查看: 772|回复: 2
AD5174.c
1元学习Allegro(1期)
发表于 2021-7-19 11:26:34 | 显示全部楼层 |阅读模式
#include "stm32f10x.h"
#include "stdio.h"
#include "AD5235.h"
#include "delay.h"
void AD5235Initialization(void)
    GPIO_InitTypeDef GPIO_InitStructure;
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOE|RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOC|RCC_APB2Periph_GPIOD,ENABLE);
    /*AD1-2片选引脚初始化*/
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_15;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;  //推挽输出
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
    GPIO_Init(GPIOE, &GPIO_InitStructure);
    GPIO_SetBits(GPIOE,GPIO_Pin_15);//AD1-2片选初始拉高
    /*AD19-20片选引脚初始化*/
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
    GPIO_Init(GPIOD, &GPIO_InitStructure);
    GPIO_SetBits(GPIOD,GPIO_Pin_9);//AD19-20片选初始拉高
        /*RDY引脚初始化*/
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
    GPIO_Init(GPIOC, &GPIO_InitStructure);
    GPIO_ResetBits(GPIOC,GPIO_Pin_8);//RDY初始拉低
    /* 模拟SPI1pins: AD5235_CLK(PA5), AD5235_SDO(PA7) and AD5235_DIN(PA6) */
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5 | GPIO_Pin_6;
    //GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
    GPIO_Init(GPIOA, &GPIO_InitStructure);
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;  //上拉输入
    AD5235_CLK=1;
    AD1_2=1;
    AD5235_DIN=1;
    //    RDY=0;
void AD5235Command(unsigned int Command, u32 *Value)
    unsigned char i;
    u32 Register,Read;
      Read=0x00000000;
    Register=0x000000;
    switch (Command)
    case CMD_NOP:
        Register=CMD_NOP;
        break;
    case WRITE_TO_RDAC1:
        Register=WRITE_TO_RDAC1 | ((*Value)&0xFF3FFF);  //将数据写入RDAC1 Register
        break;
        case WRITE_TO_RDAC2:
        Register=WRITE_TO_RDAC2 | ((*Value)&0xFF3FFF);  //将数据写入RDAC2 Register
        break;
    case Restore_EEMEM1_to_RDAC1:
        Register=Restore_EEMEM1_to_RDAC1;
        break;
        case Restore_EEMEM2_to_RDAC2:
        Register=Restore_EEMEM2_to_RDAC2 ;
        break;
      case RDAC1_Decrement_6dB:
        Register=RDAC1_Decrement_6dB ;
        break;
      case RDAC2_Decrement_6dB:
        Register=RDAC2_Decrement_6dB ;
        break;
        case ALL_RDAC_Decrement_6dB:
        Register=ALL_RDAC_Decrement_6dB ;
        break;
        case RDAC1_Decrement_1:
        Register=RDAC1_Decrement_1 ;
        break;
        case RDAC2_Decrement_1:
        Register=RDAC2_Decrement_1 ;
        break;
        case ALL_RDAC_Decrement_1:
        Register=ALL_RDAC_Decrement_1 ;
        break;
        case Refresh_RDAC:
        Register=Refresh_RDAC ;
        break;
        case Read_RDAC1:
        Register=Read_RDAC1 ;
        break;
        case Read_RDAC2:
        Register=Read_RDAC2 ;
        break;
        case RDAC1_Increment_6dB:
        Register=RDAC1_Increment_6dB ;
        break;
    case RDAC2_Increment_6dB:
        Register=RDAC2_Increment_6dB ;
        break;
        case ALL_RDAC_Increment_6dB:
        Register=ALL_RDAC_Increment_6dB ;
        break;
      case RDAC1_Increment_1:
        Register=RDAC1_Increment_1 ;
        break;
        case RDAC2_Increment_1:
        Register=RDAC2_Increment_1 ;
        break;
        case ALL_RDAC_Increment_1:
        Register=ALL_RDAC_Increment_1 ;
        break;
        case Stores_RDAC2_into_EEMEM2:
        Register=Stores_RDAC2_into_EEMEM2 ;
        break;
        case Stores_RDAC1_into_EEMEM1:
        Register=Stores_RDAC1_into_EEMEM1 ;
        break;
    default:
        break;
        AD1_2=0;
    AD5235_CLK=1;
    delay_us(5);
      for (i=0; i<24; i++)
             // AD5235_DIN=(Register&0x800000);
        if ((Register&0x800000) == 0x800000)
            AD5235_DIN=1;
        else
            AD5235_DIN=0;
        delay_us(10);
        AD5235_CLK=0;
        delay_us(10);
        AD5235_CLK=1;
                delay_us(10);
              Read<<=1;
                if (AD5235_SDO)
                    Read|=0x000001;
        Register<<=1;
        AD5235_CLK=1;
        delay_us(20);
        AD1_2=1;
        delay_us(40);
        AD1_2=0;
        delay_us(40);
    AD1_2=1;
    delay_us(50);
void AD5235Cmd(unsigned int Cmd)
    unsigned char i;
    u32 Register;
    Register=0x000000;
    switch (Cmd)
    case CMD_NOP:
        Register=CMD_NOP;
        break;
        break;
        break;
        break;
        break;
        break;
        break;
        break;
        break;
        case Refresh_RDAC:
        break;
        case Read_RDAC1:
        break;
        case Read_RDAC2:
        break;
        break;
        break;
        break;
        break;
        break;
        break;
    default:
        break;
    AD5235_CLK=1;
    delay_us(1);
        //RDY=1;
        //delay_us(5);
   AD1_2=0;
    delay_us(1);
            AD5235_DIN=1;
        else
            AD5235_DIN=0;
        delay_us(2);
        AD5235_CLK=0;
        delay_us(2);
        AD5235_CLK=1;
        Register<<=1;
        AD5235_CLK=1;
        delay_us(2);
        AD1_2=1;
        delay_us(2);
    //    RDY=0;
    //    delay_us(5);
        AD1_2=0;
        delay_us(2);
//        RDY=1;
    //    delay_us(5);
    AD1_2=1;
    delay_us(10);
u32 AD5235_value_to_Hex(u32 Rwb)//输入的阻值转化为AD5235的10位16进制数据码
    return (u32)((Rwb-300)*1024/250000);
void AD5235_DATA(u32 AD5235_zhi)
    u32 AD5235HexValue;
    AD5235HexValue = AD5235_value_to_Hex(AD5235_zhi);
    AD5235Command(WRITE_TO_RDAC1,&AD5235HexValue);
    delay_ms(3000);
    //AD5235Command(Stores_RDAC1_into_EEMEM1,&AD5235HexValue);
    //delay_ms(100);
    AD5235Command(WRITE_TO_RDAC2,&AD5235HexValue);
    //delay_us(50);
    delay_us(100);
//    AD5235Command(Stores_RDAC2_into_EEMEM2,&AD5235HexValue);
    delay_us(100);
//    AD5235Command(Read_RDAC1,&AD5235HexValue);
    delay_us(10);
//    AD5235Command(CMD_NOP,&AD5235HexValue);
发表于 2021-7-19 11:43:57 | 显示全部楼层
发表于 2021-7-20 08:31:42 | 显示全部楼层
