查看: 5594|回复: 42
[Allegro17.4以下] Acer/宏碁 ATC708-N90主板 H11H4- AD2 Rev 1.1 电脑主板PCB文件
    17万
    管理员
    原创先锋奖终身成就奖优秀斑竹奖宣传大使奖社区居民社区明星社区劳模最爱沙发新人进步奖忠实会员金点子奖特殊贡献奖
    发表于 2021-3-20 15:36:15 | 显示全部楼层 |阅读模式
    重要提示:PCB作品文件展下载说明
    A1J2X1h2x1-whJ2X1
    A2J2X1h2x1-whJ2X1
    ATX_12VATX_PWR_4P_2pw-4p2rATX_PWR_4P_2
    ATX_POWERATX_PWR_24P_1atx-pw-24p2rATX_PWR_24P_1
    AUDIOAUDIO_JACK_13P-COLAY_2au-13p-bl+li+pkAUDIO_JACK_13P-COLAY_2
    BAT1BATTERY_HOLDER_CR2032-LOTESsk-cr2032-dBATTERY_HOLDER_CR2032-LOTES
    BOSS1HOLE_TC256BC180D165PTboss_m2_h1.45HOLE_TC256BC180D165PT
    BOSS2HOLE_TC256BC180D165PTboss_m2_h1.45-oHOLE_TC256BC180D165PT
    BOSS3HOLE_TC256BC180D165PTboss_m2_h1.45HOLE_TC256BC180D165PT
    BT1BAT54_132_2bat54a-sBAT54_132_2
    BT2BAT54_132_2bat54a-s-oBAT54_132_2
    BT3BAT54_132_2bat54a-sBAT54_132_2
    BZBUZZER_1buzzer-dBUZZER_1
    CHOKE1WCM2012F2S_1cmk-90-08-hdmi-oWCM2012F2S_1
    CHOKE12WCM2012F2S_1cmk-50-08-usb3.0-oWCM2012F2S_1
    CHOKE13WCM2012F2S_1cmk-90-08-oWCM2012F2S_1
    CHOKE14WCM2012F2S_1cmk-90-08-oWCM2012F2S_1
    CHOKE15WCM2012F2S_1cmk-50-08-usb3.0-oWCM2012F2S_1
    CHOKE16WCM2012F2S_1cmk-50-08-usb3.0-oWCM2012F2S_1
    CHOKE17WCM2012F2S_1cmk-50-08-usb3.0-oWCM2012F2S_1
    CHOKE18WCM2012F2S_1cmk-50-08-usb3.0-oWCM2012F2S_1
    CLR_CMOSJ3X1h3x1-rJ3X1
    CMK1CMM21_R0402cmk-90-08-oCMM21_R0402
    CMK2CMM21_1cmk-90-08-oCMM21_1
    CMK3CMM21_1cmk-90-08-oCMM21_1
    CODECLQFP48alc662-vd0-grsLQFP48
    CPU1LGA1151-INTELskl_s_cpu_lgaLGA1151-INTEL
    CPU_FANJ4X1_WAFERh4x1-porJ4X1_WAFER
    D1SOT23_2MM_2bat54a-sSOT23_2MM_2
    D2SOT23_2MM_2bat54a-sSOT23_2MM_2
    D3SOT23_3Laz5125-02s-sSOT23_3L
    D12SOD_523az5125-01h-sSOD_523
    D13SOT23_3Lbav99-sSOT23_3L
    D14SOT23_3Laz5125-02s-sSOT23_3L
    D15SOT23_3Lbat54c-s-oSOT23_3L
    D16SOD_123_21n4148-sSOD_123_2
    D17SOT23_3Lbat54c-sSOT23_3L
    D18SOD_123_21n4148-sSOD_123_2
    D19FPC_4P10_R_1esd3v3u4ulc-oFPC_4P10_R_1
    D20FPC_4P10_R_1esd3v3u4ulc-oFPC_4P10_R_1
    D21SOD_123_21n4148-sSOD_123_2
    D22SOT23_3Lbat54c-s-oSOT23_3L
    D23SOT23_3Lbav99-s-oSOT23_3L
    D24SOT23_3Lbav99-s-oSOT23_3L
    D25SOT23_3Lbat54c-s-oSOT23_3L
