TA的每日心情 | 开心 2024-7-10 20:37 |
签到天数: 1 天 [LV.1]初来乍到
- 20876
NK980.7z
(441 KB, 下载次数: 6)
Name | Part Type | PCB Decal | Value | CON1 | POWRJACK\3P | POWRJACK\3P | | CON2 | HEADER2/2.54MM_M | HEADER2/2.54MM | | CON3 | HEADER10/2.54MM_M | SIP\10P | | CON4 | CONS/5X1/2.54 | SIP-5P | | CON5 | MICRO_USB_AB_LS | MICRO_USB_AB_LS | | CON6 | B8502A-13SB-HPA | B8502A-13SB-HPA | | CON7 | RJ45\8P\JA\LED | RJ45-8P8C/LED | | CON8 | RJ45\8P\JA\LED | RJ45-8P8C/LED | | CON9 | DB9_FMALE | DB9FM-L | | CON10 | HEADER4/2.54MM_M | SIP\4P | | CON11 | HEADER2/2.54MM_RS485 | SIP/2P_3.5MM | | CON12 | DB9_FMALE | DB9FM-L | | CON13 | HEADER4/2.54MM_M | SIP\4P | | CON14 | HEADER2/2.54MM_RS485 | SIP/2P_3.5MM | | CON15 | HEADER4/2.54MM_M | SIP\4P | | CON16 | HEADER6/2.54MM_M | SIP\6P | | CON17 | HEADER4/2.54MM_M | SIP\4P | | CON18 | HEADER6/2.54MM_M | SIP\6P | | CON19 | HEADER4/2.54MM_M | SIP\4P | | CON20 | HEADER4/2.54MM_M | SIP\4P | | CON21 | MICRO_USB_AB_LS | MICRO_USB_AB_LS | | CON22 | USB4P | USB4P | | CON23 | HEADER15X2/2.54MM_M | HEADER15X2/2.54MM_M | | CON24 | HEADER11X2/2.54MM_M | HEADER11X2 | | D1 | 403A-03 | DO-214AA | | D2 | 403A-03 | DO-214AA | | D3 | SOD-523 | SOD-523 | | D4 | SOD-523 | SOD-523 | | F1 | FUSE(6V/1A) | SIP\2P-2.54M | | F2 | FUSE(6V/1A) | SIP\2P-2.54M | | H1 | H-250 | H-250 | | H2 | H-250 | H-250 | | H3 | H-250 | H-250 | | H4 | H-250 | H-250 | | JP1 | HEADER3/2.54MM_M | SIP-3P | | JP2 | HEADER3/2.54MM_M | SIP-3P | | JP3 | HEADER_2X1_2.54MM | SIP\2P-2.54M | | K1 | STS-B5 | SW4-SMD | | K2 | STS-B5 | SW4-SMD | | K3 | STS-B5 | SW4-SMD | | K4 | STS-B5 | SW4-SMD | | K5 | STS-B5 | SW4-SMD | | K6 | STS-B5 | SW4-SMD | | L1 | SMTDR43 | SMTDR43 | | L2 | SMTDR43 | SMTDR43 | | L3 | SMTDR43 | SMTDR43 | | Q1 | SOT-23BEC | SOT23-BEC | | Q2 | SOT23-GSD | SOT23-GSD | | Q3 | SOT23-GSD | SOT23-GSD | | Q4 | SOT23-GSD | SOT23-GSD | | Q5 | SOT23-GSD | SOT23-GSD | | Q6 | SOT23-GSD | SOT23-GSD | | SW1 | DIPSWX2_2.54MM | SW-DIP4 | | SW2 | STS-B5 | SW4-SMD | | U1 | TDFN2X2-8 | TDFN2X2-8 | | U2 | TSOT-25 | TSOT-25 | | U3 | TSOT-25 | TSOT-25 | | U4 | TSOT-25 | TSOT-25 | | U5 | LQFP-128 | LQFP128 | | U6 | QFN33_5X5 | QFN_32 | | U7 | SOIC16_300 | SOP16/10.4/1.27 | | U8 | SOIC8_208 | SOIC-8P_208MIL | | U9 | QFN32 | QFN32P-0.4X4M | | U10 | ST6200T | TS6121C | | U11 | QFN32 | QFN32P-0.4X4M | | U12 | ST6200T | TS6121C | | U13 | SOP16/150 | SOP16/150 | | U14 | SOP8/6.0/1.27 | SOP8/6.0/1.27 | | U15 | SOP16/150 | SOP16/150 | | U16 | SOP8/6.0/1.27 | SOP8/6.0/1.27 | | X1 | XTAL_2P/1.5MM | TXC-9H_T9 | | X2 | TXC7M-3.2X2.5MM | SMD3225 | 12MHz | X3 | TXC7M-3.2X2.5MM | SMD3225 | 12MHz | X4 | TXC7V-3.2X2.5MM | SMD3225 | 12MHz | X5 | TXC7V-3.2X2.5MM | SMD3225 | 12MHz |
