类似于平板电脑,但是这种产品是在平板电脑出现之前就已经问世的产物。早期一般是运行 WINCE 系统的。CPU 主频不是太高。几百M而已。
朗科集团的基于S3C2440做的一个智能设备,板子画的非常牛,支持FM、GPS、摄像头、SD卡等功能,玩游戏,听歌,上网等
原理图为PROTEL99格式
****************以下信息由管理员 @老吴 编辑补充*******************
板子有以下封装,如有需要可以下载提取使用。
1600_0,CM1210 | SOT143-4 | CM1210 | 2LED,2LED | LED\0603X2 | 2LED | AD3257,ADG3257 | QSOP-16 | ADG3257 | AD8542_2,AD8542 | FPC\0.5-40PR | AD8542 | AND,74LVC1GU04/NC | SC-70-5 | 74LVC1GU04/NC | BAT54A,BAT54A | SOT-23 | BAT54A | BAT54C,BAT54C | SOT-23 | BAT54C | BATTERY,BATTERY | COM2C | BATTERY | CAP,0.01u | 603 | 0.01u | CAP,0.1u | 603 | 0.1u | CAP,0.1uF | 603 | 0.1uF | CAP,0.1uF | C\0603 | 0.1uF | CAP,1.2nF | 603 | 1.2nF | CAP,1.2pF | 603 | 1.2pF | CAP,100pF | 603 | 100pF | CAP,10uF | 805 | 10uF | CAP,10uF | C\0805 | 10uF | CAP,1nF | 603 | 1nF | CAP,1uF | 603 | 1uF | CAP,1uF | C\0603 | 1uF | CAP,22pF | 603 | 22pF | CAP,22uF | 1206 | 22uF | CAP,33pF | 603 | 33pF | CAP,4.7u | 805 | 4.7u | CAP,4.7uF | C\0805 | 4.7uF | CAP,4.7uF | 805 | 4.7uF | CAP,680pF | 603 | 680pF | CAP,7pF | 603 | 7pF | CAP,NC | 603 | NC | CAPACITOR_POL,22uF | CAP\3528 | 22uF | CAPACITOR_POL,22uF | C\3528 | 22uF | CAPACITOR_POL,22uF/10V | CAP\3528 | 22uF/10V | CAPACITOR_POL,22uF/10V | C\3528 | 22uF/10V | CAPACITOR_POL_2,10uF | 805 | 10uF | CAPACITOR_POL_2,10uF | C\0805 | 10uF | CAPACITOR_POL_2,1uF | 603 | 1uF | CAPACITOR_POL_2,220uF/4V/C | 6032 | 220uF/4V/C | CAPACITOR_POL_2,22uF | 1206 | 22uF | CAPACITOR_POL_2,22uF/10V | C\3528 | 22uF/10V | CAP_0603,0.1uF | C\0603 | 0.1uF | CAP_0603,22nF | C\0603 | 22nF | CAP_0603,4.7nF | C\0603 | 4.7nF | CAP_NP,0.01u | C\0603 | 0.01u | CAP_NP,0.1u | C\0603 | 0.1u | CAP_NP,0.1uF | C\0603 | 0.1uF | CAP_NP,10pF | C\0603 | 10pF | CAP_NP,18pF | C\0603 | 18pF | CAP_NP,1UF | C\0603 | 1UF | CAP_NP,1uF | C\0603 | 1uF | CAP_NP,20P | C\0603 | 20P | CAP_NP,330pF | C\0603 | 330pF | CAP_NP,4.7uF | CAP\1206 | 4.7uF | CAP_NP,4.7uF | C\0805 | 4.7uF | CAP_NP,47pF | 603 | 47pF | CAP_NP,NC | 603 | NC | CAP_NP_0,0.1U | C\0603 | 0.1U | CAP_NP_0,0.1uF | C\0603 | 0.1uF | CAP_NP_0,0.1uF | C\0805 | 0.1uF | CAP_NP_0,1000pF | C\0603 | 1000pF | CAP_NP_0,4.7uF | C\0805 | 4.7uF | COMPONENT_1,CONNE4 | PAD5 | CONNE4 | COMPONENT_2,XC6206P182PRCE6209A18P | SOT-89 | XC6206P182PRCE6209A18P/NC | CON4,CON4/FPC-0.5mm | FPC-0.5P-4R | CON4/FPC-0.5mm | CON4,CON4/FPC-1.0mm | FPC-1.0P-4R | | CON4,CON4/FPC-1.0mm | FPC-1.0P-4R | | CON18,JTAG | FPC\0.5-18PR | JTAG | CON26,CON24(DOWN) | FPC\0.5-24PL | CON24(DOWN) | CRYSTAL,12M | SMD5X3.2 | 12M | CRYSTAL_0,12.000M | SMD5X3.2 | 12.000M | CRYSTAL_2,32.768K | XTAL2 | 32.768K | CRYSTAL_2,32768 | XTAL2 | 32768 | DIODE,1SS355 | SOD-323 | 1SS355 | DIODE,DIODE | SOD-323 | DIODE | DIODE,DIODE | M120L | DIODE | DIODE,IN4148 | SOD-323 | IN4148 | DIODE_0,MBR0520L | SOD-123 | MBR0520L | DIODE_0,MBR0530 | SOD-123 | MBR0530 | DIODE_SCHOTTKY,B240AC/S1A | DO-214AC | B240AC/S1A | DIODE_SCHOTTKY,S1A | DO-214AC | S1A | DIODE_SCHOTTKY_1,02DZ24 | SOD-323 | 02DZ24 | EL7516,EL7516/LM3224 | MSOP-8 | EL7516/LM3224 | FM_YG,FM_T(GFT808/NC) | GFT808 | FM_T(GFT808/NC) | GL850_0,GL850A | QFP_10X10-64 | GL850A | INDUCTOR,10uH | DR43 | 10uH | INDUCTOR,2Kohm@100M | L\0603 | 2Kohm@100M | INDUCTOR,30ohm@100M | L\0603 | 30ohm@100M | INDUCTOR,Bead | L\0805 | Bead | INDUCTOR,FCM2012K-601T05 | L\0805 | FCM2012K-601T05 | INDUCTOR,FCM2012K-601T05/NC | L\0805 | FCM2012K-601T05/NC | INDUCTOR,L\0603 | L\0603 | L\0603 | INDUCTOR/SM,10uH/CDRH5D28-220 | CDRH4D18 | 10uH/CDRH5D28-220 | INDUCTOR_2,2.2uH | 805 | 2.2uH | INDUCTOR_2,2.2uH | 603 | 2.2uH | INDUCTOR_2,390nH | 603 | 390nH | INDUCTOR_2,BEAD | 603 | BEAD | INDUCTOR_2,BEAD | 805 | BEAD | INDUCTOR_2,BEAD | L\0805 | BEAD | INDUCTOR_2,CDRH5D28-100 | CDRH4D18 | CDRH5D28-100 | INDUCTOR_2,CDRH5D28-3R3 | CDRH4D18 | CDRH5D28-3R3 | INDUCTOR_IRON,BEAD | 805 | BEAD | INDUCTOR_IRON,BEAD | L\0805 | BEAD | INDUCTOR_IRON,BEAD | L\0603 | BEAD | IRF4905/TO_0,AO3401 | SOT-23 | AO3401 | K4S561632D_1,K4S561632D | TSOP-54 | K4S561632D | LED | LED\0805 | | LTC1733_0,LTC1733 | MSOP-10 | LTC1733 | MICROPHONE_1,EM-6027 | MIC | EM-6027 | MOSFET_P,AO3401 | SOT-23 | AO3401 | MPF990_1,AO3402 | SOT-23 | AO3402 | NANDFLASH,K9F8G08U0A/HY/ST | FLASH1 | K9F8G08U0A/HY/ST | NCP1550,NCP1550 | SOT23-5 | NCP1550 | NPN,2N3904 | SOT-23 | 2N3904 | NPN1,MMBT3904K/AO3402 | SOT-23 | MMBT3904K/AO3402 | NPN1,NPN1 | SOT-23 | NPN1 | PHONEJACK_DCIN_0,JACKDCIN(DV5V) | DC-JACK2 | JACK DCIN(DV5V) | PHONEJACK_STEREO,GPS_JACK | JACK-LN | GPS_JACK | PHONEJACK_STEREO,PHONEJACKSTEREO | JACK-LN | PHONEJACK STEREO | PNP1,PNP1 | SOT-23 | PNP1 | R,0 | R\0603 | 0 | R,0R/NC | R\0603 | 0R/NC | R,100K | R\0603 | 100K | R,10K | R\0603 | 10K | R,10K/NC | R\0603 | 10K/NC | R,15K | R\0603 | 15K | R,1M | R\0603 | 1M | R,1M/NC | R\0603 | 1M/NC | R,20K | R\0603 | 20K | R,22R | R\0603 | 22R | R,270 | R\0603 | 270 | R,47K | R\0603 | 47K | R,5.1K | R\0603 | 5.1K | R,510R | 603 | 510R | R,680R | 603 | 680R | R,680R 1% | R\0603 | 680R 1% | R,75R | R\0603 | 75R | R,NC | R\0603 | NC | RES1,0R/NC | R\0603 | 0R/NC | RES1,100K | R\0603 | 100K | RES2,0R | 603 | 0R | RES2,1.5K | 603 | 1.5K | RES2,100K | 603 | 100K | RES2,100K | R\0603 | 100K | RES2,100R | 603 | 100R | RES2,100k | 603 | 100k | RES2,10K | 603 | 10K | RES2,10K/NC | 603 | 10K/NC | RES2,10K?NC | 603 | 10K?NC | RES2,10M | 603 | 10M | RES2,10R | 603 | 10R | RES2,10k/NC | 603 | 10k/NC | RES2,15K | R\0603 | 15K | RES2,15k | 603 | 15k | RES2,160R | 603 | 160R | RES2,180K | 603 | 180K | RES2,1K | 603 | 1K | RES2,1K/NC | R\0603 | 1K/NC | RES2,1M | 603 | 1M | RES2,200R | 603 | 200R | RES2,220K | 603 | 220K | RES2,22K | 603 | 22K | RES2,22R | 603 | 22R | RES2,22k | 603 | 22k | RES2,22k | R\0603 | 22k | RES2,27K | R\0603 | 27K | RES2,300K | 603 | 300K | RES2,330K | 603 | 330K | RES2,330nh | 603 | 330nh | RES2,3K | 603 | 3K | RES2,4.7K | 603 | 4.7K | RES2,470R | 603 | 470R | RES2,47K | 603 | 47K | RES2,5.1K | 603 | 5.1K | RES2,510R | 603 | 510R | RES2,ESD | 603 | ESD | RES2,NC | 603 | NC | RES2,PART | 603 | PART | RES2,PART | R\0603 | PART | RES2,RES2 | 603 | RES2 | RES3,BEAD | 805 | BEAD | RES-SMT,0R/NC | R\0603 | 0R/NC | RES-SMT,10K | R\0603 | 10K | RES-SMT,10K/NC | R\0603 | 10K/NC | RES-SMT,47K | R\0603 | 47K | RES1_2,100K | 603 | 100K | RES1_2,10K | 603 | 10K | RES1_2,15K | 603 | 15K | RES1_2,27K | 603 | 27K | RES1_2,33K | 603 | 33K | RES_0603,10k | R\0603 | 10k | RES_0603,3.9K | R\0603 | 3.9K | RES_0603,30K | R\0603 | 30K | RPACK4,4x100K | R\0603X4 | 4x100K | RPACK4,4x22R | R\0603X4 | 4x22R | R_0,100K | R\0603 | 100K | R_0,39K | 603 | 39K | S3C2410,S3C2410 | FBGA-289 | S3C2410 | S3C2410,S3C2440 | FBGA-289 | S3C2440 | S3C2410_2,S3C2440 | FBGA-289 | S3C2440 | SD2098,SD2098 | SOP8 | SD2098 | SD_CARD_SOCKET,SD_CARD_SOCKET | SD_SOCKET | SD_CARD_SOCKET | SI4700,SI4700 | QFN24-G | SI4700 | SN74AC14D_(14),SN74LV14 | TSSOP-14 | SN74LV14 | SP6690,SP6690 | SOT23-5 | SP6690 | SPEAKER_0,SPEAKER 8R/1W | COM2C | SPEAKER 8R/1W | SW-PB,KB_POWER | SMT-KEY4 | KB_POWER | SW-PB,LCDOFF | SMT-KEY4 | LCDOFF | SW-PB,PHOTO | SMT-KEY4 | PHOTO | SW-PB,SW-PB | SMT-KEY2 | SW-PB | SW-SPDT,HOLD | SMD-SWITCH | HOLD | SW_DIP-4,10K | 0603X4 | 10K | SW_PUSHBUTTON,BACK | SMT-KEY2 | BACK | SW_PUSHBUTTON,BACK UP | SMT-KEY2 | BACK UP | SW_PUSHBUTTON,FM OUT | SMT-KEY2 | FM OUT | SW_PUSHBUTTON,MENU | SMT-KEY2 | MENU | SW_PUSHBUTTON,NEXT/SKRKAEE010 | SMT-KEY2 | NEXT/SKRKAEE010 | SW_PUSHBUTTON,OK | SMT-KEY2 | OK | SW_PUSHBUTTON,PRE | SMT-KEY2 | PRE | SW_PUSHBUTTON,REPEAT | SMT-KEY2 | REPEAT | SW_PUSHBUTTON,V+ | SMT-KEY2 | V+ | SW_PUSHBUTTON,V- | SMT-KEY2 | V- | TEST | TESTPAD | | TEST | TESTPAD-A | | TEST | TESTPAD-B | | TMP_4,AU6332 | SSOP-28 | AU6332 | USB_A_RIGHT_ANGLE,USB AF | USB\A-F | USB AF | USB_B_01,USB_B_01 | USB-MINI/5 | USB_B_01 | USB_CON,USB MODEL CON | FLASH-USB | USB MODEL CON | WM8750_0,WM8960 | QFN-32 | WM8960 | XC6377B_4,XC6206P132MR/CE6209A13M | SOT-23 | XC6206P132MR/CE6209A13M | XC6377B_4,XC6206P282MR/CE6209A28M | SOT-23 | XC6206P282MR/CE6209A28M | XP6209B202MR,EUP7965-28VIR | SOT23-5 | EUP7965-28VIR | XP6209B202MR,S-1200B33 | SOT23-5 | S-1200B33 | XP6209B202MR,TPS62200 | SOT23-5 | TPS62200 |
评分
查看全部评分
