Name | Part Type | PCB Decal | Value | BAT1 | BAT-2P | BATT2 | BAT-2P | BAT1(1) | BATTERY | | CR2032 | C1614 | CAP_NP | M-C0402 | 470pF/50V | CN1 | CON_USB-3-0_9P4MH_A | USB3-JACK-9PR-AF | USB-F-90-1.0mm | CN2 | CON_MICRO_USB3_CON_B | USB3-JACK-10PR-AF | USB-F-90 | CN3 | CON_SD_A | CN-GS9PM-25M-C | SD CON-12P | CN4 | SLOT_PCIE98P_NH2 | CN-GH98PS-1M | PCI-E 8X_98 | CON1 | SLOT_PCIE64P-A_NH | CN-GH64PS-1M | PCI-E 4X_64P | CON2 | CON_SATA7P-B | SATA-JACK-7PMS-AM | SATA-M-180-1.27mm | CON3 | CON_SATA7P-B | SATA-JACK-7PMS-AM | SATA-M-180-1.27mm | CP1 | CAP_NP | M-C0402 | 0.1uF/16V | D2 | DIODE | M-D1206 | LL4148-GS08 | D3 | DIODE | M-D1206 | LL4148-GS08 | D4 | DIODE | M-D1206 | LL4148-GS08 | D6 | DIODE_SCKY | M-D123 | MBR0520LT1G | D7 | DIODE_SCKY | M-D123 | MBR0520LT1G | D9 | DIODE | M-D1206 | LL4148-GS08 | D10 | DIODE | M-D1206 | LL4148-GS08 | D51 | DIODE | M-D123 | CMHD3595 | D52 | DIODE | M-D123 | CMHD3595 | D53 | LED | M-LED0603 | LTST-C190KRKT | FAN1 | CON_1X4_NH | CN-BH4PS-254M-BM | W/FAN-M-180-2.54mm | FAN2 | CON_1X4_NH | CN-BH4PS-254M-BM | W/FAN-M-180-2.54mm | FAN3 | CON_1X3A | CN-BH3PS-254M | W/FAN-M-180-2.54mm | FAN5 | CON_1X4_NH | CN-BH4PS-254M-BM | W/FAN-M-180-2.54mm | FAN8 | CON_1X3A | CN-BH3PS-254M | W/FAN-M-180-2.54mm | FAN10 | CON_1X4_NH | CN-BH4PS-254M-BM | W/FAN-M-180-2.54mm | FAN11 | CON_1X3A | CN-BH3PS-254M | W/FAN-M-180-2.54mm | FAN12 | CON_1X3A | CN-BH3PS-254M | W/FAN-M-180-2.54mm | FAN13 | CON_1X4_NH | CN-BH4PS-254M-BM | W/FAN-M-180-2.54mm | FAN14 | CON_1X3A | CN-BH3PS-254M | W/FAN-M-180-2.54mm | FB1 | FER_BEAD | M-L0603 | 120E/3000mA | FBP17 | FER_BEAD | M-L0805 | 30E/6000mA | FBP18 | FER_BEAD | M-L0805 | 30E/6000mA | FL1 | NFM41PC155B1H3L | M-FBNFM41P | NFM41PC155B1E3L | FL2 | NFM41PC155B1H3L | M-FBNFM41P | NFM41PC155B1E3L | FL3 | NFM41PC155B1H3L | M-FBNFM41P | NFM41PC155B1E3L | H16 | HOLE_9P | MTH315D158 | MTH315D158 | J1 | HEADER_1X3 | CN-BS3PS-254M-AM | PIN-M-180-2.54mm | J1(2-3) | MJ | | MINI JUMPER | J2 | CON_20P | CN-GF20PM-08M-AF | FIBER-F-90 | J3 | SFPPLUSCAGE1X4_1 | SFP-JACK10 | SFPPLUSCAGE1x4 | J4 | CON_20P | CN-GF20PM-08M-AF | FIBER-F-90 | J5 | CON_20P | CN-GF20PM-08M-AF | FIBER-F-90 | J6 | CON_20P | CN-GF20PM-08M-AF | FIBER-F-90 | J7 | HEADER_1X3 | CN-BS3PS-254M-AM | PIN-M-180-2.54mm | J7(2-3) | MJ | | MINI JUMPER | J8 | HEADER_1X3 | CN-BS3PS-254M-AM | PIN-M-180-2.54mm | J8(1-2) | MJ | | MINI JUMPER | J9 | CON_ATX_2X12_NH | CN-BA24PS-42M-AF | ATX-F-180-4.2mm | J10 | CON_ATX_2X4 | CN-BA8PS-42M-BM | ATX-M-180-4.2mm | J11 | HEADER_1X3 | CN-BS3PS-254M-AM | PIN-M-180-2.54mm | J11(2-3) | MJ | | MINI JUMPER | J12 | HEADER_1X2 | CN-BS2PS-254M-AM | PIN-M-180-2.54mm | J13 | HEADER_1X2 | CN-BS2PS-254M-AM | PIN-M-180-2.54mm | J14 | HEADER_1X3 | CN-BS3PS-254M-AM | PIN-M-180-2.54mm | J14(1-2) | MJ | | MINI JUMPER | J59 | FPC_CON_2X10 | CN-BD20PM-127M-CM | BD-M-180-1.27mm | JP1 | HEADER_1X2 | CN-BS2PS-254M-AM | PIN-M-180-2.54mm | JP2 | HEADER_1X2 | CN-BS2PS-254M-AM | PIN-M-180-2.54mm | JP2(1-2) | MJ | | MINI JUMPER | JP3 | HEADER_1X2 | CN-BS2PS-254M-AM | PIN-M-180-2.54mm | JP4 | HEADER_2X6 | CN-AI12PS-254M-AM | PIN-M-180-2.54mm | JP5 | HEADER_1X3 | CN-BS3PS-254M-AM | PIN-M-180-2.54mm | JP6 | HEADER_1X3 | CN-BS3PS-254M-AM | PIN-M-180-2.54mm | JP7 | HEADER_1X3 | CN-BS3PS-254M-AM | PIN-M-180-2.54mm | JP8 | HEADER_1X3 | CN-BS3PS-254M-AM | PIN-M-180-2.54mm | JP9 | HEADER_1X3 | CN-BS3PS-254M-AM | PIN-M-180-2.54mm | JP10 | HEADER_2X5D | CN-AI2X5PMS-127M-AM | PIN-M-180-1.27mm | JP11 | HEADER_2X4 | CN-AI8PS-254M-AM | PIN-M-180-2.54mm | JP12 | BOX_2X5 | CN-BB10PS-254M-AM | BOX-M-180-2.54mm | JP13 | HEADER_2X5 | CN-AI10PS-254M-AM | PIN-M-180-2.54mm | JP14 | HEADER_1X3 | CN-BS3PS-254M-AM | PIN-M-180-2.54mm | JP17 | HEADER_1X3 | CN-BS3PS-254M-AM | PIN-M-180-2.54mm | JP18 | HEADER_1X2 | CN-BS2PS-254M-AM | PIN-M-180-2.54mm | JP19 | HEADER_1X3 | CN-BS3PS-254M-AM | PIN-M-180-2.54mm | JP20 | HEADER_1X2 | CN-BS2PS-254M-AM | PIN-M-180-2.54mm | L1 | NFE31PT222Z1E9L | M-FBNFE31P | NFE31PT222Z1E9L | L2 | CHOKE_CM | M-CHOKE24 | 90E/400mA | L3 | CHOKE_CM | M-CHOKE24 | 90E/400mA | L4 | NFE31PT222Z1E9L | M-FBNFE31P | NFE31PT222Z1E9L | L5 | INDUCTOR | M-FB2016 | 10uH/245mA | L6 | INDUCTOR | M-FB2016 | 10uH/245mA | L7 | INDUCTOR | M-CHOKE12 | 4.7uH/1.70A | L8 | INDUCTOR | M-CHOKE12 | 4.7uH/1.70A | L9 | INDUCTOR | M-CHOKE12 | 4.7uH/1.70A | L10 | INDUCTOR | M-CHOKE12 | 4.7uH/1.70A | L61 | CHOKE_CM_8P | M-CHOKE3_2X1_6A | 220E/300mA | L62 | CHOKE_CM_8P | M-CHOKE3_2X1_6A | 220E/300mA | LAN1 | CON_RJ45L-I | JACK-12PR12C-102M-A | RJ45-90-1.02mm | LAN2 | CON_RJ45L-I | JACK-12PR12C-102M-A | RJ45-90-1.02mm | LAN3 | CON_RJ45L-I | JACK-12PR12C-102M-A | RJ45-90-1.02mm | LAN5 | CON_RJ45L-I | JACK-12PR12C-102M-A | RJ45-90-1.02mm | LED1 | LED | M-LED0603 | LTST-C190KRKT | LED2 | LED | M-LED0603 | LTST-C193KGKT-5A | LED3 | LED | M-LED0603 | LTST-C193KGKT-5A | LED4 | LED | M-LED0603 | LTST-C190YKT | LED5 | LED | M-LED0603 | LTST-C190KRKT | LED6 | LED | M-LED0603 | LTST-C190KGKT | LED7 | LED | M-LED0603 | LTST-C190KGKT | LED8 | LED | M-LED0603 | LTST-C190KGKT | LED9 | LED | M-LED0603 | LTST-C190KGKT | LED10 | LED | M-LED0603 | KPT-1608VGCK | LED11 | LED | M-LED0603 | KPT-1608VGCK | LED12 | LED-2 | LED4P-2-C | 2LED3A-40 | LED13 | LED-2 | LED4P-2-C | 2LED3A-40 | LED14 | LED | M-LED0603 | LTST-C193KGKT-5A | LED15 | LED | M-LED0603 | LTST-C190KGKT | LED16 | LED | M-LED0603 | LTST-C190KGKT | LED17 | LED | M-LED0603 | LTST-C190KGKT | LED18 | LED | M-LED0603 | LTST-C190KGKT | LP1 | CHOKE | M-CHOKE7_3X6_6B | 1.5uH/8A | LP2 | CHOKE | M-CHOKE10_5X8 | 0.23uH/61A | LP3 | CHOKE | M-CHOKE10_5X8 | 0.23uH/61A | LP4 | CHOKE | M-CHOKE10_5X8 | 0.23uH/61A | LP5 | CHOKE | M-CHOKE10_5X8 | 0.23uH/61A | LP6 | CHOKE | M-CHOKE7_3X6_6B | 1.5uH/8A | LP7 | CHOKE | M-CHOKE10_5X8 | 0.3H/61A | LP8 | CHOKE | M-CHOKE10_5X8 | 0.3H/61A | LP9 | INDUCTOR | M-CHOKE7_5X6_5 | 1.5uH/11A | LP10 | INDUCTOR | M-CHOKE7_5X6_5 | 1.5uH/11A | LP11 | CHOKE | M-CHOKE10_2X11_3 | 0.36uH/34A | LP12 | INDUCTOR | M-CHOKE7_5X6_5 | 1.5uH/11A | LP13 | INDUCTOR | M-CHOKE7_5X6_5 | 1.5uH/11A | LP14 | INDUCTOR | M-CHOKE7_5X6_5 | 1.5uH/11A | LP15 | INDUCTOR | M-CHOKE7_5X6_5 | 1.5uH/11A | LP16 | INDUCTOR | M-CHOKE7_5X6_5 | 1.5uH/11A | LP17 | CHOKE | M-CHOKE7_3X6_6B | 0.33uH/20A | LP18 | INDUCTOR | M-CHOKE7_5X6_5 | 1.5uH/11A | LP19 | INDUCTOR | M-CHOKE7_5X6_5 | 1.5uH/11A | LP21 | INDUCTOR | M-CHOKE7_5X6_5 | 1.5uH/11A | LP22 | INDUCTOR | M-CHOKE7_5X6_5 | 1.5uH/11A | M1 | UM6K1NTN | SOP6F | UM6K1NTN | M2 | MOSFET_N | FO-236 | 2N7002K-T1-E3 | M3 | MOSFET_N | FO-236 | 2N7002K-T1-E3 | M4 | UM6K1NTN | SOP6F | UM6K1NTN | M5 | MOSFET_N | FO-236 | 2N7002K-T1-E3 | M6 | MOSFET_N | FO-236 | 2N7002K-T1-E3 | M7 | MOSFET_N | FO-236 | 2N7002K-T1-E3 | M8 | UM6K1NTN | SOP6F | UM6K1NTN | M9 | UM6K1NTN | SOP6F | UM6K1NTN | M11 | UM6K1NTN | SOP6F | UM6K1NTN | MP1 | MOSFET_N-1_M | SSOP8F-1M | FDMC7696 | MP2 | MOSFET_N | FO-236 | 2N7002K-7 | P1 | CON_COMP_MH2_A | CN-CD9PR-2-277M-BM | D-SUB-M-90 | PCB1 | PCB | | PCB | RN1 | RES_8P4R | M-RP8P1 | 10K | SW1 | SW_LED-6PG | TACTSW116-D | PUSH SW_LED_GY | SW2 | SW_TACT-2PG | TACTSW116-A | DC24V/50mA | SW3 | SW_DIP-8 | M-DIPSW16P | DIP SW 2X8 | SW4 | SW_DIP-8 | M-DIPSW16P | DIP SW 2X8 | SW5 | SW_DIP-8 | M-DIPSW16P | DIP SW 2X8 | SW6 | SW_DIP-8 | M-DIPSW16P | DIP SW 2X8 | SW7 | SW_DIP-8 | M-DIPSW16P | DIP SW 2X8 | SW8 | SW_DIP-8 | M-DIPSW16P | DIP SW 2X8 | SW9 | SW_DIP-8 | M-DIPSW16P | DIP SW 2X8 | TVS13 | ESD-1_1 | M-ESD0402-A | AZ4012-01F.R7G | U1 | PLS2085ASE7V1A | BGA1292D-2M-A | PLS2085ASE7TTA | U1(1) | HEATSINK | | SOCKET | U1(2) | HEATSINK | | COOLER | U1(3) | HEATSINK | | BOTTOM PLATE | U2 | ADG836YRMZ | SSOP10I | ADG836YRMZ | U3 | NL17SZ00XV5T2G | SOP5I | NL17SZ00XV5T2G | U4 | SOCKET_DDR4_288P | CN-GH288PS-085M | DDR4 DIMM 288P | U5 | SOCKET_DDR4_288P | CN-GH288PS-085M | DDR4 DIMM 288P | U6 | SOCKET_DDR4_288P | CN-GH288PS-085M | DDR4 DIMM 288P | U7 | SOCKET_DDR4_288P | CN-GH288PS-085M | DDR4 DIMM 288P | U8 | SOCKET_DDR4_288P | CN-GH288PS-085M | DDR4 DIMM 288P | U9 | PI3PCIE3413ZHE | QFN42I-08M-A | PI3PCIE3413ZHE | U10 | PI3PCIE3413ZHE | QFN42I-08M-A | PI3PCIE3413ZHE | U11 | VBUS054B-HSF-GS08 | QFN6I-06M | VBUS054B-HSF-GS08 | U12 | MAX1558HETB+T | SSOP10I-08M-B | MAX1558HETB+T | U13 | VBUS054B-HSF-GS08 | QFN6I-06M | VBUS054B-HSF-GS08 | U14 | ICS830154AGI-08LF | SSOP8F | ICS830154AGI-08LF | U15 | PCA9547PW | SSOP24F | PCA9547PW | U16 | PCA9517ADP | SSOP8F1 | PCA9517ADP | U17 | DIODE-TVS-6 | SOP8C | SRDA3.3-6.TBT | U18 | PCA9547PW | SSOP24F | PCA9547PW | U19 | PCA9517ADP | SSOP8F1 | PCA9517ADP | U20 | AT24C02D | SOP8C | AT24C02D-SSHM-T | U21 | AT24C02 | SSOP8F | AT24C512C-XHM-T | U22 | ESD-7P | M-ESD1358-1 | PUSB3FR6Z | U23 | INA220AIDGST | SSOP10I | INA220AIDGST | U24 | ADT7481ARMZ-REEL | SSOP10I | ADT7481ARMZ-REEL | U27 | MAX14591ETA+T | SSOP8I-08M-D | MAX14591ETA+T | U28 | MAX14591ETA+T | SSOP8I-08M-D | MAX14591ETA+T | U29 | N25Q512A11GSF40F | SOP16C-265M | MT25QU512ABB8ESF-0SIT | U30 | LTC2804IGN | SSOP16G1 | LTC2804IGN-1 TRPBF | U31 | SN74CB3Q3253DGVR | SSOP16J-12M | SN74CB3Q3253DGVR | U32 | SN74CB3Q3253DGVR | SSOP16J-12M | SN74CB3Q3253DGVR | U33 | LTC2804IGN | SSOP16G1 | LTC2804IGN-1 TRPBF | U34 | SN74CB3Q3253DGVR | SSOP16J-12M | SN74CB3Q3253DGVR | U35 | SN74CB3Q3253DGVR | SSOP16J-12M | SN74CB3Q3253DGVR | U36 | ST6G3244MEBJR | BGA25J | ST6G3244MEBJR | U37 | ESD-7P | M-ESD1358-1 | PUSB3FR6Z | U38 | FXLP34L6X | SOP6I-05M | FXLP34L6X | U39 | JS28F00AM29EWHA | SSOP56I2 | S29GL01GP13TFIV10 | U43 | MT29F16G08ABACA | SSOP48I2 | MT29F16G08ABACAWP-Z | U44 | SI5341B-A03628-GM | QFP64I-09M-C | Si5341B-B03628-GM | U45 | SI52144-A01AGM | QFP24I-08M | Si52144-A01AGM | U46 | DS3232S | SOP20C | DS3232S | U47 | NC7WV07P6X | SOP6F | NC7WV07P6X | U48 | SN74LVC1G125DCKR | SOP5F | SN74LVC1G125DCKR | U49 | SN74LVC1G125DCKR | SOP5F | SN74LVC1G125DCKR | U50 | EPM1270F256C5N | BGA256D | EPM1270F256C5N | U51 | FXLP34P5X | SOP5F | FXLP34P5X | U53 | FXLP34L6X | SOP6I-05M | FXLP34L6X | U54 | FXLP34L6X | SOP6I-05M | FXLP34L6X | U55 | FXLP34L6X | SOP6I-05M | FXLP34L6X | U56 | FXLP34L6X | SOP6I-05M | FXLP34L6X | U57 | FXLP34L6X | SOP6I-05M | FXLP34L6X | U58 | CS4340_1 | BGA196D-27M | CS4340_3 | U58(1) | HEATSINK | | HEATSINK | U59 | AT24C64 | SOP8C | AT24C128C-SSHM-T | U60 | AQR405-B0-EG-Y | BGA576D-26M | AQR405-B1-EG-Y | U60(1) | HEATSINK | | HEATSINK | U61 | AT45DB041E-SSHN-B | SOP8C | AT45DB041E-SSHN2B-B | U62 | MOSFET_DUAL_N-3 | SOP6D | FDC6330L | U63 | W83793G | SSOP56G | W83793G | U64 | NVT2002DP | SSOP8F1 | NVT2002DP | U65 | DIODE-TVS-5 | SOP16C-18M | LCDA15C-8.TBT | U150 | NL17SZ00XV5T2G | SOP5I | NL17SZ00XV5T2G | U151 | NL17SZ00XV5T2G | SOP5I | NL17SZ00XV5T2G | U182 | S25FS512SAGNFI011 | SOP8C-08M-B | S25FS512SAGNFI011 | U183 | NX3DV221GM | QFP10I-05M | NX3DV221GM | U195 | FXLP34L6X | SOP6I-05M | FXLP34L6X | U196 | FXLP34L6X | SOP6I-05M | FXLP34L6X | U197 | DG9415DQ-T1-E3 | SSOP10I-11M-A | DG9415DQ-T1-E3 | U198 | MAX4906FELB+T | QFN10J-08M | MAX4906FELB+T | U199 | SN74F244 | SSOP20F2 | SN74LVC244APWR | U200 | SN74F244 | SSOP20F2 | SN74LVC244APWR | U201 | SN74F244 | SSOP20F2 | SN74LVC244APWR | U202 | FXLP34L6X | SOP6I-05M | FXLP34L6X | U203 | SN74F244 | SSOP20F2 | SN74LVC244APWR | U204 | SN74F244 | SSOP20F2 | SN74LVC244APWR | U205 | TXBN0304RSVR | QFN16J-05M | TXBN0304RSVR | U207 | 74LVC2G08DC | SSOP8I | 74LVC2G08DC | U208 | TXBN0304RSVR | QFN16J-05M | TXBN0304RSVR | U209 | NL17SZ00XV5T2G | SOP5I | NL17SZ00XV5T2G | UP1 | SN74LVC2G241 | SSOP8I | SN74LVC2G241DCU | UP2 | IR3565BMTRPBF | QFP48J-09M-A | IR3565BMTRPBF-C01 | UP3 | IR3550MTRPBF | PWMIR3550 | IR3550MTRPBF | UP4 | IR3550MTRPBF | PWMIR3550 | IR3550MTRPBF | UP5 | IR3550MTRPBF | PWMIR3550 | IR3550MTRPBF | UP6 | IR3550MTRPBF | PWMIR3550 | IR3550MTRPBF | UP7 | IR3550MTRPBF | PWMIR3550 | IR3550MTRPBF | UP8 | IR3550MTRPBF | PWMIR3550 | IR3550MTRPBF | UP9 | MC34712EP/R2_0 | QFP24I-1M-A | MC34712EP/R2 | UP10 | MC34712EP/R2_0 | QFP24I-1M-A | MC34712EP/R2 | UP11 | IR38063MTR | QFN26I-1M-A | IR38063MTRPBF-C01 | UP12 | NCP571SN10T1G | SOP5D | NCP571SN10T1G | UP13 | MC34717EP/R2_1_2 | QFN26I-1M | MC34717EP/R2 | UP14 | MC34717EP/R2_1_2 | QFN26I-1M | MC34717EP/R2 | UP15 | MC34713EP_3 | QFP24I-1M-A | MC34713EP | UP16 | MC34717EP/R2_1_2 | QFN26I-1M | MC34717EP/R2 | UP17 | MC34717EP/R2_1 | QFN26I-1M | MC34717EP/R2 | UP18 | IR3895MTRPBF | PWMIR3895 | IR3895MTRPBF | X1 | XTAL-4P-A | M-OSC3_2X2_5A | 48MHz | X2 | XTAL-2P-C | M-OSC12_7X4_7 | 25MHz | X4 | XTAL-4P | M-OSC5X7 | 25MHz | X5 | XTAL-4P | M-OSC3_2X2_5 | 48MHz |
