查看: 2105|回复: 14
[Allegro17.4以下] AQR107+QCA8075+AR8031+DS110DF111 做的一个通讯底板PCB
人人为我,我为人人。
社区居民最爱沙发宣传大使奖终身成就奖社区明星忠实会员优秀斑竹奖
发表于 2021-6-16 10:07:25 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
下载板块默认-5金币,如果会员有销售附件需要扣销售金币+板块5金币,最少要保证你的积分=100+5+附件销售金额,否则下载不了。
OK104xA-C_V1.3beta.rar (4.38 MB, 下载次数: 16)
BH1MOUNT_HOLE_MTG156_PTH_IC_MOUNTIMOUNTINGHOLEMTG156_PTH
BH2MOUNT_HOLE_MTG156_PTH_IC_MOUNTIMOUNTINGHOLEMTG156_PTH
BH3MOUNT_HOLE_MTG156_PTH_IC_MOUNTIMOUNTINGHOLEMTG156_PTH
BH4MOUNT_HOLE_MTG156_PTH_IC_MOUNTIMOUNTINGHOLEMTG156_PTH
BH5MOUNT_HOLE_MTG156_PTH_IC_MOUNTIMOUNTINGHOLEMTG156_PTH
BT1BATTERY_HOLDER_BATH_CR2032_TH_IBATTERY_HOLDERBATH_CR2032_TH
D1LED_LED_0603_IC_LED_GREENLED_GREENLED_0603
D2LED_LED_0603_IC_LED_GREENLED_GREENLED_0603
D3RB715F_SOT_23_BAT54C-7-FBAT54C-7-FSOT_23
D4LED_LED_0603_IC_LED_GREENLED_GREENLED_0603
D5LED_LED_0603_IC_LED_GREENLED_GREENLED_0603
D6LED_LED_0603_IC_LEDGREENLEDGREENLED_0603
D14LED_LED_0603_IC_LEDGREENLEDGREENLED_0603
D500ZDIODE_SOD123_IC_MMSZ5245BMMSZ5245BSOD123
F503FUSE_RESETTABLE_1812_IC_MINISMDMINISMDC150F/12-21812
F505FUSE_RESETTABLE_1812_IC_MINISMDMINISMDC150F/12-21812
F506FUSE_RESETTABLE_1812_IC_MINISMDMINISMDC150F/12-21812
J1USB_3P0_STANDARD-A_USB_91-US01-USB_3P0_Standard-AUSB_91-US01-513
J2USB_3P0_STANDARD-A_USB_91-US01-USB_3P0_Standard-AUSB_91-US01-513
J3DC_JACK_5.5X2.1_DC_JACK_EJ508A_DC_JACK_5.5x2.1DC_JACK_EJ508A
J4DB9_MALE_BECONN_DB9_MALE_BECONNDB9_MALE_BECONNDB9_MALE_BECONN
J5RJ45_HR911080A_RJ45_HR911080A_RRJ45_HR911080ARJ45_HR911080A
J6SF7W006S1A_CON_SIM_CD_2P54MM_IOCON6 SIM CARDCON_SIM_CD_2P54MM
J7CON_CAGE_SUBASSY_SFP-CAGE_IO_COCON2X10 WITH SFP CAGESUBASSY_SFP-CAGE
J8HDR_SHRD_2X1_HDR102_IO_HDR1X2HDR1X2HDR102
J94HEADER_PWR4P_4P2_4P2_4 HEADER4HEADERPWR4P_4P2_4P2
J10HDR-1X7_JUMP1X7-6040_IO_NA_HDR1NA_HDR1X7JUMP1X7-6040
J11CONN_HDR_0_TSM2X6_SMD_IO_HDR_2XHDR_2X6TSM2X6_SMD
J12MINI_PCI_LATCH_52P_CON52_0P8_SMCON2X26 MINI PCI EXPRESSCON52_0P8_SMT_FULL-HALF_NSP
J13CONN_HDR_5X2_JN5X2_2MM_TH_IO_COCONN_HDR_5X2JN5X2_2MM_TH
J14CONN_HDR_5X2_JN5X2_2MM_TH_IO_COCONN_HDR_5X2JN5X2_2MM_TH
J15CONN_HDR_5X2_JN5X2_2MM_TH_IO_COCONN_HDR_5X2JN5X2_2MM_TH
J22CONN_HDR_5X2_HDR205_10M_50_SM_IFTSH-105-01-L-DVHDR205_10M_50_SM
J25HDR_1X3_HDR1X3_TH_IO_HDR1X3HDR1X3HDR1X3_TH
J26RJ45_HR862138H_RJ45_HR862138H_IRJ45_HR862138HRJ45_HR862138H
J27RJ45_HR862138H_RJ45_HR862138H_IRJ45_HR862138HRJ45_HR862138H
J28RJ45_HR862138H_RJ45_HR862138H_IRJ45_HR862138HRJ45_HR862138H
