TA的每日心情 | 开心 2024-7-10 20:37 |
签到天数: 1 天 [LV.1]初来乍到
- 21560
重要提示:PCB作品文件展下载说明
REFDES | COMP_DEVICE_TYPE | SYM_NAME | AUDIO1 | AUDIO-JACK5P | AUDIO-JACK5P | AUDIO2 | A2004WV-2X4P | A2004WV-2X4P | BAT | BAT | BAT | BZ | BZ-HY-21B-9MM | BZ-HY-21B-9MM | CP11 | SMC8P4C-0402 | SMC8P4C-0402 | CPUFAN | FAN4P-A | FAN4P-A | D1 | SD05 | SD05 | D2 | SOD-123-AI | SOD-123-AI | D3 | SOT23 | SOT23 | D4 | SOT23 | SOT23 | D5 | SOT23 | SOT23 | D6 | DO-214AC | DO-214AC | D7 | SOD-123-AI | SOD-123-AI | D8 | SOD-123-AI | SOD-123-AI | D9 | SOD-123-AI | SOD-123-AI | D18 | DO-214AC | DO-214AC | D19 | DO-214AC | DO-214AC | D20 | SOD-123-AI | SOD-123-AI | D21 | SOT23 | SOT23 | D22 | SOT23 | SOT23 | D23 | SOD-123-AI | SOD-123-AI | D24 | SOT23 | SOT23 | D25 | SOT23 | SOT23 | D26 | SOD-323 | SOD-323 | D27 | SOD-323 | SOD-323 | D28 | SOD-123-AI | SOD-123-AI | D29 | SOD-323 | SOD-323 | D30 | SOD-123-AI | SOD-123-AI | D31 | SOT23 | SOT23 | D32 | SOT23 | SOT23 | D39 | SOD-123-AI | SOD-123-AI | D40 | SOT23 | SOT23 | D41 | SD05 | SD05 | DC_OUT | 2DC-0005 | 2DC-0005 | DIO | CON2PA_2-54MM | CON2PA_2-54MM | EC1 | EC6_3P2_54DIP | EC6_3P2_54DIP | FS15 | FUSE-A | FUSE-A | FS16 | FUSE-SMD2410 | FUSE-SMD2410 | FS17 | FUSE-A | FUSE-A | FS18 | FUSE-A | FUSE-A | FS19 | F1206 | F1206 | FS20 | F1206 | F1206 | FS21 | F1206 | F1206 | H1 | MH9A-8D4MM | MH9A-8D4MM | H2 | MH9A-8D4MM | MH9A-8D4MM | H3 | MH9A-8D4MM | MH9A-8D4MM | H4 | MH9A-8D4MM | MH9A-8D4MM | INV | A2501WV-5P | A2501WV-5P | JCMOS | CON3PA_2-54MM | CON3PA_2-54MM | JCOM2_SEL | H2N20X-2X12D0-AI | H2N20X-2X12D0-AI | JCOM1 | CON2X3PA_2-54MM | CON2X3PA_2-54MM | JCOM2 | CON2X3PA_2-54MM | CON2X3PA_2-54MM | JCOM3 | CON2X3PA_2-54MM | CON2X3PA_2-54MM | JCOM4 | CON2X3PA_2-54MM | CON2X3PA_2-54MM | JCOM5 | CON2X3PA_2-54MM | CON2X3PA_2-54MM | JCOM6 | CON2X3PA_2-54MM | CON2X3PA_2-54MM | JFRONT | A2004WV-2X5P | A2004WV-2X5P | JFRONT1 | CON2X5PA_2-54MM | CON2X5PA_2-54MM | JLPC | HEADER2X5P_2MM-SMD-N10-AI | HEADER2X5P_2MM-SMD-N10-AI | JLVDS | CON3PA_2-54MM | CON3PA_2-54MM | JLVDS_MODE | HEADER2X3P_2MM-SMD-AI | HEADER2X3P_2MM-SMD-AI | JLVDS_SEL | HEADER2X4P_2MM-SMD-AI | HEADER2X4P_2MM-SMD-AI | JPWR_SEL | CON3PA_2-54MM | CON3PA_2-54MM | JSPI | HEADER2X4P_2MM-SMD-AI | HEADER2X4P_2MM-SMD-AI | JVFD_SEL | CON2X3PA_2-54MM | CON2X3PA_2-54MM | KB_MS | PS2-C | PS2-C | L1 | L-WSRPG0503 | L-WSRPG0503 | L2 | APL1108P-R60M | APL1108P-R60M | L3 | L-WSRPG0503 | L-WSRPG0503 | L4 | L-WSRPG0503 | L-WSRPG0503 | L5 | L-WSRPG0503 | L-WSRPG0503 | L6 | APL0806P-1R0M | APL0806P-1R0M | L7 | L0603 | L0603 | L8 | L0603 | L0603 | L9 | APL0806P-1R0M | APL0806P-1R0M | L10 | APL0806P-1R0M | APL0806P-1R0M | L11 | L-WSRPG0503 | L-WSRPG0503 | L12 | APL0806P-1R0M | APL0806P-1R0M | L13 | L-WSRPG0503 | L-WSRPG0503 | L14 | 3D16FS | 3D16FS | LCD1 | A1001WV-S-F-2X15P | A1001WV-S-F-2X15P | LCD2 | A1001WV-S-F-2X15P | A1001WV-S-F-2X15P | LED1 | LED0603-AI | LED0603-AI | LPT | D-SUB25P-FEMALE | D-SUB25P-FEMALE | MCR | A2001WV-6P | A2001WV-6P | MINI-PCIE | MPCET-S5201-TP40-C | MPCET-S5201-TP40-C | OSC | OSC-DSC1025-5X3-2MM | OSC-DSC1025-5X3-2MM | PWR1 | POWER-JACK-4P | POWER-JACK-4P | PWR2 | C4255WV-2X02P | C4255WV-2X02P | Q1 | TO252-GDS | TO252-GDS | Q2 | TO252-GDS | TO252-GDS | Q3 | SOP8A_1-27 | SOP8A_1-27 | Q4 | PQFN08A | PQFN08A | Q5 | TO252-GDS | TO252-GDS | Q6 | SOT23-GDS | SOT23-GDS | Q7 | SOT23-GDS | SOT23-GDS | Q8 | SOT23-BCE | SOT23-BCE | Q9 | PQFN08A | PQFN08A | Q10 | SOT23-GDS | SOT23-GDS | Q11 | SOT23-BCE | SOT23-BCE | Q12 | PQFN08A | PQFN08A | Q13 | PQFN08A | PQFN08A | Q14 | SOT23-BCE | SOT23-BCE | Q15 | PQFN08A | PQFN08A | Q16 | SOT23-BCE | SOT23-BCE | R620 | SMR2010-B-AI | SMR2010-B-AI | R621 | SMR0402 | SMR0402 | RN1 | SMR8P4RA-0402 | SMR8P4RA-0402 | RN2 | SMR8P4RA-0402 | SMR8P4RA-0402 | RN39 | SMR8P4RA-0402 | SMR8P4RA-0402 | RN40 | 4P2R | 4P2R | RN41 | 4P2R | 4P2R | RN42 | 4P2R | 4P2R | RN43 | 4P2R | 4P2R | RN44 | SMR8P4RA-0402 | SMR8P4RA-0402 | RT1 | SMR0603 | SMR0603 | RT2 | CON2PA_2-54MM | CON2PA_2-54MM | RT3 | SMR0603 | SMR0603 | RT4 | SMR0603 | SMR0603 | SATA1 | SATA-7PS-DIP-CM | SATA-7PS-DIP-CM | SATA2 | SATA22P-DIP-180D-AI | SATA22P-DIP-180D-AI | SATA_PWR | A2501WV-4P | A2501WV-4P | SO-DIMM1A | SODIMM3-U2RN-BOT | SODIMM3-U2RN-BOT | SO-DIMM1 | SODIMM3-ASOA62-UARN | SODIMM3-ASOA62-UARN | SP1 | GND_ISOLATION | GND_ISOLATION | SP2 | GND_ISOLATION | GND_ISOLATION | SPK_OUT | A2001WV-4P | A2001WV-4P | SYSFAN | FAN3P-A | FAN3P-A | U1 | PSOP8_1-27MM | PSOP8_1-27MM | U2 | SOT-89-5P | SOT-89-5P | U3 | SOP8A_1-27 | SOP8A_1-27 | U4 | PSOP8_1-27MM | PSOP8_1-27MM | U5 | SOT-89-5P | SOT-89-5P | U6 | QFN32-5X5MM_0-5 | QFN32-5X5MM_0-5 | U7 | FTG256_1MM-17X17 | FTG256_1MM-17X17 | U8 | PNV22MMR07 | PNV22MMR07 | U9 | PSOP8_1-27MM | PSOP8_1-27MM | U10 | SOP8A_1-27 | SOP8A_1-27 | U11 | SOT23-6P | SOT23-6P | U12 | FBGA84P_0-8MM-10X12-5 | FBGA84P_0-8MM-10X12-5 | U13 | SSOP28E_0-65 | SSOP28E_0-65 | U14 | SOP8A_1-27 | SOP8A_1-27 | U15 | SC70-5P | SC70-5P | U16 | SOT-89-5P | SOT-89-5P | U17 | SC70-5P | SC70-5P | U18 | SOT23-6P | SOT23-6P | U19 | MLF56_0-4-7X7MM | MLF56_0-4-7X7MM | U20 | SSOP28E_0-65 | SSOP28E_0-65 | U21 | PSOP8_1-27MM | PSOP8_1-27MM | U22 | RCLAMP0524P-B | RCLAMP0524P-B | U23 | BGA360_TGP | BGA360_TGP | U24 | PSOP8_1-27MM | PSOP8_1-27MM | U25 | SC70-5P | SC70-5P | U26 | SO-8A | SO-8A | U27 | SC70-5P | SC70-5P | U28 | SO-8A | SO-8A | U29 | PQFP128J_0-5 | PQFP128J_0-5 | U30 | LQFP48B_0-5 | LQFP48B_0-5 | U31 | SOIC8_50-150-200 | SOIC8_50-150-200 | U32 | SOP8A_1-27 | SOP8A_1-27 | U33 | SSOP28E_0-65 | SSOP28E_0-65 | U34 | SSOP28E_0-65 | SSOP28E_0-65 | U35 | SSOP28E_0-65 | SSOP28E_0-65 | U36 | SSOP28E_0-65 | SSOP28E_0-65 | U37 | QFN48_0-5-7X7MM | QFN48_0-5-7X7MM | U38 | SO-8A | SO-8A | U39 | RCLAMP0524P-B | RCLAMP0524P-B | U40 | QFN48-RTL8111E | QFN48-RTL8111E | U41 | RCLAMP0524P-B | RCLAMP0524P-B | U42 | RCLAMP0524P-B | RCLAMP0524P-B | U43 | SOT23-6P | SOT23-6P | U44 | RCLAMP0524P-B | RCLAMP0524P-B | USB1_COM4 | USB-COM-24P-UB11123 | USB-COM-24P-UB11123 | USB2_LAN | USB-LAN-30P-JFM24U1-O | USB-LAN-30P-JFM24U1-O | USB3 | CON2X5PA_2-54MM-N9 | CON2X5PA_2-54MM-N9 | VGA1_COM2 | COM-VGA-2IN1-301 | COM-VGA-2IN1-301 | VGA2 | A2004WV-2X5P | A2004WV-2X5P | X1 | XTAL-FSX-5L | XTAL-FSX-5L | X2 | XTAL-MC-146 | XTAL-MC-146 | X3 | XTAL-FSX-5L | XTAL-FSX-5L |
重要提示:PCB作品文件展下载说明
