设计挺牛逼的 2层板。
Name | PCB Decal | Part Type | Value | ANT1 | RF-CABLE-CON2 | RCA_JACK_1 | U.FL-R-SMT | ANT2 | RF-CABLE-CON2 | RCA_JACK_1 | U.FL-R-SMT | ANT3 | ANT-TEMP | RCA_JACK_1 | U.FL-R-SMT | ANT4 | ANT-TEMP | RCA_JACK_1 | U.FL-R-SMT | BS1 | BOSA_APAT | AB2481-564-20-SU-4C-12_5 | AB2481-564-20-SU-4C-12 | CON1 | CON20VP2R54-1X3TM | CON5X1_MALE_CONSOLE_SIP_7 | CON5X1,Male,Console,SIP | CON2 | CON20VP2R54-1X2TM | CON5X1_MALE_CONSOLE_SIP_5 | CON5X1,Male,Console,SIP | CON4 | CON20VP2R54-1X5TM | CON5X1_MALE_CONSOLE_SIP_8 | CON5X1,Male,Console,SIP | CON6 | DIP/2.0-1X4 | CON5X1_MALE_CONSOLE_SIP_11 | CON5X1,Male,Console,SIP | CON7 | DIP/2.0-1X4 | CON5X1_MALE_CONSOLE_SIP_11 | CON5X1,Male,Console,SIP | D3 | SOD-123 | BAT46W | SS10100FL | D5 | SOT-23 | DIODE_SOT23_SINGLE | BAV99 | D6 | SOT-23 | DIODE_SOT23_SINGLE | BAV99 | D8 | LL34 | DIODE_SCHOTTKY_0 | LUDZS5/0.5W/5.1V/NC | DSW3 | SOT23 | DIODE_SOT23_SINGLE_4 | SOT23_SINGLE | DSW4 | SMA | DIODE_0_2 | ES1D | ECP1 | ECAP-5.0-10X12 | CAPACITOR_POL | 470uF/25V | ECP2 | ECAP-5.0-10X12 | CAPACITOR_POL | 470uF/25V | J1 | DC-JACK-180 | POWER_JACK_2 | DC电源插座 | J2 | CON90RS2R00-4TM | CON_USB-A_RAV_AMP1734775 | CON/USB/A/RAV | J5 | RJ11-1PORT-180 | RJ11_0_2 | RJ11/6P4C | J6 | RJ45-4PORT-180 | PHJ8X4_0 | P64/13Z/0AG9 | K1 | SW2P | SW_PUSHBUTTON_0 | 轻触开关 | L1 | FCD754R7M | INDUCTOR_FERRITE | 4.7uH/3A | L2 | FCD754R7M | INDUCTOR_FERRITE | 4.7uH/3A | L3 | IND2SM-4R0X4R5 | INDUCTOR_FERRITE | 2.2uH/2.6A/NC | L4 | FCD754R7M | INDUCTOR_FERRITE | 4.7uH/3A | L5 | L0402 | INDUCTOR | LQG15HS4N7S02/4.7nH | L6 | L0402 | INDUCTOR | LQG15HS4N7S02/4.7nH | L12 | L0402 | INDUCTOR | 600R/100MHz/300mA/DCR | L13 | LS-SNR4030 | INDUCTOR_FERRITE | 6.8uH ±20%/4*4*1.8mm | L23 | L/IND/SMD/LQM2MP_G0/1008 | INDUCTOR_FERRITE | 0R | L25 | SWPA4030S | INDUCTOR_0 | 4.7uH | Q3 | SOT23C | 2301 | 2305 PEMOSFET/NC | RVR2 | CAP-A-5MM | VARISTOR | PPL09500MA0C0YN1/NC | RVR3 | CAP-A-5MM | VARISTOR | PPL09500MA0C0YN1/NC | RVS1 | RES0805 | RESISTOR_2 | 1M/1% | RVS2 | RES0805 | RESISTOR_2 | 0R | RVS3 | RES0805 | RESISTOR_2 | 0R | SW1 | POWER-SWITCH-180 | POWER_SWITCH_5 | 电源开关 | SW3 | SW2P | SW_PUSHBUTTON_0_2 | SW,PushButton,RA,DIP4 | T2 | TR20-H2001DG | H2001DG_0 | H2001DG | T3 | TFM18-1P78X4P8 | MT0864 | G1801DG | T6 | DIP-12 | H2001DG_0_2 | FE/DIP/12 | U1 | SOP6-0280-0950-1 | MP1583_1 | SY113BADC/RT7294C | U2 | SOP6-0280-0950-1 | MP1583_1 | SY113BADC/RT7294C | U3 | SOT23-5-B | U | RT8059GJS | U4 | SOP6-0280-0950-1 | MP1583_1 | SY113BADC/RT7294C | U5 | TSSOP8 | AT24C08-10TC-1_2.8 | AT24C08-10TC-1.8 | U6 | GN25L95 | GN25L95_6 | GN25L95 | U7 | TQFN16 | MP3430_8 | MAX15059AETE+ | U8 | TSOP12X18R4-48 | TMP_0 | NAND,Flash,x8,TSOP48 | U11 | PBGA19X19F0325-0R80-N | ZX279100A | ZX279100A | U12 | R-PBGA9R0X15R5-96-0R80-2 | H5PS1G83KFR-S6C_19 | H5PS1G83KFR-S6C | U14 | SO-8P-127 | TISP61089_BD/HD | TISP61089BD | U15 | QFN48 | ZLMISLIC_56_ABS_5 | Le9641 | U16 | SOT-223-GOI | AME1117_4 | AME1117-1V5 | WANT1 | JACK-COAXIAL-3P | JACK-COAXIAL-3P_0 | NI/911-001-0006RLF | WANT2 | JACK-COAXIAL-3P | JACK-COAXIAL-3P_0 | NI/911-001-0006RLF | WANT3 | RJ45 | R_2 | 75R/5% | WANT4 | RJ45 | R_2 | 75R/5% | WANT5 | RJ45 | R_2 | 75R/5% | WANT6 | RJ45 | R_2 | 75R/5% | WU1 | QFN7X7-56-G4R6X4R6-B | RL5760_0 | RTL8192ER | WX1 | XTAL/D1B | CRYSTAL | 25.000M/10ppm/13pF | X1 | TRAN48SM-12R2X27R8/2 | 1000BASE-T_DUALPORT_XFORMER_0 | H5014 | X2 | TRAN48SM-12R2X27R8/2 | 1000BASE-T_DUALPORT_XFORMER_0 | H5014 | X3 | SSOT-6 | FDV301N_NCHL_25V_220MA_ROHS_0 | FDC86244 | Y1 | XTAL/D1B | TSX-3225_1 | 25.000M/10ppm/13pF |