J29RJ45_HR862138H_RJ45_HR862138H_IRJ45_HR862138HRJ45_HR862138H
J500CONN_SDCARD_1X13_F_511_CON_SDCASD/MMCSKTCON_SDCARD_13F_SM_RA_511
J501MINI_PCI_LATCH_52P_CON52_0P8_SMCON2X26 MINI PCI EXPRESSCON52_0P8_SMT_FULL-HALF_NSP
J502HDR_1X3_HDR1X3_2MM_TH_IO_HDR1XHDR1X3HDR1X3_2MM_TH
J503SOMA_COME_AB_220_FEMALE_(S1+S2)COME_AB_220_MALE(1-5353606-6)COME_AB_220_FEMALE
J507HEAD3-S_HD100_1X3_HEAD3-SHEAD3-SHD100_1X3
J508CONNSOCKET 1X4_B4B-PH-K-S_HDRHDR1X4B4B-PH-K-S
L1DLW43_IND4_CHOKE_0805_DISCRETE_90OHM@100MIND4_CHOKE_0805
L3BEAD_FERRITE_IND_0603A_DISCRETEBLM18KG121TN1IND_0603A
L4DLW43_IND4_CHOKE_0805_DISCRETE_90OHM@100MIND4_CHOKE_0805
L5CHOKE_4P_IND4_7X13_SM_DISCRETE_400OHM@10MHZIND4_7X13_SM
L8INDUCTOR_IND_0402_DISCRETE_10001000OHMIND_0402
L9INDUCTOR_IND_0402_DISCRETE_10001000OHMIND_0402
L14BEAD_FERRITE_IND_0603A_DISCRETEBLM18KG121TN1IND_0603A
L15BEAD_FERRITE_IND_0603A_DISCRETEBLM18KG121TN1IND_0603A
L17INDUCTOR_VLF4032_2.2UH3.5A 25M2.2uH3.5A 25mOhmVLF4032
L18INDUCTOR_IND_VLS3012_SM_DISCRET4.7UHIND_VLS3012_SM
L19INDUCTOR_IND_VLS3012_SM_DISCRET4.7UHIND_VLS3012_SM
L20INDUCTOR_IND_VLS3012_SM_DISCRET4.7UHIND_VLS3012_SM
L21BEAD_FERRITE_IND_0603A_DISCRETEBLM18KG121TN1IND_0603A
L22BEAD_FERRITE_IND_0603A_DISCRETEBLM18KG121TN1IND_0603A
L23BEAD_FERRITE_IND_0603A_DISCRETEBLM18KG121TN1IND_0603A
L24BEAD_FERRITE_IND_0603_DISCRETE_120OHMIND_0603
L500BEAD_FERRITE_IND_0603A_DISCRETEBLM18KG121TN1IND_0603A
L501BEAD_IND_0805_DISCRETE_600OHM600OHMIND_0805
L502BEAD_IND_0805_DISCRETE_600OHM600OHMIND_0805
L503BEAD_IND_0805_DISCRETE_600OHM600OHMIND_0805
L504BEAD_FERRITE_IND_0603A_DISCRETEBLM18KG121TN1IND_0603A
L505BEAD_IND_0805_DISCRETE_600OHM600OHMIND_0805
L506DLW43_IND4_CHOKE_0805_DISCRETE_90OHM@100MIND4_CHOKE_0805
L514INDUCTOR_IND2_4P3SQ_XFL4020_DIS1uHIND2_4P3SQ_XFL4020
L520INDUCTOR_IND_VLS3012_SM_DISCRET4.7UHIND_VLS3012_SM
L521INDUCTOR_CHK_7P2X6P8_H5_6.8UH66.8uH6A 36.5mOhmCHK_7P2X6P8_H5
L522INDUCTOR_CHK_7P2X6P8_H5_1.0UH11.0uH14A 5.6mOhmCHK_7P2X6P8_H5
L523INDUCTOR_VLF4032_2.2UH3.5A 25M2.2uH3.5A 25mOhmVLF4032
L524BEAD_FERRITE_IND_0603A_DISCRETEBLM18KG121TN1IND_0603A
P3PCIEXPRESS X1_PCI_36_EXPRESS_CPCIEXPRESS 36PCI_36_EXPRESS_CONN_TH
P4PCIEXPRESS X1_PCI_36_EXPRESS_CPCIEXPRESS 36PCI_36_EXPRESS_CONN_TH
Q1FDMS6681Z_SO8_PAK_IC_FDMS6681ZFDMS6681ZSO8_PAK
SW1SWITCH_DTSMJ-6__DTSM-62DTSM-62DTSMJ-6
SW2TS03ABE_SS-12D11_IC_SS-12D11SS-12D11SS-12D11
SW4SW_DIP_8_SW_DIP16_8POS_TH_IC_SWSW_DIP16_8POS_THSW_DIP16_8POS_TH
