查看: 4338|回复: 26
[Allegro16.6以下] P2020主机板及PCB(powerpc)
发表于 2020-8-27 09:22:59 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
P2020主机板及PCB(powerpc) P2020原理及PCB.zip (9.39 MB, 下载次数: 45)
以下内容由管理员整理补充。
D1LED_LED_0603_C1-370-75078BLUELED_0603_C1
D21LED_LED_0603_C1-370-75077-LED_0603_C1LED_GREENLED_0603_C1
DDRCLKTP_COLORS_TP040-210-75685TP-105-01-09TEST_LOOP
F1FERRITE_IND_0805-180-3007-IND_0805600OHMIND_0805
G4TP_COLORS_TP040-210-75683TEST POINT BLACKTEST_LOOP
G5TP_COLORS_TP040-210-75683TEST POINT BLACKTEST_LOOP
J1HEADER_1X2_HEADER_1X2-210-76037-HDR102HDR 1X2HDR102
J2HDR_2X5_SHROUDED_HDR_2X5-210-76356-HDR205_4WCON_2X5HDR205_4W
J3DDR3_240P_CON_240_DDR3_DIMM_SKT-TMP-WF-6058-CON_240_DDR3_DIMM_SKTCON_240_DIMMCON_240_DDR3_DIMM_SKT
J4CONN_RJ45_2X1VERT_LED_RA_CONN_RJ45_2X1VERT_LED-210-76036-CON_RJ45_2X1_MAG_LEDRJ45 13X2PORTSCON_RJ45_2X1_MAG_LED
J5CONN_GIGENET_OVER_USB_CONN_RJ45LED_USBDUAL_RA-210-78077-CON20_RJ45_USBAUSB_TYPE_A + RJ45-12CON20_RJ45_USBA
J6CONN_SDC013_19P_CON19_SDCARD_28X16_SM-TMP-WF-6202-CON19_SDCARD_28X16_SMCONN CRD 19CON19_SDCARD_28X16_SM
J7PCIEXPRESS_MIDBUSPROBE_GEN_X16_PCIEXPRESS_MIDBUSPROBE_GEN_X16-TMP-WF-3720-CONN_PCIEX16_LAICONN_PCIEX16_LAICONN_PCIEX16_LAI
J8CONN_HDR_3X1_CONN_HDR_3X1_SMT-211-30029-HEADER_1X3_SMHDR1X3HEADER_1X3_SM
J9PCIEXPRESS_CONN_X16_CONN_PCIEXPRESS16-210-76047-CONN_PCIEXPRESS16PCI EXPRESS 164CONN_PCIEXPRESS16
J10PCIEXPRESS_CONN_X16_CONN_PCIEXPRESS16-210-76047-CONN_PCIEXPRESS16PCI EXPRESS 164CONN_PCIEXPRESS16
J11CONN_SATA_7PIN_VERT_SATA_VERT-211-75318-CON_7_SATA_V_SMHDR 1X7CON_7_SATA_V_SM
J12CONN_SATA_7PIN_VERT_SATA_VERT-211-75318-CON_7_SATA_V_SMHDR 1X7CON_7_SATA_V_SM
J13CONN_SATA_7PIN_VERT_SATA_VERT-211-75318-CON_7_SATA_V_SMHDR 1X7CON_7_SATA_V_SM
J14CONN_ESATA_7PIN_RA_ESATA_RA-TMP-WF-6291-CONN_7_ESATA_RA_SMHDR 1X7CONN_7_ESATA_RA_SM
J15AUDIOJACK_3PORT_3PORT-210-76104-TRIPLEDB-RAAUD_JACK_3PORTTRIPLEDB-RA
J16PCICONN_32BIT_5V_CONAMP_5V-210-75752-CONN_PCI_32B_5V_THPCI_2X60CONN_PCI_32B_5V_TH
