10层PCB设计。。项目名称 PCB-SNOA5001-3A
Name | PCB Decal | Part Type | BFD1 | FID-R3R | FID-R3R | D1 | SOT23 | DI-4148-03 | D2 | IC-TO263-3(D2PAK) | DI-32CTQ030-01 | D3 | IC-TO263-3(D2PAK) | DI-32CTQ030-01 | D4 | SOT23 | DI-6V2-01 | D5 | SOT23 | DI-4148-03 | D6 | SOT23 | DI-13V0-01 | D7 | DI-DO214AB(SMC) | DI-MURS320-01 | D8 | SOT23 | DI-BAS70-02 | D9 | SOT23 | DI-BAS70-02 | D10 | DI-DO214AA(SMB) | DI-MBRS130LTR-01 | D11 | DI-DO214AB(SMC) | DI-MURS320-01 | D12 | DI-DO214AA(SMB) | DI-MBRS130LTR-01 | D13 | DI-DO214AB(SMC) | DI-MURS320-01 | D14 | DI-DO214AB(SMC) | DI-MURS320-01 | D15 | SOT23 | DI-4148-03 | D16 | SOT23 | DI-4148-03 | D17 | DI-SOD123 | DI-1N5711-01 | D18 | DI-SOD123 | DI-1N5711-01 | D19 | LED-3MMX2MM | DI-LEDG1208-01 | D20 | LED-1206-CCV | DI-LEDR1206-01 | D21 | LED-1206-CCV | DI-LEDG1206-01 | D22 | LED-1206-CCV | DI-LEDB1206-01 | D23 | LED-1206-CCV | DI-LEDR1206-01 | D24 | LED-1206-CCV | DI-LEDR1206-01 | D25 | LED-1206-CCV | DI-LEDY1206-01 | D26 | LED-3MMX2MM | DI-LEDG1208-01 | D27 | DI-DO214AA(SMB) | DI-MBRS130LTR-01 | D28 | DI-DO214AA(SMB) | DI-MBRS130LTR-01 | D29 | DI-DO214AB(SMC) | DI-SMCJ11CA-01 | D30 | DI-DO214AB(SMC) | DI-SMCJ11CA-01 | F1 | FUS-1206 | FUS-3A32V-01 | F2 | FUS-1206 | FUS-3A32V-01 | F3 | FUS-1206 | FUS-3A32V-01 | F4 | FUS-1206 | FUS-3A32V-01 | FB1 | 1206 | FB-120R-60 | GP1 | HW-GP70292 | HW-GPREC-01 | GP2 | HW-GP70292 | HW-GPREC-01 | IND1 | IND-SUMIDA-CDRH127 | IND-22U0-01 | IND2 | 1812 | IND-1U00-01 | IND3 | 1812 | IND-1U00-01 | IND4 | 1812 | IND-1U00-01 | J4 | CON-HDR1X2-100 | TESTPOINT_JUMPER | J5 | CON-HDR-SAM-TSM-105-DV-A | CON-TSM105-02 | J6 | CON-HDR-SAM-TSM-105-DV-A | CON-TSM105-02 | J7 | CON-HDR-SAM-TSM-105-DV-A | CON-TSM105-02 | J8 | CON-HDR-SAM-TSM-108-DV-A | CON-TSM108-01 | J9 | CON-HDR-SAM-TSM-115-DV-A | CON-TSM115-01 | J10 | CON-KYCON-GM-SMT2-S6-88 | CON-RJ45SHLD-04 | J11 | CON-KYCON-GM-SMT2-S6-88 | CON-RJ45SHLD-04 | J12 | CON-MFB5X12-90D-F | CON-FB5X12RAF-01 | J13 | CON-MFB5X12-90D-F | CON-FB5X12RAF-01 | J14 | CON-MFB5X12-90D-F | CON-FB5X12RAF-01 | J15 | CON-MFB5X12-90D-F | CON-FB5X12RAF-01 | JP1 | 603 | RES-0R00-35 | LP1 | LP-LUMEX-C012303S | HW-LPF-C012303S-01 | LP2 | LP-DIALIGHT-515-1069 | HW-LPX3RA-01 | LP3 | LP-DIALIGHT-515-1069 | HW-LPX3RA-01 | MH1 | HOL-125P | MOUNTING_HOLE_125P | MH2 | HOL-125P | MOUNTING_HOLE_125P | MH3 | HOL-125P | MOUNTING_HOLE_125P | MH4 | HOL-125P | MOUNTING_HOLE_125P | PAD1 | TP-SMT-32NS | SMT-PAD | PAD2 | TP-SMT-32NS | SMT-PAD | PAD3 | TP-SMT-32NS | SMT-PAD | PAD4 | TP-SMT-32NS | SMT-PAD | Q1 | SOT23 | BIP-3906-01 | Q2 | SOT23 | BIP-3906-01 | Q3 | SOT23 | BIP-3906-01 | Q4 | SOT23 | BIP-3906-01 | Q5 | SOT23 | BIP-3904-01 | Q6 | SOT23 | BIP-3904-01 | Q7 | SOT23 | BIP-3904-01 | Q8 | SOT23 | BIP-3906-01 | Q9 | SOT23 | BIP-3906-01 | Q10 | IC-TO252-3(DPAK) | MOS-IRLR2703-01 | Q11 | IC-TO252-3(DPAK) | MOS-IRLR2703-01 | Q12 | SOT23 | BIP-3906-01 | Q13 | SOT23 | BIP-3906-01 | Q14 | SOT23 | BIP-3904-01 | Q15 | SOT23 | BIP-3906-01 | Q16 | SOT23 | MOS-NDS351-01 | Q17 | SOT23 | MOS-NDS351-01 | Q33 | SOT23 | MOS-NDS351-01 | Q34 | SOT23 | BIP-4403-01 | Q35 | SOT23 | MOS-NDS351-01 | Q36 | SOT23 | BIP-4403-01 | Q37 | IC-TO252-3(DPAK) | BIP-MJD200-01 | Q38 | IC-TO252-3(DPAK) | BIP-MJD200-01 | Q39 | SOT23 | BIP-4403-01 | Q40 | SOT23 | BIP-4403-01 | RLY1 | RLY-AGN210S-G6JU2FL | RLY-G6J2FL-01 | RVH8 | HOL-130P-2MMKO | RIVET_HOLE | SW1 | SW-GRAYHILL-38BM | SW-PBSPST-01 | T1 | XFO-PULSE-H110X | TRA-H1102-01 | THOLE1 | HOL-156NP | TOOLING_HOLE_156 | TPC1 | TP-KEYSTONE-5016 | HW-SMTTP5016-01 | TPC2 | TP-KEYSTONE-5016 | HW-SMTTP5016-01 | TPC3 | TP-KEYSTONE-5016 | HW-SMTTP5016-01 | TPC4 | TP-KEYSTONE-5016 | HW-SMTTP5016-01 | TPC5 | TP-KEYSTONE-5016 | HW-SMTTP5016-01 | TPC6 | TP-KEYSTONE-5016 | HW-SMTTP5016-01 | TVS1 | IC-SO8 | DI-LC03-6-01 | TVS2 | IC-SO8 | DI-LC03-6-01 | U1 | SOT23-5 | IC-TL431-02 | U2 | IC-MSO10 | IC-LTC2900-02 | U3 | IC-TSSOP14 | IC-7414-04 | U4 | IC-SO8 | IC-DS1822Z-01 | U5 | IC-TSSOP14 | IC-74125-02 | U6 | SOT223-6 | IC-TPS73601-01 | U7 | IC-MSO8 | IC-LP3982-02 | U8 | IC-TSOC6 | IC-DS2401P-01 | U9 | IC-TSSOP14 | IC-74125-02 | U10 | SOT23-5 | IC-TL431-02 | U11 | IC-SO14 | IC-7408-01 | U12 | IC-QFP100-14X14 | IC-XC2C256-02 | U13 | OSC-5MMX7MM5-4P-CCV | IC-OSC25M-01 | U14 | IC-BGA256-1MM-17X17 | IC-XC3S400-03 | U15 | IC-TSSOP14 | IC-7414-04 | U16 | IC-TSSOP16 | IC-74157-01 | U17 | IC-SO14 | IC-7408-01 | U18 | IC-TSSOP14 | IC-74125-02 | U19 | IC-TSSOP48 | IC-74LVTH16373-01 | U20 | IC-TSOP56-14X20 | IC-FLASH256M-01 | U21 | IC-TSSOP20-PWP | IC-TPS54316-01 | U22 | IC-TSSOP14 | IC-74125-02 | U23 | IC-SO14 | IC-7408-01 | U24 | SOT23-6 | IC-LM2664-01 | U25 | IC-TSOP54-400 | IC-SDRAM256M-01 | U26 | IC-SO8 | IC-LM6492-01 | U27 | SOT23-5 | IC-TL431-02 | U28 | IC-TSOP54-400 | IC-SDRAM256M-01 | U29 | IC-SO8 | IC-LM6492-01 | U30 | SOT23-5 | IC-TL431-02 | U31 | IC-SSOP20 | IC-ADS7844-01 | U32 | IC-SO8 | IC-LM6492-01 | U33 | IC-MSO8 | IC-LP3982-02 | U34 | SOT23 | IC-REF3125-01 | U35 | IC-SO8 | IC-CY2305-01 | U36 | IC-QFN16-3X3 | IC-M41T60-01 | U37 | IC-BGA256-1MM27-23X23 | IC-MPC852T-04 | U38 | IC-MSO8 | IC-LM75CIMM-01 | U39 | IC-TSSOP16 | IC-74157-01 | U40 | OSC-5MMX7MM5-4P-CCV | IC-OSC25M-01 | U41 | IC-QFP64-10X10 | IC-BCM5221-01 | U42 | IC-TSSOP14 | IC-7414-04 | U43 | IC-TSSOP14 | IC-74125-02 | U44 | IC-TSSOP14 | IC-74125-02 | U45 | IC-DIP10/12GW | IC-LF111ESI-01 | U46 | IC-DIP6GW-3627 | IC-4N25S-01 | U47 | IC-DIP6GW-3627 | IC-4N25S-01 | U48 | IC-TSSOP14 | IC-LMV339-01 | U49 | IC-TSSOP14 | IC-7414-04 | U50 | SOT23-5 | IC-TL431-02 | U51 | IC-TSSOP20 | IC-TPS2301-01 | U52 | SOT23-8 | IC-DAC7513-01 | U53 | SOT23-8 | IC-DAC7513-01 | U54 | OSC-5MMX7MM5-4P-CCV | IC-OSC10M-02 | U55 | IC-SO8 | IC-LM6492-01 | U56 | IC-SO8 | IC-LM6492-01 | U57 | IC-SSOP16 | IC-MAX3221E-02 | X1 | XTAL-CITIZEN-CMR200T | XTL-32K768-01 |
