REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME | D1 | SOD323 | 1N5819WS | SOD323 | D2 | SOD323 | 1N5819WS | SOD323 | D3 | D0603 | MVR0603-5R5E2R5 | D0603 | D27 | D0603 | YELLOWLED | D0603 | D28 | D0603 | MVR0603-5R5E2R5 | D0603 | D29 | D0603 | MVR0603-5R5E2R5 | D0603 | D30 | D0603 | MVR0603-5R5E2R5 | D0603 | D31 | D0603 | MVR0603-5R5E2R5 | D0603 | D32 | D0603 | MVR0603-5R5E2R5 | D0603 | D33 | D0603 | REDLED | D0603 | D34 | D0603 | BLUELED | D0603 | D35 | D0603 | GREENLED | D0603 | D47 | D0603 | MVR0603-5R5E2R5 | D0603 | D48 | SMB | SS24 | SMB | D49 | SOD323 | 1N5819WS | SOD323 | D50 | SOD323 | 1N5819WS | SOD323 | D51 | SOD123 | MMSZ5258BT1G | SOD123 | D52 | D0603 | MVR0603-5R5E2R5 | D0603 | D53 | DUAL_LED | Dual_LED | DUAL_LED | F1 | L1206 | 1206L020 | L1206 | F2 | L1206 | 1206L100 | L1206 | F3 | L1206 | 1206L050 | L1206 | F4 | L1206 | 1206L020 | L1206 | F5 | L1812 | 1812L200TH | L1812 | J1 | CON-HDMI-TH | 284-1921QA0229 | CON-HDMI-TH | J2 | TFCARD | MSPN09-A0-2004 | TFCARD | J3 | CON7_SATA_TH_17X5MM | CON7 SATA | CON7_SATA_TH_17X5MM | J4 | CON4_2_0 | XH-4A | CON4_2_0 | J5 | CON2_2_0 | CON2 | CON2_2_0 | J6 | CON2_2_0 | CON2 | CON2_2_0 | J7 | PJ-325C | PJ-325CGREEN | PJ-325C | J8 | PJ-325C | PJ-325CPINK | PJ-325C | J9 | CON5_2_0 | CON5 | CON5_2_0 | J10 | DUAL_USB_M | DUAL_USB_CON | DUAL_USB_M | J11 | DUAL_USB_M | DUAL_USB_CON | DUAL_USB_M | J12 | GBE_RJ45_FC-202GYDNL | FC-202GYDNL | GBE_RJ45_FC-202GYDNL | J13 | DB9-M | CONNECTORDB9 | DB9-M | J14 | CON3_2_0 | CON3 | CON3_2_0 | J15 | DB9-M | CONNECTORDB9 | DB9-M | J16 | ARAF0013-P001A | ANTENA_CONN | ARAF0013-P001A | J17 | CON12_1_5 | CON12 | CON12_1_5 | J18 | VGA_DB15_B | VGA_DB15_B | VGA_DB15_B | J19 | CON_2X26_0P8_SMT | CON2X26 MINI PCI EXPRESS | CON_2X26_0P8_SMT | J20 | KONG-2 | KONG | KONG-2 | J21 | KONG-2 | KONG | KONG-2 | J22 | KONG-2 | KONG | KONG-2 | J23 | KONG-2 | KONG | KONG-2 | J24 | CON2_2_0 | CON2 | CON2_2_0 | J25 | CON2_1_25SMD | CON2 | CON2_1_25SMD | J33 | KONG-2 | KONG | KONG-2 | JP1 | DIP_2_0_26X2 | HEADER26X2 | DIP_2_0_26X2 | JP2 | DIP_2_0_5X2 | HEADER5X2 | DIP_2_0_5X2 | JP3 | DF13_30DP_1_25V | DF13_30DP_1.25V | DF13_30DP_1_25V | JP4 | DIP_2_0_18X2 | HEADER18X2 | DIP_2_0_18X2 | JP5 | DIP_2_54_3X2 | HEADER3X2 | DIP_2_54_3X2 | JP6 | DIP_2_54_3X2 | HEADER3X2 | DIP_2_54_3X2 | L1 | ACM2012-2P | ACM2012-900 | ACM2012-2P | L21 | ACM2012-2P | ACM2012-900 | ACM2012-2P | L22 | L0402 | 0.082uH | L0402 | L23 | L0402 | 0.082uH | L0402 | L24 | L0402 | 0.082uH | L0402 | L25 | L4540 | SWPU6028S1R5MT | L4540 | L26 | L3530 | SWPU4030S1R5MT | L3530 | L27 | L4540 | SWPU6028S1R5MT | L4540 | P1 | PJ-202B | CONNPWR 1 | PJ-202B | Q1 | SOT23 | IRLML6401 | SOT23 | Q2 | SOT23 | IRLML6401 | SOT23 | Q3 | SOT23 | MMBT3904 | SOT23 | Q4 | SOT23 | IRLML6401 | SOT23 | Q5 | SOT23 | MMBT3904 | SOT23 | Q6 | SOT23 | IRLML6401 | SOT23 | Q7 | SOT23 | MMBT3904 | SOT23 | Q8 | SOT23 | MMBT3904 | SOT23 | Q9 | SOT23 | IRLML6401 | SOT23 | Q10 | SOT23 | IRLML6401 | SOT23 | Q11 | SOT23 | MMBT3904 | SOT23 | Q12 | SOT23 | MMBT3904 | SOT23 | Q13 | SOT23 | IRLML6401 | SOT23 | Q14 | SOT23 | MMBT3904 | SOT23 | Q15 | SOT23 | IRLML6401 | SOT23 | Q16 | SOT23 | MMBT3904 | SOT23 | Q17 | SOP-8 | AO4421 | SOP-8 | Q18 | SOT23 | MMBT3906 | SOT23 | Q19 | SOT23 | BAT54C | SOT23 | Q20 | SOT23 | MMBT3904 | SOT23 | S1 | KEY3_5X3_5_SMT | KEY,NP | KEY3_5X3_5_SMT | S2 | KEY4_5X4_5_DIP | KEY | KEY4_5X4_5_DIP | SW1 | SW_SOP16_8POS_SM | SWSOP-8 | SW_SOP16_8POS_SM | SW2 | SW_SOP4_2POS_SM | SWSOP-2 | SW_SOP4_2POS_SM | U1 | BGA624_0P8_21X21 | MCIMX6Q6AVT10AC | BGA624_0P8_21X21 | U2 | BGA96_0P8_8P15X14P15 | MT41K128M16JT | BGA96_0P8_8P15X14P15 | U3 | BGA96_0P8_8P15X14P15 | MT41K128M16JT | BGA96_0P8_8P15X14P15 | U4 | BGA96_0P8_8P15X14P15 | MT41K128M16JT | BGA96_0P8_8P15X14P15 | U5 | BGA96_0P8_8P15X14P15 | MT41K128M16JT | BGA96_0P8_8P15X14P15 | U6 | FBGA153_0P5_11P5X13 | THGBM5G6A2JBAIR | FBGA153_0P5_11P5X13 | U7 | SOP-8 | AT25DF321_SU | SOP-8 | U8 | TSSOP38_0P5_4P5X9P8 | CM2020 | TSSOP38_0P5_4P5X9P8 | U9 | QFN32_5X5 | WM8960GEFL | QFN32_5X5 | U10 | LQFP48 | FE2.1-48 | LQFP48 | U11 | QFN-48 | RTL8211E | QFN-48 | U12 | TSSOP-16 | SP3232EEY | TSSOP-16 | U13 | TSSOP-16 | SP3232EEY | TSSOP-16 | U14 | SOP-8 | SP3483 | SOP-8 | U15 | CON3_2_54 | IRM-3638T | CON3_2_54 | U16 | FP_RTL8189ES | RTL8189ES | FP_RTL8189ES | U17 | LQFP48 | CS7123 | LQFP48 | U18 | VSSOP-8 | TXS0102DCUR | VSSOP-8 | U19 | VSSOP-8 | TXS0102DCUR | VSSOP-8 | U20 | MICRO_SIM | MSCP0X-A0-0135 | MICRO_SIM | U21 | SOT143 | CAT811T | SOT143 | U22 | SOT23-5 | XC6219B332MR | SOT23-5 | U23 | SOP-9 | RT8073GSP | SOP-9 | U24 | SOT23-8 | MP2143DJ-LF-Z | SOT23-8 | U25 | SOP-9 | RT8074GSP | SOP-9 | Y1 | CY3225 | 24MHz | CY3225 | Y2 | CY2012 | 32.768KHZ | CY2012 | Y3 | CY3225 | 12MHz | CY3225 | Y4 | CY3225 | 25MHz | CY3225 |
