* 文件名 :I2C.c
* 描述 :IIC外设EEPROM(AT24C512)应用函数库
* 硬件连接: ---------------------------
* | PB6 - I2C1_SCL |
* | PB7 - I2C1_SDA |
* 说明 :模拟IIC
#include "drive.h"
#include "system.h"
#include "app.h"
#include "w5500_conf.h"
#define ATMEL_EEPROM
//#define CYPRESS_FRAM
//#define CONFIG_HAVE_FM24V05
#define CONFIG_HAVE_FM24V10
#define ADDR_24CXX 0xA0
#define SCLH GPIOB->BSRR = GPIO_Pin_6
#define SCLL GPIOB->BRR = GPIO_Pin_6
#define SDAH GPIOB->BSRR = GPIO_Pin_7
#define SDAL GPIOB->BRR = GPIO_Pin_7
#define SCLread GPIOB->IDR & GPIO_Pin_6
#define SDAread GPIOB->IDR & GPIO_Pin_7
void InitI2C(void)
GPIO_InitTypeDef GPIO_InitStructure;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6|GPIO_Pin_7;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_OD;
GPIO_Init(GPIOB, &GPIO_InitStructure);
bool I2C_Start(void)
SDAH;
SCLH;
DelayUs(5);
if(!SDAread)return false; //SDA线为低电平则总线忙,退出
SDAL;
DelayUs(5);
if(SDAread) return false; //SDA线为高电平则总线出错,退出
SDAL;
DelayUs(5);
return true;
void I2C_Stop(void)
SCLL;
DelayUs(5);
SDAL;
DelayUs(5);
SCLH;
DelayUs(5);
SDAH;
DelayUs(5);
void I2C_Ack(void)
SCLL;
DelayUs(5);
SDAL;
DelayUs(5);
SCLH;
DelayUs(5);
SCLL;
DelayUs(5);
void I2C_NoAck(void)
SCLL;
DelayUs(5);
SDAH;
DelayUs(5);
SCLH;
DelayUs(5);
SCLL;
DelayUs(5);
bool I2C_WaitAck(void) //返回为:=1有ACK,=0无ACK
SCLL;
DelayUs(5);
SDAH;
DelayUs(5);
SCLH;
DelayUs(5);
if(SDAread)
SCLL;
return false;
SCLL;
return true;
void I2C_SendByte(byte SendByte) //数据从高位到低位//
byte i=8;
while(i--)
SCLL;
DelayUs(5);
if(SendByte&0x80)
SDAH;
else
SDAL;
SendByte<<=1;
DelayUs(5);
SCLH;
DelayUs(5);
SCLL;
byte I2C_ReceiveByte(void) //数据从高位到低位
byte i=8;
byte ReceiveByte=0;
SDAH;
while(i--)
ReceiveByte<<=1;
SCLL;
DelayUs(5);
SCLH;
DelayUs(5);
if(SDAread)
ReceiveByte|=0x01;
SCLL;
return ReceiveByte;
#ifdef CYPRESS_FRAM
bool I2C_WriteByte(byte SendByte, uint WriteAddress, byte DeviceAddress)
if(!I2C_Start()) return false;
I2C_SendByte( DeviceAddress & 0xFE);//写器件地址
if(!I2C_WaitAck()){I2C_Stop(); return false;}
I2C_SendByte((byte)((WriteAddress>>8) & 0xFF)); //设置高起始地址
I2C_WaitAck();
I2C_SendByte((byte)((WriteAddress) & 0xFF)); //设置低起始地址
I2C_WaitAck();
I2C_SendByte(SendByte); //写数据
I2C_WaitAck();
I2C_Stop();
//要等待EEPROM写完,可以采用查询或延时方式(10ms)
DelayMs(1);
return true;
uint I2C_EEPROM_BufferWrite(byte* pBuffer, uint WriteAddr, uint NumByteToWrite){
uint i;
byte *p;
p = pBuffer;
I2C_SendByte( ADDR_24CXX & 0xFE);//写器件地址
I2C_SendByte((byte)((WriteAddr>>8) & 0xFF)); //设置高起始地址
I2C_WaitAck();
