查看: 801|回复: 0
九宫格-python
发表于 2020-4-19 18:21:22 | 显示全部楼层 |阅读模式
[/free]from PIL import Image
import sys
#先将 input image 填充为正方形
def fill_image(image):
    width, height = image.size
    #选取长和宽中较大值作为新图片的
    new_image_length = width if width > height else height
    #生成新图片[白底]
    new_image = Image.new(image.mode, (new_image_length, new_image_length), color='white')   #注意这个函数!
    #将之前的图粘贴在新图上,居中
    if width > height:#原图宽大于高,则填充图片的竖直维度  #(x,y)二元组表示粘贴上图相对下图的起始位置,是个坐标点。
        new_image.paste(image, (0, int((new_image_length - height) / 2)))
    else:
        new_image.paste(image, (int((new_image_length - width) / 2),0))
    return new_image
def cut_image(image):
    item_width = int(width / 3)  #因为朋友圈一行放3张图。
    box_list = []
    # (left, upper, right, lower)
    for i in range(0,3):
        for j in range(0,3):
            #print((i*item_width,j*item_width,(i+1)*item_width,(j+1)*item_width))
            box = (j*item_width,i*item_width,(j+1)*item_width,(i+1)*item_width)
            box_list.append(box)
    image_list = [image.crop(box) for box in box_list]
    return image_list
#保存
def save_images(image_list):
    index = 1
    for image in image_list:
        image.save(str(index) + '.png', &#39NG')
        index += 1
if __name__ == '__main__':
    file_path = "4.jpg"
    image = Image.open(file_path)
    #image.show()
    image = fill_image(image)
    image_list = cut_image(image)
    save_images(image_list) [free]
购买主题 本主题需向作者支付 2 枚金币 才能浏览
