查看: 4209|回复: 18
[Pads_VX.2x] 新唐NUC977+IP101GR+TS8121C+NCU8822L 做的开发板PCB和原理图
    终身成就奖社区居民忠实会员宣传大使奖优秀斑竹奖
    发表于 2019-9-25 16:16:59 | 显示全部楼层 |阅读模式
    重要提示:PCB作品文件展下载说明
    NamePart TypePCB DecalValue
    BT1BATTERY_ELEMBAT\CR2032-4-2CR2032
    CON1POWER_JACKPOWRJACK\3PDC-PLUG
    CON2HEADER_2X20_0HEADER10X2\BOXJTAG ICE
    CON20CON40A_0M_DIN_32X2/2.54ALCD
    CON21CON24AHEADER_2X12_2.54MMCMOS Sensor
    CON22AXA2R63061_1AXA2R63021SD Card
    CON23CON2HEADER_2X1_2.54MMNANDMLC
    CON24RJ45_SHLD_0RJ45\8P\JA\LEDRJ-45 8P8C_LED R/A
    CON25CON2HEADER_2X1_2.54MMSpko
    CON26CON2HEADER_2X1_2.54MMAUXo
    CON27CON2HEADER_2X1_2.54MMAUXi
    CON29PHONEJACK_STEREO_SW_PJK-634_4PHONE-PJK-631EARPhone
    CON30CON4AHEADER_2X2_2.54MMCAN0
    CON31AXA2R63061_0AXA2R63021eMMC Card
    CON32HEADER_6_0_2SIM-CARDSIM CARD SLOT
    CON33CONNECTOR_DB9_0DB9_FMALEUART0
    CON34CONNECTOR_DB9_0DB9_FMALEUART8
    CON36CONNECTOR_DB9_0DB9_FMALEUART6
    CON37CONNECTOR_DB9_0DB9_FMALEUART10
    CON38USB_TYPE_B_0MINI_5P_B_TYPEUSB miniAB RECEP.
    CON39USB_TYPE_A_CONNECTORUSB4PUSB TYPE-A RECAP.
    CON40USB_TYPE_A_CONNECTORUSB4PUSB TYPE-A RECAP.
    CON41HEADER_5HEADER_5X1_2.54MMKPI
    D1ZENAR_0SOD-523RB521S-30
    D2ZENAR_0SOD-523RB521S-30
    D3ZENAR_0SOD-523RB521S-30
    J1CON2HEADER_2X1_2.54MM5Vin
    J2CON2HEADER_2X1_2.54MMVin
    J3CON2HEADER_2X1_2.54MMICERst
    J4CON3HEADER_3X1_2.54MMDevice / HOST
    K1SW-SSTS-B5Exit
    L3INDUCTOR_IRONSMTDR434.7uH
    L6INDUCTORL06031608-221T
    LED1LEDLED_0603P_Fault
    M1MICROPHONE_09.7D2.54MMMIC
    M2MICROPHONE_09.7D2.54MMMIC
    PAD11PAD1PAD_1.25X1.25MMN_Pre
    PAD21PAD1PAD_1.25X1.25MMSDWP
    PAD31PAD1PAD_1.25X1.25MMeMWP
    PAD41PAD1PAD_1.25X1.25MMRLIN
    Q1NPN_1SOT23-BEC2N3904
    Q2NPN_1SOT23-BEC2N3904
    Q3SI2303CDS_1SOT23-GSDSI2303CDS
    Q4SI2303CDS_1SOT23-GSDSI2303CDS
    Q5SI2303CDS_1SOT23-GSDSI2303CDS
    Q6NPN_1SOT23-BEC2N3904
    Q7NPN_1SOT23-BEC2N3904
    SW1SW2PHS2P-1.2MMVD33
    SW2CON3HEADER_3X1_2.54MMVRTC
    SW3SW2PHS2P-1.2MMVD12
    SW4SW2PHS2P-1.2MMVD18
    SW5SW-SSTS-B5RTC Key
    SW6SW_DIP-10DIPSWX10_2.54MMCfg[0:9]
    SW8SW_DIP-5DIPSWX5_2.54MMICE
    SW9SW-SSTS-B5Reset
    SW10SW_DIP-6_0DIPSWX6_2.54MMPWM
    SW11SW_DIP-5_0DIPSWX5_2.54MMKPI
