这是一个我们早些时候做的一个Android微型投影项目,是采用amlogic M806方案,先分享给大家,有需要可以下载看看。
iseemini_dlp_ti_m806_refb_basic.pdf
(623 KB, 下载次数: 21)
ISEEMINI_DLP_TI_M806_REFB_BASIC_V03B.pcb
(2.92 MB, 下载次数: 25)
以下内容由管理员补充
Name | Part Type | PCB Decal | Value | 1D1 | SOD123H14A | SOD123H14A | B5819W | 1D2 | D0402 | D0402 | NC/AZ5325-01F | 1D3 | D0402 | D0402 | NC/AZ5325-01F | 1D5 | SOD123H14A | SOD123H14A | B5819W | 1D6 | SOD123H14A | SOD123H14A | B5819W | 1D7 | SOD123H14A | SOD123H14A | B5819W | 1D8 | SOD123H14A | SOD123H14A | B5819W | 1L1 | L5050 | L5050 | 4.7UH_2A | 1L2 | L5050 | L5050 | 2.2UH_2A_4018_DCR<45MR | 1L3 | L5050 | L5050 | 4.7UH_2.5A_5018_DCR<30MR | 1L4 | L4040 | L4040 | 4.7UH_1.7A | 1L5 | L5050 | L5050 | 4.7UH_2A | 1L6 | L4040 | L4040 | 2.2UH_2A | 1Q1 | SOT-23 | SOT-23 | WPM2026 | 1Q4 | SOT-23 | SOT-23 | WPM2026 | 1U6 | SOT23-6 | SOT23-6 | SY8009BABC/2A | 2Y1 | XT-MC_146 | XT-MC_146 | XTAL_32.768KHZ | 2Y2 | XT-SMD4P3225 | XT-SMD4P3225 | 24MHZ_12PF_20PPM | 3U4 | BGA96-0P8MM | BGA96-0P8MM | H5TQ4G63AFR-PBC | 3U5 | BGA96-0P8MM | BGA96-0P8MM | H5TQ4G63AFR-PBC | 6CON1 | MICROUSB | MICROUSBAA | | 6D1 | D0402 | D0402 | AZ5325-01F | 6D2 | D0402 | D0402 | NC/AZ5725-01F | 6D3 | D0402 | D0402 | AZ5325-01F | 6D4 | D0402 | D0402 | NC/AZ5725-01F | 6D5 | D0402 | D0402 | NC/AZ5725-01F | 6D6 | D0402 | D0402 | NC/AZ5725-01F | 6D7 | D0402 | D0402 | NC/AZ5725-01F | 6D8 | D0402 | D0402 | NC/AZ5725-01F | 6FB1 | L0805 | L0805 | 120R/100MHZ_3A | 6L1 | COMMON-COIL4P | COMMON-COIL4P | NC/EXD24CD900U | 6U2 | TF-CKT01-009D | TF-CKT01-009D | TF_SD_SOCKET | 7FB1 | FB0402 | FB0402 | 100MHZ220OHM | 7J1 | GPS-ANT | GPS-ANT | NC | 7L1 | L3030 | L3030 | | 7M1 | SOP44_AP6S | SOP44_AP6S | | AJ1 | PJ-3538-L6S | PJ-3538-L6S | | AR28 | SHORTER_0402 | SHORTER_0402B | | AR29 | SHORTER_0402 | SHORTER_0402A | NC | AU2 | BGA12-PT05 | BGA12-PT05 | AW8010AFCR | AU3 | BGA12-PT05 | BGA12-PT05 | | CN2 | 8P1_25 | 8P1_25 | J-S1.25-8P-L | CN3 | USB-AF-130SMD-4P | USB-AF-130SMD-4P | USB_Type_A | CN5 | 2P1_25 | 2P1_25 | J-S1.25-2P-L | CN7 | 2P1_25 | 2P1_25 | J-S1.25-2P-L | CN8 | 2P1_25 | 2P1_25 | J-S1.25-2P-L | CN9 | 4P1_0 | 4P1_0 | ZYA1001-FRS04 | CN10 | FPC_8P_0_5 | FPC_8P_0_5 | | D4 | SOD123H14A | SOD123H14A | | D5 | SOD123H14A | SOD123H14A | | D17 | D0402 | D0402 | | D18 | D0402 | D0402 | | F1 | FUSE-0805 | FUSE-0805 | | FB19 | L0603 | L0603 | | FB20 | L0603 | L0603 | | FB22 | L0805 | L0805 | | FB23 | L0805 | L0805 | | J1 | DC-001C | DC-001C | DCJACK_056 | J2 | CON2_2 | CON2_2 | J-S2.0-2P-L | J912 | FH26_51P_0_6 | FH26_51P_0_6 | FH26-51S-0.3MM | J913 | FH26_51P_0_6 | FH26_51P_0_6 | | J918 | CON2_2 | CON2_2 | J-S2.0-2P-L | L1 | L5_4 | L5_4 | | L6 | L5_4 | L5_4 | | L11 | COMMON-COIL4P | COMMON-COIL4P | | LED1 | LED12-22 | LED12-22 | GREEN | Q7 | SOT-23 | SOT-23 | | S6 | SCON2S | SCON2S | | S7 | SCON2S | SCON2S | | S8 | SCON2S | SCON2S | | S9 | SCON2S | SCON2S | | SW1 | SW-SMT | SW-SMT | KEY_PWR | U1 | BGA306-0P65 | BGA306-0P65 | M806 | U2 | QFN88-PT04-10X10MM | QFN88-PT04-10X10MM | P218 | U3 | SOT23-6P | SOT23-6P | | U18 | SOT23-5 | SOT23-5 | | U21 | QFN28LD | QFN28LD | | U34 | BMA250 | BMA250 | | Y4 | Y-SJK_4P2_5X3_2 | Y-SJK_4P2_5X3_2 | |
评分
查看全部评分
