查看: 4716|回复: 17
[Allegro16.6以下] VXS DSP Rear Transition Module
发表于 2019-10-30 19:39:25 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
3322.png PCB.rar (988 KB, 下载次数: 14) 原理图.pdf (828 KB, 下载次数: 19)
C1,C18,C33,C3561210YD226KA16V 10% SMD Low-ESR Ceramic Capacitor22uFAVX1210YD226KA1210
C43,C45
C2,C19,C32,C346EEEFK1C681AP16V 20% Aluminum Electrolytic Capacitor series FK680uFPANASONICEEEFK1C681APG
C42,C44
C3,C8,C12,C208A700X157M006ATE0106.3V 20% Aluminum Organic Capacitor A700 Series150uFKEMETA700X157M006ATE010X
C36,C38,C46,C48
C4,C21,C37,C396CC1210KKX5R5BB1076.3V 20% SMD X5R Ceramic Capacitor100uFYAGEOCC1210KKX5R5BB1071210
C47,C49
C5,C92CC1206_1NF_100V_10%_X7R100V 10% SMD X7R Ceramic Capacitor1nFGENERICCC1206_1NF_100V_10%_X7R1206
C6,C7,C10,C114CC0805_4UF7_16V_10%_X5R16V 10% SMD X5R Ceramic Capacitor4.7uFGENERICCC0805_4UF7_16V_10%_X5R0805
C13->C16,C23,C2413CC0603_10NF_50V_10%_X7R50V 10% SMD X7R Ceramic Capacitor10nFGENERICCC0603_10NF_50V_10%_X7R0603
C26,C27,C30,C31
C40,C41,C50
C17,C51210.82.01.380.416V 20% SMD Tantalum Electrolytic Capacitor22uFSIEMENSB45196E3226M409D
C22,C25,C283CC0603_47NF_16V_10%_X7R16V 10% SMD X7R Ceramic Capacitor47nFGENERICCC0603_47NF_16V_10%_X7R0603
C291CTE3216-18_22UF_6.3V_10%SMD Tantalum Electrolytic Capacitor22uFGENERICCTE3216-18_22UF_6.3V_10%A
C521CC0603_100NF_16V_10%_X7R16V 10% SMD X7R Ceramic Capacitor100nFGENERICCC0603_100NF_16V_10%_X7R0603
C531T491X157K016ASMD Tantalum Electrolytic Capacitor150uFKEMETT491X157K016AX
D11PRTR5V0U4YIntegrated Quand Ultra-Low Capacitance ESD Protection DeviceNXP/PHILIPSPRTR5V0U4YSOT363
D21VS-15MQ040NPBF40V 3A Schottky RectifierVISHAYVS-15MQ040NPBFSMA
D3->D1917BAS70-04Schottky Diodes Dual SeriesPHILIPSBAS70-04SOT23
IC1,IC2,IC7,IC84SN74LVC1G97DCKTConfigurable Multiple-Function GateTEXAS INSTRUMENTSSN74LVC1G97DCKTSC70
IC3,IC10,IC133PCA9552BS16-bit I2C-Bus LED Driver with Programmable Blink RatesNXP/PHILIPSPCA9552BSHVQFN24
IC41CD74ACT541MOctal Non-Inverting Buffer/Line Driver with 3-State OutputsTEXAS INSTRUMENTSCD74ACT541MSOIC20
IC51DS18B20Z+Programmable Resolution 1-Wire Digital ThermometerMAXIMDS18B20Z+SOIC8
IC61DS2482S-100+Single-Channel 1-Wire MasterMAXIMDS2482S-100+SOIC
IC91ISPPAC-POWR1014A-01TN48IIn-System Programmable Power Supply Supervisor, Reset Generator and Sequencing Controller (ADC Present)LATTICEISPPAC-POWR1014A-01TN48ITQFP48
IC111SN74LVC540APWOctal Buffers/Drivers with 3-State OutputsTEXAS_INSTRUMENTSSN74LVC540APWSOIC
IC12,IC142SN74LVC541APWRG4Octal Buffer/Line Driver with 5V Tolerant 3-State Inputs/OutputsNXP/PHILIPSSN74LVC541APWRG4TSSOP20
J1102 04 160 1101160 Contacts (zabcd32) DIN41621 Har-Bus64(R) VME 64x Right-Angle Female ConnectorHARTING02 04 160 1101
J21N2510-6002RB0.1 x 0.1 Low Profile Straight Header 2500 Series3MN2510-6002RB
L1,L42B82442-A1223-KSMD Inductor SIMID Series22uHEPCOSB82442-A1223-KSELF2220
L2,L327427512SMD EMI Suppression 5-Hole Ferrite Bead - WE-SUKW SeriesWURTH7427512WE-SUKW
L51UP3B-1R0-RPower Inductor1uHCOOPER-BUSSMANNUP3B-1R0-R_
L614701-001SMD EMI/RFI Filter 4700pi SeriesTUSONIX4701-001EMI_PI4701
LD1->LD1313570-0100-132F2mm Tri-Level Housing Red/Yellow/Green Tinted Diffused Right Angle LEDDIALIGHT570-0100-132FLED_DIALIGHT_570-0100-XXXF
LM1->LM131309.46.11.188.850ohm Size00 Right Angle LEMO Duplex for PCB with Offset from PCBLEMOEPY.00.250.NTNY
PWR1,PWR22PTH04T230WAZ6-A,2.2-V to 5.5-V Input, Non-Isolated, Wide-Output, Adjustable Power Module with Turbo-TransTEXAS INSTRUMENTSPTH04T230WAZBCM