I2C_SendByte((byte)((WriteAddr) & 0xFF)); //设置低起始地址
I2C_WaitAck();
for(i=0;i<NumByteToWrite;i++){
I2C_SendByte(*(p+i)); //写数据
I2C_WaitAck();
DelayUs(1);
I2C_Stop();
DelayMs(1);
return true;
//读出1字节数据 待读出地址 器件类型
byte I2C_ReadByte( uint ReadAddress, byte DeviceAddress)
byte temp;
if(!I2C_Start())return false;
I2C_SendByte((DeviceAddress & 0xFE));//写器件地址
I2C_SendByte((byte)((ReadAddress>>8) & 0xFF)); //设置高起始地址
I2C_WaitAck();
I2C_SendByte((byte)((ReadAddress) & 0xFF)); //设置低起始地址
I2C_WaitAck();
I2C_Start();
I2C_SendByte((DeviceAddress & 0xFE)|0x01); //读器件地址
I2C_WaitAck();
temp = I2C_ReceiveByte();
I2C_NoAck();
I2C_Stop();
return temp;
void I2C_24CXX_Read(uint nAddr, byte* pDat, uint nLen)
ushort i;
for(i=0;i<nLen;i++)
*(pDat+i)=I2C_ReadByte(nAddr+i, ADDR_24CXX);
uint I2C_24CXX_ReadID(void){
byte temp;
uint rv = 0;
I2C_SendByte(0xf8);
I2C_SendByte((ADDR_24CXX & 0xFE));//写器件地址
I2C_SendByte(0xf9);
I2C_WaitAck();
rv = rv | (temp<<24);
I2C_Ack();
rv = rv | (temp<<16);
I2C_Ack();
I2C_NoAck();
I2C_Stop();
return rv;
#endif
#ifdef ATMEL_EEPROM
//写入1字节数据 待写入数据 待写入地址 器件类型
I2C_WaitAck();
I2C_WaitAck();
I2C_WaitAck();
I2C_Stop();
DelayMs(10);
return true;
byte temp;
I2C_WaitAck();
I2C_WaitAck();
I2C_Start();
I2C_WaitAck();
I2C_NoAck();
I2C_Stop();
return temp;
void I2C_24CXX_Write(uint nAddr, byte* pDat, uint nLen)
ushort i;
for(i=0;i<nLen;i++)
I2C_WriteByte(*(pDat+i), nAddr+i, ADDR_24CXX);
ushort i;
for(i=0;i<nLen;i++)
* 函数名:I2C_EEPROM_PageWrite
* 描述 :向EEPROM的一个写循环中可以写多个字节,但一次写入的
* 字节数不能超过EEPROM页的大小,AT24C02每页有8个字节
* 输入 :-pBuffer 缓冲区指针
* -WriteAddr 接收数据的EEPROM的内部地址
* -NumByteToWrite 要写入EEPROM的字节数
* 输出 :无
* 调用 :外部调用
bool I2C_EEPROM_PageWrite(byte* pBuffer, uint WriteAddress, uint NumByteToWrite)
I2C_WaitAck();
I2C_WaitAck();
while(NumByteToWrite--)
//发送当前数据
I2C_SendByte(*pBuffer);
//指针指向下一字节
pBuffer++;
//等待发送数据寄存器为空,即收到ACK
I2C_WaitAck();
//发送停止传输指令
I2C_Stop();
//DelayUs(500);
DelayMs(10);
return true;
bool I2C_EEPROM_PageWrite1(byte* pBuffer, uint WriteAddress, uint NumByteToWrite)
I2C_WaitAck();
I2C_WaitAck();
//发送当前数据
//指针指向下一字节
pBuffer++;
I2C_WaitAck();
//发送停止传输指令
I2C_Stop();
//DelayUs(700);
DelayMs(2);
return true;
* 函数名:I2C_EEPROM_BufferWrite
* 描述 :将缓冲区中的数据写到I2C的外设(EEPROM)中
* 输出 :无
* 调用 :外部调用
//定义4个8位的变量,分别为页数,不足一页字节数,字节地址,字节计数器
byte NumOfPage = 0, NumOfSingle = 0, count = 0; //页数,不足一页字节数,计数器
ushort Addr = 0; //字节地址
//字节地址(不足一页)
Addr = WriteAddr % PageSize;
//一页中的剩余字节数
count = PageSize - Addr;
//欲写入数据所占的页数
NumOfPage = NumByteToWrite / PageSize;
//欲写入数据所占的字节数(不足一页)
