查看: 1780|回复: 10
蜂鸣器音乐程序(C语言编写,可用于51单片机)
发表于 2021-7-20 16:04:27 | 显示全部楼层 |阅读模式
#include<reg52.h>
sbit beep=P2^0;
unsigned char song,a,tone,toneh,tonel,ttt,tt,a,beat,
        basekey,p,pp,speed,beat,k;
char temp;
unsigned char code tonehtable[]={     //音高频率设置高八位
        0xE4,0xE6,0xE7,0xE8,0xEA,0xEB,0xEC,0xED,0xEE,0xEF,0xF0,0xF1,
        0xF2,0xF3,0xF3,0xF4,0xF5,0xF5,0xF6,0xF6,0xF7,0xF7,0xF8,0xF8,
        0xF9,0xF9,0xF9,0xFA,0xFA,0xFA,0xFB,0xFB,0xFB,0xFB,0xFC,0xFC,
        0xFC,0xFC,0xFC,0xFD,0xFD,0xFD,0xFD,0xFD,0xFD,0xFD,0xFE,0xFE,
        0xFE,0xFE,0xFE,0xFE,0xFE,0xFE,0xFE,0xFE,0xFE,0xFE,0xFF,0xFF};
unsigned char code toneltable[]={    //音高频率设置低八位
        0x7A,0x06,0x7B,0xDB,0x28,0x62,0x8A,0xA1,0xA9,0xA2,0x8E,0x6B,
        0x3D,0x03,0xBD,0x6D,0x14,0xB1,0x45,0xD0,0x54,0xD1,0x47,0xB5,
        0x1E,0x81,0xDE,0x36,0x8A,0xD8,0x22,0x68,0xAA,0xE8,0x23,0x5A,
        0x8F,0xC0,0xEF,0x1B,0x45,0x6C,0x91,0xB4,0xD5,0xF4,0x11,0x2D,
        0x47,0x60,0x77,0x8D,0xA2,0xB6,0xC8,0xDA,0xEA,0xFA,0x08,0x16};
char code tonetone[]={                                //音阶转化为半音差值
        0,5,7,9,10,12,14,16,17,19,21,22,24,0,2,4};
//从左到右,16进制0-F分别对应简谱的
// 0    1 2 3 4 5 6 7  8 9 A B C  D E F
// 0    1 2 3 4 5 6 7  1 2 3 4 5  5 6 7
//休止  ----中音-----  ---高音--  -低音-
unsigned char code music0[]={
0x54,0x52,0x62,0x28,   0x14,0x12,0xe2,0x28,
        0x54,0x54,0x62,0x82,0x62,0x52,0x14,0x12,0xe2,0x28,
  0x54,0x24,0x14,0xf2,0xe2,0xd4,0x54,0x24,
  0x32,0x22,0x14,0x12,0xe2,
  0x22,0x32,0x22,0x12,0x22,0x12,0xf2,0xe2,0xdb,0x04,0x00};
//乐谱,第一位表示音高,第二位表示音长为几个16分音符(1/4拍子)。
//        如1为16分音符,2为8分音符,3为附点8分音符,
//  4为4分音符...... 另外为了方便,F定为全音符
void delayms(unsigned int ms)                        //N毫秒延迟函数
        unsigned int ms1; unsigned char ms2;
        for(ms1=ms;ms1>0;ms1--)
                for(ms2=110;ms2>0;ms2--);
void settone(unsigned char tone)                //音调设置函数
        toneh=tonehtable[tone];
        tonel=toneltable[tone];
        TH1=toneh;
        TL1=tonel;
        EA=1;
        ET1=1;
        TR1=1;
void onekey()         //发出单个音
        unsigned char al,ah;
        beat=0;
        do
                switch(song)
                        case 0:ah=music0[a]>>4;al=music0[a]&0x0F;break;
                if(al==0)                        //末位为0用于特殊功能
                switch(ah)
                        case 0:a=0;break;                                //0x00音乐结束,从头演奏
                        case 1:basekey++;a++;break;                //0x10后面全部升半音
                        case 2:basekey--;a++;break;                //0x20后面全部降半音
                        case 3:basekey+=12;a++;break;        //0x30后面全部升八度
                        case 4:basekey-=12;a++;break;        //0x40后面全部降八度
                        case 5:beat+=8;a++;break;                        //0x50下个音长延长2分音符时长
                        case 6:beat+=16;a++;break;                //0x60下个音长延长全音符时长
        while(al==0);
        al+=(al==15);                                //末位为F(15)时,加1变成全音符
        beat+=al;                                                //加长音
        if(ah==0)
                p=0;
        else
                p=0;                                                        //p=0不发声
                delayms(20);                        //延时20ms,使两个音之间有一点间隙
                settone(tonetone[ah]+basekey);
                p=1;                                                        //p=1发声
void Init_Timer()                        //初始化时钟设置
        TMOD=0x11;
        EA=1;
        ET0=1;
        TR0=1;
void main()                                        //主程序
        beep=0;
        song=0;
        ttt=0;
        tt=0;
        basekey=19;   //定调值,C调19,每半音相差1,每八度相差12
        speed=5;                        //速度,数字越大越慢
        a=0;
        Init_Timer();
void int3() interrupt 3                        //音高方波产生中断程序
        TH1=toneh;        //存入1号定时器的高8位值
        TL1=tonel;                //存入1号定时器的高8位值
        if(p!=0)        //p=0不执行程序,使两个音之间有间隙
                beep=~beep;                                                        //蜂鸣器定时将电位取反,产生方波
void int1() interrupt 1                                //音长控制中断程序
  TH0=76;        //50毫秒定时
        TL0=0;
        ttt++;        //每隔50毫秒,ttt计数器加一
        if(ttt==speed)                //ttt计数器与速度值相等时
                ttt=0;
                tt++;                                                        //tt计数器加1,即已演奏完1个16分音符时长
        if(tt==beat)                                //tt计数器与音长相等时
                tt=0;
                onekey();                                        //执行下一个音符程序
                a++;
 楼主| 发表于 2021-7-20 16:25:43 | 显示全部楼层
发表于 2021-7-20 18:31:37 | 显示全部楼层
终身成就奖特殊贡献奖优秀斑竹奖
发表于 2021-7-20 18:53:26 | 显示全部楼层
    3 小时前
  • 签到天数: 258 天
    发表于 2021-7-20 20:34:27 | 显示全部楼层
    发表于 2021-7-21 07:47:35 | 显示全部楼层
    发表于 2021-7-21 08:39:23 | 显示全部楼层
    5 天前
  • 签到天数: 109 天
    发表于 2021-7-21 08:48:19 | 显示全部楼层
    1元学习Allegro(1期)
    发表于 2021-7-21 08:59:50 | 显示全部楼层
    昨天 15:06
  • 签到天数: 112 天
    发表于 2021-7-27 19:57:44 | 显示全部楼层