    DIMM1DDR3_240P_2ddr3-240p-blDDR3_240P_2
    DIMM2DDR3_240P_2ddr3-240p-blDDR3_240P_2
    EC1EC2D5_6D3_H11MM100u-16deEC2D5_6D3_H11MM
    EC2EC2D5_6D3_H11MM220u-16deEC2D5_6D3_H11MM
    EC3EC2D5_6D3_H11MM100u-16deEC2D5_6D3_H11MM
    EC4EC2D5_6D3_H11MM100u-16deEC2D5_6D3_H11MM
    EC5EC2D5_6D3_H11MM100u-16deEC2D5_6D3_H11MM
    EC6EC2D5_6D3_H11MM220u-16deEC2D5_6D3_H11MM
    EC7EC3D5_8_H11MM_1P270u-16d-osEC3D5_8_H11MM_1P
    EC8EC3D5_8_H11MM_1P270u-16d-os-oEC3D5_8_H11MM_1P
    EC9EC3D5_8_H11MM_1P270u-16d-osEC3D5_8_H11MM_1P
    EC10EC3D5_8_H11MM_1P470u-16de-oEC3D5_8_H11MM_1P
    EC11EC3D5_8_H11D5MM_1P1000u-6v3ld8h11e-oEC3D5_8_H11D5MM_1P
    EC12EC2D5_6D3_H8MM560u-6v3ld6h8eEC2D5_6D3_H8MM
    EC13EC2D5_6D3_H8MM560u-6v3ld6h8eEC2D5_6D3_H8MM
    EC14EC2D5_6D3_H8MM560u-6v3ld6h8eEC2D5_6D3_H8MM
    EC15EC2D5_6D3_H8MM560u-6v3ld6h8eEC2D5_6D3_H8MM
    EC16EC200_260_SMD560u-2v5lod6h5.9eEC200_260_SMD
    EC17EC2D5_6D3_H8MM560u-6v3ld6h8eEC2D5_6D3_H8MM
    EC18EC2D5_6D3_H8MM560u-6v3ld6h8eEC2D5_6D3_H8MM
    EC19EC2D5_6D3_H8MM560u-6v3ld6h8e-oEC2D5_6D3_H8MM
    EC20EC3D5_8_H11MM_1P270u-16d-osEC3D5_8_H11MM_1P
    EC21EC2D5_6D3_H8MM560u-6v3ld6h8eEC2D5_6D3_H8MM
    EC22EC2D5_6D3_H8MM560u-6v3ld6h8eEC2D5_6D3_H8MM
    EC23EC2D5_6D3_H8MM560u-6v3ld6h8eEC2D5_6D3_H8MM
    EC24EC2D5_6D3_H8MM560u-6v3ld6h8eEC2D5_6D3_H8MM
    EC25EC2D5_6D3_H11MM100u-16deEC2D5_6D3_H11MM
    EC26EC2D5_6D3_H11MM100u-16deEC2D5_6D3_H11MM
    EC27EC2D5_6D3_H9MM560u-6v3ld6h8eEC2D5_6D3_H9MM
    EC28EC2D5_6D3_H9MM560u-6v3ld6h8eEC2D5_6D3_H9MM
    EC29EC2D5_6D3_H9MM560u-6v3ld6h8eEC2D5_6D3_H9MM
    EC30EC2D5_6D3_H11MM100u-16deEC2D5_6D3_H11MM
    EC31EC2D5_6D3_H11MM220u-16deEC2D5_6D3_H11MM
    EC32EC2D5_6D3_H11MM100u-16de-oEC2D5_6D3_H11MM
    EC33EC2D5_6D3_H12D5MM470u-6v3d6h11e-oEC2D5_6D3_H12D5MM
    EC34EC2D5_6D3_H8MM820u-2v5d6h8eEC2D5_6D3_H8MM
    EC35EC2D5_6D3_H12D5MM470u-6v3d6h11eEC2D5_6D3_H12D5MM
    EC36EC2D5_6D3_H11MM220u-16deEC2D5_6D3_H11MM
    F1FUSE_SMD_1fuse-1.1a-18FUSE_SMD_1
    F2FUSE_SMD_1fuse-1.1a-18FUSE_SMD_1
    FB1FB0402_2fb-30-04-b-oFB0402_2
    FB2FB0402_2fb-30-04-b-oFB0402_2
    FB3FB0402_2fb-30-04-b-oFB0402_2
