查看: 1567|回复: 5
[ALLEGRO格式] 一个ALLEGRO 板子封装库共享 有需要的下载
    终身成就奖社区居民忠实会员宣传大使奖优秀斑竹奖
    发表于 2019-11-21 09:33:40 | 显示全部楼层 |阅读模式
    ALLEGRO16.6格式
    IED_wire_elf_V1_0.7z (508 KB, 下载次数: 21)
    BT1BATTERY_1_BS1220_BATTERYBATTERYBS1220
    D1DIODESCHOTTKY_3_DO-214AA_SMBJ6SMBJ6.5CADO-214AA
    D8ZC2800E/SOT_1_DO-214AA_SS35SS35DO-214AA
    D9BAT54C/SOT_SOT23_BAT54CBAT54CSOT23
    D10BAT54A/SOT_1_SOT23_BAT54CBAT54CSOT23
    D11DIODE_SOD-323_ESD05V32D-LCESD05V32D-LCSOD-323
    D19LED_LED0805_LEDLEDLED0805
    D20DIOD,CLMP,PGB001,0603,ESDSUPRS_ESD05V32D-LCSOD-323
    D21DIOD,CLMP,PGB001,0603,ESDSUPRS_ESD05V32D-LCSOD-323
    D22LED_LED0805_LEDLEDLED0805
    D23DIOD,CLMP,PGB001,0603,ESDSUPRS_ESD05V32D-LCSOD-323
    D24DIOD,CLMP,PGB001,0603,ESDSUPRS_ESD05V32D-LCSOD-323
    D25ZC2800E/SOT_1_SOD_123_B0520B0520SOD_123
    D26ZC2800E/SOT_1_SOD_123_B0520B0520SOD_123
    D27DIOD,CLMP,PGB001,0603,ESDSUPRS_ESD05V32D-LCSOD-323
    D29DIOD,CLMP,PGB001,0603,ESDSUPRS_ESD05V32D-LCSOD-323
    D30DIOD,CLMP,PGB001,0603,ESDSUPRS_ESD05V32D-LCSOD-323
    D31DIOD,CLMP,PGB001,0603,ESDSUPRS_ESD05V32D-LCSOD-323
    D32DIODE_SOD-323_ESD05V32D-LCESD05V32D-LCSOD-323
    D33DIOD,CLMP,PGB001,0603,ESDSUPRS_ESD05V32D-LCSOD-323
    F1FUSE_1812R_SMD1812P020TFSMD1812P020TF1812R
    F2FUSE_1812R_SMD1812P020TFSMD1812P020TF1812R
    F3FUSE_PPTC_S_5A/16V5A/16VPPTC_S
    F4FUSE_1812R_SMD1812P050TFSMD1812P050TF1812R
    FB3INDUCTOR_0805R_FBFB0805R
    FB4FB,120OHM,2A,25%,0603,0.05DCR_120 OHM/2A@100MHz0805L
    G1DIODESCHOTTKY_2_3R_6_3RM090M-63RM090M-63R_6
    G2DIODESCHOTTKY_3_GDT-1812_UN181UN1812-90CSMDGDT-1812
    G3DIODESCHOTTKY_3_GDT-1812_UN181UN1812-90CSMDGDT-1812
    J2CON12-LN_1_381-S-4-EAR_CON4-LN3CON4-LN381381-S-4-EAR
    J3CONN PCB8_4_SIP4_127_PIN4-127PIN4-127SIP4_127
    J4CONN PCB8_6_SIP4_127_PIN4-127PIN4-127SIP4_127
    J5CONN PCB8_23_JC4_200_PIN4-200PIN4-200JC4_200
    J6CONN PCB8_21_JC4_200_PIN4-200PIN4-200JC4_200
    J7CONN PCB8_20_JC4_200_PIN4-200PIN4-200JC4_200
    J8MICROUSB_0_MICRO_USB_180_MICROUMICROUSBMICRO_USB_180
    J9MICROUSB_0_MICRO_USB_180_MICROUMICROUSBMICRO_USB_180
    J10CON14A_8_RF-51-3612-50-H_51-36151-3612-50-HRF-51-3612-50-H
    J13CON14A_8_RF-51-3612-50-H_51-3_151-3612-50-H_NCRF-51-3612-50-H
    J14CON10A_6_NANOSIM_TF_NANOSIM+TFNANO SIM+TFNANOSIM_TF
    J15CON10A_6_NANOSIM_TF_BACK_NANOSNANO SIM+TFNANOSIM_TF_BACK
    J16CONN PCB8_7_SIP4_254_O_PIN4-25PIN4-254SIP4_254_O
    J17CONN PCB8_7_SIP4_254_O_PIN4-25PIN4-254SIP4_254_O
    J18IMX6UL-CM-FCI_6_IMX6UL_200N-FCIIMX6UL_200N-FCI_10142990C_AIMX6UL_200N-FCI-2P
    J19CON14A_8_RF-51-3612-50-H_51-36151-3612-50-HRF-51-3612-50-H
