• 芯片制造中的阻挡层沉积技术介绍
  • 接地搭接电缆布局屏蔽!!!
  • 北美液冷生态解码:超微spuermicro,24年营
  • SK海力士全球首发HBM4-16层堆叠、2.0TB/s
  • 2纳米Nanosheet技术及其以后的选择性层减薄
STM32 SPI FLASH W25Q64
查看758 | 回复7 | 2020-11-24 07:53:15 | 显示全部楼层 |阅读模式
#include "flash.h"
unsigned short SPI_FLASH_TYPE=W25Q64;//默认就是25Q64
//4Kbytes为一个Sector
//16个扇区为1个Block
//W25X16
//容量为2M字节,共有32个Block,512个Sector
//初始化SPI FLASH的IO口
void delay_us1(unsigned int i)
    unsigned char j=0xff;
    while(i--)
        while(j--);
        j=0xff;
//unsigned char SPI1Buffer[1024]={0};
//void SPI_Flash_Init1(     unsigned int SPI1_DR_Addr,
//                      unsigned int SPI1_RX_Buff ,unsigned int SPI1_ReciveBufferSize,
//                      unsigned int SPI1_TX_Buff ,unsigned int SPI1_SendBufferSize )
//  DMA_InitTypeDef DMA_InitStructure;
//    /* DMA1 Channel2 (triggered by SPI1 Rx event) Config */
//  DMA_DeInit(DMA1_Channel2);
//  DMA_InitStructure.DMA_PeripheralBaseAddr = SPI1_DR_Addr;                          //?? SPI1 ????(0x4001300C) ??(????)
//  DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)SPI1_RX_Buff;                    //?? SRAM ????(????)
//  DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;                                //???? ??-??
//  DMA_InitStructure.DMA_BufferSize = SPI1_ReciveBufferSize;                         //?? SPI1 ????
//  DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
//  DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
//  DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;
//  DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte;
//  DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;
//  DMA_InitStructure.DMA_Priority = DMA_Priority_VeryHigh;
//  DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
//  DMA_Init(DMA1_Channel2, &DMA_InitStructure);
//  DMA_ITConfig(DMA1_Channel2, DMA_IT_TC, ENABLE);
//  /* Enable SPI1 DMA RX request */
//  SPI1->CR2 |= 1<<0;        //?????DMA??
//  DMA_Cmd(DMA1_Channel2, ENABLE);
//  /* DMA1 Channel3 (triggered by SPI1 Tx event) Config */
//  DMA_DeInit(DMA1_Channel3);
//  DMA_InitStructure.DMA_PeripheralBaseAddr = SPI1_DR_Addr;                          //??  ????(0x4001300C) ??(???)
//  DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)SPI1_TX_Buff;                    //?? SRAM ????(???)
//  DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralDST;                                //???? ??-??
//  DMA_InitStructure.DMA_BufferSize = SPI1_SendBufferSize;                           //?? SPI1 ????
//  DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;                  //??????(??)
//  DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;                           //??????(??)
//  DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;           //??????(??)
//  DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte;                   //??????(??)
//  DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;                                     //????,???????,?????
//  DMA_InitStructure.DMA_Priority = DMA_Priority_VeryHigh;                           //????-?(??)
//  DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;                                      //?????????
//  DMA_Init(DMA1_Channel3, &DMA_InitStructure);
//  DMA_ITConfig(DMA1_Channel3, DMA_IT_TC, ENABLE);                                   //?? DMA1_Channel3 ??????
//  DMA_ITConfig(DMA1_Channel3, DMA_IT_TE, ENABLE);                                   //?? DMA1_Channel3 ??????
//  /* Enable SPI1 DMA TX request */
//  SPI1->CR2 |= 1<<1;        //?????DMA??
//  DMA_Cmd(DMA1_Channel3, DISABLE);                                                  //?? DMA ?? DMA1_Channel3
//void SPI1_Recive( unsigned int SPI1_DR_Addr, unsigned char *buff, unsigned int len )
//    DMA1_Channel2->CCR &= ~( 1 << 0 );          //??DMA??2
//    DMA1_Channel2->CPAR = SPI1_DR_Addr; //????
