Name | Part Type | PCB Decal |
CON1 | COAXIAL/SMD/CON/V/I-PEX | COAXIAL/SMD/CON/V/I-PEX |
D2 | C0603/FCS | C0603/FCS |
D5 | D/SMD/P6.61/B540C | D/SMD/P6.61/B540C |
D8 | DO-214AC/SMD/SM5817A | DO-214AC/SMD/SM5817A |
D18 | LED/2P/SMD/0603/LT8A22-54-UR86-T5 | LED/2P/SMD/0603/LT8A22-54-UR86-T5 |
D21 | D-SMA/SMD/B230A | D-SMA/SMD/B230A |
H1 | HOLE/PTH/R0.762X1.6D0.508X1.3 | HOLE/PTH/R0.762X1.6D0.508X1.3 |
H2 | HOLE/PTH/R0.762X1.6D0.508X1.3 | HOLE/PTH/R0.762X1.6D0.508X1.3 |
H3 | HOLE/PTH/R0.762X1.6D0.508X1.3 | HOLE/PTH/R0.762X1.6D0.508X1.3 |
J1 | DIP4/P2.54 | DIP4/P2.54 |
J2 | USB/4P/P2.0/DIP/R/F/SUA-110VB-B2N | USB/4P/P2.0/DIP/R/F/SUA-110VB-B2N |
J3 | DIP1/P2.54 | DIP1/P2.54 |
J10 | CON\DC-JACK\4.7 | CON\DC-JACK\4.7 |
J11 | DIP5/P2.54 | DIP5/P2.54 |
JP2 | DIP6X2/P2.54 | DIP6X2/P2.54 |
L1 | L0402/FCS | L0402/FCS |
L2 | L0402/FCS | L0402/FCS |
L3 | L0402/FCS | L0402/FCS |
L4 | L0402 | L0402 |
L5 | L0402 | L0402 |
L24 | L/IND/SMD/VLS252010/TDK | L/IND/SMD/VLS252010/TDK |
L29 | L0402/FCS | L0402/FCS |
L30 | L0402/FCS | L0402/FCS |
L31 | L0402/FCS | L0402/FCS |
L32 | L/IND/SMD/VLS252012E | L/IND/SMD/VLS252012E |
L33 | L0402 | L0402 |
L34 | L0402 | L0402 |
L41 | L/IND/DIP/GDR0810 | L/IND/DIP/GDR0810 |
L42 | L/IND/SMD/LVS606045-150M | L/IND/SMD/LVS606045-150M |
L44 | R0805 | R0805 |
L46 | L/IND/SMD/LVS606045-150M | L/IND/SMD/LVS606045-150M |
S1 | SW-2P2T-6.3 | SW-2P2T-6.3 |
S3 | SW-TACT\4.5MM | SW-TACT\4.5MM |
SR1 | R0402/FCS | R0402/FCS |
SR2 | R0402/FCS | R0402/FCS |
U1 | MT7628AN/DRQFN156/SMD/P0.5/12X12 | MT7628AN/DRQFN156/SMD/P0.5/12X12 |
U2 | CRYS/DIP/D5X10.6/GB2000025/ECERA | CRYS/DIP/D5X10.6/GB2000025/ECERA |
U3 | XTAL-SMD/3.2X2.5 | XTAL-SMD/3.2X2.5 |
U4 | SOP8/SMD/P1.27/MX25L1605D | SOP8/SMD/P1.27/MX25L1605D |
U6 | WBGA84/SMD/P0.8/W9751G6IB | WBGA84/SMD/P0.8/W9751G6IB |
U7 | MT7662/WSQFN76/SMD/P0.4/9X9/S | MT7662/WSQFN76/SMD/P0.4/9X9/S |
U8 | CRYS/SMD/D3.2X2.5/E3SB40/HOSONIC | CRYS/SMD/D3.2X2.5/E3SB40/HOSONIC |
U11 | TRANSFORMER/20P/DIP/HN2066CG | TRANSFORMER/20P/DIP/HN2066CG |
U12 | RJ45/32P/DIP/R/N3642-001 | RJ45/32P/DIP/R/N3642-001 |
U13 | TRANSFORMER/20P/DIP/HN2066CG | TRANSFORMER/20P/DIP/HN2066CG |
U14 | TRANSFORMER/16P/DIP/HN1674CG | TRANSFORMER/16P/DIP/HN1674CG |
U15 | RJ45/8P/DIP/R/N3612-002 | RJ45/8P/DIP/R/N3612-002 |
U18 | SOP8/SMD/P1.27/FR9888 | SOP8/SMD/P1.27/FR9888 |
U20 | SOP8AG1-1.8 | SOP8AG1-1.8 |
U22 | SOP8AG1-1.8 | SOP8AG1-1.8 |
U26 | QFN16/SMD/P0.5/3-IN-1 | QFN16/SMD/P0.5/3-IN-1 |
U27 | QFN16/SMD/P0.5/3-IN-1 | QFN16/SMD/P0.5/3-IN-1 |
UC1 | R0402/FCS | R0402/FCS |
UC2 | R0402/FCS | R0402/FCS |
