REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME | BAT1 | MS621FEL11E_2P | MS412FEFFL26E | MS621FEL11E_2P | CE2 | CAPE8X11_5 | 220uF25V8*11.5 | CAPE8X11_5 | CE4 | CAPE_6_3X11_2_2_5 | 220uF16V6.3*11.2 | CAPE_6_3X11_2_2_5 | CE5 | CAPE8X11_5 | 470uF16V8*11.5 | CAPE8X11_5 | CE6 | CAPE8X11_5 | 470uF16V8*11.5 | CAPE8X11_5 | CN1 | SIP-6P-1_25MM | | SIP-6P-1_25MM | CN3 | SATA7_SM_H | SATA7P | SATA7_SM_H | CON3 | LC-04A | LC-04A | LC-04A | D10 | D1206 | LL4148 | D1206 | D14 | SK34_D_LL34 | SS52 | SK34_D_LL34 | D15 | DIO_SMB | SS54 | DIO_SMB | ESD7 | C0603 | NC | C0603 | FB10 | L0603 | CBW160808U310 | L0603 | J1 | DIP2X30_2_54 | DIP2X30_2.54 | DIP2X30_2_54 | J6 | CON-4PIN-1_25-SMT | T1.25B-4PWB/AB | CON-4PIN-1_25-SMT | J7 | SIP-2P_2_0MM | PH-2AX2.0MM | SIP-2P_2_0MM | J9 | RJ45_1USBA | RJ45+1USB | RJ45_1USBA | JP1 | SIP_2P_200 | 1X2P_2.0M | SIP_2P_200 | L1 | LCH895 | PIN0810C-100MB | LCH895 | L2 | LCH895 | PIN0810C-100MB | LCH895 | L3 | LCH895 | PIN0810C-100MB | LCH895 | L11 | L-10X10MM | MS104R-4R7NT | L-10X10MM | L14 | L-1206 | NC | L-1206 | L16 | L-1206 | NC | L-1206 | LED1 | LED0603 | LED | LED0603 | LED2 | LED | LED3%Green | LED | Q6 | SOT23-P | IRLML6402 | SOT23-P | Q8 | SOT23 | LMBT3904LT1G | SOT23 | Q9 | SOT23 | LMBT3904LT1G | SOT23 | Q10 | SOT23-P | IRLML6402 | SOT23-P | Q11 | SOT23 | LMBT3904LT1G | SOT23 | Q12 | SOT23 | LMBT3904LT1G | SOT23 | RP9 | RP_4_0402 | RTA02-4D510J | RP_4_0402 | SW1 | SW_BUTTON | 6X6X4.3H | SW_BUTTON | SW2 | SW_BUTTON | 6X6X4.3H | SW_BUTTON | TP1 | SIP_1P_SMD | 1V2 | SIP_1P_SMD | TP2 | SIP_1P | NC | SIP_1P | TP3 | SIP_1P_SMD | TP_SMD | SIP_1P_SMD | TP4 | SIP_1P_SMD_OVAL | TP_SMD | SIP_1P_SMD_OVAL | U1 | QFP216_040_EPAD-72X72 | GM8283_EPAD-LQFP216 | QFP216_040_EPAD-72X72 | U2 | SOIC8N | MP2380DN | SOIC8N | U3 | SOIC8_208 | W25Q128FVSIG | SOIC8_208 | U4 | DDR3_FBGA_X16_9X15P5 | H5TQ4G63AFR-H9C | DDR3_FBGA_X16_9X15P5 | U6 | SOT223 | AMS1117-1.2/SOT223 | SOT223 | U7 | 14L_SOIC_150_MIL | CS4354-CSZR | 14L_SOIC_150_MIL | U8 | TQFN32_040_EPAD | IP101GR | TQFN32_040_EPAD | U9 | SOP16_300 | TS8121C_SOP16 | SOP16_300 | U10 | SOIC8_150 | DS1307 | SOIC8_150 | U11 | SOT223 | AMS1117-5.0 | SOT223 | U12 | SOP8_EPAD | MP2307DN/SOIC8N | SOP8_EPAD | U13 | SOP8_EPAD | MP1482DS | SOP8_EPAD | U14 | SOT23G691L293T73U | G691L293T73U | SOT23G691L293T73U | U16 | SOP8_EPAD | MP1484EN | SOP8_EPAD | U56 | SOT223 | AMS1117-ADJ/SOT223 | SOT223 | Y1 | XTAL_UP | 49S 12MHz 20PF 10PPM | XTAL_UP | Y2 | XTAL_0P7L | 32.768KHz 12.5PF20PPM | XTAL_0P7L |
