重要提示:PCB作品文件展下载说明
Name | PCB Decal | Value | Part Type | CM1 | CHOKE_0805 | Choke_0805 | CHOKE_0 | CM2 | CHOKE_0805 | Choke_0805 | CHOKE_0 | CON1 | TU1252WNV-05 | TU1252WNV-05 | HEADER_4_5 | CON2 | CKS-001FA-A1NW | USB Port A | USB_PORTA_1 | CON3 | CON_MINI-USB-0.8-1 | USB_Mini B | USB_PORT_MINI_B | CON4 | FPC-05-50P | AT070TN92_FPC_P0.5 | 03._AT070TN92_FPC_P0.5 | D1 | SOD323F | RB751V | DIODE_2 | D2 | DO-214AC | SS24L | DIODE_ZENER_0 | D6 | SOT-523 | NC/Rclamp0502B_SC-75_3L | DZ_DUAL_CA_KKJ_3 | D7 | SOT-523 | NC/Rclamp0502B_SC-75_3L | DZ_DUAL_CA_KKJ_3 | D8 | SOD323F | RB751V | DIODE_2 | D9 | SOD323F | RB751V | DIODE_2 | D10 | SOT-523 | Rclamp0502B_SC-75_3L | DZ_DUAL_CA_KKJ_3 | D11 | SOT-523 | Rclamp0502B_SC-75_3L | DZ_DUAL_CA_KKJ_3 | D12 | DO-214AC | SS24L | DIODE_ZENER_0 | D13 | D0603 | LED_Red | LED_0 | D14 | DO-214AC | SS24L | DIODE_ZENER_0 | D15 | SOT23-3P-1/GSD-1 | BAS40-04 | BAS40-04_0 | D16 | SOT23-3P-1/GSD-1 | BAS40-04 | BAS40-04_0 | F1 | F1206 | MF-NSMF150-2 | THERMAL_FUSE_0 | H1 | MTG3.0 | Hole | TEST_POINT_0 | H2 | MTG3.0 | Hole | TEST_POINT_0 | H3 | MTG3.0 | Hole | TEST_POINT_0 | H4 | MTG3.0 | Hole | TEST_POINT_0 | J2 | FPHSI-102T1W000 | FPHSI-102T1W000 | HEADER_2_1 | J3 | TSH-369 | PHONEJACK STEREO SW | PHONEJACK_STEREO_SW_1 | J4 | FPHSI-110T1W000 | HEADER 10/2.0 | HEADER_8_3 | J5 | HEADER3X1/2.0 | HEADER3X1/2.0 | HEADER_5_2 | J6 | FPHSI-104T1W000 | FPHSI-104T1W000 | HEADER_4_2 | J7 | HEADER5X1/2.54 | HEADER 5X1/2.54 | HEADER_5 | J8 | FPHSI-105T1W000 | HEADER 5 | HEADER_5 | J9 | FPHSI-103T1W000 | FPHSI-103T1W000 | HEADER_3_3 | J10 | FPHSI-105T1W000 | FPHSI-105T1W000 | HEADER_8_2 | J11 | FPHSI-105T1W000 | FPHSI-105T1W000 | HEADER_8_2 | J12 | HEADER2X1/2.0 | HD 1x2_2.0mm | HEADER_1X2_0 | J13 | TU1252WNV-06 | TU1252WNV-06 | HEADER_10_1 | J14 | HEADER2X1/2.54 | HEADER 2 | HEADER_2 | J15 | SCD473 | DC_JACK-5V | 5V_POWER_SOCKET_0 | L2 | ZAD-4030 | LPC5015FT-2R2M-A | INDUCTOR | L3 | ZAD-4030 | LPC5015FT-2R2M-A | INDUCTOR | L4 | ZAD-4030 | LPC5015FT-2R2M-A | INDUCTOR | L5 | ZAD-6045 | 10uH | L_SMD_15UH_3.2A | L6 | ZAD-6045 | 10uH | L_SMD_15UH_3.2A | Q1 | SOT23-3P-1/GSD | TSM2301 | MOSFET_P_2 | Q2 | SOT23-3P-1/GSD-1 | MMBT3904 | NPN_3 | RN6 | RP0402X4 | 33R | RESARR_IS_4/SO | RST_KEY1 | PSW_STS-076 | System_RST | SW_PUSHBUTTON_1 | U1 | LQFP-128P-E/0.4/14X14 | IT9852 | IT9852_2 | U2 | SOT23-3P-1/GSD-1 | TS3809CXF | TS809CXC_1 | U3 | TSOT25-5P/0.95/3X3 | VP3162 | EUP2584A_0 | U4 | TQFN-16P/0.5/3X3 | G5520-TQFN3X3-16 | CAT7202_0 | U7 | QFN-32P/0.4/4X4 | ALC5616 | SP3232EU_4 | U8 | QFN-20P/0.4/3X3 | AW8733 | SP3232EU_0 | U10 | SOP-8P/1.27/5X8 | MX25L12835FM2I-10G | NORFLAH_EN25B16 | U11 | SO-8P/1.27/5X6 | SP485_SOICN8 | 03._SP458_SOICN | U12 | FPC-05-6P | NC/To_Capacitor Touch | TO_TOUCH_0 | U13 | TSOT25-5P/0.95/3X3 | G5728T01 | 05._IT7831TS_TSOT25 | U14 | TSOT25-5P/0.95/3X3 | ETA3409/2A_out | 05._IT7831TS_TSOT25 | U15 | TSOT25-5P/0.95/3X3 | G5728T01 | 05._IT7831TS_TSOT25 | U16 | C2002-C-00 | Macro SD Con | MACRO_SD_CON_2 | Y1 | XTAL-HC49USY2 | 12MHz | CRYSTAL_0_2 | Y2 | SF-3215 | 32.768k | CRYSTAL_2 |
重要提示:PCB作品文件展下载说明