J17HEADER_1X2_HEADER_1X2-210-76037HDR 1X2HDR102
J18HEADER_1X2_HEADER_1X2-210-76037-HDR102HDR 1X2HDR102
J19HEADER_1X2_HEADER_1X2-210-76037HDR 1X2HDR102
J20ATXPWR_2X12VERT_NOPEG_ATXPWR_2X12_VERT-TMP-WF-6398-CON_ATXPWR_2X12_ACON_2X12_PWRCON_ATXPWR_2X12_A
J21HEADER_1X3_HEADER_1X3_PTH-210-76038HDR_1X3HDR103
J22HEADER_1X3_HEADER_1X3_PTH-210-76038HDR_1X3HDR103
J23ATXPWR_12V_2X2VERT_CONN_ATX12V_2X2-211-30025-CONN_ATX12V_2X2CON_2X2CONN_ATX12V_2X2
J24CONN_BATTERY_CONN_BATTERY-801-75074-CONN_BATTERYHU2032-LFCONN_BATTERY
J25CONN_SMA_CONN_SMA-210-30138CON 1 SMACON_SMA
J26CONN_SMA_CONN_SMA-210-30138CON 1 SMACON_SMA
J27CONN_SMA_CONN_SMA-210-30138CON 1 SMACON_SMA
J28CONN_SMA_CONN_SMA-210-30138CON 1 SMACON_SMA
J29CONN_SMA_CONN_SMA-210-30138CON 1 SMACON_SMA
J30CONN_2X13_CONN_2X13_050_SMA-211-30030-CONN_2X13_050_SMACONN PLUG 26CONN_2X13_050_SMA
J31CONN_SDMEDIA_9PIN_CONN_SDMEDIA_9PIN-TMP-WF-4866CON 9CON9_SDCARD_28X31MM
J32HEADER_1X3_HEADER_1X3_PTH-210-76038-HDR103HDR_1X3HDR103
J33HEADER_1X3_HEADER_1X3_PTH-210-76038-HDR103HDR_1X3HDR103
J34CONN_170_MICRO_SMT_CON_170PIN_MICRO_TCA-211-75621CON170CON_170PIN_MICRO_TCA
J35HEADER_1X3_HEADER_1X3_PTH-210-76038-HDR103HDR_1X3HDR103
J36HEADER_1X2_HEADER_1X2-210-76037HDR 1X2HDR102
J37CONN_DUAL_DE9M_STACKED_RA_CONN_DUAL_STACKED_DB9-210-76331-DUALDB-9M_RA2XDB9DUALDB-9M_RA
J38HEADER_2X5_HEADER_2X5-210-76042HDR_2X5HDR205
J39HEADER_1X3_HEADER_1X3_PTH-210-76038HDR_1X3HDR103
J50HEADER_1X2_HEADER_1X2-210-76037HDR 1X2HDR102
L1INDUCTOR_IND_IHLP-180-75018-IND_IHLP2.2UHIND_IHLP
L2INDUCTOR_IND_IHLP-TMP-WF-6346-IND_IHLP0.68UHIND_IHLP
L3INDUCTOR_IND_IHLP-180-75111-IND_IHLP4.7UHIND_IHLP
L4INDUCTOR_IND_IHLP-TMP-WF-49491UHIND_IHLP
L5INDUCTOR_4PIN_CHOKE_0805-180-75108-CHOKE_080590OHMCHOKE_0805
MH1MOUNTING_HOLE_ATX_MTG156_PTH-TMP-WF-3725MOUNTING HOLEMTG156_PTH
MVREFTP_COLORS_TP040-210-75684TEST POINT REDTEST_LOOP
P1CONN_DUELING_BANJO_NUTBAR_CONN_DUELING_BANJO_NUTBAR-TMP-WF-3718NOTACOMPONENTCONN_DUELING_BANJO_NUTBAR
