查看: 6237|回复: 26
[AD格式] VME FMC carrier
发表于 2019-10-30 19:47:46 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
VME FMC carrier
PCB图
PCB图
pcb.rar (7.1 MB, 下载次数: 22) Schematics.rar (1.85 MB, 下载次数: 23)
DescriptionFootprintQuantityCaseDeviceManufacturer Part Number
Non-polarised capacitorCAPC1608X87N2603CC0603_4.7uF_6.3V_10%_X5R, CC0603_100NF_50V_10%_X7R
Polarised capacitorCAPAE830X620N4ECAE830-620_330UF_6.3V_20%
Polarised capacitorCAPAE1030X1020N8GCAE1030-1020_470UF_25V_20%
Non-polarised capacitorCAPC2012X135N40805CC0805_1NF_50V_10%_X7R, CC0805_22NF_50V_10%_X7R, CC0805_22UF_6.3V_20%_X5R, CC0805_100PF_50V_5%_NP0, CC0805_220NF_50V_10%_X7R, CC0805_220PF_50V_5%_NP0
Non-polarised capacitorCAPC3216X140N131206CC1206_10uF_16V_10%_X7R, CC1206_22UF_6.3V_20%_X5R
Non-polarised capacitorCAPC3225X270N81210CC1210_10UF_50V_10%_X7R
Polarised capacitorCAPMP7343X310N37DCTE7343-31_470UF_6.3V_10%
Non-polarised capacitorCAPC1005X55N393402CC0402_33NF_16V_10%_X7R, CC0402_100NF_16V_10%_X7R
SFP  Cage Bottom (Small Form-factor Pluggable)TYCO_6367034-12TYCO_6367034-1
SFP  Cage Top (Small Form-factor Pluggable)TYCO_6367035-12TYCO_6367035-1
FuseFUSRC3216X100N2nanoSMDC016F
FuseFUSRC4632X90N13miniSMDC014F
16 Meg x 16 x 8 Banks DDR3 SDRAMBGA96C80P9X16_900X1400X1201BGA96MT41J128M16HA-15EMT41J128M16HA-15E
SPARTAN-6, FPGA, 676-Ball BGA, Commercial Grade, Pb-FreeBGA676C100P26X26_2700X2700X26030BGA676XC6SLX150T-2FGG676CXC6SLX150T-2FGG676C
14-Output Clock Generator with Integrated 1.6 GHz VCOQFN50P900X900X100-65N-S6354QFN64AD9516-4BCPZAD9516-4BCPZ
Single Output LDO, 3.0A, Adj.(0.8 to 3.3V), Fast Transient Response, Programmable SoftStartQFN65P500X500X100-21N-S3255QFN20TPS74401RGWTTPS74401RGWT
1 GSPS, 14-Bit, 3.3 V CMOS Direct Digital SynthesizerQFP50P1600X1600X120-101N-S5001QFP100AD9910BSVZAD9910BSVZ
2.7 V to 5.25 V, Micro Power, 8-Channel, 125 kSPS, 12-Bit ADCSOIC127P600X175-16N1SOIC16AD7888ARAD7888AR
128 Mbit (Multilevel), low-voltage, Serial Flash memory with 50-MHz SPI bus interfaceSOIC127P1030X265-16N2M25P128-VMF6GM25P128-VMF6G
Sink/Source DDR Termination RegulatorSON50P300X300X100-11N-R175X2501SON10TPS51200DRCTTPS51200DRCT
8-Bit Universal Bus Transceiver and Two 1-Bit Bus Transceivers with 3-State OutputsSOP50P810X120-48N15TSSOP48SN74VMEH22501DGGRSN74VMEH22501DGGR
10-Bit, Nonvolatile Linear-Taper Digital PotentiometerSOP65P640X110-14N2TSSOP 14MAX5483EUD+MAX5483EUD+
Quad, 16-Bit DAC with 5 ppm/∞C On-Chip ReferenceSOP65P640X120-14N1TSSOP14AD5666BRUZ-1AD5666BRUZ-1
6-A, 2.2-V to 5.5-V Input, Non-Isolated, Wide-Output, Adjustable Power Modue With TurboTransôTEXAS_BCM (R-PDSS-T10)4PTH04T230WAZPTH04T230WAZ
12 Watt 5V/3.3V Input Plus to Minus Voltage ConverterTEXAS_ELC (R-MSIP-G23)2PT6914C, PT6915CPT6914C, PT6915C
Programmable Resolution 1-Wire Digital ThermometerTO-92AA-P2541TO-92DS18B20+DS18B20+
