Name | PCB Decal | Value | Part Type | AVDD | TP1.6 | | TP1.6 | BL901 | R1/2W | | R1/2W | CN900 | AI_06_25AA | | AI_06_25A | CN901 | CON_3AW2D_3P2_3 | | CON_3AW2D_3P2_3 | CNF1 | FPC-60PIN62-05MM | | CON-FPC-60PIN62-05MM | CNF2 | TL_FPC-JB96-01895MM | | TL_FPC-JB96-01895MM | CON1 | CON-XH254-4PIN90_2.5MM | | CON-XH254-4PIN90_2.5MM | CON101 | CN3P-20 | | CN3P-20 | CON502 | CON30-2.0MM | CON-DIP?? | CON30-2.0MM | CON601 | IF_JACK | ANT_JACK | IF_JACK | CON603 | PHONEJACKSTEREO | | PHONEJACKSTEREO | CON604 | RCA-AV11 | | RCA-AV11 | CON607 | CN-RCA303 | | CN-RCA303 | CON610 | USB9009 | | USB9009 | CON800 | CON2_2.0MM | | CON2_2.0MM | CON801 | CON_SIP_3PIN_2.0MM | | CON_SIP_3PIN_2.0MM | CON802 | CON2_2.0MM | | CON2_2.0MM | CPV1 | TP | TP | TP | CPV2 | TP1.6 | | TP1.6 | CT26 | SMD-C(1608) | | SMD-C(1608) | CT27 | TL_C(0805-0603) | | TL_C(0805-0603) | CT28 | TL_C(0805-0603) | | TL_C(0805-0603) | CT29 | EC5_2.5MM | | EC5_2.5MM | CT41 | EC5_2.5MM | | EC5_2.5MM | CT535 | C0805 | NC | C0805 | CX902 | 474/275VAC | | 474/275VAC | CY901 | C10Y | | C10Y | CY902 | C10Y | | C10Y | CY904 | C10Y | | C10Y | D202 | SOT23-BCE-132 | | SOT23-BCE-132 | D206 | DO-214 | | DO-214 | FB701 | L0805 | | L0805 | FB801 | L0805 | | L0805 | GREF | TP1.6 | | TP1.6 | L4 | SMD03X03-MV | | SMD03X03-MV | L7 | SMD_L6X6 | SMD_L6X6 | SMD_L6X6 | L800 | L7.5/12.8 | | L7.5/12.8 | LED1 | LED-3PIN-2MM54_9M5 | | LED_3PIN_2MM54_9M5 | LED2 | LED_2PIN254MM-8MM | | LED_2PIN254MM-8MM | LF900 | UU9.8 | | UU9.8 | LF901 | LF_UC19C | | LF_UC19C | LF901A | ET20 | | ET20 | LF901B | LF-UC15C | | LF-UC15C | LT1 | NR4018 | | NR4018 | P502 | HDMI19P-HAIER | | HDMI19P-HAIER | P802 | USB_MINI_4P | | USB_MINI_4P | PAD901 | AC/AC | | AC/AC | PAD902 | AC/AC | | AC/AC | PANEL-VCC1 | TP1.6 | | TP1.6 | POL | TP | TP | TP | Q1 | SOT23-BCE-132 | | SOT23-BCE-132 | Q2 | SOT23-BCE-132 | | SOT23-BCE-132 | Q3 | SOT23-BCE-132 | | SOT23-BCE-132 | Q4 | SOT-23 | | SOT-23 | Q5 | SOT-23 | | SOT-23 | Q502 | SOT-23 | | SOT-23 | Q503 | SOT23 | | SOT23 | Q701 | SOT23-BCE-132 | | SOT23-BCE-132 | Q702 | SOT23-BCE-132 | | SOT23-BCE-132 | Q703 | SOT23-BCE-132 | | SOT23-BCE-132 | Q717 | SOT23-BCE-132 | | SOT23-BCE-132 | Q718 | SOT23-BCE-132 | | SOT23-BCE-132 | Q800 | TO-252-3 | NC | TO-252-3 | Q901 | TO-252-3 | NC | TO-252-3 | Q901A | TO-263-3 | | TO-263-3 | Q902 | SOT23-BCE-132 | | SOT23-BCE-132 | RT901 | 10D471K | | 10D471K | SHIELD1 | SHIELD | | SHIELD | SK806 | KEY-4P-7MM | | KEY-4P-7MM | STV1 | TP | TP | TP | STV2 | TP | TP | TP | T902 | TF_EQ2648AA | | TF_EQ2648 | U23 | IC-156P-EPLQFP | | IC-156P-EPLQFP | U113 | SOT223-GOI-123 | | SOT223-GOI-123 | U204 | IC-8P-SOICA | | IC-8P-SOICA | U402 | TSOT23-6 | | TSOT23-6 | U403 | SOT223-GOI-123 | | SOT223-GOI-123 | U404 | SOT223-GOI-123 | | SOT223-GOI-123 | U408 | SOT23-5P | | SOT23-5P | U602 | QFN24N3X3P0.4AB2074 | | QFN24N3X3P0.4 | U701 | EUA2313 | EUA2313 | EUA2313 | U801 | TL-TSOT26-6 | | TL-TSOT26-6 | U903 | SOT-26 | | SOT-26 | U904 | PC871M | | PC871M | U905 | SOT-23TL431 | | SOT-23TL431 | UT1 | G5517_TQFN4X4-24 | | G5517_TQFN4X4-24 | UX501 | RCLAMP0522 | NM/RClamp0524P/AZ1045-4F | RCLAMP0522 | UX502 | RCLAMP0522 | NM/RClamp0524P/AZ1045-4F | RCLAMP0522 | UX503 | RCLAMP0522 | NM/RClamp0524P/AZ1045-4F | RCLAMP0522 | UX504 | RCLAMP0522 | NM/RClamp0524P/AZ1045-4F | RCLAMP0522 | Y201 | XTAL\HC49\F | | XTAL\HC49\F | ZD901 | DO214AB | | DO214AB |