NumOfSingle = NumByteToWrite % PageSize;
//判断写入起始地址是否为某页的第一个字节地址处,是则进入
if(Addr == 0)
//判断写入的数据字节数是否足一页,不足则进入
if(NumOfPage == 0)
//向EEPROM写入NumOfSingle个字节的数据
I2C_EEPROM_PageWrite(pBuffer, WriteAddr, NumOfSingle);
//I2C_24CXX_Write(WriteAddr, pBuffer, NumOfSingle);
//写入的数据字节数超过一页
else
//向EEPROM写入NumOfPage页数据
while(NumOfPage--)
//向EEPROM写入一页数据
I2C_EEPROM_PageWrite(pBuffer, WriteAddr, PageSize);
//写入数据地址指向下一页起始地址
WriteAddr += PageSize;
//写入数据指向下一页的数据
pBuffer += PageSize;
//写入余下不足一页的数据
if(NumOfSingle != 0)
//写入数据的起始地址不是某页的第一个字节地址处
else
if(NumOfPage == 0)
//向EEPROM写入NumOfSingle个字节的数据,当写到页边界时,将从该页的起始地址继续写入数据
//****所以,遇到这种情况要特别处理****
if(count>=NumByteToWrite) //如果当前页剩余字节数大于或等于要写入的字节数
else
I2C_EEPROM_PageWrite(pBuffer, WriteAddr, count); //先写入当前页剩余的字节数
//将数据写满当前页后剩余的字节数
NumByteToWrite -= count;
//写入数据地址指向下一页起始地址
WriteAddr += count;
//写入数据指向下一页的数据
pBuffer += count;
I2C_EEPROM_PageWrite(pBuffer, WriteAddr, NumByteToWrite); //写入下页剩余的字节数
//写入的数据字节数超过一页
else
//将数据写满当前页后剩余的字节数
//除去当前页后欲写入的页数
//除去当前页后欲写入数据所占的字节数(不足一页)
//判断当前页是否还有剩余空间,是则进入
if(count != 0)
//将当前页所剩空间写满
//写入数据地址指向下一页起始地址
WriteAddr += count;
//写入数据指向下一页的数据
pBuffer += count;
while(NumOfPage--)
//向EEPROM写入一页数据
//写入数据地址指向下一页起始地址
//写入数据指向下一页的数据
//写入余下不足一页的数据
return 0;
uint I2C_EEPROM_BufferWrite1(byte* pBuffer, uint WriteAddr, uint NumByteToWrite)
//字节地址(不足一页)
//一页中的剩余字节数
//欲写入数据所占的页数
//欲写入数据所占的字节数(不足一页)
if(Addr == 0)
if(NumOfPage == 0)
I2C_EEPROM_PageWrite1(pBuffer, WriteAddr, NumOfSingle);
//写入的数据字节数超过一页
else
while(NumOfPage--)
//向EEPROM写入一页数据
I2C_EEPROM_PageWrite1(pBuffer, WriteAddr, PageSize);
//写入数据地址指向下一页起始地址
//写入数据指向下一页的数据
//写入余下不足一页的数据
else
if(NumOfPage == 0)
else
I2C_EEPROM_PageWrite1(pBuffer, WriteAddr, count); //先写入当前页剩余的字节数
//将数据写满当前页后剩余的字节数
//写入数据地址指向下一页起始地址
WriteAddr += count;
//写入数据指向下一页的数据
pBuffer += count;
I2C_EEPROM_PageWrite1(pBuffer, WriteAddr, NumByteToWrite); //写入下页剩余的字节数
//写入的数据字节数超过一页
else
//将数据写满当前页后剩余的字节数
//除去当前页后欲写入的页数
if(count != 0)
//将当前页所剩空间写满
//写入数据地址指向下一页起始地址
WriteAddr += count;
//写入数据指向下一页的数据
pBuffer += count;
while(NumOfPage--)
//向EEPROM写入一页数据
//写入数据地址指向下一页起始地址
//写入数据指向下一页的数据
//写入余下不足一页的数据
return 0;
* 函数名:I2C_EEPROM_BufferRead
* 描述 :从EEPROM里读取一块数据
* 输入 :-pBuffer 存放从EEPROM读取到的数据的缓冲区指针
* -ReadAddr 读取数据的EEPROM的内部地址
* -NumByteToRead 要从EEPROM读取的字节数
* 输出 :无
* 调用 :外部调用
//bool I2C_EEPROM_BufferRead(ushort ReadAddress, byte* pBuffer, ushort NumByteToRead)
// if(!I2C_Start()) return false;
// I2C_SendByte( ADDR_24CXX & 0xFE);//写器件地址
// if(!I2C_WaitAck()){I2C_Stop(); return false;}