    F_AUDIOJ5X2_AUDIO_1h5x2-p-p8eJ5X2_AUDIO_1
    F_PANELJ7X2_PANEL_10Ph7x2-bk-p10eJ7X2_PANEL_10P
    F_USB1J5X2_USB_1394h5x2-bk-p9eJ5X2_USB_1394
    F_USB2J5X1_CRh5x1-y-p5eJ5X1_CR
    HDMI2HDMI_19P-F_SMD-HIGH-TOP_5hdmi-19p_hi-topHDMI_19P-F_SMD-HIGH-TOP_5
    L8WCM2012F2S_1cmk-90-08-muti-taitechWCM2012F2S_1
    L9L0805_2ind-10u-08L0805_2
    L10FB0805_2fb-120-s08-5aFB0805_2
    L11CHOKE_NLC252018_SMD_2Pind-4.7u-29x25x21CHOKE_NLC252018_SMD_2P
    L12CHOKE_9D5X11_PT7MM_H_2rck-0.5ud-oCHOKE_9D5X11_PT7MM_H_2
    L13CHOKE_R30_PT6D3X1D4MM_1pind-0.3u-38aCHOKE_R30_PT6D3X1D4MM_1
    L14CHOKE_R30_PT6D3X1D4MM_1pind-0.3u-38aCHOKE_R30_PT6D3X1D4MM_1
    L15CHOKE_PT3D5X5D5MMpind-0.47u-dipCHOKE_PT3D5X5D5MM
    L16CHOKE_R30_PT6D3X1D4MM_1pind-0.3u-38aCHOKE_R30_PT6D3X1D4MM_1
    L17CHOKE_R30_PT6D3X1D4MM_1pind-0.3u-38aCHOKE_R30_PT6D3X1D4MM_1
    L18CHOKE_R30_PT6D3X1D4MM_1pind-0.3u-38aCHOKE_R30_PT6D3X1D4MM_1
    L19CHOKE_PT5D45MM_SMDpind-1.0u-d-smdCHOKE_PT5D45MM_SMD
    L20FB0805_2fb-120-s08-5aFB0805_2
    L21CMM21_R0402cmk-90-08-oCMM21_R0402
    L22CHOKE_1R0M_PT6D6X4D8MMinc0809-1r0m-jy1wCHOKE_1R0M_PT6D6X4D8MM
    L23CHOKE_1R0M_PT6D6X4D8MMinc0809-1r0m-jy1wCHOKE_1R0M_PT6D6X4D8MM
    L24FB0603_2fb120FB0603_2
    L25WCM2012F2S_1cmk-90-08-oWCM2012F2S_1
    L26WCM2012F2S_1cmk-90-08-oWCM2012F2S_1
    LPC_DEBUGJ10X2_JLPCh10x2-bk-p4e-oJ10X2_JLPC
    M2_1CON75P_PT05_SMD_P24_31-LOTESm2_2230_keye_h3.2CON75P_PT05_SMD_P24_31-LOTES
    M2_2CON75P_PT05_SMD_B-LOTESm2_2280_keyb_h3.2CON75P_PT05_SMD_B-LOTES
    ME_DISABLEJ3X1h3x1-b-oJ3X1
    ME_TESTJ3X2h3x2-b-oJ3X2
    PCH1BGA837-INTEL_1spt_pch_dtBGA837-INTEL_1
    PCIE1XPCIE_X1_36P_2pciex1-wPCIE_X1_36P_2
    PCIE16XPCIE_X16_164P_4pciex16-gyPCIE_X16_164P_4
    PFB1FB0402_20-04-oFB0402_2
    PFB2FB0402_20-04-oFB0402_2
    PFB3FB0402_2fb-60-04-b-oFB0402_2
    PFB4FB0402_2fb-60-04-b-oFB0402_2
    PFB5FB0805_20-08FB0805_2
    PFB6FB0402_20-04-oFB0402_2
    PFB7FB0805_2fb-120-s08-5aFB0805_2
    PFB8FB0805_2fb-120-s08-5aFB0805_2
    PFB9FB0805_2fb-120-s08-5aFB0805_2
    PFB10FB0603_2fb600-06FB0603_2
    Q1SOT363_6Phbn2040s6r-s-oSOT363_6P
    Q2SOT363_6Phbn2040s6r-sSOT363_6P
