | WQPIG3015LF-3R3M | IND-3X3 | L206 | IND-3X3 | WQPIG3015LF-3R3M | IND-3X3 | L207 | IND-4X4 | 3.3UH/3.3A | IND-4X4 | L208 | IND-4X4 | 4.7UH/4.9A | IND-4X4 | L209 | IND-4X4 | 4.7UH/4.9A | IND-4X4 | L210 | IND-4X4 | 2.2UH/3A | IND-4X4 | L501 | IND-3X3 | WQPIG3015LF-100M | IND-3X3 | L502 | IND-3X3 | WQPIG3015LF-100M | IND-3X3 | L601 | IND-4X4 | 2.2UH/3A | IND-4X4 | L701 | L0402 | 220NH | L0402 | L702 | L0402 | 220NH | L0402 | L801 | IND-3X3 | WQPIG3015LF-3R3M | IND-3X3 | M1 | MARK | MARK | MARK | M2 | MARK | MARK | MARK | M3 | MARK | MARK | MARK | M4 | MARK | MARK | MARK | MIC1 | SMD_10_2P | WAFER_1.0-2P | SMD_10_2P | Q100 | SOT23 | NC/WPM2026 | SOT23 | Q101 | SOT23 | PJA3401 | SOT23 | Q102 | SOT23 | L8050QLT1G | SOT23 | Q103 | SOT23 | L8050QLT1G | SOT23 | Q104 | SOT23 | L8050QLT1G | SOT23 | Q201 | SOT23 | PJA3401 | SOT23 | Q202 | SOT23 | L8050QLT1G | SOT23 | Q203 | SOT23 | WNM3003-3/TR | SOT23 | Q204 | SOT23 | WNM3003-3/TR | SOT23 | Q205 | SOT23 | L8050QLT1G | SOT23 | Q206 | SOT23 | PJA3401 | SOT23 | Q320 | SOT23 | L8050QLT1G | SOT23 | Q401 | SOT23 | L8050QLT1G | SOT23 | Q402 | SOT23 | PJA3401 | SOT23 | Q403 | SOT23 | L8050QLT1G | SOT23 | Q404 | SOT23 | L8050QLT1G | SOT23 | Q405 | SOT23 | L8050QLT1G | SOT23 | Q406 | SOT23 | WNT2F04-3/TR | SOT23 | Q407 | SOT23 | WNT2F04-3/TR | SOT23 | RP1 | R0402S4 | 10K/8P4R | R0402S4 | RP2 | R0402S4 | 10K/8P4R | R0402S4 | SR101 | R0402 | | R0402 | SW6 | SW_SK-12D02 | OTG-ID | SW_SK-12D02 | SW201 | SW_GT_TC197B | POWER | SW_GT_TC197B | SW202 | SW_GT_TC197B | RESET | SW_GT_TC197B | SW203 | SW_GT_TC197B | VOL+ | SW_GT_TC197B | SW204 | SW_GT_TC197B | VOL- | SW_GT_TC197B | SW560 | K2-1817UQ | KEY | K2-1817UQ | SW561 | K2-1817UQ | KEY | K2-1817UQ | SW562 | K2-1817UQ | KEY | K2-1817UQ | SW563 | K2-1817UQ | KEY | K2-1817UQ | U1 | BGA636_1 | MCU_RK3288 | BGA636_1 | U2 | FBGA96-10X14 | DDR3_256MX16BIT | FBGA96-10X14 | U3 | FBGA96-10X14 | DDR3_256MX16BIT | FBGA96-10X14 | U4 | FBGA96-10X14 | DDR3_256MX16BIT | FBGA96-10X14 | U5 | FBGA96-10X14 | DDR3_256MX16BIT | FBGA96-10X14 | U8 | INAND_169B | eMMC_FLASH | INAND_169B | U9 | SOT-23-5 | RT9080-18GJ5 | SOT-23-5 | U150 | LQFP48 | FE2_1 | LQFP48 | U151 | SOT-23-5 | SY6280AAC | SOT-23-5 | U152 | SOT-23-5 | SY6280AAC | SOT-23-5 | U201 | QFN68_7X7 | RK808-B | QFN68_7X7 | U202 | SOT-23-5 | SY8089AAAC | SOT-23-5 | U203 | SOT-23-5 | SY8089AAAC | SOT-23-5 | U204 | SOT23 | RT9064-50GVN | SOT23 | U205 | QFN24_3R5X5R5 | BQ24133RGYR | QFN24_3R5X5R5 | U206 | TSOT_23_8 | MP1495DJ | TSOT_23_8 | U207 | TSOT_23_8 | MP1495DJ | TSOT_23_8 | U208 | TDFN8 | CW2013CASD | TDFN8 | U209 | SOT-23-6 | SY8113BADC | SOT23-6 | U320 | QFN48-6X6 | ALC5672 | QFN48-6X6 | U321 | SOT-23-5 | RT9080-18GJ5 | SOT-23-5 | U322 | SOP_16PIN | NS4263 | SOP_16PIN | U401 | TSSOP_20P | STM32F030F4P6 | TSSOP_20P | U404 | SSOP20 | WK2124 | SSOP20 | U405 | SSOP_16PIN | SP3232EEA | SSOP_16PIN | U406 | SOP8 | MAX3485ESA | SOP8 | U407 | TSSOP_20P | M536AS | TSSOP_20P | U501 | SOT-23-6 | SY7201ABC | SOT23-6 | U502 | SOT-23-6 | SY7208ABC | SOT23-6 | U560 | QX10_NFC | QX10_NFC | QX10_NFC | U601 | QFN48-6X6 | RTL8211E-VB-CG | QFN48-6X6 | U602 | SOIC_24 | CS2407 | SOIC_24 | U701 | QFN24_4X4 | AS569_QW9Z/NC | QFN24_4X4 | U702 | QFN32-5X5 | ST25R3912/NC | QFN32-5X5 | U703 | LQFP32_9X9 | STM32F030K6T6/NC | LQFP32_9X9 | U770 | LGA_16P | LIS3DH/NC | LGA_16P | U801 | AP6493 | AP6255 | AP6493 | Y101 | CRY-D3225 | 7V24000023 | CRY-D3225 | Y150 | CRY-D3225 | 7V12000015 | CRY-D3225 | Y201 | CRY-MC146 | 32.768K | CRY-MC146 | Y401 | CRY-D3225 | 8MHZ/10PPM | CRY-D3225 | Y402 | CRY-D3225 | 11.0592MHZ-10PPM | CRY-D3225 | Y403 | CRY-D3225 | 7V12000015 | CRY-D3225 | Y601 | CRY-D3225 | 7V25000012 | CRY-D3225 | Y701 | CRY-D3225 | 27.12MHZ/10PPM | CRY-D3225 | Y702 | CRY-D3225 | 8MHZ/10PPM | CRY-D3225 | Y801 | CRY-D3225 | 37.4MHZ/10PPM | CRY-D3225 |