// I2C_SendByte((byte)((ReadAddress>>8) & 0xFF)); //设置高起始地址
// I2C_WaitAck();
// I2C_SendByte((byte)((ReadAddress) & 0xFF)); //设置低起始地址
// I2C_WaitAck();
// I2C_Start();
// I2C_SendByte((ADDR_24CXX & 0xFE)|0x01); //读器件地址
// I2C_WaitAck();
// //读取NumByteToRead个字节数据
// while(NumByteToRead)
// //从EEPROM中读取一个字节的数据并储存到缓冲区中
// *pBuffer = I2C_ReceiveByte();
// //缓冲区指针指向下一个字节存放地址
// pBuffer++;
// //字节数减1
// NumByteToRead--;
// //I2C_NoAck();
// //I2C_WaitAck();
// I2C_Stop();
#endif
byte WriteFlagInit = WriteDataFlag;
unsigned int InputChannelAddress ;
unsigned int OutputChannelAddress ;
unsigned int LockDataAddress ;
unsigned int Step ;
unsigned int SystemDataAddress ;
unsigned int FactoryDataAddress ;
void I2C_DataInit(void) //数据初始化
unsigned int i=0;
unsigned char WriteFlag=0xff;
unsigned char FactoryDataFlag=0xff;
I2C_24CXX_Read( FactoryDataFlagAddress,&FactoryDataFlag,1 );
if( FactoryDataFlag!=WriteDataFlag ) //单片机第一次上电 初始化外部存储的数据
I2C_EEPROM_BufferWrite( &AppInit.FactoryData.ModeSet,FactoryDataAddress, sizeof(FactorySetStruct) );
FactoryDataFlag = WriteDataFlag;
I2C_EEPROM_BufferWrite( &FactoryDataFlag,FactoryDataFlagAddress, sizeof(FactoryDataFlag) );
I2C_24CXX_Read( FactoryDataAddress,&App.FactoryData.ModeSet,sizeof(FactorySetStruct) );
I2C_24CXX_Read(WriteDataFlagAddress,&WriteFlag,1);
//写入初始化数据
if(WriteFlag!=WriteDataFlag)
LcdDisplayString(0," Data Writing...... ");
LcdDisplayString(1," Please Wait! ");
for(i=0;i<31;i++)
if( (i!=0)&&(i<=App.FactoryData.FixedNumber) )
continue;
//写当前组和30组的用户数据,包括输入通道,输出通道,锁定数据(注意系统锁定数据只使用当前组)
I2C_EEPROM_BufferWrite( &AppInit.InputData[0].ChannelName[0], InputChannelAddress+Step*i,Step);
for( i=1;i<(App.FactoryData.FixedNumber+1);i++) //工厂程序的名字不可初始化
I2C_24CXX_Read( SystemDataAddress+(unsigned char*)(&App.SystemData.ProgramName[0])-(unsigned char*)(&App.SystemData.DeviceID),
(unsigned char*)(&AppInit.SystemData.ProgramName[0]),13 );
//写系统数据
I2C_EEPROM_BufferWrite( &AppInit.SystemData.DeviceID,SystemDataAddress, sizeof(SystemSetStruct) );
WriteFlag = WriteDataFlag;
I2C_EEPROM_BufferWrite((unsigned char*)(&WriteFlag),WriteDataFlagAddress,1);
//读系统的数据
I2C_24CXX_Read( SystemDataAddress,&App.SystemData.DeviceID,sizeof(SystemSetStruct) );
memcpy( LcdBuffer0,App.SystemData.LogoString1,24);
memcpy( LcdBuffer1,App.SystemData.LogoString2,24);
local_ip[0]=App.SystemData.IP[0];
local_ip[1]=App.SystemData.IP[1];
local_ip[2]=App.SystemData.IP[2];
local_ip[3]=App.SystemData.IP[3];
mac[5]=App.SystemData.IP[3];