//    DMA1_Channel2->CMAR = (uint32_t)buff; //mem??
//    DMA1_Channel2->CNDTR = len ; //????
//    DMA1_Channel2->CCR    =   (0 << 14) | // ??????????
//                          (2 << 12) | // ??????
//                          (0 << 11) | // ???????8bit
//                          (0 << 10) | // ???????8bit
//                          (0 <<  9) | // ??????8bit
//                          (0 <<  8) | // ??????8bit
//                          (1 <<  7) | // ?????????
//                          (0 <<  6) | // ????????(??)
//                          (0 <<  5) | // ?????
//                          (0 <<  4) | // ???? ??-??
//                          (0 <<  3) | // ????????
//                          (0 <<  2) | // ???????
//                          (1 <<  1) | // ????????
//                          (1 <<  0) ; // ????
//void SPI1_Send( unsigned int SPI1_DR_Addr,unsigned char *buff, unsigned int len )
//  DMA1_Channel3->CPAR = SPI1_DR_Addr; //????
//  DMA1_Channel3->CMAR = (u32) buff; //mem??
//  DMA1_Channel3->CNDTR = len ; //????
//  DMA1_Channel3->CCR  =   (0 << 14) | // ??????????
//                          (1 <<  4) | // ?????
//                          (1 <<  3) | // ????????
void SPI_Flash_Init(void)
    //char tem[1024]={0};
    GPIO_InitTypeDef GPIO_InitStructure;
    RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOA, ENABLE );
    GPIO_InitStructure.GPIO_Pin = /*GPIO_Pin_2|GPIO_Pin_3|*/GPIO_Pin_4;  //SPI CS
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;  //复用推挽输出
    GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
    GPIO_Init(GPIOA, &GPIO_InitStructure);
    GPIO_SetBits(GPIOA,/*GPIO_Pin_2|GPIO_Pin_3|*/GPIO_Pin_4);
    SPI1_Init();           //初始化SPI
    SPI1_SetSpeed(SPI_BaudRatePrescaler_2); //设置为18M时钟,高速模式
    SPI_FLASH_TYPE=SPI_Flash_ReadID();//读取FLASH ID.
    //SPI_Flash_Read( (unsigned char*)tem,0,1024 );             //从倒数第100个地址处开始,读出SIZE个字节
//读取SPI_FLASH的状态寄存器
//BIT7  6   5   4   3   2   1   0
//SPR   RV  TB BP2 BP1 BP0 WEL BUSY
//SPR:默认0,状态寄存器保护位,配合WP使用
//TB,BP2,BP1,BP0:FLASH区域写保护设置
//WEL:写使能锁定
//BUSY:忙标记位(1,忙;0,空闲)
//默认:0x00
unsigned char SPI_Flash_ReadSR(void)
    unsigned char byte=0;
    SPI_FLASH_CS=0;                            //使能器件
    SPI1_ReadWriteByte(W25X_ReadStatusReg);    //发送读取状态寄存器命令
    byte=SPI1_ReadWriteByte(0Xff);             //读取一个字节
    SPI_FLASH_CS=1;                            //取消片选
    return byte;
//写SPI_FLASH状态寄存器
//只有SPR,TB,BP2,BP1,BP0(bit 7,5,4,3,2)可以写!!!
