查看: 1093|回复: 2
[技术文章] Altium Designer14 图文安装步骤教程和破解教程
PADS-190603高级班
社区居民忠实会员终身成就奖
发表于 2021-4-23 13:34:57 | 显示全部楼层 |阅读模式
先网上下载Altium Designer14安装包解压出来
找着解压后的文件夹,双击打开setup.exe
3ac71c214f579356f0b0f994effb960b302170a3.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500% (27.12 MB, 下载次数: 0)
点击“NEXT”即可
f9617afb960b3121ad6a0517dee983aee9d76da3.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500% (259.3 MB, 下载次数: 0)
选择select language “Chinese”;选择”I accept the agreement”;单击:”NEXT“
04201aa355e983ae44dc589e68efe078153169a3.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500% (278.86 MB, 下载次数: 0)
下图中的步骤1保持默认,单击NEXT.
82eff6d7592ae3ef4f73158554b6326c566664a3.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500% (279.65 MB, 下载次数: 0)
(1)选择”程序安装文件夹”,(2)选择”共享文件夹,(3)点击“NEXT”
e1390a31dfb6326ce46d987b89532f63228560a3.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500% (269.08 MB, 下载次数: 0)
点击“NEXT”
988e1c532f632385583de325cce833e038725da3.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500% (257.52 MB, 下载次数: 0)
等待安装
e177fc9147e833e085793cb730ea3e86314859a3.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500% (253.82 MB, 下载次数: 0)
32a127723d03bbea818d31fcea43d7d4493154a3.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500% (255.14 MB, 下载次数: 0)
当出现下图时,一定不要手贱点cancel,要做的只需等待
3fc72e486143d7d48b3a055f7da75f0f832b50a3.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500% (283.38 MB, 下载次数: 0)
当出现下图时,你就安装成功了,这时要把”launch Altium Designer“之前的勾去掉,再点“finish”.千万不要直接运行软件,否者会影响后面的破解过程。
d695563104ebf6a79904839fffee1c324a184fa3.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500% (255.43 MB, 下载次数: 0)
破解方法1.将medicine文件夹里的DXP.exe复制到软件安装目录里下,覆盖原来的文件
2.启动Altium Designer14,进入界面后找到如下图中的“Add standalone license file”3.添加licenses文件夹里的任意一个许可文件即可激活,并且提示你的到期时间
f7e6410f822b74eed5394aacda2c8cf1d9a74aa3.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500% (38.85 MB, 下载次数: 0) 75af02324b18512c40fad913ad334884cce349a3.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500% (31.47 MB, 下载次数: 0)
    发表于 2021-4-25 08:08:18 | 显示全部楼层
    AD 更新换代的速度 很快
    PADS20210122高级班
    发表于 2021-4-25 08:57:34 | 显示全部楼层
