REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
BAT+ | TONY_4_T1_TONY | Tony | T1 |
BAT- | TONY_4_T1_TONY | Tony | T1 |
D1 | D1N4745_0_SOD-323_1N5817/SOD323 | 1N5817/SOD323 | SOD-323 |
D2 | DIODEPIN_0_DO_214AA_SS34 | SS34 | DO_214AA |
D3 | D1N4745_0_SOD-323_1N5817/SOD323 | 1N5817/SOD323 | SOD-323 |
D6 | DIODEPIN_1_DO_214AA_FR107 | FR107 | DO_214AA |
D7 | DIODEPIN_2_SOD-323_1N4148 | 1N4148 | SOD-323 |
D8 | DIODEPIN_3_SOD-323_1N4148 | 1N4148 | SOD-323 |
D17 | D1N4745_0_SOD-323_1N5817/SOD323 | 1N5817/SOD323 | SOD-323 |
ESD1 | LED_0_L_0402_5.1V | 5.1V | L_0402 |
ESD2 | LED_0_L_0402_5.1V | 5.1V | L_0402 |
ESD3 | LED_0_L_0402_5.1V | 5.1V | L_0402 |
ESD4 | LED_0_L_0402_5.1V | 5.1V | L_0402 |
F1 | R_0402_SL1206_FS/7.4V/2A | FS/7.4V/2A | SL1206 |
J1 | CON6_0_CON125P5AW_S_CON4/1.25AW | CON4/1.25AW | CON125P5AW_S |
J2 | CON12_3_CON125P6AW_L_CON12 | CON12 | CON125P6AW_L |
K1 | SWKEY-SPST_KEY_H_SW KEY-SPST | SWKEY-SPST | KEY_H |
K2 | SWKEY-SPST_KEY_H_SW KEY-SPST | SWKEY-SPST | KEY_H |
K3 | SWKEY-SPST_KEY_H_SW KEY-SPST | SWKEY-SPST | KEY_H |
K4 | SWKEY-SPST_KEY_H_SW KEY-SPST | SWKEY-SPST | KEY_H |
K5 | SWKEY-SPST_KEY_H_SW KEY-SPST | SWKEY-SPST | KEY_H |
L1 | INDUCTOR_0_L0603_10UH | 10uH | L0603 |
L2 | INDUCTOR_0_L0603_10UH | 10uH | L0603 |
L3 | INDUCTOR_0_L0808_4MM_3.3UH/5A | 3.3uH/5A | L0808_4MM |
L4 | INDUCTOR_0_L0603_10UH | 10uH | L0603 |
LEDA1 | LED_0_LED0402_WHITE | white | LED0402 |
LEDM1 | LED_0_LED0402_WHITE | white | LED0402 |
LEDM2 | LED_0_LED0402_WHITE | white | LED0402 |
LEDN1 | TONY_4_SIP1_TONY | Tony | SIP1 |
LEDNC1 | LED_0_LED0402_WHITE_NC | white_NC | LED0402 |
LEDNC2 | LED_0_LED0402_NC2 | NC2 | LED0402 |
LEDP1 | TONY_4_SIP1_TONY | Tony | SIP1 |
LEDP2 | LED_0_LED0402_WHITE | white | LED0402 |
LEDP3 | LED_0_LED0402_WHITE | white | LED0402 |
LEDP4 | LED_0_LED0402_WHITE | white | LED0402 |
LEDP5 | LED_0_LED0402_WHITE | white | LED0402 |
LEDPSI | LED_0_LED0402_WHITE | white | LED0402 |
LEDR | LED_0_LED0402_RED | RED | LED0402 |
LEDU1 | LED_0_LED0402_WHITE | white | LED0402 |
LEDU2 | LED_0_LED0402_WHITE | white | LED0402 |
LEDY | LED_0_LED0402_Y | Y | LED0402 |
M+ | TONY_4_T1_TONY | Tony | T1 |
M- | TONY_4_T1_TONY | Tony | T1 |
Q1 | Q2SC1342_1_SOT23_DT_8050 | 8050 | SOT23_DT |
Q2 | Q2SC1342_1_SOT23_DT_8050 | 8050 | SOT23_DT |
Q3 | ZVN3320/SOT_2_SOT23_DT_AO3401 | AO3401 | SOT23_DT |
Q6 | Q2SC1342_1_SOT23_DT_8050 | 8050 | SOT23_DT |
Q18 | Q2SC1342_1_SOT23_DT_8050 | 8050 | SOT23_DT |
U1 | STM8S103K_0_QFP48-20-0707S_18M8 | 18M88 | QFP48-20-0707S |
U2 | CON6_2_SOT23_6_8205/NMOS | 8205/NMOS | SOT23_6 |
U3 | DEI1073_16_SOP8-50-0504_5302 | 5302 | SOP8-50-0504 |
U4 | BP4_8_SOP24-26-0805-TM_TM1668 | TM1668 | SOP24-26-0805-TM |
U5 | UA78M15_1_SOT223-3_AMS1117-33 | AMS1117-33 | SOT223-3 |
U7 | DEI1073_5_SOT23_5_SMG321 | SMG321 | SOT23_5 |
U8 | CM1033_DFN5X6_8_SM4504 | sm4504 | DFN5X6_8 |