Q1IRF7821_SO8-480-3027IRF7821PBFSO_8_1P27_4X5
Q2IRF7832_SO8-480-75208IRF7832SO_8_1P27_4X5
Q4IRF7821_SO8-480-3027-SO_8_1P27_4X5IRF7821PBFSO_8_1P27_4X5
Q5IRF7832_SO8-480-75208-SO_8_1P27_4X5IRF7832SO_8_1P27_4X5
Q6IRF7821_SO8-480-3007-SO_8_1P27_4X5IRF7821PBFSO_8_1P27_4X5
Q7IRF7832_SO8-480-75208-SO_8_1P27_4X5IRF7832SO_8_1P27_4X5
Q8MMBT3904_SOT23-480-75757-SOT23MMBT3904SOT23
RTCCLKTP_COLORS_TP040-210-75685TP-105-01-09TEST_LOOP
SVD1TP_COLORS_TP040-210-75684TEST POINT REDTEST_LOOP
SVD2TP_COLORS_TP040-210-75684TEST POINT REDTEST_LOOP
SW1SW_8SPST_SW_SOM16-510-30020-SW_DIP16_8POS_SM218-8LPSTSW_DIP16_8POS_SM
SW13SW_1SPDT_SW_SM_SPDT_RA-510-30041-SW_3P_7P5X8P5_RA_SMG3B15AH-XC-ROSW_3P_7P5X8P5_RA_SM
SYSCLKTP_COLORS_TP040-210-75685TP-105-01-09TEST_LOOP
TP1TP_SMT_TPAD_030-TMP-WF-3721TPAD_030TPAD_030
TP2TP_SMT_TPAD_030-TMP-WF-3721TPAD_030TPAD_030
TP3TP_PTH_TP_PTH-TMP-WF-3719-TP_PTHTP_PTHTP_PTH
TP4TP_SMT_TPAD_030-TMP-WF-3721-TPAD_030TPAD_030TPAD_030
U1SN74LVC1G125_SC70-5P-312-75240SN74LVC1G125DCKRSC-70
U2SN74LVC1G125_SC70-5P-312-75240SN74LVC1G125DCKRSC-70
U3SN74LVC1G125_SC70-5P-312-75240-SC-70SN74LVC1G125DCKRSC-70
U4TPS72518_DDPAK5-315-75312-DDPAK5_1P7_10P61.8V/1.0ADDPAK5_1P7_10P6
U5TPS54310_HTSSOP20-312-75584-HTSSOP20TPS54310HTSSOP20
U6TPS72515_DDPAK5-315-75431-DD-PAK5_420X625TPS72515KTTRDD-PAK5_420X625
U7ZL2006_QFN36-TMP-WF-8003-QFN36ZL2006QFN36
U8TPS54310_HTSSOP20-312-75584-HTSSOP20TPS54310HTSSOP20
U9TPS72518_DDPAK5-315-75312-DDPAK5_1P7_10P61.8V/1.0ADDPAK5_1P7_10P6
U10TPS72525_DDPAK5-315-75313-DDPAK5_1P7_10P6TPS72525DDPAK5_1P7_10P6
U11TPS73701_SOT223-6-312-75981-SOT223-6TPS73701SOT223-6
U12OSC_4PIN_XTLOSC4_5X7_5-230-75794-XTLOSC4_5X7_533.333MXTLOSC4_5X7_5
U13A3P600_FGG484_BGA484_1MM-TMP-WF-7981-BGA_484_1MM_23X23A3P600-FGG484BGA_484_1MM_23X23
U14OSC_4PIN_XTLOSC4_5X7_5-230-75794-XTLOSC4_5X7_533.333MXTLOSC4_5X7_5
U15OSC_4PIN_XTLOSC4_5X7_5-230-7548214.318MHZXTLOSC4_5X7_5
U16SN74LVC1G04_SOT_5P-312-75339SN74LVC1G04DCKRE4SC-70
