重要提示:PCB作品文件展下载说明
Name | Part Type | PCB Decal | Value | C1728 | 0.1UF/25V_+80%-20%_CC_S0603 | C0402 | 0.1uF | C1729 | CAP/1210_1206 | C0603 | 10uF | C1730 | CAP/1210_1206 | C0603 | 10uF | C1731 | CAP/1210_1206 | C0603 | 10uF | CT18 | CAPACITOR_POL_2 | SMD-CT_3216 | 22uF 6.3V | CT20 | CAPACITOR_POL | CE_AX_6R3 | 47uF/35V | D7 | LED/0603_1 | LED_2PIN_2R54 | LED_GREEN | D11 | DIODE_SK34A | D/SMD/P3.325/SOD-123/1N4148 | 1N4148/NL | D12 | DIODE_SCHOTTKY_2 | SOD-123A | PFM26A | D14 | 40CPQ060/TO_1 | SOT-23 | [RTC]BAT54C:NC | F1 | FUSE_0 | R1812 | PolySw_xV6W | J1 | WIFI_MODULE | WIFI_5CMX3CM | WIFI_MODULE | J2 | WIFI_MODULE | WIFI_5CMX3CM | WIFI_MODULE | J3 | WIFI_MODULE | WIFI_5CMX3CM | WIFI_MODULE NC | J6 | CON3 | DC-005A | DC JACK | J45 | 4_HEADER | SIP_4PIN_1R27 | 4 HEADER | J505 | BATTERY_SOCKET | CR2032_S | [RTC]Battery Socket:NC | J506 | 4_HEADER | SIP_4PIN_2R0 | 4 HEADER | J507 | 4_HEADER | SIP_4PIN_2R0 | 4 HEADER | J508 | WAFER_6PIN_SOCKET | SMD_JF6_S_1R25 | WAFER_6PIN_SOCKET | J509 | CON16 | SIP16_2R0 | CON16 | J510 | 4_HEADER | WAFFER_4PIN_2R54_180DEG | Waffer 2.54mm 4Pin | J511 | CONN_SOCKET_6 | SIP6_1R27 | CONN SOCKET 6 | J512 | CONN_RCPT_5X2 | DIP5X2_2R54 | CONN RCPT 5x2 | L27 | INDUCTOR | PS8D38 | 22uH I>2.0A | L360 | INDUCTOR_2 | L0603 | 0 | L361 | INDUCTOR_2 | L0402 | Bead,0402 | L729 | INDUCTOR_1 | SLPS4018 | 1.8uH 2.5A | L730 | INDUCTOR_1 | SLPS4018 | 1.8uH 2.5A | L732 | INDUCTOR_1 | SLPS4018 | [5V_TO_1V0]2.2uH 1.5A:NC | P1202 | PHJ8X4_2 | PHJ8X4_N | PHJ8X4 | RC1 | CAP/0603 | C0805 | 10uF | S3 | SW_PUSHBUTTON_0 | TS45HE | TS45HE | S4 | SW_PUSHBUTTON_0 | TS45HE | TS45HE | T300 | XMER_2P_G2PM109N | TRANSFORMER/48P/SMD/GS5014LF | GS5014 | T301 | XMER_2P_G2PM109N | TRANSFORMER/48P/SMD/GS5014LF | GS5014 | T302 | FT20-252B_2 | TRANSFORMER/24P/SMD/HN2429CG | FT20-252B | TP18 | 7SDCN-B0-1X14-SD_CARD_SLOT_1 | CON10P/SMD/R/F/7SDCN-B0-1X14 | 7SDCN-B0-1X14-SD Card Slot | U6 | MT7621 | MT7621/LFBGA346/P0.65/B0.3/11.7X13.6 | MT7621 | U8 | SPIFLASH-WINBOND25P16_1 | SOP8/SMD/P1.27/MX25L3206E | MX25L6406EM2I | U17 | LDO_RT9164A-SOT223_1 | SOT223-3/SMD/P2.3/AX1007 | ZTP1117SA | U19 | IRLML5103_1 | SOT23-5 | XC6210B122MR | U23 | XTAL_3.2X2.5 | XTAL-SMD/3.2X2.5 | [2.4G_CLK_OUT]NC:40MHz | U24 | XTAL_3.2X2.5 | XTAL-SMD/3.2X2.5 | 25MHz/NI | U83 | IC_DET_SOT-143/SC-82AB | SOT-143/SMD/G693 | G693L_R3132Q/NL | U86 | RT9715AGBG_6 | SOT23-6 | SY8009BABC | U400 | IC_DDR3_X16_FBGA-96 | FBGA96/SMD/P0.8/MICRON | DDR3-128Mx16 | U404 | HEADER_4X2_0 | SOP-8 | AT88SC0104 | U428 | PM1066_0 | SO-8-EPAD | EUP3484 | U431 | CMFILTER | ACM4520 | CMFilter | U1207 | RT9715AGBG_6 | SOT23-6 | SY8009BABC | U1211 | RT9293B_0 | SOT23-5 | [5V_TO_1V0]RT8059GJ5:NC | U1212 | MCU_8PIN | SOP-8 | [EXT_WDT]MCU_8PIN:NC | U1213 | HYM8563 | SOP-8 | [RTC]HYM8563:NC | U1217 | IRLML5103_1 | SOT23-5 | XC6210B482MR | U1218 | IRLML5103_1 | SOT23-5 | XC6210B482MR | Y1 | CRYSTAL_0 | JU-26 | [RTC]32.768KHz 20ppM:NC |
重要提示:PCB作品文件展下载说明
