TA的每日心情 | 开心 2024-7-10 20:37 |
签到天数: 1 天 [LV.1]初来乍到
- 20878
Name | PCB Decal | Part Type | Value | B1 | CON_2.0_4PIN_SM | CON4-SM | 2.0mm4Pin | B2 | BAT_D10MM | BATTERY | MS920SE-FL27E9.5*2.1 | B5 | BUTTERY-CR1220_SM | BAT-1220 | 1220 | BGND | ANT1 | TP-100 | | CD1 | C0603 | C0603 | 10uF | CD4 | CE-SMDB | CE220/16C | 100uF/6.3v | CD5 | CE-SMDB | CE220/16C | 100uF/6.3v | D1 | SMA | D_SCHOTTKY | SS54 | D3 | SOD123 | SOD_323 | 1N5819 | D4 | SOD123 | SOD_323 | 1N5819 | D6 | SOD123 | SOD_323 | 1N5819 | D7 | SMA | DIODE_DIP_SCHOTTKY_2 | SS54 | D10 | SMA | DIODE_DIP_SCHOTTKY_2 | SS54 | DM | TEST_1.2 | TP-100 | | DP | TEST_1.2 | TP-100 | | E1 | ESD0402 | TVS_0 | ESD5V 0.5PF | E19 | CE-SMDB | E | 100uF/6.3V | E20 | CE-SMDBA | UUG1H221MNQ1MS | 100uF/6.3V | E21 | CE-SMDB | E | 100uF/10V | E22 | CE-SMDB | E | 100uF/10V | E34 | ESD0402 | TVS_0 | ESD5V 0.5PF | E35 | ESD0402 | TVS_0 | ESD5V 0.5PF | E36 | ESD0402 | TVS_0 | ESD5V 0.5PF | E37 | ESD0402 | TVS_0 | ESD5V 0.5PF | E38 | ESD0402 | TVS_0 | ESD5V 0.5PF | E39 | VR0402 | VR0402 | ESD5V 0.5PF | FB1 | R1206S | R1/4W | 47Ω 100MHZ | FB2 | R1206S | R1/4W | 47Ω 100MHZ | FB3 | R1206S | R1/4W | 47Ω100MHZ | FB4 | R1206S | R1/4W | 47Ω 100MHZ | FB5 | R0603 | INDUCTOR1 | BLM15AX601SZ1D | FB6 | R0603 | INDUCTOR1 | BLM15AX601SZ1D | GND | TP-175 | TP_1 | | ID | ANT1 | TP-100 | | J1 | 10051922-1210EHLF | 10051922-1210EHLF | 0.5MM12Pin | J2 | 10051922-1210EHLF | 10051922-1210EHLF | 0.5mm12Pin | J3 | CON_2.0_3PIN_SM | BAT_3PIN | 2.0mm3Pin | J4 | FPC-1.0-7 | CON7_SM | 1.0mm7Pin | J5 | CON_2.0_4PIN_SM | CON4-SM | 2.0mm4Pin | J6 | FPC-1.0-7 | CON7_SM | NC | J8 | CON2_1.25 | COM_2_1.25 | 2P1.25 | J9 | CON_2.0_4PIN_SM | CON4-SM | 2.0mm4Pin | J13 | CON_2.0_2PIN_SM | CON-2-SM | 2.0mm2Pin | KC0 | TP-175 | TP_1 | | KC1 | TP-175 | TP_1 | | KR0 | TP-175 | TP_1 | | L1 | L7X7S | INDUCTOR | 22uH | L3 | L7X7S | L_PWR | 2.2uH/HA63-2R2MT | L4 | L4X4.5X3-A | L | 2.2uH/HA42-2R2MT | L5 | L7X7S | L | 2.2uH/HA42-2R2MT | LCD1 | BL125-25RL-NEW | CON25 | 25P0.3MM | LD1 | L4X4.5X3-A | L | 10uH | LED+ | TEST_1.2 | TP-100 | | LED- | TEST_1.2 | TP-100 | | LED3 | LED_RGB_SMT | LED_RGB_5MM | LED_RGB | Q2 | IC-SOT23 | NPN | 9014 | Q4 | IC-SOT23 | NPN | NC/9014 | Q5 | IC-SOT23 | NPN | 9014 | Q10 | IC-SOT23 | NPN | 9014 | Q15 | IC-SOT23 | EPMOS | AO3401 | Q29 | TCRT5000L | 817 | TCRT5000L | SIM1 | SIM_NANO_A | SIM_NANO_A | NANO SIM 6PIN | TF1 | T-FLASH_1618 | TF_CARD | mpu-616 | TP1 | FPC-6P05H20 | CONN_SOCKET_8 | 6P0.5MM | U1 | LQFP64PIN | STM32F103RCT6 | STM32F103RCT6 | U2 | SOP-8 | 24C256 | AT24C256C-SSHL-T | U3 | TSSOP-24 | A3983SLPT | A3983SLPT | U4 | SOT-23-5 | MC74VHC1GT126 | MC74VHC1GT126 | U5 | AW2013MEW | AW2013 | AW2013 | U6 | SOT-23-5 | MC74VHC1GT126 | MC74VHC1GT126 | U7 | BQ24296 | BQ24296 | BQ24296 | U8 | SOT23-5 | APL515X | BL8558-28PRN | U9 | SOT23-5 | APL515X | BL8558-18PRN | U10 | RT9284 | RT9284 | CP2123-A2 | U11 | IM35S_MB_NC_ANT | IM35_MINI2_0 | IM37S 8+8 | U12 | SOT23-5 | APL515X | BL8558-18PRN | U13 | SOT23-5 | APL515X | BL8558-33PRN | U14 | TSSOP16 | MAX3232 | MAX3232_TSSOP16 | U15 | TSSOP14 | TXS0104 | TXS0104 | U16 | TSSOP14 | TXS0104 | TXS0104 | U17 | TSSOP16 | MAX3232CD | MAX3232EUE | U18 | SOIC16-D | CAT4109 | CAT4109 | U19 | TO-92A | B3B-XH-A | DS18B20 | U20 | SO8 | AP4435GM | AO4437 | U21 | MP3428 | MP3428 | MP3428 | U22 | RT9284 | SY7069 | SY7069 | U23 | SOT23-6 | MAX6033AAUT25 | MAX6033AAUT25 | U24 | SOT-223 | AMS1117-3.3V | LM1117-3.3V | U25 | SOT-223 | AMS1117-3.3V | LM1117-5V | U26 | SOT-223 | AMS1117-3.3V | LM1117-ADJ | U27 | TSSOP-16 | ADS1246 | ADS1246IPW | U30 | SOP-8 | TPS5430DDA | TPS5430DDA | USB1 | USB_3.1_16P | USB-16 | TYPE C 16Pin | USB2 | USB_MINI | USB_MINI | miniUSB | USB3 | USB_MINI | USB_MINI | miniUSB | Y1 | CT-3215 | CRYSTAL_1 | CSTNE8M00GH5C000R0 |
