REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
B1 | F0401_3.6V,1.2AH,1/2AA_BAT_24MM | F0401(3.6V,1.2AH,1/2AA) | BAT_24MM5X14MM5_26MM |
BZ1 | TMB12A05_BZ_12MM_7MM6_TMB12A05 | TMB12A05 | BZ_12MM_7MM6 |
D1 | LED_IR_6MM_2MM54_LED | LED | IR_6MM_2MM54 |
D2 | LED_D_A_LED_1206_4_LED_D_A | LED_D_A | LED_1206_4 |
D3 | LED_D_A_LED_1206_4_LED_D_A | LED_D_A | LED_1206_4 |
D4 | ESD0532_Q_SOT23_ESD0532 | ESD0532 | Q_SOT23 |
D5 | ESD0532_Q_SOT23_ESD0532 | ESD0532 | Q_SOT23 |
D6 | ESD0532_Q_SOT23_ESD0532 | ESD0532 | Q_SOT23 |
D7 | ESD0532_Q_SOT23_ESD0532 | ESD0532 | Q_SOT23 |
D8 | ESD0532_Q_SOT23_ESD0532 | ESD0532 | Q_SOT23 |
D9 | BAT54WSL9_D_SOD_323_BAT54WSL9 | BAT54WSL9 | D_SOD_323 |
D10 | ESD0532_Q_SOT23_ESD0532 | ESD0532 | Q_SOT23 |
D11 | ESD0532_Q_SOT23_ESD0532 | ESD0532 | Q_SOT23 |
D12 | TVS_D_DO_214AA_SMBJ6.0CA | SMBJ6.0CA | D_DO_214AA |
D13 | TVS_D_DO_214AA_SMBJ6.0CA | SMBJ6.0CA | D_DO_214AA |
D14 | LED_LED_1206_LED | LED | LED_1206 |
D15 | LED_LED_1206_LED | LED | LED_1206 |
D16 | LED_LED_1206_LED | LED | LED_1206 |
D17 | LED_D_A_LED_1206_4_LED_D_A | LED_D_A | LED_1206_4 |
D18 | LED_D_A_LED_1206_4_LED_D_A | LED_D_A | LED_1206_4 |
D19 | BAT54WSL9_D_SOD_323_BAT54WSL9 | BAT54WSL9 | D_SOD_323 |
D20 | BAT54WSL9_D_SOD_323_BAT54WSL9 | BAT54WSL9 | D_SOD_323 |
D21 | BAT54WSL9_D_SOD_323_BAT54WSL9 | BAT54WSL9 | D_SOD_323 |
D22 | BAV70_U_SOT23_3_BAV70 | BAV70 | U_SOT23_3 |
D23 | BAV70_U_SOT23_3_BAV70 | BAV70 | U_SOT23_3 |
D24 | TVS_D_DO_214AA_SMBJ6.0CA | SMBJ6.0CA | D_DO_214AA |
D25 | BAV70_U_SOT23_3_BAV70 | BAV70 | U_SOT23_3 |
D26 | M7_D_DO_214AC_M7 | M7 | D_DO_214AC |
D27 | TVS_D_DO_214AA_SMBJ6.0CA | SMBJ6.0CA | D_DO_214AA |
D28 | BAV70_U_SOT23_3_BAV70 | BAV70 | U_SOT23_3 |
D29 | BAV70_U_SOT23_3_BAV70 | BAV70 | U_SOT23_3 |
D30 | BAV70_U_SOT23_3_BAV70 | BAV70 | U_SOT23_3 |
D31 | M7_D_DO_214AC_M7 | M7 | D_DO_214AC |
D32 | TVS_D_DO_214AA_SMBJ6.0CA | SMBJ6.0CA | D_DO_214AA |
D33 | M7_D_DO_214AC_M7 | M7 | D_DO_214AC |
D34 | TVS_D_DO_214AA_SMBJ6.0CA | SMBJ6.0CA | D_DO_214AA |
D35 | BAT54WSL9_D_SOD_323_BAT54WSL9 | BAT54WSL9 | D_SOD_323 |
D36 | BAT54WSL9_D_SOD_323_BAT54WSL9 | BAT54WSL9 | D_SOD_323 |
D37 | M7_D_DO_214AC_M7 | M7 | D_DO_214AC |
D38 | BAT54WSL9_D_SOD_323_BAT54WSL9 | BAT54WSL9 | D_SOD_323 |
D39 | TVS_D_DO_214AA_SMBJ6.0CA | SMBJ6.0CA | D_DO_214AA |
D40 | BAT54WSL9_D_SOD_323_BAT54WSL9 | BAT54WSL9 | D_SOD_323 |
D41 | SS34_D_DO_214AC_SS34 | SS34 | D_DO_214AC |
D42 | M7_D_DO_214AC_M7 | M7 | D_DO_214AC |
