查看: 562|回复: 1
10S计时器
发表于 2020-12-1 10:10:57 | 显示全部楼层 |阅读模式
  1. #include <reg52.h>
  2. #define uchar unsigned char
  3. #define uint unsigned int
  4. sbit K1 = P3^7;
  5. uchar i,Second_Counts,Key_Flag_Idx;
  6. bit Key_State;
  7. uchar DSY_CODE[]=
  8. {
  9.      0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f
  10. };
  11. void DelayMS(uint ms)
  12. {
  13.      uchar t;
  14.     while(ms--)
  15.     {
  16.          for(t=0;t<120;t++);
  17.     }
  18. }
  19. void Key_Event_Handle()
  20. {
  21.      if(Key_State == 0)
  22.     {
  23.          Key_Flag_Idx=(Key_Flag_Idx+1)%3;
  24.         switch(Key_Flag_Idx)
  25.         {
  26.              case 1:EA=1;ET0=1;TR0=1;break;
  27.             case 2:EA=0;ET0=0;TR0=0;break;
  28.             case 0:P0=0x3f;P2=0x3f;i=0;Second_Counts=0;
  29.         }
  30.     }
  31. }
  32. void main()
  33. {
  34.      P0 = 0x3f;
  35.     P2 = 0x3f;
  36.     i = 0;
  37.     Second_Counts = 0;
  38.     Key_State = 1;
  39.     TMOD = 0x01;
  40.     TH0  = (65535-50000)/256;
  41.     TL0  = (65535-50000)%256;
  42.     while(1)
  43.     {
  44.          if(Key_State != K1)
  45.         {
  46.              DelayMS(10);
  47.             Key_State = K1;
  48.             Key_Event_Handle();
  49.         }
  50.     }
  51. }
  52. void DSY_Refresh() interrupt 1
  53. {
  54.      TH0  = (65535-50000)/256;
  55.     TL0  = (65535-50000)%256;
  56.     if(++i==2)
  57.     {
  58.          i = 0;
  59.         ++Second_Counts;
  60.         P0 = DSY_CODE[Second_Counts/10];
  61.         P2 = DSY_CODE[Second_Counts%10];
  62.         if(Second_Counts == 100) Second_Counts = 0;
  63.     }
  64. }
复制代码
发表于 2020-12-1 11:16:49 | 显示全部楼层