    Q3SOT363_6Phbn2040s6r-sSOT363_6P
    Q4SOT363_6Phbn2040s6r-sSOT363_6P
    Q5SOT363_6Phbn2040s6r-sSOT363_6P
    Q6SOT23_BCE_2pmbs3906-sSOT23_BCE_2
    Q7SOT23_BCE_2pmbs3906-sSOT23_BCE_2
    Q8SOT23_BCE_2pmbs3906-sSOT23_BCE_2
    Q39SOT23_BCE_2mmbt3904-sSOT23_BCE_2
    Q40SOT23_BCE_2mmbt3904-sSOT23_BCE_2
    Q44SOT23_BCE_2pmbs3906-sSOT23_BCE_2
    QBH1Q_TDSON8-GDS-4sm4377nskpc-trg-sQ_TDSON8-GDS-4
    QBL1Q_TDSON8-GDS-4sm4364nakpc-trg-sQ_TDSON8-GDS-4
    QCGH1Q_TDSON8-GDS-4sm4377nskpc-trg-sQ_TDSON8-GDS-4
    QCGH2Q_TDSON8-GDS-4sm4377nskpc-trg-sQ_TDSON8-GDS-4
    QCGL1Q_TDSON8-GDS-4sm4364nakpc-trgQ_TDSON8-GDS-4
    QCGL2Q_TDSON8-GDS-4sm4364nakpc-trgQ_TDSON8-GDS-4
    QCGL3Q_TDSON8-GDS-4sm4364nakpc-trgQ_TDSON8-GDS-4
    QCGL4Q_TDSON8-GDS-4sm4364nakpc-trgQ_TDSON8-GDS-4
    QCH1Q_TDSON8-GDS-4sm4377nskpc-trg-sQ_TDSON8-GDS-4
    QCH2Q_TDSON8-GDS-4sm4377nskpc-trg-sQ_TDSON8-GDS-4
    QCH3Q_TDSON8-GDS-4sm4377nskpc-trg-sQ_TDSON8-GDS-4
    QCL1Q_TDSON8-GDS-4sm4364nakpc-trgQ_TDSON8-GDS-4
    QCL2Q_TDSON8-GDS-4sm4364nakpc-trgQ_TDSON8-GDS-4
    QCL3Q_TDSON8-GDS-4sm4364nakpc-trgQ_TDSON8-GDS-4
    QCL4Q_TDSON8-GDS-4sm4364nakpc-trgQ_TDSON8-GDS-4
    QCL5Q_TDSON8-GDS-4sm4364nakpc-trgQ_TDSON8-GDS-4
    QCL6Q_TDSON8-GDS-4sm4364nakpc-trgQ_TDSON8-GDS-4
    QCSH1Q_TDSON8-GDS-4sm4377nskpc-trg-sQ_TDSON8-GDS-4
    QCSL1Q_TDSON8-GDS-4sm4364nakpc-trgQ_TDSON8-GDS-4
    QN1SOT23_2MM_2nx7002ak-sSOT23_2MM_2
    QN2SOT23_2MM_2nx7002ak-sSOT23_2MM_2
    QN18SOT23_2MM_2nx7002ak-s-oSOT23_2MM_2
    QN19SOT23_2MM_2nx7002ak-s-oSOT23_2MM_2
    QN20DFN6_PT065_SM2203NSQGsm2203nsqgDFN6_PT065_SM2203NSQG
    QN40SOT23_2MM_2nx7002ak-s-oSOT23_2MM_2
    QSW1SOT23_GDS_2sm2313psac-trg-s-oSOT23_GDS_2
    QSW2SOP8_W150_PT50apm4500akc-trg-sSOP8_W150_PT50
    RN128P4R-0402150-8p4r-048P4R-0402
    RN138P4R0-8p4r8P4R
    RT1R0402_2ntc-100k-1-04R0402_2
    RT2R0402_2ntc-10k-1-04R0402_2
    RT3R0402_2ntc-100k-1-04R0402_2
    RT4R0402_2ntc-10k-1-04R0402_2
    SATA1SATA3_7P-HI-TOPsata3-7p2r-rSATA3_7P-HI-TOP
    SATA2SATA3_7P-HI-TOPsata3-7p2r-rSATA3_7P-HI-TOP
    SC19C0402_210p-04-x-oC0402_2
    SC20C0603_4D7UF22u-6v3x5-xC0603_4D7UF
