[li]
新建或者打开一个PCB库文件。
e86ba4b842406afe5bdeae711eee41c1b6279f62.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500%
(186.03 MB, 下载次数: 0)
ad121888912ca5ca7d22cffc8bfc77f7990e9462.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500%
(116.8 MB, 下载次数: 0)
[/li][li]2
点击菜单栏的“Tools ->Component Wizard”进入封装设计向导。
423041db3620b93a66437f71ad0f8835dc8a8a62.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500%
(187.94 MB, 下载次数: 0)
[/li][li]3
点击Next
589f5b0788013870618b65382d08a50f95fc8362.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500%
(144.62 MB, 下载次数: 0)
[/li][li]4
选择封装类型和单位类型,上面的列表框为封装类型,下面的下拉框为单位,确认后点击“Next”。
95bd4e8c9bcec7f836bd0269034ce54a2e27fb62.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500%
(110.51 MB, 下载次数: 0)
2e66f9ef28066b0156176cf43df39187021cf362.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500%
(108.41 MB, 下载次数: 0)
[/li][li]5
选择焊盘尺寸,可以设置各层的内径、外径,确认后点击“Next”。
90c61d1c99c0affc2a4c7b9b2372941fbfe4ea62.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500%
(97.03 MB, 下载次数: 0)
[/li][li]6
选择焊盘间距,确认点击“Next”
a9338a1fbee434da21941597f271fe1d97d8e462.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500%
(88.24 MB, 下载次数: 0)
[/li][li]7
选择丝印宽度,Ok后点击“Next”
7830e01d96d81819b6eaf879876efbf203b3de62.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500%
(78.79 MB, 下载次数: 0)
[/li][li]8
选择所需的引脚数码,确认后点击“Next”
0d2fe5f202b375d744b1e440515872dadf49d862.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500%
(84.63 MB, 下载次数: 0)
[/li][li]9
输入封装名称,之后点击“Next”
db196cdade49610f689cf2b0a56817e950e1d262.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500%
(71.93 MB, 下载次数: 0)
[/li][li]10
以向导设计封装结束,点击“Finish”。
50a010f85856d53d43ee875d47d2bb665059ca62.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500%
(139.05 MB, 下载次数: 0)
ba274f598540102af6286116b142a07aa110c562.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500%
(204.86 MB, 下载次数: 0)
END[/li]
全程手动画封装[backcolor=url(&amp][/table]
[li]
点击菜单栏的“Tools ->New Blank Component”
bd72f23834bb19ef599553a0497bd28287893a63.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500%
(256.84 MB, 下载次数: 0)
[/li][li]
PCB库的“PCB Library”视图的“Components”的列表中出现新的原件,双击它可更改封装名称。
a007a9b1eef97fbd48b76b07b74133bad2413363.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500%
(144.83 MB, 下载次数: 0)
d2001d7de137c9762e77227144672b5fd4462b63.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500%
(20.07 MB, 下载次数: 0)
[/li][li]
在Name文本框中输入封装名称,在Height中输入高度,在Description中输入备注信息,确认后点击“OK”。
d4071b96b814f4d0a1c89766cdfe474ec3832363.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500%
(19.29 MB, 下载次数: 0)
460fdc8333bf3bef2e840f0c3f3ea8db564a1a63.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500%
(136.77 MB, 下载次数: 0)
[/li][li]
在工具栏选择“焊盘”,放一个到封装编辑区域,放置焊盘的时候点击TAB键可以切换到该焊盘的属性对话框,对该焊盘的尺寸等参数进行更改。
b57fb6db574afa32b257734354b2dc19cf2c1463.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500%
(154.32 MB, 下载次数: 0)
[/li][li]
焊盘属性用的最多的就是Size and Shape,这里X-Size代表焊盘的X轴长度,Y-size代表焊盘的Y轴长度,而Shape则是焊盘的形状。
def3c219ce2c5b1b3915ab682b39131fcfec0e63.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500%
(156.99 MB, 下载次数: 0)
[/li][li]
焊盘放置完毕,接着需要绘制丝印了,由于本次绘制的是一个蜂鸣器,一般蜂鸣器都是轴对称的,那么我们需要一个中心点作参考,为了增加工作效率我们可以采用软件自带的中心定位功能。点击菜单栏的“Edit ->Set Reference”选择“Center”。
5a5a00def4dca03939d4915858d96975f3c40d63.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500%
(194.25 MB, 下载次数: 0)
[/li][li]
中心点自动移到了两个焊盘的正中间,这就是自动中心定位。
f59dbe39131fceecff1236c179c4ec9958430b63.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500%
(175.53 MB, 下载次数: 0)
[/li][li]
将图层切换到顶层丝印“Top Overlayer”,选择菜单栏的“Place ->Full Circle”准备画圆形丝印。
d2987775f2c4ec9969885bb5c3fe1e425c6b0763.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500%
(196.54 MB, 下载次数: 0)
[/li][li]
将圆形放到中心点,拖动鼠标,绘制一个圆,接着双击该圆,调出属性对话框。
054056fe1e425d6b311a169d11883913e9e50063.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500%
(197.05 MB, 下载次数: 0)
[/li][li]
弹出Arc[mm]对话框,这里有圆的直径(Radius),圆心Center,设置为你需要的尺寸,确认后点击“OK”即可。
3852f6e5eceeadbc82e418c4cd18dfdae53b7b63.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500%
(65.97 MB, 下载次数: 0)
[/li] |
