[li]
先关闭杀毒软件及防火墙。[/li][li]2 [/li]
在虚拟光驱加载下载来的 ISO 文件,打开 虚拟光驱对应的盘符,如下图,运行 AltiumInstaller.exe。
de9bfa3b3b86022124d4a4e5d8bbf82065fb72da.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500%
(154.82 MB, 下载次数: 0)
启动程序安装画面。卸载的时候不能在控制面板中卸载,也是到这个目录下运行“AltiumUninstaller.exe” 4
点击“Next”进入下一步
30601b6104a355e9f62ddf64d22ae3efe17868da.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500%
(192.92 MB, 下载次数: 0)
选择语言“Chinese”,勾上“I accept the agreement”,点击“Next”进入下一步。
def72c6c576699cf7dd018d0a885e036e3915eda.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500%
(294.17 MB, 下载次数: 0)
保持默认设置,点击“Next”进入下一步。
6002c9d4483104eb792468bc092b74ee1d324eda.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500%
(210.31 MB, 下载次数: 0)
选择“PCB and Soft Design”,点击“Next”进入下一步。
1d735518512c8cf14f241180c384cde34a2c46da.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500%
(140.58 MB, 下载次数: 0)
选择安装路径,点击“Next”进入下一步。
49c5d3e34b2c56eee6fcb1bdf775e5f4fdf540da.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500%
(221.85 MB, 下载次数: 0)
9
点击“Next”进入下一步。
3b8fb4d7726b0ce2c26403bcef781423bfb9b6da.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500%
(168.53 MB, 下载次数: 0)
程序安装中……,待进度条完成后自动进入下一步。
ba97ffd06de89a6134a6762045e8b004551badda.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500%
(180.72 MB, 下载次数: 0)
点击“Finish”完成安装。
(最好不要勾选“Launch Altium Designer”,勾选了会自动打开软件,而此时还没有完成破解步骤)
d04eec260d9a310eac1ade9931b842406bfea2da.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500%
(167.21 MB, 下载次数: 0)
打开虚拟光驱目录,拷贝“!CRACK”文件夹到电脑中。
4080a927ac53068856af927957e8904801fc96da.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500%
(196.01 MB, 下载次数: 0)
13
打开“!CRACK”文件夹,用记事本打开”AD10.INI“文件。
3761a73acd8920c5f38cbf86568a59de440788da.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500%
(200.12 MB, 下载次数: 0)
14
图中文字说明
3931cb413a8ca6087a8ca34fdb8c9bcec6f8feda.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500%
(226.33 MB, 下载次数: 0)
运行“Генератор лицензии ALTIUM-(RU).EXE“
5c9c964ce54a2f270e6c1fb5e00192dd3240f4da.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500%
(226.27 MB, 下载次数: 0)
16
有三个按钮,点击第一个。
979906196120a7cd0deacc4189b375d7987bdcda.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500%
(96.33 MB, 下载次数: 0)
17
选择之前修改好的“AD10.INI“文件。
fab31cb375d7997bbd70edebf9dade49600fd9da.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500%
(45.82 MB, 下载次数: 0)
18
有三个按钮,点击第二个
739bc049610f8b56a18019db9ce951e10ff8d3da.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500%
(96.86 MB, 下载次数: 0)
选择目录保存所生成的” *.alf”。
可以直接保存到 Altium Designer 的安装目录下,也可以保存任 意目录,生成后再拷贝到安装目录。
2f2909e951e10ef849d2e28e2324d8e9cdd2ccda.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500%
(45.92 MB, 下载次数: 0)
保存后会弹出以下界面,直接点击“确定“。
d9a8d2d2bb6651599dc427998fe23ea23b42c7da.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500%
(21 MB, 下载次数: 0)
有三个按钮,点击第三个。退出许可文件生成器。
3fe32442a07aa010a3b7db8bbfbb19efa35f3edb.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500%
(98.05 MB, 下载次数: 0)
将生成的文件拷贝到 Altium Designer 的安装目录下“X :\Program Files\Altium\AD 10 “
18aebc5f0c14c27bf406b13a2a46b7b1eff939db.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500%
(173.13 MB, 下载次数: 0)
将 DXP патченый 文件夹下的“DXP.EXE “文件
拷贝到 Altium Designer 的安装目录下“X:\Program Files\Altium\AD 10 “
efb861bd4c7c34b312c504095841037de03731db.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500%
(149.11 MB, 下载次数: 0)
选择替换同名的文件。
c8373cbc7dc5cf671cdbe2f58e96b814f5d026db.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500%
(98.94 MB, 下载次数: 0)
图中文字说明
04d7a614f4d0b503f556714dcc4ec28332bf20db.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500%
(182.14 MB, 下载次数: 0)
至此,安装破解的整个过程完毕。
、验收,开始菜单中运行:Altium Designer Release 10
弹出启动画面。
3aae2b4f50b8b43eee5f60f97132939c2df719db.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500%
(134.03 MB, 下载次数: 0)
启动过程中会弹出对话框,提示您是否导入使用之前版本的一些设置。按个人的情况选择。
dd58d02c5b1b1edea458978a981fceecd2d90fdb.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500%
(35.04 MB, 下载次数: 0)
如上一步选“yes“则会弹出加载之前版本设置的过程
1f03436b04d14929c50c0ea063e5eceeacbc7edb.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500%
(16.45 MB, 下载次数: 0)
启动画面完毕后,如果按钮是灰色的(即不可按),此时需要手动加载许可文件。
点击“Add standalone license file“,选择之前生成的”*.alf”文件既可。
acfda02f47704618b85ed388b08602214e5776db.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500%
(130.7 MB, 下载次数: 0)
