Name | Part Type | PCB Decal | Value | BT2 | BATTERY | BAT_ML621_SMD | ML621 | CB1 | CAP-B_1 | C0805 | 47u | CB3 | CAP-B_1 | C0603 | 0.1u | CON1 | CON24 | CON24_CMOS | CON24 | CON2 | RJ-45WITHT | RJ-45-LED | RJ-45WITHT | D1 | DIODE | SOD123 | B5819W | D2 | DIODE_TVS_DUR_0 | ESD0402 | ESD5451N | D3 | DIODE_TVS_DUR_0 | ESD0402 | ESD5451N | D4 | DIODE_TVS_DUR_0 | ESD0402 | ESD5451N | D5 | DIODE_TVS_DUR_0 | SMA | SMAJ5.0CA | D6 | DIODE_ZENER1 | SOD123 | MM1Z3V9 | D7 | LED0603_2 | LED0603 | RED | D8 | DIODE | SOD323 | B5819WS | D9 | DIODE | SOD323 | B5819WS | D10 | DIODE_ZENER1 | SOD123 | B5819W | D11 | LED0603 | LED0603 | OVP | D12 | DIODE | SOD123 | DSK34 | D13 | DIODE_TVS_DUR_0 | ESD0402 | ESD5451N | D14 | DIODE_TVS_DUR_0 | ESD0402 | ESD5451N | D15 | BAV99 | SOT23 | BAV99 | D16 | DIODE_ZENER1 | SOD123 | MM1Z7V5 | D17 | BAV99 | SOT23 | BAV99 | D18 | DIODE_ZENER1 | SOD123 | MM1Z16 | D19 | DIODE_2 | SOD123 | B5819W | D20 | DIODE_TVS_DUR_0 | ESD0402 | ESD5451N | D21 | DIODE_TVS_DUR_0 | ESD0402 | ESD5451N | D22 | LED0603 | LED0603 | DCOM | D32 | DIODE | SMB | S2M | D33 | DIODE_TVS_DUR_0 | SMB | SMBJ30CA | J1 | CON4 | CON_DCDC5P5_2P1_SMD | CON4 | J2 | SPEAKER | SPEAKER_23MM_DIP | SPEAKER | J3 | MINIPCI-E | MINIPCI-E | minipci-e | J4 | CORE_NUC972 | CORE_A33_D30X2_1P27_46X40 | CORE_A33 | J5 | TFCARD_DEC | TFCARD_DEC | TFCARD_DEC | J6 | ANT_SMA_TRANS | ANT_SMA_TRANS | ANT_SMA_TRANS | J7 | USB_MINI | USB_MINI_B | USB_MINI | J8 | SPEAKER | J2-2.54-90-SMD | SPEAKER | J9 | MIC | MIC_6MM | MIC | J10 | ANT_IPX | ANT_IPX | ANT_IPX | J14 | CON3 | J3-2.54-90-SMD | CON3 | J15 | CON50_LCD | LCD-FPC-50-REV-EP | AT070TN92 | J16 | CON8_JTAG | LCD_KUANG_070_8P | LCD_QUANG | J17 | ANT_SMA | ANT_SMA | ANT_SMA | J18 | CON6 | FPC-6-EP | CON6 | J19 | CON3 | J3-2.54-SMD | CON3 | J20 | ANT_SMA_TRANS | ANT_SMA_TRANS | ANT_SMA_TRANS | J21 | CON7X2 | CON7X2_1.27MM | CON7x2 | L1 | INDUCTOR | L5X5 | FNR5040S100MT | L2 | INDUCTOR | L4X4 | 10uH | L3 | INDUCTOR_3 | L4X4 | 10uH | L4 | IND | L5X5 | SWPA5040S2R2NT | L5 | INDUCTOR_2 | L7.3X6.6 | SWPA6045S100MT | Q1 | DTC143EUA | SOT523 | DTC143ZE | Q2 | DTC143EUA | SOT523 | DTC143ZE | Q3 | DTC143EUA | SOT523 | DTC143ZE | SW1 | SW_6X6_SMD | SW_4P5_90_DIP | SW_4.5X4.5_DIP | U1 | 74VHC86 | TSSOP14 | 74VHC86 | U2 | MT3608 | SOT23-6 | MT3608 | U3 | SY7200AABC | SOT23-6 | MT9284BS6 | U4 | SY7200AABC | SOT23-6 | MT9284BS6 | U5 | LM4890 | MSOP8 | NS4150 | U6 | GL850G | SSOP28 | GL850G | U7 | SY8009A/B_1 | SOT23-6 | FP6373A | U8 | FR9833 | SO8_EP | FR9833 | U9 | PCF8563TS | TSSOP8 | HYM8563T | U10 | RTL8152B | QFN24_0P5_4X4_EP | RTL8152B | U11 | WIFI_RTL8723BS | WIFI_RTL8723BS | WIFI_RTL8723BS | U12 | MT9700 | SOT23-5 | MT9700 | USBH1 | USB_A | USB_BS | USB type_A connector | USBH2 | USB_A | USB_BS | USB type_A connector | X3 | XTAL_SMD1 | XTAL_SMD_3225 | 25MHz 10ppm | Y1 | CRYSTAL1 | XTAL_SMALL_2X6_SMD | 32.768KHz 12.5pF | Y2 | CRYSTAL_1 | XTAL_SMD_3225 | 12MHz |