PWR3-&gtWR53PTH04T260WAZ3-A,2.2-V to 5.5-V Input, Non-Isolated, Wide-Output, Adjustable Power Module with Turbo-TransTEXAS INSTRUMENTSPTH04T260WAZBCM
PWR61PTH04T240WAZ10-A,2.2-V to 5.5-V Input, Non-Isolated, Wide-Output, Adjustable Power Module with Turbo-TransTEXAS INSTRUMENTSPTH04T240WAZBCM
R1,R23211.24.03.424.50.1W 1% SMD Resistor24kGENERICR0603_24K_1%_0.1W_100PPM0603
R2,R25211.24.03.251.80.1W 1% SMD Resistor510GENERICR0603_510R_1%_0.1W_100PPM0603
R4,R15,R17,R183611.24.03.333.70.1W 1% SMD Resistor3.3kGENERICR0603_3K3_1%_0.1W_100PPM0603
R21,R22,R26,R36
R42->R49,R52
R55->R62,R69->R78
R109
R5,R6,R27,R28411.24.03.312.20.1W 1% SMD Resistor1.2kGENERICR0603_1K2_1%_0.1W_100PPM0603
R7,R29211.24.03.324.80.1W 1% SMD Resistor2.4kGENERICR0603_2K4_1%_0.1W_100PPM0603
R8,R30211.24.03.322.00.1W 1% SMD Resistor2.2kGENERICR0603_2K2_1%_0.1W_100PPM0603
R9->R12,R31->R34811.24.03.233.00.1W 1% SMD Resistor330GENERICR0603_330R_1%_0.1W_100PPM0603
R13,R35211.24.03.351.50.1W 1% SMD Resistor5.1kGENERICR0603_5K1_1%_0.1W_100PPM0603
R14,R19211.24.03.315.90.1W 1% SMD Resistor1.5kGENERICR0603_1K5_1%_0.1W_100PPM0603
R16,R39,R40,R638R2512_0R005_1%_1W_75PPM1% SMD Low Ohmic Current Sense Resistors0R005GENERICR2512_0R005_1%_1W_75PPMRESC6432X60N
R66,R79,R82,R85
R20,R37,R38,R1141911.24.03.347.10.1W 1% SMD Resistor4.7kGENERICR0603_4K7_1%_0.1W_100PPM0603
R117,R120,R123,R126
R129,R132,R135,R138
R141,R144,R147,R150
R153,R156,R159
R41,R50,R51311.24.03.500.30.1W 1% SMD Resistor100kGENERICR0603_100K_1%_0.1W_100PPM0603
R53111.24.05.291.00.25W 1% SMD Resistor910GENERICR1206_910R_1%_0.25W_100PPM1206
R54111.24.05.327.50.25W 1% SMD Resistor2.7kGENERICR1206_2K7_1%_0.25W_100PPM1206
R651R0603_10K_1%_0.1W_100PPM0.1W 1% SMD Resistor10kGENERICR0603_10K_1%_0.1W_100PPM0603
R68111.24.03.412.90.1W 1% SMD Resistor12kGENERICR0603_12K_1%_0.1W_100PPM0603
R81,R84211.24.03.420.90.1W 1% SMD Resistor20kGENERICR0603_20K_1%_0.1W_100PPM0603
R86->R91,R94->R963911.24.03.227.80.1W 1% SMD Resistor270GENERICR0603_270R_1%_0.1W_100PPM0603
R99->R101,R104->R106
R160->R183
R92,R93,R97,R98811.24.03.110.10.1W 1% SMD Resistor10GENERICR0603_10R_1%_0.1W_100PPM0603
R102,R103,R107,R108
R110111.24.03.000.50603 Size SMD Jumper00GENERICR0603_00_JUMPER0603
R112,R113,R115,R1163211.24.05.200.90.25W 1% SMD Resistor100GENERICR1206_100R_1%_0.25W_100PPM1206
R118,R119,R121,R122
R124,R125,R127,R128
R130,R131,R133,R134
R136,R137,R139,R140
R142,R143,R145,R146
R148,R149,R151,R152
R154,R155,R157,R158
R184,R1852CMB02070X1004G1W 2% 500V Carbon Film High Pulse Load MELF Resistor1MTOKENCMB02070X1004G0207
REG1,REG22TPS74401KTW3.0A Ultra-LDO with Programmable Soft-StartTEXAS INSTRUMENTSTPS74401KTWDDPAK
ST1,ST22MTLW-102-07-L-S-2502 Contacts 2.54mm Pitch Single Row Vertical 0.25 Square Post Header - Insulator 1.52mm
(Receptacle for Short Circuit Shunt)
SAMTECMTLW-102-07-L-S-250
T1->T33332N7002N-Channel Enhancement Mode Field Effect TransistorFAIRCHILD SEMICONDUCTOR2N7002SOT23
重要提示:PCB作品文件展下载说明
    终身成就奖社区居民优秀斑竹奖
    发表于 2019-10-30 20:12:13 | 显示全部楼层
    谢谢分享VXS DSP Rear Transition Module PCB
    半小时前
  • 签到天数: 312 天
    发表于 2019-10-30 20:24:54 | 显示全部楼层
    4 小时前
  • 签到天数: 268 天
    终身成就奖社区居民忠实会员
    发表于 2019-10-30 21:39:12 | 显示全部楼层
    发表于 2019-10-31 06:51:14 | 显示全部楼层
    终身成就奖特殊贡献奖原创先锋奖金点子奖优秀斑竹奖
    发表于 2019-10-31 07:56:43 | 显示全部楼层
    发表于 2019-10-31 08:02:31 | 显示全部楼层
    PADS-190819初级班
    发表于 2019-10-31 08:09:51 | 显示全部楼层
    昨天 19:20
  • 签到天数: 309 天
    发表于 2019-10-31 08:41:25 | 显示全部楼层
    发表于 2019-10-31 08:51:58 | 显示全部楼层