void SPI_FLASH_Write_SR(unsigned char sr)
    SPI1_ReadWriteByte(W25X_WriteStatusReg);   //发送写取状态寄存器命令
    SPI1_ReadWriteByte(sr);               //写入一个字节
//SPI_FLASH写使能
//将WEL置位
void SPI_FLASH_Write_Enable(void)
    SPI1_ReadWriteByte(W25X_WriteEnable);      //发送写使能
//SPI_FLASH写禁止
//将WEL清零
void SPI_FLASH_Write_Disable(void)
    SPI1_ReadWriteByte(W25X_WriteDisable);     //发送写禁止指令
//读取芯片ID W25X16的ID:0XEF14
unsigned short SPI_Flash_ReadID(void)
    unsigned short Temp = 0;
    SPI_FLASH_CS=0;
    SPI1_ReadWriteByte(0x90);//发送读取ID命令
    SPI1_ReadWriteByte(0x00);
    Temp|=SPI1_ReadWriteByte(0xFF)<<8;
    Temp|=SPI1_ReadWriteByte(0xFF);
    SPI_FLASH_CS=1;
    return Temp;
//读取SPI FLASH
//在指定地址开始读取指定长度的数据
//pBuffer:数据存储区
//ReadAddr:开始读取的地址(24bit)
//NumByteToRead:要读取的字节数(最大65535)
void SPI_Flash_Read(unsigned char * pBuffer,unsigned int ReadAddr,unsigned short NumByteToRead)
    unsigned short i;
    SPI1_ReadWriteByte(W25X_ReadData);         //发送读取命令
    SPI1_ReadWriteByte((unsigned char)((ReadAddr)>>16));  //发送24bit地址
    SPI1_ReadWriteByte((unsigned char)((ReadAddr)>>8));
    SPI1_ReadWriteByte((unsigned char)ReadAddr);
    for(i=0;i<NumByteToRead;i++)
//        pBuffer=SPI1_ReadWriteByte(0XFF);   //循环读数
//      while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_TXE) == RESET); //检查指定的SPI标志位设置与否:发送缓存空标志位
//      SPI_I2S_SendData(SPI1,0xff);                                    //通过外设SPIx发送一个数据
//      while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_RXNE) == RESET);//检查指定的SPI标志位设置与否:接受缓存非空标志位
//      pBuffer = SPI_I2S_ReceiveData(SPI1);                         //返回通过SPIx最近接收的数据
        while( (SPI1->SR&SPI_I2S_FLAG_TXE)==RESET );
        SPI1->DR = 0xFF;
        while( (SPI1->SR&SPI_I2S_FLAG_RXNE)==RESET );
        pBuffer = SPI1->DR;
//SPI在一页(0~65535)内写入少于256个字节的数据
//在指定地址开始写入最大256字节的数据
//pBuffer:数据存储区
//WriteAddr:开始写入的地址(24bit)
//NumByteToWrite:要写入的字节数(最大256),该数不应该超过该页的剩余字节数!!!
void SPI_Flash_Write_Page(unsigned char* pBuffer,unsigned int WriteAddr,unsigned short NumByteToWrite)
    unsigned short i;
    SPI_FLASH_Write_Enable();                  //SET WEL
    SPI1_ReadWriteByte(W25X_PageProgram);      //发送写页命令
    SPI1_ReadWriteByte((unsigned char)((WriteAddr)>>16)); //发送24bit地址
    SPI1_ReadWriteByte((unsigned char)((WriteAddr)>>8));
    SPI1_ReadWriteByte((unsigned char)WriteAddr);
    for(i=0;i<NumByteToWrite;i++)SPI1_ReadWriteByte(pBuffer);//循环写数
    SPI_Flash_Wait_Busy();                     //等待写入结束
//无检验写SPI FLASH
//必须确保所写的地址范围内的数据全部为0XFF,否则在非0XFF处写入的数据将失败!
//具有自动换页功能
//在指定地址开始写入指定长度的数据,但是要确保地址不越界!
//pBuffer:数据存储区
//NumByteToWrite:要写入的字节数(最大65535)
//CHECK OK
void SPI_Flash_Write_NoCheck(unsigned char* pBuffer,u32 WriteAddr,unsigned short NumByteToWrite)
    unsigned short pageremain;
    pageremain=256-WriteAddr%256; //单页剩余的字节数
    if(NumByteToWrite<=pageremain)pageremain=NumByteToWrite;//不大于256个字节
    while(1)
        SPI_Flash_Write_Page(pBuffer,WriteAddr,pageremain);
        if(NumByteToWrite==pageremain)break;//写入结束了
        else //NumByteToWrite>pageremain
            pBuffer+=pageremain;
            WriteAddr+=pageremain;
            NumByteToWrite-=pageremain;           //减去已经写入了的字节数
            if(NumByteToWrite>256)pageremain=256; //一次可以写入256个字节
            else pageremain=NumByteToWrite;       //不够256个字节了
//写SPI FLASH
//在指定地址开始写入指定长度的数据
//该函数带擦除操作!