U17SN74LVC1G04_SOT_5P-312-75339SN74LVC1G04DCKRE4SC-70
U18ICS9FG108_TSSOP48-312-75881ICS9FG108TSSOP48
U19OSC_4PIN_XTLOSC4_5X7_5-TMP-WF-6272-XTLOSC4_5X7_5125MHZXTLOSC4_5X7_5
U20OSC_4PIN_XTLOSC4_5X7_5-TMP-WF-6271-XTLOSC4_5X7_525MHZXTLOSC4_5X7_5
U21MPC8526_TEPBGA689_1MM_31X31-TMP-WF-6297-TEPBGA689_1MM_31X31MPC8526TEPBGA689_1MM_31X31
U22SN74LVC1G04_SOT_5P-312-75339SN74LVC1G04DCKRE4SC-70
U23TPS51116_TSSOP20HT-315-75240-TSSOP20_PWRPADTPS51116TSSOP20_PWRPAD
U24VSC8244_PBGA260_19X19MM-312-75586VSC8244XHGPBGA260_19X19MM_0P16
U25SN74CBTLV1G125_SC70-5P-312-75769SN74CBTLV1G125DCKRSC70-5
U26S29GL01GP_TSOP56-342-00096-TSOP56S29GL01GP11TFI01TSOP56
U27K9NBG08U5M_TSOP48W-334-75376-TSOP48_DSPK9NBG08U5MTSOP48_DSP
U28LT1331_SSOP28-312-75272-SSOP28LT1331CG#PBFSSOP28
U29LT1331_SSOP28-312-75272-SSOP28LT1331CG#PBFSSOP28
U30SN74LVC1G04_SOT_5P-312-75339SN74LVC1G04DCKRE4SC-70
U31SN74LVC1G04_SOT_5P-312-75339SN74LVC1G04DCKRE4SC-70
U32USB3300_A_QFN32-312-75538-QFN32USB3300QFN32
U33VBUS054B_LLP75_6A-TMP-WF-7575-LLP75_6AVBUS054B-HS3-GS08LLP75_6A
U34S25FL128P9_WSON_8-TMP-WF-6281-WSON_8S25FL128P0XNFI00WSON_8
U35ECLAMP2357N_QFN16_3X3MM_1P6-312-76061-QFN16_3X3MM_1P6ECLAMP2357N.TCTQFN16_3X3MM_1P6
U36ECLAMP2357N_QFN16_3X3MM_1P6-312-76061-QFN16_3X3MM_1P6ECLAMP2357N.TCTQFN16_3X3MM_1P6
U37ECLAMP2357N_QFN16_3X3MM_1P6-312-76061-QFN16_3X3MM_1P6ECLAMP2357N.TCTQFN16_3X3MM_1P6
U38AT24C64A_SO8-334-76379-SO_8AT24C64CSO_8
U39SN74CBTLV1G125_SC70-5P-312-75769SN74CBTLV1G125DCKRSC70-5
U40SN74CBTLV1G125_SC70-5P-312-75769SN74CBTLV1G125DCKRSC70-5
U41DS3232_SO20W-TMP-WF-6280-SO20WDS3232SO20W
U42AT24C02_TSSOP8-334-75798-TSSOP8AT24C02B-TH-BTSSOP8
U43PI2PCIE2412_TQFN42_TAB-TMP-WF-4990-TQFN42_TABPI2PCIE2412TQFN42_TAB
U44PI2PCIE2412_TQFN42_TAB-TMP-WF-4990-TQFN42_TABPI2PCIE2412TQFN42_TAB
U4574LVT244_TSSOP20-312-75186-TSSOP2074LVT244APWTSSOP20
U4774ALVCH32973_LFBGA96_016PAD-312-7533574ALVCH32973ZKERBGA96_8MM
U48HEADER_RISCWATCH_HEADER_RISCWATCH-210-30058-HDR208_BCON_2X8HDR208_B