    J20CON5-LN_1_LORA-RA-02_LORA-RA-02LoRa-Ra-02LORA-RA-02
    J21CON5-LN_0_ET100_ET100ET100ET100
    J25CON14A_0_RF-51-3612-50-H_51-36151-3612-50-HRF-51-3612-50-H
    J26CON14A_0_RF-51-3612-50-H_51-36151-3612-50-HRF-51-3612-50-H
    J27CON10A_0_GF15_200_TFTFGF15_200
    J28CON10A_1_GF6_254_NANOSIMNANO SIMGF6_254
    J29CON14A_8_RF-51-3612-50-H_51-36151-3612-50-HRF-51-3612-50-H
    JC1CONN PCB8_8_JC2_254_JC2_254JC2_254JC2_254
    JC2CONN PCB8_8_JC2_200_JC2_200JC2_200JC2_200
    JC3CONN PCB8_4_JC3_254_JC3_254JC3_254JC3_254
    JC5CONN PCB8_8_PH2X1-254_JC2_254JC2_254PH2X1-254
    JC6CONN PCB8_8_PH2X1-254_JC2_254JC2_254PH2X1-254
    L1INDUCTOR_8MMX7R5MM-L_744777004_744777004_4.7uH8MMX7R5MM-L
    L2INDUCTOR_8MMX7R5MM-L_744777004_744777004_4.7uH8MMX7R5MM-L
    L3INDUCTOR_8MMX7R5MM-L_744777004_744777004_4.7uH8MMX7R5MM-L
    L4INDUCTOR_0603L_56NH_NC56nH_NC0603L
    L5DLW21HN900HQ2_SOP4-EMI-2_DISCREDLW21HN900HQ2SOP4-EMI-2
    L6INDUCTOR_0603R_2.7NH2.7nH0603R
    L7INDUCTOR_0603R_2.7NH2.7nH0603R
    L8DLW21HN900HQ2_SOP4-EMI-2_DISCREDLW21HN900HQ2SOP4-EMI-2
    L9DLW21HN900HQ2_SOP4-EMI-2_DISCREDLW21HN900HQ2SOP4-EMI-2
    LED1LED_LED0805_LEDLEDLED0805
    LED9LED_LED0805_LED_GREENLED_GREENLED0805
    Q1PNP BCE_1_SOT23_S8550S8550SOT23
    Q2MPF6660_0_SOT23_2N7002K2N7002KSOT23
    Q3MPF6660_0_SOT23_2N7002K2N7002KSOT23
    Q4MPF6660_0_SOT23_2N7002K2N7002KSOT23
    Q5IRF4905/TO_7_SOT23_BSS84BSS84SOT23
    Q6IRF4905/TO_7_SOT23_BSS84BSS84SOT23
    Q7IRF4905/TO_7_SOT23_BSS84BSS84SOT23
    Q8IRF7104/SO_6_SO8_IRF7328IRF7328SO8
    Q9MPF6660_0_SOT23_2N7002K2N7002KSOT23
    Q10MPF6660_0_SOT23_2N7002K2N7002KSOT23
    Q11IRF7104/SO_6_SO8_IRF7328IRF7328SO8
    Q12MPF6660_0_SOT23_2N7002K2N7002KSOT23
    Q132N7002_0_SOT23_2N7002K2N7002KSOT23
    Q142N7002_0_SOT23_2N7002K2N7002KSOT23
    Q152N7002_0_SOT23_2N7002K2N7002KSOT23
    Q16IRF4905/TO_6_SOT23_IRLML6401IRLML6401SOT23
    Q17MPF6660_0_SOT23_2N7002K2N7002KSOT23
    Q18IRF7104/SO_6_SO8_IRF7328IRF7328SO8
    Q19MPF6660_0_SOT23_2N7002K2N7002KSOT23
    Q20MPF6660_0_SOT23_2N7002K2N7002KSOT23
    Q21MPF6660_0_SOT23_2N7002K2N7002KSOT23
    Q222N7002_0_SOT23_S8050S8050SOT23
    Q232N7002_0_SOT23_S8050S8050SOT23
    Q242N7002_0_SOT23_S8050S8050SOT23
    Q25IRF4905/TO_6_SOT23_IRLML6401IRLML6401SOT23
    Q26MPF6660_0_SOT23_2N7002K2N7002KSOT23
    Q27IRF4905/TO_6_SOT23_IRLML6401IRLML6401SOT23
    Q28IRF4905/TO_6_SOT23_IRLML6401IRLML6401SOT23
    Q29IRF4905/TO_6_SOT23_IRLML6401IRLML6401SOT23
    Q30MPF6660_0_SOT23_2N7002K2N7002KSOT23
    Q372N7002_0_SOT23_S8050S8050SOT23
    RA1RN_33RX4_0_0603RA_49R949R90603RA
    RA2RN_33RX4_0_0603RA_49R949R90603RA
