#include <linux/module.h>
#include <linux/kernel.h>
#include <linux/errno.h>
#include <linux/string.h>
#include <linux/mm.h>
#include <linux/slab.h>
#include <linux/delay.h>
#include <linux/fb.h>
#include <linux/init.h>
#include <linux/dma-mapping.h>
#include <linux/interrupt.h>
#include <linux/workqueue.h>
#include <linux/wait.h>
#include <linux/platform_device.h>
#include <linux/clk.h>
#include <asm/io.h>
#include <asm/uaccess.h>
#include <asm/div64.h>
#include <asm/mach/map.h>
#include <asm/arch/regs-lcd.h>
#include <asm/arch/regs-gpio.h>
#include <asm/arch/fb.h>
#include "./S3C2440.h"
#define DEVICE_NAME "LCD"
static struct lcd_sturt* LCD;
static struct gpio_sturt* GPIO;
static unsigned char* frambuffer;
static int major;
static struct class *lcd_class;
static struct class_device lcd_class_devs;
static struct file_operations lcd_fops = {
.owner = THIS_MODULE, /* 这是一个宏,推向编译模块时自动创建的__this_module变量 */
.open = s3c24xx_leds_open,
.read = s3c24xx_leds_read,
.write = s3c24xx_leds_write,
static int lcd_init(void)
major = register_chrdev(0, DEVICE_NAME, &lcd_fops); //注册
lcd_class = class_create(THIS_MODULE, DEVICE_NAME ); //设备对象
lcd_class_devs = class_device_create(lcd_class, NULL, MKDEV(major, 0), NULL, DEVICE_NAME ); //创建设备文件
GPIO = (struct gpio_sturt*)ioremap( GPIO_BASE, sizeof(struct gpio_sturt) ); //寄存器重映射
LCD = (struct lcd_sturt*)ioremap( LCD_BASE, sizeof(struct lcd_sturt) ); //寄存器重映射
/* 3. 硬件相关的操作 */
/* 3.1 配置GPIO用于LCD */
GPIO->GPCCON = 0xaaaaaaaa; /* GPIO管脚用于VD[7:0],LCDVF[2:0],VM,VFRAME,VLINE,VCLK,LEND */
GPIO->GPDCON = 0xaaaaaaaa; /* GPIO管脚用于VD[23:8] */
GPIO->GPBCON &= ~(3); /* GPB0设置为输出引脚 */
GPIO->GPBCON |= 1;
GPIO->GPBDAT |= 1; /* 输出高电平, 使能背光 */
GPIO->GPGCON |= (3<<8); /* GPG4用作LCD_PWREN */
/* 3.2 根据LCD手册设置LCD控制器, 比如VCLK的频率等 */
/* bit[17:8]: VCLK = HCLK / [(CLKVAL+1) x 2], LCD手册P14
* 10MHz(100ns) = 100MHz / [(CLKVAL+1) x 2]
* CLKVAL = 4
* bit[6:5]: 0b11, TFT LCD
* bit[4:1]: 0b1100, 16 bpp for TFT
* bit[0] : 0 = Disable the video output and the LCD control signal.
LCD->LCDCON1 = (4<<8) | (3<<5) | (0x0c<<1);
#if 1
/* 垂直方向的时间参数
* bit[31:24]: VBPD, VSYNC之后再过多长时间才能发出第1行数据
* LCD手册 T0-T2-T1=4
* VBPD=3
* bit[23:14]: 多少行, 320, 所以LINEVAL=320-1=319
* bit[13:6] : VFPD, 发出最后一行数据之后,再过多长时间才发出VSYNC
* LCD手册T2-T5=322-320=2, 所以VFPD=2-1=1
* bit[5:0] : VSPW, VSYNC信号的脉冲宽度, LCD手册T1=1, 所以VSPW=1-1=0
LCD->LCDCON2 = (1<<24) | (271<<14) | (1<<6) | (9);
/* 水平方向的时间参数
* bit[25:19]: HBPD, VSYNC之后再过多长时间才能发出第1行数据
* LCD手册 T6-T7-T8=17
* HBPD=16
* bit[18:8]: 多少列, 240, 所以HOZVAL=240-1=239
* bit[7:0] : HFPD, 发出最后一行里最后一个象素数据之后,再过多长时间才发出HSYNC
* LCD手册T8-T11=251-240=11, 所以HFPD=11-1=10
LCD->LCDCON3 = (1<<19) | (479<<8) | (1);
/* 水平方向的同步信号
* bit[7:0] : HSPW, HSYNC信号的脉冲宽度, LCD手册T7=5, 所以HSPW=5-1=4
LCD->LCDCON4 = 40;
#else
LCD->LCDCON2 = S3C2410_LCDCON2_VBPD(5) | \
S3C2410_LCDCON2_LINEVAL(319) | \
S3C2410_LCDCON2_VFPD(3) | \
S3C2410_LCDCON2_VSPW(1);
LCD->LCDCON3 = S3C2410_LCDCON3_HBPD(10) | \
S3C2410_LCDCON3_HOZVAL(239) | \
S3C2410_LCDCON3_HFPD(1);
LCD->LCDCON4 = S3C2410_LCDCON4_MVAL(13) | \
S3C2410_LCDCON4_HSPW(0);
#endif
/* 信号的极性
* bit[11]: 1=565 format
* bit[10]: 0 = The video data is fetched at VCLK falling edge
* bit[9] : 1 = HSYNC信号要反转,即低电平有效
* bit[8] : 1 = VSYNC信号要反转,即低电平有效
* bit[6] : 0 = VDEN不用反转
* bit[3] : 0 = PWREN输出0
* bit[1] : 0 = BSWP
* bit[0] : 1 = HWSWP 2440手册P413
LCD->LCDCON5 = (1<<11) | (0<<10) | (1<<9) | (1<<8) | (1<<0);
/* 3.3 分配显存(framebuffer), 并把地址告诉LCD控制器 */
frambuffer = kmalloc( 1024*1024*4,)
LCD->LCDSADDR1 = (s3c_lcd->fix.smem_start >> 1) & ~(3<<30);
LCD->LCDSADDR2 = ((s3c_lcd->fix.smem_start + s3c_lcd->fix.smem_len) >> 1) & 0x1fffff;
LCD->LCDSADDR3 = (480*16/16); /* 一行的长度(单位: 2字节) */
//s3c_lcd->fix.smem_start = xxx; /* 显存的物理地址 */
/* 启动LCD */
LCD->LCDCON1 |= (1<<0); /* 使能LCD控制器 */
LCD->LCDCON5 |= (1<<3); /* 使能LCD本身 */
return 0;
static void lcd_exit(void)
unregister_chrdev(major, DEVICE_NAME);
class_device_unregister(lcd_class_devs);
class_destroy(lcd_class);
iounmap(LCD);
iounmap(GPIO);
module_init(lcd_init);
module_exit(lcd_exit);
/* 描述驱动程序的一些信息,不是必须的 */
MODULE_AUTHOR("db-Mark");
MODULE_VERSION("0.1.0");
MODULE_DESCRIPTION("LCD Driver");
MODULE_LICENSE("GPL"); |