//pBuffer:数据存储区
unsigned char SPI_FLASH_BUF[4096];
void SPI_Flash_Write(unsigned char* pBuffer,u32 WriteAddr,unsigned short NumByteToWrite)
    unsigned int secpos;
    unsigned short secoff;
    unsigned short secremain;
    unsigned short i;
    secpos=WriteAddr/4096;//扇区地址 0~511 for w25x16
    secoff=WriteAddr%4096;//在扇区内的偏移
    secremain=4096-secoff;//扇区剩余空间大小
    if(NumByteToWrite<=secremain)secremain=NumByteToWrite;//不大于4096个字节
    while(1)
        SPI_Flash_Read(SPI_FLASH_BUF,secpos*4096,4096);//读出整个扇区的内容
        for(i=0;i<secremain;i++)//校验数据
            if(SPI_FLASH_BUF[secoff+i]!=0XFF)break;//需要擦除
        if(i<secremain)//需要擦除
            SPI_Flash_Erase_Sector(secpos);//擦除这个扇区
            for(i=0;i<secremain;i++)       //复制
                SPI_FLASH_BUF[i+secoff]=pBuffer;
            SPI_Flash_Write_NoCheck(SPI_FLASH_BUF,secpos*4096,4096);//写入整个扇区
        }else SPI_Flash_Write_NoCheck(pBuffer,WriteAddr,secremain);//写已经擦除了的,直接写入扇区剩余区间.
        if(NumByteToWrite==secremain)break;//写入结束了
        else//写入未结束
            secpos++;//扇区地址增1
            secoff=0;//偏移位置为0
            pBuffer+=secremain;  //指针偏移
            WriteAddr+=secremain;//写地址偏移
            NumByteToWrite-=secremain;              //字节数递减
            if(NumByteToWrite>4096)secremain=4096;  //下一个扇区还是写不完
            else secremain=NumByteToWrite;          //下一个扇区可以写完了
//擦除整个芯片
//整片擦除时间:
//W25X16:25s
//W25X32:40s
//W25X64:40s
//等待时间超长...
void SPI_Flash_Erase_Chip(void)
    SPI1_ReadWriteByte(W25X_ChipErase);        //发送片擦除命令
    SPI_Flash_Wait_Busy();                     //等待芯片擦除结束
//擦除一个扇区
//Dst_Addr:扇区地址 0~511 for w25x16
//擦除一个山区的最少时间:150ms
void SPI_Flash_Erase_Sector(unsigned int Dst_Addr)
    Dst_Addr*=4096;
    SPI1_ReadWriteByte(W25X_SectorErase);      //发送扇区擦除指令
    SPI1_ReadWriteByte((unsigned char)((Dst_Addr)>>16));  //发送24bit地址
    SPI1_ReadWriteByte((unsigned char)((Dst_Addr)>>8));
    SPI1_ReadWriteByte((unsigned char)  Dst_Addr);
    SPI_Flash_Wait_Busy();                     //等待擦除完成
//等待空闲
void SPI_Flash_Wait_Busy(void)
    while ((SPI_Flash_ReadSR()&0x01)==0x01);   // 等待BUSY位清空
//进入掉电模式
void SPI_Flash_PowerDown1(void)
    SPI1_ReadWriteByte(W25X_PowerDown);        //发送掉电命令
    delay_us1(3);                               //等待TPD
//唤醒
void SPI_Flash_WAKEUP1(void)
    SPI1_ReadWriteByte(W25X_ReleasePowerDown);   //  send W25X_PowerDown command 0xAB
    delay_us1(3);                               //等待TRES1
lqsgg | 2020-11-24 07:56:20 | 显示全部楼层
bidinghong | 2020-11-24 08:17:55 | 显示全部楼层
郑先生 | 2020-11-24 08:18:56 | 显示全部楼层
小小路人甲 | 2020-11-24 08:26:51 | 显示全部楼层
1123581321 | 2020-11-24 08:33:08 | 显示全部楼层
wangyitu | 2020-11-24 08:49:46 | 显示全部楼层
不系统学习这个是不是很难看懂~
清心如水 | 2020-11-24 08:52:38 | 显示全部楼层