72-Mbit (2M x 36) Pipelined SRAM with NoBL ArchitectureBGA165C100P11X15_1500X1700X1404BGA165CY7C1470BV25-167BZXCCY7C1470BV25-167BZXC
LEMO_EPA.00.250.NTN2EPA.00.250.NTN
Dual Female Coax 1-2 Common Shield 3LEMO_EPY.00.250.NTN4EPY.00.250.NTN
Connector 14 MaleMOLEX_87832-1420187832-1420
7 Pin + 1 Shield SATA ReceptacleMOLEX_47082-1000147082-1000
20 Position SFP  Connector (Small Form-factor Pluggable)TYCO_1367073-121367073-1
Connector 160zabcd Male (5x32), Connector HAR-BUS 95 Female (abcdef) + Shield (f), Connector VITA 57, 400 Female contacts in 10 row abcdefghj5
Inductor With Magnetic coreINDC2012X145N2805L0805C4R7MDWIT
Inductor With Magnetic coreINDC2014X145N4805B82498B1102J
LED x4 Red 1C2A-BOT_3C4A_5C6A_7C8A-TOPLED_BIVAR_H485CHDL8H485CHDLH485CHDL
LED Green 1C 2ALED_OSRAM_LGN971231206LGN971LGN971
Oscillator 4 pins 1=Voltage Control 2=GND 3=OUT 4=VCCOSC_RAKON_IVT3200C1IVT3205CR 25.0 MHz
Any-Rate I2C Programmable XO Oscillator Si570 SerieOSC_SILICON-LAB_SI5701570BBC000121DG
Push-Button Switch SPDTPB_TYCO_ALCOSWITCH_FSM2JSMA1FSM2JSMA or  2-1437565-7
Resistor - 1%RESC1005X40N111402R0402_0R_JUMPER, R0402_1K1_1%_0.0625W_100PPM, R0402_1K3_1%_0.0625W_100PPM, R0402_3K_1%_0.0625W_100PPM, R0402_5K6_1%_0.0625W_100PPM, R0402_10K_1%_0.0625W_100PPM, R0402_30R_1%_0.0625W_100PPM, R0402_51R_1%_0.0625W_100PPM, R0402_100K_1%_0.0625W_100PPM, R0402_100R_1%_0.0625W_100PPM, R0402_150R_1%_0.0625W_100PPM, R0402_240R_1%_0.0625W_100PPM
Resistor - 0.1%, Resistor - 1%RESC1608X55N43603R0603_0R_JUMPER, R0603_1K15_0.1%_0.063W_10PPM, R0603_2K49_0.1%_0.063W_10PPM, R0603_2K87_0.1%_0.063W_10PPM, R0603_3K57_0.1%_0.063W_10PPM, R0603_4K99_0.1%_0.063W_10PPM, R0603_6K98_0.1%_0.063W_10PPM, R0603_10K_0.1%_0.063W_10PPM, R0603_49R9_0.1%_0.063W_10PPM, R0603_931R_0.1%_0.063W_10PPM
Resistor - 0.1%, Resistor - 1%RESC2012X60N122805R0805_0R_JUMPER, R0805_1K6_1%_0.125W_100PPM, R0805_2K4_1%_0.125W_100PPM, R0805_4K7_1%_0.125W_100PPM, R0805_4K12_0.1%_0.1W_10PPM, R0805_5K1_1%_0.125W_100PPM, R0805_51R_1%_0.125W_100PPM, R0805_100R_1%_0.125W_100PPM, R0805_200R_1%_0.125W_100PPM
8 Ways SPST DIP SwitchSW_OMRON_A6S-8102-H1A6S-8102-H
N-CHANNEL MOSFET WITH DIODESOT95P240X130-3N8SOT23-32N70022N7002
重要提示:PCB作品文件展下载说明
    终身成就奖社区居民优秀斑竹奖
    发表于 2019-10-30 20:11:52 | 显示全部楼层
    谢谢分享VME FMC carrier PCB
    发表于 2019-10-30 21:32:26 | 显示全部楼层
    4 小时前
  • 签到天数: 268 天
    终身成就奖社区居民忠实会员
    发表于 2019-10-30 21:37:19 | 显示全部楼层
    终身成就奖特殊贡献奖原创先锋奖金点子奖优秀斑竹奖
    发表于 2019-10-31 07:56:01 | 显示全部楼层
    发表于 2019-10-31 08:02:18 | 显示全部楼层
  • 签到天数: 5 天
    PADS20210616高级班
    发表于 2019-10-31 08:05:07 | 显示全部楼层
    早上好呀,过来学习一下,设计得不错哟
    社区居民忠实会员终身成就奖
    发表于 2019-10-31 08:35:05 | 显示全部楼层
    发表于 2019-10-31 08:35:15 | 显示全部楼层
    昨天 19:20
  • 签到天数: 309 天
    发表于 2019-10-31 08:41:33 | 显示全部楼层