D43 | TVS_D_DO_214AA_SMBJ6.0CA | SMBJ6.0CA | D_DO_214AA |
D44 | SS24_D_DO_214AC_SS24 | SS24 | D_DO_214AC |
D45 | LED_LED_1206_LED | LED | LED_1206 |
D46 | LED_LED_1206_LED | LED | LED_1206 |
D47 | TVS_D_DO_214AA_SMBJ10CA | SMBJ10CA | D_DO_214AA |
D48 | TVS_D_DO_214AA_SMBJ10CA | SMBJ10CA | D_DO_214AA |
D49 | TVS_D_DO_214AA_SMBJ10CA | SMBJ10CA | D_DO_214AA |
E14 | LTV-816S-TAI-D-CU_U_SOP4_9MM_2M | LTV-816S-TAI-D-CU | U_SOP4_9MM_2MM54 |
J1 | USB-AF_USB_A_H_USB-AF | USB-AF | USB_A_H |
J2 | RJ45_LED_CN_RJ45_RJ45_LED | RJ45_LED | CN_RJ45 |
J3 | USB-AF_USB_A_H_USB-AF | USB-AF | USB_A_H |
J4 | CON30A_CN_2X15A_CON30A | CON30A | CN_2X15A |
J5 | JUMP_JP_1X2_6MM_JUMP | JUMP | JP_1X2_6MM |
J6 | JUMP_JP_1X2_6MM_JUMP | JUMP | JP_1X2_6MM |
J7 | CON26A_CN_2X13_22_CON26A | CON26A | CN_2X13_22 |
J8 | JUMP_JP_0805_JUMP | JUMP | JP_0805 |
J9 | USB-AF_USB_A_V_USB-AF | USB-AF | USB_A_V |
J10 | PS/2_CN_MDC_6_04_PS/2 | PS/2 | CN_MDC_6_04 |
J11 | CON2_CN_1X2_CON2 | CON2 | CN_1X2 |
J12 | CON2_CN_1X2_CON2 | CON2 | CN_1X2 |
J13 | CON2_CN_1X2_CON2 | CON2 | CN_1X2 |
J14 | CON3_CN_1X3_3_CON 3 | CON3 | CN_1X3_3 |
J15 | CON1_TE_THRU_1MM2_0MM8_CON1 | CON1 | TE_THRU_1MM2_0MM8 |
J16 | CON1_TE_THRU_1MM2_0MM8_CON1 | CON1 | TE_THRU_1MM2_0MM8 |
J17 | CON4_CN_1X4_CON 4 | CON4 | CN_1X4 |
J18 | CON10_CN_1X10_10_CON10 | CON10 | CN_1X10_10 |
J19 | CON18A_CN_2X9_14_CON18A | CON18A | CN_2X9_14 |
J20 | CON4_CN_1X4_CON 4 | CON4 | CN_1X4 |
J21 | CON2_CN_5624_2HX_CON2 | CON2 | CN_5624_2HX |
J22 | JUMP_JP_0805_JUMP | JUMP | JP_0805 |
J23 | CON4_JW_1X4_CON 4 | CON4 | JW_1X4 |
J24 | CON20_8_CN_2X10_8_CON20_8 | CON20_8 | CN_2X10_8 |
L2 | L_R0805_SMB0805-601M | SMB0805-601M | R0805 |
L3 | L_R0805_SMB0805-601M | SMB0805-601M | R0805 |
L4 | L_R0805_SMB0805-601M | SMB0805-601M | R0805 |
L5 | SFT1206-900P_L_SFT1206_SFT1206- | SFT1206-900P | L_SFT1206 |
L6 | L_L_SHP0603_IND | IND | L_SHP0603 |
L7 | L_L_SNR2015_SNR2015-2R2N | SNR2015-2R2N | L_SNR2015 |
Q1 | PNP_Q_SOT23_BC807-40LT1(5C) | BC807-40LT1(5C) | Q_SOT23 |
Q2 | NPN_Q_SOT23_BC817-40LT1(6C) | BC817-40LT1(6C) | Q_SOT23 |
Q3 | NPN_Q_SOT23_BC817-40LT1(6C) | BC817-40LT1(6C) | Q_SOT23 |
Q4 | NPN_Q_SOT23_NPN | NPN | Q_SOT23 |
Q12 | MOSFETP_Q_SOT23_DTS2301S | DTS2301S | Q_SOT23 |
Q13 | PNP_Q_SOT23_BC807-40LT1(5C) | BC807-40LT1(5C) | Q_SOT23 |
Q18 | NPN_Q_SOT23_NPN | NPN | Q_SOT23 |
Q19 | NPN_Q_SOT23_BC817-40LT1(6C) | BC817-40LT1(6C) | Q_SOT23 |
Q20 | NPN_Q_SOT23_NPN | NPN | Q_SOT23 |
