REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
D1 | 5035_WPE3V3D3UL-SOD323_0_SOD-32 | WPE3V3D3UL | SOD-323 |
D2 | 5035_WPE3V3D3UL-SOD323_0_SOD-32 | WPE3V3D3UL | SOD-323 |
D3 | 5221_LANTSPD-C8-SMB_0_TVS-SMB-A | LANTSPD-C8 | TVS-SMB-A |
D4 | XXXX_S-SESD0402X1BN_0402D_SESD0 | SESD0402X1BN | 0402D |
D7 | 5031_TVS-SMBJ15CA-24.4V/600W_TV | SMBJ15A | TVS-SMB-A |
D8 | XXXX_S-SESD0402X1BN_0402D_SESD0 | SESD0402X1BN | 0402D |
J4 | 1061_D-4-1.25S_SIP4-1_27S_NC_D- | NC_D-4-1_25S | SIP4-1_27S |
J8 | 1500_S-FPC-2X12-0.5S_FPC24-0_5S | FPC12X2 | FPC24-0_5S |
J9 | 1142_S-8-1.25S_SIS8-1_25_S-8-1_ | S-8-1_25S | SIS8-1_25 |
J25 | 1010_S-2-1.25S_SIS2-1_25S_S-2-1 | S-2-1_25S | SIS2-1_25S |
J26 | 1010_S-2-1.25S_SIS2-1_25S_S-2-1 | S-2-1_25S | SIS2-1_25S |
J29 | SD_CONNECTOR_0_SD14X15_2-R2_519 | 5190009-191-R | SD14X15_2-R2 |
J30 | 1011_D-2-1.25S_SIP2-1_27S_D-2-1 | D-2-1_25S | SIP2-1_27S |
K2 | 1033_S-KEY-37X46X14-180_9_SW3_5 | SW3.7*4.6S | SW3_5X4_5SA |
L2 | 1170_S-2.2UH30%-1.6A-SMD3X3_LS- | 2.2uH | LS-3X3 |
L3 | 1170_S-2.2UH30%-1.6A-SMD3X3_LS- | 2.2uH | LS-3X3 |
L4 | 1100_S-1_0.8UH10%-350MA-15-0603 | 1.5uH | 0603L |
L5 | 1100_S-1_0.8UH10%-350MA-15-0603 | 1.5uH | 0603L |
L6 | 1208_S-4.7UH30%-1.1A-SMD3X3_LS- | 4.7uH | LS-3X3 |
L7 | 1170_S-2.2UH30%-1.6A-SMD3X3_LS- | 2.2uH | LS-3X3 |
L8 | 1100_S-1_0.8UH10%-350MA-15-0603 | 1.5uH | 0603L |
L9 | 3210_S-BEAD-1K100MHZ-0402_0402L | 1K@100M | 0402L |
L10 | 1020_S-220NH5%-100MA-0402_0_040 | 330nH_NC | 0402L |
L11 | 3210_S-BEAD-1K100MHZ-0402_0402L | 1K@100M | 0402L |
L12 | 1202_S-4.7UH20%-1_0.7A-SNR3018_ | 2.2uH | LS-2_8X2 |
L13 | 1100_S-1_0.8UH10%-350MA-15-0603 | 1.5uH | 0603L |
L16 | 3210_S-BEAD-1K100MHZ-0402_0402L | 1K@100M | 0402L |
L17 | 3210_S-BEAD-1K100MHZ-0402_0402L | 1K@100M | 0402L |
L18 | 1020_S-220NH5%-100MA-0402_0_0_1 | 330nH | 0402L |
L19 | 1020_S-220NH5%-100MA-0402_0_0_1 | 330nH | 0402L |
L20 | 1020_S-220NH5%-100MA-0402_0_0_1 | 330nH | 0402L |
Q2 | 2010-01_S-NPN-LMBT3904-SOT23_SO | 3904 | SOT23 |
Q3 | 2100_S-PNP-MMBT3906-SOT23_SOT23 | 3906 | SOT23 |
T1 | 4050-TRANSFORMER-TRC1102NLE\HST | H1102 | STFM16-50-285 |
U1 | 1645_S-GPS-ANTENNACONN-S_WIFI-A | S-GPS-S | WIFI-ATENNER |
U2 | 2395_RT8096B-DCDC-1A/6V-SOT23-5 | RT8096B | SOT23-5 |
U8 | 3293_W25Q64FVSSIG-WSOP8_SOP8-7_ | W25Q64FVSSIG | SOP8-7_6-1_27 |
U11 | 2395_RT8096B-DCDC-1A/6V-SOT23-5 | RT8096B | SOT23-5 |
U13 | 2392_JW5051-SOT23-6-2A/23V_SOT2 | JW5051 | SOT23-6 |
U16 | SGM4891_4_SOP8-6-1_27_TC8002D | TC8002D | SOP8-6-1_27 |
U19 | XM530WX1-QFN96-V5_0_QFN96-1010- | XM550WX2 | QFN96-1010-0_35A |
U20 | 2395_RT8096B-DCDC-1A/6V-SOT23-5 | RT8096B | SOT23-5 |
U21 | 1101_TM1020-3.3V-SDIO-44PIN_QFN | XM712 | QFN44-1212-0_9A |
U38 | 2060_BL9193-1_2.5-SOT23-5_DFN4- | WL2820D-18 | DFN4-10X10-6_5X7_7 |
X1 | D-CRYS-32_0.768KHZ_XTAL-08S-A_3 | 32.768KHz | XTAL-08S-A |
X2 | 1041_S-XTL-12MHZ-SMD3225_XTAL32 | 12M | XTAL3225 |