mac[4]=App.SystemData.IP[2];
mac[3]=App.SystemData.IP[1];
mac[2]=App.SystemData.IP[0];
gateway[0] = App.SystemData.Gateway[0];
gateway[1] = App.SystemData.Gateway[1];
gateway[2] = App.SystemData.Gateway[2];
gateway[3] = App.SystemData.Gateway[3];
switch(App.SystemData.PowerOnState)
//power on keep state
case 1:
//读当前组数据
I2C_24CXX_Read(InputChannelAddress, &App.InputData[0].ChannelName[0], Step);
break;
//all mute
case 2:
//读当前组数据
//静音
for( i=0;i<4;i++ ) App.InputData.Mute = 0;
for( i=0;i<8;i++ ) App.OutputData.Mute = 0;
I2C_EEPROM_BufferWrite( (unsigned char*)(&App.InputData[0].ChannelName[0]),InputChannelAddress, Step-sizeof(LockDataStruct) );
break;
//load program
case 3:
LcdDisplayString(0," Waiting ");
LcdDisplayString(1," Power On Loading...... ");
//读对应组数据
I2C_24CXX_Read( InputChannelAddress+App.SystemData.PowerLoadNumber*Step, &App.InputData[0].ChannelName[0], Step);
I2C_24CXX_Read( LockDataAddress+64, &App.CurrentLockData.SystemLoadProgram, 32);
App.SystemData.CurrentProgramNumber = App.SystemData.PowerLoadNumber;
memcpy( (unsigned char*)(&App.SystemData.ProgramName[0][0]),
(unsigned char*)(&App.SystemData.ProgramName[App.SystemData.PowerLoadNumber][0]),12);
break;
//异常处理防止连不上设备
default:
break;
App.OutputData[0].AllVolume = 0; //总音量设置为0
if( FactoryFlag==1 ) //工厂模式
//静音
if( (App.FactoryData.TimeHourSet>0)||(App.FactoryData.MinuteSet>0) )
switch( App.FactoryData.ModeSet )
case 0:
if( App.FactoryData.TimeHourCount<9952 )
App.FactoryData.TimeHourCount++;
I2C_EEPROM_BufferWrite( (unsigned char*)(&App.FactoryData.TimeHourCount),
FactoryDataAddress+(unsigned int)(&App.FactoryData.TimeHourCount)-(unsigned int)(&App.FactoryData.ModeSet),2);
if( App.FactoryData.TimeHourCount>App.FactoryData.TimeHourSet )
FactoryLockFlag = 1;
for( i=0;i<4;i++ ) App.InputData.Mute = 0; //静音
GPIO_WriteBit( GPIOA, GPIO_Pin_1, Bit_RESET); //直接关静音继电器
break;
case 1:
if( (App.FactoryData.TimeHourCount*60+App.FactoryData.MinuteCount)
>=(App.FactoryData.TimeHourSet*60+App.FactoryData.MinuteSet) )
break;
if( App.FactoryData.FixedNumber>30 )
App.FactoryData.FixedNumber = 0;
I2C_EEPROM_BufferWrite( (unsigned char*)(&App.FactoryData.FixedNumber),
SystemDataAddress+(unsigned int)&App.FactoryData.FixedNumber-(unsigned int)&App.FactoryData.ModeSet,1);
//App.FactoryData.DeviceMode = 24;
//App.FactoryData.DeviceMode = 26;
//App.FactoryData.DeviceMode = 28;
//App.FactoryData.DeviceMode = 36;
//App.FactoryData.DeviceMode = 46;
App.FactoryData.DeviceMode = 48;
