重要提示:PCB作品文件展下载说明
Name | Part Type | PCB Decal | Value | 0T1 | PC817 | DIP4 | | 0T2 | PC817 | DIP4 | | BD100 | BRG | BRGDB4-3005 | 25A/800V | CHGND | PAD///// | P1.55B | | CON1 | CON8P-2.54-H | CON8P-2.54-H | | CX1 | C105-C107 | C105/630V | 0.82UF/305V X2 | CX2 | C105-C107 | C105/630V | 0.82UF/305V X2 | CX3 | C103/C8/C474/ | C474/250V/15BAB | 0.82UF/305V X2 | CX4 | C103/C8/C474/ | C474/250V/15BAC | 0.82UF/305V X2 | CX5 | C103/C8/C474/ | C474/250V/15BAA | 0.82UF/305V X2 | CY1 | C101-C102 | C102/250V/Y1/10 | 102/250V | CY2 | C101-C102 | C102/250V/7.5 | 102/250V | CY3 | C101-C102 | C102/250V/7.5 | 102/250V | CY4 | C101-C102 | C102/250V/7.5 | 102/250V | CY5 | C101-C102 | C102/250V/7.5 | 102/250V | CY7 | C101-C102 | C102/250V/Y1/10A | 223/2KV | CY8 | C101-C102 | C102/250V/7.5 | 102/250V | CY9 | C101-C102 | C102/250V/Y1/10A | 223/2KV | CY11 | C101-C102 | C102/250V/7.5 | 102/250V | D1 | DIODE/W | SOD-123/W | | D2 | BAT54A/W | SOT-23/WELDING | | D3 | DIODE/W | SOD-123/W | | D4 | BAT54C/W | SOT-23/WELDING | BAV70LT | D5 | BAT54C | SOT-23/WELDING | | D6 | BAT54C/W | SOT-23/WELDING | BAV70LT | D8 | D2 | SOT-23/WELDING | BAV70LT | D9 | D2 | SOT-23/WELDING | BAV70LT1 | D10 | DIODE | DO201HA | | D11 | DIODE | DO201HA | | D12 | DIODE/W | SOD-123/W | | D13 | D2 | SOT-23/WELDING | BAV70LT1 | D14 | BAT54A/W | SOT-23/WELDING | | D15 | D2 | SOT-23/WELDING | BAV70LT | D16 | D1-1/ | TO220/9 | | D17 | D1-1 | DO41V | MUR260 | D18 | D2 | SOT-23/WELDING | BAV70LT | D19 | D1-1/ | TO220/9 | | D20 | SMA-SMC/W | SMA/W | | D21 | DIODE/W | SOD-123/W | | D22 | BAT54C/W | SOT-23/WELDING | BAV70LT | D24 | SMA-SMC/W | SMA/W | | D25 | DIODE/W | SOD-123/W | | D26 | BAT54A/W | SOT-23/WELDING | | D27 | DIODE | DO201HA | | D28 | DIODE | DO201HA | | D29 | D1-1 | DO41H | MUR260 | D30 | SMA-SMC/W | SMA/W | | D31 | D2 | D220A | ER1602CT | D32 | D1 | DO201HF | 1N5408 | D47 | BAT54C | SOT-23/WELDING | BAV70LT1 | D48 | BAT54C | SOT-23/WELDING | BAV70LT1 | D49 | SMA-SMC/W | SMA/W | | D50 | SMA-SMC/W | SMA/W | | D51 | BAT54C/W | SOT-23/WELDING | BAV70LT | D200 | SMA-SMC/W | SMA/W | | D300 | DIODE/W | SOD-123/W | | F1 | F/2 | F20/7.5H | T15A/250VAC | F3 | F/2 | F20/7.5H | T15A/250VAC | FDG1 | FDG | FDG1 | EC600X | FDG2 | PADD | PAD_12X15MM | | GND | PAD///// | P1.55C | | HS8 | P3.5 | LSK_4BA | | JMP1 | JMPB | JMP15A | | JMP2 | JMPB | JMP15AA | | JMP3 | JMPB | JMP15B | | JMP4 | JMPB | JMP15D | | JMP5 | JMPB | JMP15C | | JMP6 | JMPB | JMP15AA | | JMP7 | JMPB | JMP15AAB | | JMP8 | JMPB | JMP15AA | | JMP9 | JMPB | JMP15AAA | | JMP10 | JMPB | JMP15AA | | K1 | RLY888 | GHQ-19-UA | | L | PAD///// | P1.55A | | L1 | L25X12AA/// | L32X17-P | T16*9.6*8 | L2 | L25X12AA/// | L32X17-P | T16*9.6*8 | L3 | AA// | T16X9X5-P// | | L4 | RES/R | R0805/WAVE | 100R | L5 | L-CS270125-2 | 13D127003-ON | | L6 | L/4 | L-13D180009AAAAA | L001 | L7 | AA// | T16X9X5-P// | | L8 | L25X12AA/// | L32X17-P | T16*9.6*8 | L9 | L-CS270125-2 | 13D127003-ON | | L10 | L/4/S | L/4/SB | L001 | L11 | L/4/S | L/4/SA | L001 | LS | PAD///// | P1.55C | | MOV4 | MOV | MOV20621 | TVR10471 | N | PAD///// | P1.55A | | OUT | PAD///// | P1.55C | | PWM | PAD///// | P1.55C | | Q1 | 2N7002/W | SOT-23/WELDING | 2N7002 | Q2 | BCX56(ZETEX)/W | SOT-89/W | BCX56-16 | Q3 | MMBT4401/W | SOT-23/WELDING | MMBT4401 | Q4 | MMBT2907/W | SOT-23/WELDING | | Q5 | Q1 | TO-92CA | sk4002 | Q6 | 2N7002/W | SOT-23/WELDING | 2N7002 | Q7 | 2N7002 | SOT-23/WELDING | 2N7002 | Q8 | MMBT2907/W | SOT-23/WELDING | | Q9 | Q220 | D247 | STW26NM60N | Q10 | MMBT4401/W | SOT-23/WELDING | MMBT4401 | Q11 | MMBT2907/W | SOT-23/WELDING | | Q12 | MMBT4401/W | SOT-23/WELDING | MMBT4401 | Q13 | BCX56(ZETEX)/W | SOT-89/W | BCX56-16 | Q14A | Q220 | D247 | STW26NM60N | Q15 | Q220 | TO-220P/3.8AAA | 16N50 | Q16 | Q220 | TO-220P/3.8AAA | 16N50 | Q17 | MMBT2907/W | SOT-23/WELDING | | Q18 | Q220 | TO-220P/3.8AAA | 16N50 | Q19 | Q220 | TO-220P/3.8AAA | 16N50 | Q20 | MMBT4401/W | SOT-23/WELDING | MMBT4401 | Q21 | MMBT2907/W | SOT-23/WELDING | | Q23 | 2N7002/W | SOT-23/WELDING | 2N7002 | Q24 | Q220 | TO-220P/3.8AA | 16N50 | Q25 | Q220 | TO-220P/3.8AA | 16N50 | Q26 | MMBT2907/W | SOT-23/WELDING | | Q27 | MMBT4401/W | SOT-23/WELDING | MMBT4401 | Q200 | BCX56(ZETEX)/W | SOT-89/W | BCX56-16 | T1 | T/14 | T/14 | | T4 | T/14 | T/14 | | T5 | DRIVE_T | T16X9X5-PA | | T202 | DRIVE_T | T16X9X5-PA | | U1 | LM2904 | SO-8A | LM2904 | U2 | LM2904/ | SO-8/WAVE | LM2904 | U3 | LM2904/W | SO-8/WAVE | LM2904 | U4 | TLV431A(SOT23) | SOT-23/WELDING | LR431ALT1G | U5 | LM2904/ | SO-8/WAVE | LM2904 | U6 | LM2904/W | SO-8/WAVE | LM2904 | U7 | TLV431A(SOT23) | SOT-23/WELDING | LR431ALT1G | U8 | DIP16AYUU | SO-16/W | L6599AD | U9 | TLV431A(SOT23) | SOT-23/WELDING | LR431ALT1G | U10 | UCC28070 | SO-20/W | | U11 | TLV431A(SOT23) | SOT-23/WELDING | LR431ALT1G | VD18 | D2 | SOT-23/WELDING | BAV70LT1G | VD19 | D2 | SOT-23/WELDING | BAV70L | VO+ | PAD///// | P2.3 | | VO- | PAD///// | P2.3 | | Z1 | ZXRE4041/W/ | SOT-23(Z)/WELDING | 18V | Z2 | ZXRE4041/W | SOT-23/WELDING | 14v | Z4 | ZXRE4041/W/ | SOT-23(Z)/WELDING | 12V | Z7 | ZXRE4041/W/ | SOT-23(Z)/WELDING | 14v | ZD1 | ZXRE4041 | SOT-23/WELDING | 14V | ZD2 | ZXRE4041 | SOT-23/WELDING | 6.2V | ZD3 | ZXRE4041 | SOT-23/WELDING | 10V | ZD4 | ZXRE4041 | SOT-23/WELDING | 20V | ZD5 | ZXRE4041 | SOT-23/WELDING | 5.1V | ZD6 | DIODE/W | SOD-123/W | | ZD7 | BZX84C33/W | SOT-23/WELDING | 15V | ZD8 | ZXRE4041 | SOT-23/WELDING | ZXRE4041 |
重要提示:PCB作品文件展下载说明
