#include "eeprom.h"
/** I2C 总线接口 */
#define I2C_PORT GPIOB
#define SDA_Pin GPIO_Pin_7
#define SCL_Pin GPIO_Pin_6
#define FAILURE 0
#define SUCCESS 1
void SendData(uint8_t addr ,uint8_t data)
I2CStart();
I2CSendByte(0xa0);
I2CWaitAck();
I2CSendByte(addr);
I2CWaitAck();
I2CSendByte(data);
I2CWaitAck();
I2CStop();
uint8_t ReadData(uint8_t addr )
uint8_t data;
I2CStart();
I2CSendByte(0xa0);
I2CWaitAck();
I2CSendByte(addr);
I2CWaitAck();
I2CStart();
I2CSendByte(0xa1);
I2CWaitAck();
data = I2CReceiveByte();
I2CSendNotAck();
I2CStop();
return data;
//配置SDA信号线为输入模式
void SDA_Input_Mode()
GPIO_InitTypeDef GPIO_InitStructure;
GPIO_InitStructure.GPIO_Pin = SDA_Pin;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_2MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPD;
GPIO_Init(I2C_PORT, &GPIO_InitStructure);
//配置SDA信号线为输出模式
void SDA_Output_Mode()
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
void SDA_Output( uint16_t val )
if ( val ) {
GPIO_SetBits(I2C_PORT,SDA_Pin);
} else {
GPIO_ResetBits(I2C_PORT,SDA_Pin);
void SCL_Output( uint16_t val )
if ( val ) {
GPIO_SetBits(I2C_PORT,SCL_Pin);
} else {
GPIO_ResetBits(I2C_PORT,SCL_Pin);
uint8_t SDA_Input()
return GPIO_ReadInputDataBit( I2C_PORT, SDA_Pin);
//延时程序
void delay1(unsigned int n)
unsigned int i;
for ( i=0;i<n;++i);
//I2C总线启动
void I2CStart(void)
SDA_Output(1);delay1(500);
SCL_Output(1);delay1(500);
SDA_Output(0);delay1(500);
SCL_Output(0);delay1(500);
//I2C总线停止
void I2CStop(void)
SCL_Output(0); delay1(500);
SDA_Output(0); delay1(500);
SCL_Output(1); delay1(500);
SDA_Output(1); delay1(500);
//等待应答
unsigned char I2CWaitAck(void)
unsigned short cErrTime = 5;
SDA_Input_Mode();
delay1(500);
while(SDA_Input())
cErrTime--;
delay1(500);
if (0 == cErrTime)
SDA_Output_Mode();
I2CStop();
return FAILURE;
SDA_Output_Mode();
return SUCCESS;
//发送应答位
void I2CSendAck(void)
delay1(500);
void I2CSendNotAck(void)
SDA_Output(1);
delay1(500);
//通过I2C总线发送一个字节数据
void I2CSendByte(unsigned char cSendByte)
unsigned char i = 8;
while (i--)
SDA_Output(cSendByte & 0x80); delay1(500);
cSendByte += cSendByte;
delay1(500);
//从I2C总线接收一个字节数据
unsigned char I2CReceiveByte(void)
unsigned char cR_Byte = 0;
SDA_Input_Mode();
while (i--)
cR_Byte += cR_Byte;
delay1(500);
cR_Byte |= SDA_Input();
SDA_Output_Mode();
return cR_Byte;
//I2C总线初始化
void i2c_init()
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
GPIO_InitStructure.GPIO_Pin = SDA_Pin | SCL_Pin;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; // **