    SC645C0402_21u-6v3x5-04-x-oC0402_2
    SP1SHORT2-NMNPshortpadSHORT2-NMNP
    SP2SHORT2-NMNPshortpadSHORT2-NMNP
    SP3SHORT2-NMNPshortpadSHORT2-NMNP
    SP4SHORT2-NMNPshortpadSHORT2-NMNP
    SP5SHORT2-NMNPshortpadSHORT2-NMNP
    SP6SHORT2-NMNPshortpadSHORT2-NMNP
    SP7SHORT2-NMNPshortpadSHORT2-NMNP
    SP8SHORT2-NMNPshortpadSHORT2-NMNP
    SP9SHORT2-NMNPshortpadSHORT2-NMNP
    SP10SHORT2-NMNPshortpadSHORT2-NMNP
    SPIROM1SOP8_W210_PT50_SPI_1spi-8p-bk-oSOP8_W210_PT50_SPI_1
    SPI_DEBUGJ5X2_PT1D27MM_SMD_2P_1h5x2-bk-p2e-p1.27-oJ5X2_PT1D27MM_SMD_2P_1
    SQ42SOT23_BCE_2mmbt3904-s-x-oSOT23_BCE_2
    SQ43SOT23_BCE_2mmbt3904-s-x-oSOT23_BCE_2
    STP74TP30_SMDtpTP30_SMD
    SY1CRYSTAL_4P_PT2D2X1D6_SMDx-24m-smd-xCRYSTAL_4P_PT2D2X1D6_SMD
    SYS_FANJ4X1_WAFERh4x1-powJ4X1_WAFER
    TP20TP30_SMDtpTP30_SMD
    U1SOT23_6P_2azc099-04s-r7g-s-oSOT23_6P_2
    U2SOT23_6P_2azc099-04s-r7g-s-oSOT23_6P_2
    U3FPC_4P10_R_1az1045-04f-s-oFPC_4P10_R_1
    U4FPC_4P10_R_1az1045-04f-s-oFPC_4P10_R_1
    U5SOT23_5P_1u74lvc1g32g-af5-r-oSOT23_5P_1
    U6SOT23_5P_1u74lvc1g32g-af5-r-oSOT23_5P_1
    U7QFN40_PT04_E2201it6516afn_qfn-40-oQFN40_PT04_E2201
    U8SOT23_6P_2azc099-04s-r7g-s-oSOT23_6P_2
    U9FPC_4P10_R_1az1045-04f-s-oFPC_4P10_R_1
    U10FPC_4P10_R_1az1045-04f-s-oFPC_4P10_R_1
    U11SOT23_6P_2azc099-04s-r7g-s-oSOT23_6P_2
    U12FPC_4P10_R_1esd3v3u4ulc-oFPC_4P10_R_1
    U13FPC_4P10_R_1esd3v3u4ulc-oFPC_4P10_R_1
    U14SOT23_6P_2azc099-04s-r7g-s-oSOT23_6P_2
    U15PSOP8_W150_PT50_PAD-UP7719B_1up7537bsu8sPSOP8_W150_PT50_PAD-UP7719B_1
    U16SOT23_6P_2azc099-04s-r7g-s-oSOT23_6P_2
    U17SOT23_6P_2az1013-04sSOT23_6P_2
    U18SOT23_6P_2az1013-04sSOT23_6P_2
    U19QFN52_PT04_NCP61X1S_1isl95858hrzQFN52_PT04_NCP61X1S_1
    U20SOT23_8P_1up7536ama8sSOT23_8P_1
    U21QFN32_PT04_NCP81102rtl8111ga-cgQFN32_PT04_NCP81102
    U22DFN10_PT05_RT8015A_1up1537DFN10_PT05_RT8015A_1
    U23SOT353_5P74lvc1g08gwsSOT353_5P
    U24DFN8_PT05_ISL6208_1isl95808DFN8_PT05_ISL6208_1
    U25PSOP8_W150_PT50_PAD-UP6281_1up0104ssw8-oPSOP8_W150_PT50_PAD-UP6281_1
    U26DFN8_NCP5359A_1apl3529aDFN8_NCP5359A_1