RP1 | FUSE_R1206_FUSE | FUSE | R1206 |
RP2 | RP_R_15MMX5MM5_21MM_RES | RES | R_15MMX5MM5_21MM |
RP3 | RP_R_10MMX4MM_15MM_RES | RES | R_10MMX4MM_15MM |
RT10 | PTC_RT_10MM5X5MM_5MM_<VALUE> | <Value> | RT_10MM5X5MM_5MM |
S1 | S_TACT_SOP-4_4P_ST-L6W6H5-BK_SW | RESET | SW_DP4_6MMX6MM |
S2 | S_TACT_SOP-4_4P_ST-L6W6H5-BK_SW | RESET | SW_DP4_6MMX6MM |
S3 | S_TACT_SOP-4_4P_ST-L6W6H5-BK_SW | RESET | SW_DP4_6MMX6MM |
S4 | S_TACT_SOP-4_4P_ST-L6W6H5-BK_SW | RESET | SW_DP4_6MMX6MM |
S5 | S_TACT_SOP-4_4P_ST-L6W6H5-BK_SW | RESET | SW_DP4_6MMX6MM |
S6 | S_TACT_SOP-4_4P_ST-L6W6H5-BK_SW | RESET | SW_DP4_6MMX6MM |
T1 | FC1008CLE_U_SOP16_9MM_1MM27_FC1 | FC1008CLE | U_SOP16_9MM_1MM27 |
U1 | IRCS_IR_6MMX7MM_2MM54_<VALUE> | <Value> | IR_6MMX7MM_2MM54 |
U2 | HYG160160A4G-VB_CN_FPC_9_1MM_HY | HYG160160A4G-VB | CN_FPC_9_1MM |
U3 | USB2517I_U_QFN64_9MM_0MM5_USB25 | USB2517i | U_QFN64_9MM_0MM5 |
U4 | SP2526A-2EN-L_U_SOP8_6MM_1MM27_ | SP2526A-2EN-L | U_SOP8_6MM_1MM27 |
U5 | DP83848KSQ_1_U_QFN40_5MM8_0MM5_ | DP83848KSQ | U_QFN40_5MM8_0MM5 |
U6 | SPX3819_U_SOT23_5_SPX3819-M5-L- | SPX3819-M5-L-3-3 | U_SOT23_5 |
U7 | SPX29302_U_TO263_5_SPX29302 | SPX29302 | U_TO263_5 |
U8 | DP83848KSQ_1_U_QFN40_5MM8_0MM5_ | DP83848KSQ | U_QFN40_5MM8_0MM5 |
U9 | SP2323EEN_U_SOP16_6MM_1MM27_SP2 | SP2323EEN | U_SOP16_6MM_1MM27 |
U10 | AZRS485_1_U_SOP8_6MM_1MM27_AZRS | AZRS485 | U_SOP8_6MM_1MM27 |
U11 | CON_CORE_9_CN_CORE_CON_CORE | CON_CORE | CN_CORE |
U12 | AZRS485_1_U_SOP8_6MM_1MM27_AZRS | AZRS485 | U_SOP8_6MM_1MM27 |
U13 | YH148_U_SOT23_3_YH148 | YH148 | U_SOT23_3 |
U14 | YH148_U_SOT23_3_YH148 | YH148 | U_SOT23_3 |
U15 | YH148_U_SOT23_3_YH148 | YH148 | U_SOT23_3 |
U16 | AZRS485_1_U_SOP8_6MM_1MM27_AZRS | AZRS485 | U_SOP8_6MM_1MM27 |
U17 | RX8025T_U_SOP14_6MM_1MM27_RX802 | RX8025T | U_SOP14_6MM_1MM27 |
U18 | L78L05_U_TO_92_L78L05 | L78L05 | U_TO_92 |
U19 | MP9943_U_QFN_8_MP9943 | MP9943 | U_QFN_8 |
U20 | HT7133-3_U_SOT_89_HT7133-3 | HT7133-3 | U_SOT_89 |
U21 | BL8028_U_SOT23_5_BL8028 | BL8028 | U_SOT23_5 |
U22 | SGM324SY14_U_SOP14_6MM_1MM27_SG | SGM324SY14 | U_SOP14_6MM_1MM27 |
U23 | ESAM_U_SOP8_6MM_1MM27_ESAM | ESAM | U_SOP8_6MM_1MM27 |
U24 | L78L05_U_TO_92_L78L05 | L78L05 | U_TO_92 |
U25 | SPX29302_U_TO263_5_SPX29302 | SPX29302 | U_TO263_5 |
U26 | SPX3819_U_SOT23_5_SPX3819-M5-L- | SPX3819-M5-L-3-3 | U_SOT23_5 |
X1 | CRY_X_HC_49S_2_24.000MHZ | 24.000MHz | X_HC_49S_2 |
X2 | CRY_ACT_X_CYC50M_CPY_ACT | CPY_ACT | X_CYC50M |