TVS1DIODE_TVS_BIDIR_DIODE_BIDIR_040SESD0402X1BNDIODE_BIDIR_0402
U2MAX811_SOT143-25X60_IC_MAX811MAX811SOT143-25X60
U5TPS2065DR_SOIC8_IC_TPS2065DRTPS2065DRSOIC8
U6TPS2065DR_SOIC8_IC_TPS2065DRTPS2065DRSOIC8
U7SP3232E_SOIC16_IC_MAX3232IDBMAX3232IDBSOIC16
U974AUP1G00GW_SC70-5_IC_74AUP1G0074AUP1G00GWSC70-5
U10ASIC_QCA8075_109PIN_109PSM358X3asic_qca8075_109pin109PSM358X358N197
U12LT3065_DFN10_TDFN10_0P5_3P1X3P1LT3065TDFN10_0P5_3P1X3P1
U13LT3065_DFN10_TDFN10_0P5_3P1X3P1LT3065TDFN10_0P5_3P1X3P1
U15MX25V4006E_8P_SO8_1P27_4X5_IC_MMX25V4006ESO8_1P27_4X5
U16MP2307_0_SO08-EDP-2_MP2307DN-LFMP2307DN-LF-ZSO08-EDP-2
U17AR8031_QFN48_QFN48_0P4_6X6MM_EPAR8031QFN48_0P4_6X6MM_EPAD
U18AR8031_QFN48_QFN48_0P4_6X6MM_EPAR8031QFN48_0P4_6X6MM_EPAD
U20AQR107_BGA_104P_BGA104_0P8_7X11AQR107BGA104_0P8_7X11
U22DS110DF111_QFN_24P_EP_QFN24_0P5DS110DF111QFN24_0P5_4P15SQ_EP2P6
U2374LVC2G34_SOT363_A_IC_74LVC2G3474LVC2G34GWSOT363_A
U26NX3DV221TK_10P_B_TDFN10_0P5_3P1NX3DV221TKTDFN10_0P5_3P1X3P1
U27NX3DV221TK_10P_B_TDFN10_0P5_3P1NX3DV221TKTDFN10_0P5_3P1X3P1
U28NX3DV221TK_10P_B_TDFN10_0P5_3P1NX3DV221TKTDFN10_0P5_3P1X3P1
U29NX3DV221TK_10P_B_TDFN10_0P5_3P1NX3DV221TKTDFN10_0P5_3P1X3P1
U309DML0441_VFQFN_24P_VFQFPN24_IC_9DML0441AKILFT_VFQFN_24PVFQFPN24
U31TPS53319_LSON-CLIP22_TPS53318DQTPS53318DQPRLSON-CLIP22
U32TPS62160DSG_WSON-8_TPS62160DSGTTPS62160DSGTWSON-8
U33TPS62095RGTR_0_VQFN-16_TPS62095TPS62095RGTRVQFN-16
U48RX8010SJ_0_SOP-8_IC_RX8010SJRX8010SJSOP-8
U71ICS8304_SOIC8_ICS8304AMIICS8304AMISOIC8
U507LT3085EDCB_6P_DFN6_0P5_3X2_EP_ILT3085DFN6_0P5_3X2_EP
U515PUSB3AB6_XSON7_0P5_2P2X1P2_IC_PPUSB3AB6XSON7_0P5_2P2X1P2
U516PUSB3AB6_XSON7_0P5_2P2X1P2_IC_PPUSB3AB6XSON7_0P5_2P2X1P2
U52274LVC244A_SO20_74LVC244AD74LVC244ADSO20
U523PUSB3AB6_XSON7_0P5_2P2X1P2_IC_PPUSB3AB6XSON7_0P5_2P2X1P2
Y1XTAL_13Y_XTAL4_3P3X2P6_SM_FL_IC50MHz,20ppm,20PFXTAL4_3P3X2P6_SM_FL
Y500CLKGEN-SM_XTAL4_3P3X2P6_SM_FL_I25MHz,20ppm,CMOSXTAL4_3P3X2P6_SM_FL
重要提示:PCB作品文件展下载说明
人人为我,我为人人。希望大家下载资料的同时能回帖支持,你们的支持,是我最大的共享动力。不回帖以后不共享了。哈哈
    1元学习Allegro(1期)
    发表于 2021-6-16 10:46:32 | 显示全部楼层
    发表于 2021-6-16 11:33:44 | 显示全部楼层
    发表于 2021-6-17 09:08:20 | 显示全部楼层
    发表于 2021-6-17 11:30:04 | 显示全部楼层
    社区居民终身成就奖特殊贡献奖原创先锋奖
    发表于 2021-6-17 11:38:59 | 显示全部楼层
    非常感谢楼主大神分享
    发表于 2021-6-17 12:12:34 | 显示全部楼层
    好东西,值得我们参考
    发表于 2021-6-18 12:00:42 | 显示全部楼层
    发表于 2021-6-19 11:38:21 | 显示全部楼层
    向楼主学习,楼主辛苦了!
    发表于 2021-6-19 12:22:12 | 显示全部楼层
    参考一下,辛苦您了!