    SW12SW_DIP-6DIPSWX6_2.54MMSPI
    SW13SW_DIP-5DIPSWX5_2.54MMNANDD[0:4]
    SW14SW_DIP-8DIPSWX8_2.54MMSD
    SW15SW_DIP-5DIPSWX5_2.54MMNANDD[5:7]/Ctrl
    SW16SW_DIP-5DIPSWX5_2.54MMNANDCtrl
    SW17SW-3PAD23P-1.2MMPSL
    SW18SW_DIP-5_0DIPSWX5_2.54MMEthernet
    SW19SW_DIP-5_0DIPSWX5_2.54MMEthernet
    SW20SW_DIP-8DIPSWX8_2.54MMIIS
    SW21SW_DIP-2_0DIPSWX2_2.54MMCAN Bus0
    SW22SW_DIP-3DIPSWX3_2.54MMCAN 0 Cfg
    SW23SW_DIP-6_1DIPSWX6_2.54MMeMMC
    SW24SW_DIP-5DIPSWX5_2.54MMSIM Card
    SW25SW_DIP-2_0DIPSWX2_2.54MMUART0
    SW26SW_DIP-4_0SDS-8UART8
    SW27SW_DIP-4_0SDS-8UART6
    SW28SW_DIP-4_0SDS-8UART10
    SW29SW_DIP-4_4DIPSWX4_2.54MMUSB P_Ctrl
    SW30SW_DIP-4DIPSWX4_2.54MMUSB P_Ind
    U1APL3203A_1_2TDFN2X2-8APL3203A
    U2ZT7103S_0TSOT-25ZT7103T
    U3ZT7103S_0TSOT-25ZT7103T
    U4ZT7103S_0TSOT-25ZT7103T
    U5NUC977_13LQFP-128NUC977
    U6W55X10_2SOIC8_208W55X16
    U7W25Q128BV_4SOIC16_300W25Q128BV
    U8NAND_4-8G_0TSOP48-0.5MMNAND Flash
    U9IP101GA_0QFN32IP101GR
    U10PE-68515_1ST6200TTS8121C
    U11NAU8501QFN32L_5X5MM\0.5MM_PITCHNCU8822L
    U12SN65HVD230SO-8-1.27X5.4MSN65HVD230
    U13ADM232_1SOP16/150TRS3232EC
    U14ADM232_1SOP16/150TRS3232EC
    U15ADM232_1SOP16/150TRS3232EC
    U16ADM232_1SOP16/150TRS3232EC
    U17NCT3520W-H10MSOP-8NCT3520W-H10
    U18NCT3520W-H10MSOP-8NCT3520W-H10
    UX1XC6206P182MRSOT-23XC6206P332MR
    X1MA306/SM_2XTAL_2P/1.5MMTXC-9H T9 SMD 32.768KHz 30ppm
    X2CRYSTAL_SMD_2TXC7M-3.2X2.5MM12MHz
    X3CRYSTAL_SMD_2SOT-14325MHz
    重要提示:PCB作品文件展下载说明
     楼主| 发表于 2019-9-25 16:19:14 | 显示全部楼层
    PCB 和原理图共享
    NUC977_MAIN_BD.7z (891 KB, 下载次数: 32)
    CMOS sensor BD.7z (163 KB, 下载次数: 2) LCD BD.7z (346 KB, 下载次数: 0) RMII BD.7z (345 KB, 下载次数: 5)
    5 天前
  • 签到天数: 62 天
    PADS-171101高级班
    终身成就奖特殊贡献奖优秀斑竹奖
    发表于 2019-9-25 16:21:20 | 显示全部楼层
    发表于 2019-9-26 08:20:14 | 显示全部楼层
    6 天前
  • 签到天数: 52 天
    终身成就奖社区居民特殊贡献奖原创先锋奖
    发表于 2019-9-26 08:29:11 | 显示全部楼层
    发表于 2019-9-26 08:47:24 | 显示全部楼层
    发表于 2019-9-26 08:53:43 | 显示全部楼层
    郁闷
    2024-11-7 10:22
  • 签到天数: 9 天
    发表于 2019-9-27 08:25:11 | 显示全部楼层
    终身成就奖社区居民宣传大使奖优秀斑竹奖
    发表于 2019-9-27 08:53:46 | 显示全部楼层
    昨天 18:40
  • 签到天数: 91 天
    终身成就奖社区居民
    发表于 2019-9-27 11:28:44 | 显示全部楼层
    看起来不错,清新脱俗