    T1TESTPOINT_4_TESTPOINT_TESTPOINTtestpointTESTPOINT
    U2SP3485_SOIC8_MAX3485ESAMAX3485ESASOIC8
    U3TPS5430_0_SO8-TPS5430_TPS54340TPS54340SO8-TPS5430
    U4TPS5430_0_SO8-TPS5430_TPS54340BTPS54340BSO8-TPS5430
    U5TPS5430_0_SO8-TPS5430_TPS54340BTPS54340BSO8-TPS5430
    U6HEF4521B_0_SO16_HEF4521BHEF4521BSO16
    U774HC05PW_6_TSSOP-14_74HC05PW74HC05PWTSSOP-14
    U8CON3_3_SOT-23-5_ME6214C33M5GME6214C33M5GSOT-23-5
    U9MPU-6881A_0_QFN24_MPU6881_MPU-6MPU-6881AQFN24_MPU6881
    U10MPU-6881A_4_SCL3300-DO1_SCL3300SCL3300-D01SCL3300-DO1
    U11CN301_13_BMP180_BMP180BMP180BMP180
    U12SP-4_0_ET_SWITCH-S6_SP-6SP-6ET_SWITCH-S6
    U13MAX3387ECUG_25_SOT23_MAX809STR/MAX809STR/2.9VSOT23
    U14STM8L151C8TX_1_LQFP48_STM8L151CSTM8L151C8TxLQFP48
    U15MIC2526-2BM_0_SO8_MIC2526-1BMMIC2526-1BMSO8
    U16IC_AU6259-JBL_LQFP_1_LQFP48_AU6AU6268-JBLLQFP48
    U17MIC2526-2BM_2_SO8_MIC2526-1BMMIC2526-1BMSO8
    U18ET-SWITCH-8_ET_SWITCH-S8_SP-4SP-4ET_SWITCH-S8
    U19CH340G_0_SO8_CH340NCH340NSO8
    U20SP-4_6_ET_SWITCH-S4_SP-4SP-4ET_SWITCH-S4
    U21EC20_EC20_EC20EC20EC20
    U22SIM_13_TSSOP-14_TXS0104EPWRTXS0104EPWRTSSOP-14
    U23ESDA6V1SC6_SOT23-6_UDT26A05L05UDT26A05L05SOT23-6
    U25SIM_0_NANO_SIM_SIMSIMNANO_SIM
    U26ESDA6V1SC6_SOT23-6_UDT26A05L05UDT26A05L05SOT23-6
    U27RT9261_0_QFN-24_LAN8720ALAN8720AQFN-24
    U28SP-4_1_SO-8_SLVU2.8-4SLVU2.8-4SO-8
    U29PM44-11BP_PM44-11BP_PM44-11BPPM44-11BPPM44-11BP
    U30RT9261_0_QFN-24_LAN8720ALAN8720AQFN-24
    U31SP-4_1_SO-8_SLVU2.8-4SLVU2.8-4SO-8
    U32PM44-11BP_PM44-11BP_PM44-11BPPM44-11BPPM44-11BP
    U33DS3231-M_SOP8-50-150_DS3231MDS3231MSOP8-50-150
    U34MAX3387ECUG_25_SOT23_MAX809STR/MAX809STR/2.9VSOT23
    U35BL-R8723BT1_1_BL-R8723BT1_BL-R8BL-R8723BT1BL-R8723BT1
    U36SIM_7_MSOP10_FSUSB30FSUSB30MSOP10
    U37CON6_2_ET_SWITCH-S4_SP-4SP-4ET_SWITCH-S4
    U38SIM_12_TSSOP-14_TXS0104EPWRTXS0104EPWRTSSOP-14
    U40EC_20_PCIE_7_CX6600_CX6600CX6600CX6600
    U41TF_TF-DRAWER_TFTFTF-DRAWER
    U42SIM_0_NANO_SIM_SIMSIMNANO_SIM
    U43EC20_EC20_EC20EC20EC20
    W1CONN PCB8_0_TO-92_DS18B20DS18B20TO-92
    W2CONN PCB8_0_PH3_200_DS18B20DS18B20PH3_200
    W3CONN PCB8_0_PH3_200_DS18B20DS18B20PH3_200
    X1XTAL_XTAL4-3225_40MHZ/3.3V40MHz/3.3VXTAL4-3225
    Y1CRYSTAL_8_SMD5032_NEW_8MHZ8MHZSMD5032_NEW
    Y2CRYSTAL_8_SMD5032_NEW_12MHZ12MHZSMD5032_NEW
    昨天 09:45
  • 签到天数: 140 天
    社区居民终身成就奖特殊贡献奖优秀斑竹奖
    发表于 2019-11-21 10:00:53 | 显示全部楼层
    发表于 2019-11-22 08:48:24 | 显示全部楼层
    谢谢分享!!!
    发表于 2019-11-22 08:58:12 | 显示全部楼层
    谢谢分享
    发表于 2020-2-27 21:18:33 | 显示全部楼层
    感谢楼主分享
    发表于 2023-2-20 11:09:45 | 显示全部楼层
    等我升到二级回来下载
