TPSM63606EVM.zip
(1.38 MB, 下载次数: 3)
Designator | Quantity | Value | Description | !PCB1 | 1 | | Printed CircuitBoard | C1, C2, C3, C4 | 4 | 2.2uF | CAP,CERM, 2.2 uF, 50 V, +/- 10%, X7R, AEC-Q200 Grade 1, 0805 | C5 | 1 | 100uF | CAP, AL, 100uF, 50 V, +/- 20%, 0.34 ohm, SMD | C6, C7, C8, C9 | 4 | 10uF | CAP,CERM, 10 uF, 50 V, +/- 10%, X7R, 1210 | C10, C11,C12, C13 | 4 | 47uF | CAP, CERM, 47uF, 16 V, +/- 20%, X6S, 1210 | C14 | 1 | 0.1uF | CAP,CERM, 0.1 uF, 25 V, +/- 10%, X7R, AEC-Q200 Grade 1, 0603 | C15 | 1 | 1000pF | CAP, CERM, 1000pF, 50 V, +/- 5%, C0G/NP0, 0402 | C16 | 1 | 22pF | CAP,CERM, 22 pF, 50 V, +/- 5%, C0G/NP0, AEC-Q200 Grade 1, 0402 | FID1,FID2, FID3, FID4, FID5, FID6 | 6 | | Fiducialmark. There is nothing to buy ormount. | H1, H2, H3, H4 | 4 | | Standoff,Hex, 0.5"L #4-40 Nylon | H5, H6,H7, H8 | 4 | | Screw, Pan Head, 4-40, 3/8", Nylon | J1, J2 | 2 | | TERMBLOCK 2POS 5mm, TH | J3, J4 | 2 | | Header, 100mil,5x2, Tin, TH | J5 | 1 | | Header,100mil, 8x1, Gold, TH | L1 | 1 | 1.5uH | Shielded PowerInductors 1.5 µH 10.2A 10.5mOhm Max Nonstandard | LBL1 | 1 | | | R1 | 1 | 0 | RES, 0, 5%, 0.1W, AEC-Q200 Grade 0, 0603 | R2 | 1 | 10 | RES,10.0, 1%, 0.063 W, 0402 | R3 | 1 | 402k | RES, 402 k, 1%,0.063 W, 0402 | R4 | 1 | 0 | RES,0, 0%, 0.2 W, AEC-Q200 Grade 0, 0402 | R5 | 1 | 1 | RES, 1.00, 1%,0.063 W, AEC-Q200 Grade 0, 0402 | R6 | 1 | 133k | RES,133 k, 1%, 0.063 W, 0402 | R7 | 1 | 10.0k | RES, 10.0 k,1%, 0.063 W, AEC-Q200 Grade 0, 0402 | R8 | 1 | 49.9k | RES,49.9 k, 1%, 0.063 W, 0402 | R9, R11 | 2 | 8.06k | RES, 8.06 k,1%, 0.063 W, AEC-Q200 Grade 0, 0402 | R10 | 1 | 6.98k | RES,6.98 k, 1%, 0.063 W, AEC-Q200 Grade 0, 0402 | R12 | 1 | 16.9k | RES, 16.9 k,1%, 0.063 W, AEC-Q200 Grade 0, 0402 | R13 | 1 | 69.8k | RES,69.8 k, 1%, 0.063 W, 0402 | R14 | 1 | 26.7k | RES, 26.7 k,1%, 0.063 W, AEC-Q200 Grade 0, 0402 | R15 | 1 | 17.4k | RES,17.4 k, 1%, 0.063 W, 0402 | R16 | 1 | 13.0k | RES, 13.0 k,1%, 0.063 W, 0402 | R17 | 1 | 8.66k | RES,8.66 k, 1%, 0.063 W, 0402 | R18 | 1 | 6.34k | RES, 6.34 k,1%, 0.063 W, 0402 | SH-J1, SH-J2, SH-J3 | 3 | 1x2 | Shunt,2mm, Gold plated, Black | TP1, TP2,TP3, TP5 | 4 | | Test Point,Miniature, SMT | U1 | 1 | | 6APower Module |
