TA的每日心情 | 开心 2024-7-10 20:37 |
签到天数: 1 天 [LV.1]初来乍到
- 20875
Comment | Pattern | Quantity | Components | 06012002-SW-DIO-100V-200MA-MMBD7000LT1G | SOT-23 | 8 | D1, D2, D3, D4, D5, D7, D8, D9 | 06013002-S-DIO-40V-100MA-BAS40-06LT1G | SOT-23 | 1 | D6 | 06013004-S-DIO-30V-200MA-BAT54SLT1G | SOT-23 | 2 | D17, D20 | 06021007-NPN-DYN-40V-0.6A-MMBT4401LT1G | SOT-23 | 6 | Q1, Q2, Q3, Q4, Q5, Q7 | 08011006-GATE-SN74ACT244-SOP20 | SOP-20 | 2 | U9, U11 | 10010008-GO-HCPL-181-00BE-SOP4 | HCPL-181 | 2 | U5, U6 | 10012001-GO-TLP114A-TPR-SDOP5 | TLP114A | 3 | U1, U2, U4 | 10uF | C0805 | 1 | C97 | 11011001-L-100MHZ-PBY201209T-101Y-N | L0805 | 2 | L1, L2 | 12010003-RLY5-892-1CC-C/24V | RLY5-7.62MM-20.5X10.2 | 2 | K1, K2 | 120R | R0805 | 1 | R139 | 15010024-DIP34-2.54MM-2313411001 | CON-34-100 | 1 | J6 | 15011003-SIP-3-100-3A-201K0300 | SIP-3-100 | 1 | J2 | 232 Communication | PIN3-5 | 2 | J7, J8 | 28010001-FUSE-10A-B(J)K-MSM020 | R0805 | 4 | F1, F2, F3, F4 | 3.3K | R0805 | 4 | R134, R143, R146, R153 | 3.3V/30MHz/5*7 | 4脚有源晶振 | 1 | Y1 | 300R | R0805 | 3 | R140, R145, R154 | 47uF | 100uF/35V 贴片 | 4 | C87, C90, C91, C95 | 485 Communication | PIN3-5 | 4 | J1, J3, J4, J11 | BLM21PP221 | L0805 | 2 | L3, L4 | CAN Communication | PIN2-5 | 2 | J12, J14 | CON3 | SIP-3-100 | 2 | J13, J15 | F0505S-1W | F0505S-1W | 2 | DC1, DC2 | F28335PGFA | LQFP176 | 1 | U10 | FCA82C250T/N4.115 | SOP-8 | 2 | U18, U19 | FM25V02-G | | 1 | U15 | HCPL-0601 | HCPL-0601 | 7 | OP1, OP2, OP3, OP4, OP5, OP6, OP7 | JTAGTest | JTAG | 1 | JK1 | LM393DR2G | | 3 | U3, U7, U8 | LM393DR2G | SOIC-8 | 1 | U14 | MAX485ESA | MAX485ESA | 1 | U17 | MC33272ADR2G | | 1 | U12 | NPN 8050S | SOT-23 | 3 | Q6, Q8, Q9 | Power Input | XH2.5-8P | 1 | J10 | SM05T1 | SOT-23 | 2 | D22, D23 | SMD LED Red | LED_0805 | 3 | LED1, LED2, LED3 | SW-PB | SW-4-6mm | 1 | S1 | TPS3828-33DBVT | TPS3828-33DBVT | 1 | U13 | TPS767D301PWP | TPS767D301PWP | 1 | U16 | Trans Cupl | SL4-7.5MMX2.54MM | 2 | L5, L6 | 钳位二极管-SW-DIO-100V-200MA-MMBD7000LT1G | SOT-23 | 10 | D10, D11, D12, D13, D14, D15, D16, D18, D19, D21 |
