查看: 683|回复: 0
24C0102驱动代码(mega128)
发表于 2020-4-29 09:08:08 | 显示全部楼层 |阅读模式
#define __24C01_02_C__
#include "config.h"
#include "24C01_02.h"
                        IIC函数模块
/*开始信号*/
void start(void)
    sdaon;
    sclon;
    delay_us(10);
    sdaoff;
    delay_us(10);
    scloff;
/*停止信号*/
void stop(void)
    sdaoff;
    delay_us(10);
    sclon;
    delay_us(10);
    sdaon;
/*读取一个字节数据*/
uchar shin(void)
    uchar i,read_data,data;
    DDRD &= 0xf7;
    for(i=0; i<8; i++)
        sclon;
        read_data <<= 1;
        read_data |= (uchar)((PIND & 0x08)>>3);
        scloff;
        delay_us(10);
    DDRD|=0x08;
    return(read_data);
/*写一个字节数据*/
uchar shout(uchar write_data)
    uchar i,temp;
    uchar ack_bit;
    for ( i=0; i<8; i++ )
        temp = (write_data & 0x80)>>7;
        if(temp == 0)
            sdaoff;
        else
            sdaon;
        delay_us(10);
        sclon;
        delay_us(10);
        scloff;
        write_data <<= 1;
    sdaon;
    delay_us(10);
    sclon;
    delay_us(10);
    ack_bit = (PIND & 0x08)>>3;
    scloff;
    return ack_bit;
/*向指定地址写数据*/
void write_byte(uchar addr,uchar write_data)
    start();
    shout(OP_WRITE);
    shout(addr);
    shout(write_data);
    stop();
    delay_ms(10);
/*读取当前地址数据*/
uchar read_current(void)
    uchar read_data;
    start();
    shout(OP_READ);
    read_data = shin();
    stop();
    return read_data;
/*向指定地址读数据*/
uchar read_random(uchar random_addr)
    start();
    shout(OP_WRITE);
    shout(random_addr);
    return(read_current());
/*从指定地址开始写入一个4字节数据*/
void MultiByte_write(uchar add ,long dat)
    union data
        long dat;
        uchar tab[4];
    }count;
    count.dat = dat;
    write_byte(add,count.tab[0]);
    write_byte(add+1,count.tab[1]);
    write_byte(add+2,count.tab[2]);
    write_byte(add+3,count.tab[3]);
    delay_ms(100);
/*从指定地址开始读取一个4字节数据*/
long MultiByte_read(uchar add)
    union data
        long dat;
        uchar tab[4];
    }count;
    count.tab[0] = read_random(add);
    count.tab[1] = read_random(add+1);
    count.tab[2] = read_random(add+2);
    count.tab[3] = read_random(add+3);
    return count.dat;
