查看: 8441|回复: 73
[Allegro17.4以下] ARLink_C201_D +IT66021FN 做的主板PCB
    终身成就奖社区居民忠实会员宣传大使奖优秀斑竹奖
    发表于 2020-11-28 16:04:51 | 显示全部楼层 |阅读模式
    重要提示:PCB作品文件展下载说明
    ARLINK-C201-D_pcb_v2-0111.7z (393 KB, 下载次数: 21)
    D1SMF24_SOD123_SMF12ASMF12ASOD123
    D14TVS_CA_A179_D_0402_5V_CG0402MLC5VA179_D_0402
    D15TVS_CA_A179_D_0402_5V_CG0402MLC5VA179_D_0402
    D16TVS_CA_A179_D_0402_5V_CG0402MLC5VA179_D_0402
    D18TVS_CA_A179_D_0402_5V_CG0402MLC5VA179_D_0402
    D19TVS_CA_A179_D_0402_5V_CG0402MLC5VA179_D_0402
    D20LED_1_LED_BI_0606_LEDLEDLED_BI_0606
    D21LED_1_LED_BI_0606_LEDLEDLED_BI_0606
    F1RESISTOR_1_R1206_JFC1206-1400FSJFC1206-1400FS/32V/4AR1206
    F2RESISTOR_1_R1206_JFC1206-1400_1JFC1206-1400FS/32V/1AR1206
    FB1BEAD_A041_L_0402_H60_120OHM_100120ohm_100MHz_1.5AA041_L_0402_H60
    FB2BEAD_A041_L_0402_H60_120OHM_100120ohm_100MHz_1.5AA041_L_0402_H60
    FB3BEAD_A041_L_0402_H60_120OHM_100120ohm_100MHz_1.5AA041_L_0402_H60
    FB4BEAD_A041_L_0402_H60_120OHM_100120ohm_100MHz_1.5AA041_L_0402_H60
    FB5BEAD_A041_L_0402_H60_120OHM_100120ohm_100MHz_1.5AA041_L_0402_H60
    FB6BEAD_A041_L_0402_H60_120OHM_100120ohm_100MHz_1.5AA041_L_0402_H60
    FB7BEAD_A041_L_0402_H60_120OHM_100120ohm_100MHz_1.5AA041_L_0402_H60
    FB8BEAD_A041_L_0402_H60_120OHM_100120ohm_100MHz_1.5AA041_L_0402_H60
    FB9BEAD_A041_L_0402_H60_120OHM_100120ohm_100MHz_1.5AA041_L_0402_H60
    FB10BEAD_A041_L_0402_H60_120OHM_100120ohm_100MHz_1.5AA041_L_0402_H60
    J6CONNECTOR1X4_4PIN_SMD_1P25_V_CCONNECTOR1X4_R4PIN_SMD_1P25_V
    J8SMA-FE-ME_0_RF_II__IPEX50 OHMS RF_II
    J10SMA-FE-ME_0_RF_II_IPEX-3X3X1P25IPEX-3X3X1P25RF_II
    J16MINIHDMI_19P_4_A430_HDMIS_F_MI A430_HDMIS_F_MINI_H320
    J17CON3_3PIN_1P25_SMD_R_CON3_53261CON33PIN_1P25_SMD_R
    J18CON3_3PIN_1P25_SMD_V_CON3_53398CON33PIN_1P25_SMD_V
    J19CON3_3PIN_1P25_SMD_R_CON3_53261CON33PIN_1P25_SMD_R
    J20CON3_3PIN_1P25_SMD_R_CON3_53261CON33PIN_1P25_SMD_R
    J21CONNECTOR1X2 _PWR_2PIN_SIP_3_RPWRCONN 1X2PWR_2PIN_SIP_3_R
    J23CONNECTOR1X2 _2PIN_SMD_1P25_R_CONNECTOR1X2_V2PIN_SMD_1P25_R
    J24SW_2_8PIN_SMD_1P27_SW_SW_4SW_48PIN_SMD_1P27_SW
    J25CON3_3PIN_1P25_SMD_R_CON3_53261CON33PIN_1P25_SMD_R
    L1INDUCTOR_A344_L_P350X500_H200_33.3uHA344_L_P350X500_H200
    LED7LED-LT8A23-51-UR96-T5_0_R_LED_ILT8AB3-54-URC3-TE-Z-greenR_LED
    LED8LED-LT8A23-51-UR96-T5_0_R_LED_ILT8AB3-54-URC3-TE-Z-greenR_LED
    Q2PMOS_A098_SOT23_3_H115_AO3401A_AO3401AA098_SOT23_3_H115
    S2SWPUSHBUTTON_4P_A_SW_4-2P15-4PSKRPACE010SW_4-2P15-4P2X3P2-2P5
    U1MP2235_A291_TSOT23_8_H100_MP223MP2235GJA291_TSOT23_8_H100
    U2MPM38222GR_QFN14_40X40H16_MPM38MPM38222GRQFN14_40X40H16
    U4C201_D_C201-D_STAMP_ARLINK_C201ARLink_C201_DC201-D_STAMP
    U5TPS2553_A100_SOT23_6_H145_TPS25TPS2553DBV-1A100_SOT23_6_H145
    U8RCLAMP0524J_A143_SLP2510P8_H50_RClamp0524JA143_SLP2510P8_H50
    U9RCLAMP0524J_A143_SLP2510P8_H50_RClamp0524JA143_SLP2510P8_H50
    U100010-IT66021FN_0010-IT66021FN-7IT66021FN0010-IT66021FN-76-PIN-QFN
    U11RCLAMP0524J_A143_SLP2510P8_H50_RClamp0524JA143_SLP2510P8_H50
    U19MAX3232_0_TSSOP_16P_MAX3232IPWMAX3232IPWTSSOP_16P
    X1CRYSTAL_4P_A481_OSCS_2520_P180EE2SB27E000001EA481_OSCS_2520_P180E115_H90
    重要提示:PCB作品文件展下载说明
  • 签到天数: 132 天
    你必须非常努力才能显
    发表于 2020-11-28 19:22:49 | 显示全部楼层
    发表于 2020-11-28 21:42:43 | 显示全部楼层
  • 签到天数: 103 天
    7万
    发表于 2020-11-29 05:43:00 | 显示全部楼层
    昨天 09:01
  • 签到天数: 248 天
    发表于 2020-11-29 08:13:00 | 显示全部楼层
  • 签到天数: 60 天
    发表于 2020-11-29 08:33:03 | 显示全部楼层
    PADS20210616高级班
    发表于 2020-11-29 08:47:17 | 显示全部楼层
    发表于 2020-11-29 08:49:26 | 显示全部楼层
  • 签到天数: 8 天
    发表于 2020-11-29 08:54:01 | 显示全部楼层
  • 签到天数: 5 天
    发表于 2020-11-29 09:06:18 | 显示全部楼层