U49MPC94551_MPC94551EF-312-75580MPC94551SO8
U50ICS307_02_SO16-312-75752ICS307M-02SO16
U51ICS307_02_SO16-312-75752ICS307M-02SO16
U52MPC94551_MPC94551EF-312-75580MPC94551SO8
U53ICS8304_SO8_1P27_4X5-312-75767-SO8_1P27_4X5ICS8304AMLFSO8_1P27_4X5
U54NC7SB3157_SC70-6XP-312-30204NC7SB3157SC70-6
U55SN74LVC1G86_SOT23_5P-312-75582-SOT-23-5SN74LVC1G86SOT-23-5
U56SN74LVC1G86_SOT23_5P-312-75582-SOT-23-5SN74LVC1G86SOT-23-5
U57HEADER_2X25_05SP_HEADER_2X25_05SP_SMT-211-75181-CON_FTR-125-01-S-DHDR_2X25CON_FTR-125-01-S-D
U58NC7SB3157_SC70-6XP-312-30204-SC70-6NC7SB3157SC70-6
U59NC7SB3157_SC70-6XP-312-30204-SC70-6NC7SB3157SC70-6
U60MIC2076_1YM_SO8-312-75935-SOP8-1MIC2076-1YMSOP8-1
U61IDTQS3VH257_TSSOP16-312-75284IDTQS3VH257PATSSOP16
U62AT24C02_TSSOP8-334-75798-TSSOP8AT24C02B-TH-BTSSOP8
U64M1575SB_PBGA628-312-75628-PBGA628M1575PBGA628
U65ALC655_LQFP48-TMP-WF-7825-LQFP48ALC655LQFP48
U66SN74CBTLV1G125_SC70-5P-312-75769SN74CBTLV1G125DCKRSC70-5
U67AT24C64A_SO8-334-76379-SO_8AT24C64CSO_8
U68RCLAMP0524J_SLP16-TMP-WF-8478-SLP2710P8RCLAMP0524JSLP2710P8
VCC_DDRTP_COLORS_TP040-210-75684TEST POINT REDTEST_LOOP
VTTTP_COLORS_TP040-210-75684TEST POINT REDTEST_LOOP
Y1XTAL_13Y_XTLOSC4_6X3P5MM_SM-TMP-WF-6284-XTLOSC4_6P2X3P7MM_SM24MHZ CRYSTALXTLOSC4_6P2X3P7MM_SM
Y2CRYSTAL_4PIN_XTL4_306_SM-230-75484-XTL4_306_SM32.768KHZXTL4_306_SM
Y3CRYSTAL_2PIN_SMD_CRYSTAL_2PIN_SMD-230-75476-HC49SDLF25MHZHC49SDLF
重要提示:PCB作品文件展下载说明
PADS-181217初级班
终身成就奖原创先锋奖
发表于 2020-8-27 10:00:43 | 显示全部楼层
发表于 2020-8-27 10:16:37 | 显示全部楼层
    昨天 09:45
  • 签到天数: 119 天
    社区居民终身成就奖特殊贡献奖优秀斑竹奖
    发表于 2020-8-27 11:11:58 | 显示全部楼层
    昨天 08:18
  • 签到天数: 94 天
    发表于 2020-8-27 12:13:10 | 显示全部楼层
    昨天 18:08
  • 签到天数: 224 天
    发表于 2020-8-27 15:00:47 | 显示全部楼层
    终身成就奖社区居民优秀斑竹奖
    发表于 2020-8-27 19:40:01 | 显示全部楼层
    谢谢分享P2020主机板及PCB
  • 签到天数: 103 天
    7万
    发表于 2020-8-28 05:50:47 | 显示全部楼层
    昨天 08:05
  • 签到天数: 237 天
    发表于 2020-8-28 08:19:21 | 显示全部楼层
    发表于 2020-8-28 08:24:29 | 显示全部楼层