    U27DFN8_PT05_ISL6208_1isl95808DFN8_PT05_ISL6208_1
    U28FCQFN16_RT7290A_NB669nb671FCQFN16_RT7290A_NB669
    U29SOT353_5P74lvc1g14gw-oSOT353_5P
    U30SOT23_8P_1up7536ama8sSOT23_8P_1
    U31QFN32_PT04_UP1740Q_2up1740pQFN32_PT04_UP1740Q_2
    U32SOT23_6P_2azc099-04s-r7g-s-oSOT23_6P_2
    U33PSOP8_W150_PT50_PAD-UP7719B_1up7537bsu8sPSOP8_W150_PT50_PAD-UP7719B_1
    U34SOP8_W150_PT50gs358sfs-oSOP8_W150_PT50
    U35DFN10_PT05_RT8015A_1up1537DFN10_PT05_RT8015A_1
    U36PSOP8_W150_PT50_PAD-UP6281_1up0104ssw8PSOP8_W150_PT50_PAD-UP6281_1
    U37QFN16_PT05_2D1X2D6MM5v2305nrgi8s-oQFN16_PT05_2D1X2D6MM
    U38TQFP64_PT04_F71808Ait8613e-bxTQFP64_PT04_F71808A
    U39SOT23_6P_2azc099-04s-r7g-s-oSOT23_6P_2
    U40SOT23_8P_1up7536ama8sSOT23_8P_1
    U41SOT353_5P74lvc1g14gwSOT353_5P
    U42SOT23_6P_2azc099-04s-r7g-s-oSOT23_6P_2
    U43SON6_SOT891_PT035_74AUP1G0874aup1g08gf-oSON6_SOT891_PT035_74AUP1G08
    USB2_LANRJ45_USB_22P-ICOTHING_2usbx2-lan-1000-6k/2k-speedtechRJ45_USB_22P-ICOTHING_2
    USB3F1CON10X2_2MM_20P_USB3_1h10x2-p20e-bkCON10X2_2MM_20P_USB3_1
    USB3X2USB3_18P4R-LOTES-SHORTBODY_1usb3x2-sbUSB3_18P4R-LOTES-SHORTBODY_1
    VGAD-SUB_15P-HDR-HTconn-vga-stbl-oD-SUB_15P-HDR-HT
    WBT_LEDJ4X1_PT2D5MM-LONGSHOUNG_1h4x1-wawh-p2.5-oJ4X1_PT2D5MM-LONGSHOUNG_1
    X1CRYSTAL_PT4D88MM-AT49_2x-25m-30m20dCRYSTAL_PT4D88MM-AT49_2
    Y1ETXTALS-SPAD_1x-32.768kETXTALS-SPAD_1
    Z1JOPEN_200X60jopen_200x60milJOPEN_200X60
    Z2JOPEN_200X60-NMNPjopen_200x60-nmnpJOPEN_200X60-NMNP
    Z3JOPEN_200X60-NMNPjopen_200x60-nmnpJOPEN_200X60-NMNP
    重要提示:PCB作品文件展下载说明
    17万
    管理员
     楼主| 发表于 2021-3-20 15:38:38 | 显示全部楼层
    PCB文件来了。 回复可见。销售20金币。
    游客,如果您要查看本帖隐藏内容请回复
    发表于 2021-3-20 17:10:43 | 显示全部楼层
    10 小时前
  • 签到天数: 233 天
    发表于 2021-3-20 17:23:13 | 显示全部楼层
    头像被屏蔽
    禁止发言
    发表于 2021-3-20 20:18:21 | 显示全部楼层
    提示: 作者被禁止或删除 内容自动屏蔽
    终身成就奖社区居民优秀斑竹奖
    发表于 2021-3-20 20:21:58 | 显示全部楼层
    谢谢分享ATC708-N90主板 H11H4- AD2 Rev 1.1 电脑主板PCB
    发表于 2021-3-20 20:29:34 | 显示全部楼层
    PADS20201123初级班
    发表于 2021-3-20 21:07:29 | 显示全部楼层
    前天 19:56
  • 签到天数: 90 天
    发表于 2021-3-20 22:44:01 | 显示全部楼层
    发表于 2021-3-21 08:02:45 | 显示全部楼层
